[U-Boot] booting signed Images
Hello Simon,
just talked with Wolfgang about the booting process from signed images, as it is described in:
doc/uImage.FIT/verified-boot.txt doc/uImage.FIT/signature.txt
If we see it correct, then it is still possible to boot an uImage or a FIT image without signature with "bootm" when CONFIG_FIT_SIGNATURE is defined.
The question raised, if this is a good behaviour.
Should we not prevent booting uImages or not signed FIT Images when CONFIG_FIT_SIGNATURE is defined? Or at least prevent booting such unsigned images through an U-Boot env variable.
What Do you think?
Thanks in advance
bye, Heiko
HI Heiko,
On 5 May 2014 01:35, Heiko Schocher hs@denx.de wrote:
Hello Simon,
What Do you think?
There is a 'required' property in the public keys which is intended to support this. If you mark a key as 'required then it will need to be verified by any image that is loaded. There is a test for this case, but it may not be comprehensive.
Dear Simon,
In message CAPnjgZ2-qC8YK8t2DvmzXWKy3Wd+=7VY1Ti=Jm98LF96PLfu-g@mail.gmail.com you wrote:
What Do you think?
But what about legacy uImage files? It appears nothing would stop booting one of those?
Hi Wolfgang,
On 5 May 2014 11:55, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
What Do you think?
That's right, there is nothing to stop that at present. The verification happens either on each image (for per-image signing) or on the selected configuration as a whole (in fit_image_load() when it sees the kernel being loaded).
One simple solution might be to check a CONFIG option in boot_get_kernel() and disable support for IMAGE_FORMAT_LEGACY.
Dear Simon,
In message CAPnjgZ3OKQ8UZMOrQ7m7zWDWsFa2yZqCT2F69sKwgjDymOzePw@mail.gmail.com you wrote:
This makes sense to me. Thanks!
Hello Simon,
Am 05.05.2014 20:31, schrieb Simon Glass:
Hi Wolfgang,
On 5 May 2014 11:55, Wolfgang Denkwd@denx.de wrote:
Dear Simon,
In messageCAPnjgZ2-qC8YK8t2DvmzXWKy3Wd+=7VY1Ti=Jm98LF96PLfu-g@mail.gmail.com you wrote:
What Do you think?
The question is here, do we introduce a new config option for this, or do we use for example CONFIG_FIT_SIGNATURE to disable it?
I prefer to check CONFIG_FIT_SIGNATURE, and disable IMAGE_FORMAT_LEGACY complete.
bye, Heiko
Hi Heiko,
On 7 May 2014 01:06, Heiko Schocher hs@denx.de wrote:
Hello Simon,
Hi Wolfgang,
Dear Simon,
In message<CAPnjgZ2-qC8YK8t2DvmzXWKy3Wd+=7VY1Ti=Jm 98LF96PLfu-g@mail.gmail.com> you wrote:
What Do you think?
I suggest a new CONFIG option, like CONFIG_DISABLE_IMAGE_FORMAT_LEGACY or possible a device tree option, since if you force disable of the legacy format you are actually removing functionality. At present CONFIG_FIT_SIGNATURE is a capability, and one capability should not normally preclude another.
Heiko Schocher
