[U-Boot-Users] [PATCH] SPI command support for ARM AT91rm9200
Signed-off-by: Jens Scharsig esw@bus-elektronik.de
DESCRIPTION -----------
The patch provides the spi_xfer funtion, which used by cmd_spi.c to support the sspi command for all at91rm9200 boards.
This patch is based on Ulf Samuelsson's at45 split patch, but don't include this
diff --git a/cpu/arm920t/at91rm9200/spi.c b/cpu/arm920t/at91rm9200/spi.c new file mode 100755 index 0000000..403f96a --- /dev/null +++ b/cpu/arm920t/at91rm9200/spi.c @@ -0,0 +1,212 @@ +/* Driver for ATMEL DataFlash support + * Author : Hamid Ikdoumi (Atmel) + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <config.h> +#if defined(CONFIG_SPI) && defined(CONFIG_HAS_DATAFLASH) + +#include <common.h> +#include <asm/hardware.h> +#include <dataflash.h> +#include <spi.h> + +#define AT91C_SPI_CLK 10000000 /* Max Value = 10MHz to be compliant to + the Continuous Array Read function */ + +/* AC Characteristics */ +/* DLYBS = tCSS = 250ns min and DLYBCT = tCSH = 250ns */ +#define DATAFLASH_TCSS (0xC << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +#define AT91C_TIMEOUT_WRDY 200000 +#define AT91C_SPI_PCS0_SERIAL_DATAFLASH 0xE /* Chip Select 0 : NPCS0 %1110 */ +#define AT91C_SPI_PCS3_DATAFLASH_CARD 0x7 /* Chip Select 3 : NPCS3 %0111 */ + +void AT91F_SpiInit(void) { + +/*-------------------------------------------------------------------*/ +/* SPI DataFlash Init */ +/*-------------------------------------------------------------------*/ + /* Configure PIOs */ + AT91C_BASE_PIOA->PIO_ASR = AT91C_PA3_NPCS0 | AT91C_PA4_NPCS1 | AT91C_PA1_MOSI | AT91C_PA5_NPCS2 | + AT91C_PA6_NPCS3 | AT91C_PA0_MISO | AT91C_PA2_SPCK; + AT91C_BASE_PIOA->PIO_PDR = AT91C_PA3_NPCS0 | AT91C_PA4_NPCS1 | AT91C_PA1_MOSI | AT91C_PA5_NPCS2 | + AT91C_PA6_NPCS3 | AT91C_PA0_MISO | AT91C_PA2_SPCK; + /* Enable CLock */ + AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_SPI; + + /* Reset the SPI */ + AT91C_BASE_SPI->SPI_CR = AT91C_SPI_SWRST; + + /* Configure SPI in Master Mode with No CS selected !!! */ + AT91C_BASE_SPI->SPI_MR = AT91C_SPI_MSTR | AT91C_SPI_MODFDIS | AT91C_SPI_PCS; + + /* Configure CS0 and CS3 */ + *(AT91C_SPI_CSR + 0) = AT91C_SPI_CPOL | (AT91C_SPI_DLYBS & DATAFLASH_TCSS) | (AT91C_SPI_DLYBCT & + DATAFLASH_TCHS) | ((AT91C_MASTER_CLOCK / (2*AT91C_SPI_CLK)) << 8); + + *(AT91C_SPI_CSR + 3) = AT91C_SPI_CPOL | (AT91C_SPI_DLYBS & DATAFLASH_TCSS) | (AT91C_SPI_DLYBCT & + DATAFLASH_TCHS) | ((AT91C_MASTER_CLOCK / (2*AT91C_SPI_CLK)) << 8); + +} + +void AT91F_SpiEnable(int cs) { + switch(cs) { + case 0: /* Configure SPI CS0 for Serial DataFlash AT45DBxx */ + AT91C_BASE_SPI->SPI_MR &= 0xFFF0FFFF; + AT91C_BASE_SPI->SPI_MR |= ((AT91C_SPI_PCS0_SERIAL_DATAFLASH<<16) & AT91C_SPI_PCS); + break; + case 3: /* Configure SPI CS3 for Serial DataFlash Card */ + /* Set up PIO SDC_TYPE to switch on DataFlash Card and not MMC/SDCard */ + AT91C_BASE_PIOB->PIO_PER = AT91C_PIO_PB7; /* Set in PIO mode */ + AT91C_BASE_PIOB->PIO_OER = AT91C_PIO_PB7; /* Configure in output */ + /* Clear Output */ + AT91C_BASE_PIOB->PIO_CODR = AT91C_PIO_PB7; + /* Configure PCS */ + AT91C_BASE_SPI->SPI_MR &= 0xFFF0FFFF; + AT91C_BASE_SPI->SPI_MR |= ((AT91C_SPI_PCS3_DATAFLASH_CARD<<16) & AT91C_SPI_PCS); + break; + } + + /* SPI_Enable */ + AT91C_BASE_SPI->SPI_CR = AT91C_SPI_SPIEN; +} + +/*----------------------------------------------------------------------------*/ +/* \fn AT91F_SpiWrite */ +/* \brief Set the PDC registers for a transfert */ +/*----------------------------------------------------------------------------*/ +unsigned int AT91F_SpiWrite ( AT91PS_DataflashDesc pDesc ) +{ + unsigned int timeout; + + pDesc->state = BUSY; + + AT91C_BASE_SPI->SPI_PTCR = AT91C_PDC_TXTDIS + AT91C_PDC_RXTDIS; + + /* Initialize the Transmit and Receive Pointer */ + AT91C_BASE_SPI->SPI_RPR = (unsigned int)pDesc->rx_cmd_pt ; + AT91C_BASE_SPI->SPI_TPR = (unsigned int)pDesc->tx_cmd_pt ; + + /* Intialize the Transmit and Receive Counters */ + AT91C_BASE_SPI->SPI_RCR = pDesc->rx_cmd_size; + AT91C_BASE_SPI->SPI_TCR = pDesc->tx_cmd_size; + + if ( pDesc->tx_data_size != 0 ) { + /* Initialize the Next Transmit and Next Receive Pointer */ + AT91C_BASE_SPI->SPI_RNPR = (unsigned int)pDesc->rx_data_pt ; + AT91C_BASE_SPI->SPI_TNPR = (unsigned int)pDesc->tx_data_pt ; + + /* Intialize the Next Transmit and Next Receive Counters */ + AT91C_BASE_SPI->SPI_RNCR = pDesc->rx_data_size ; + AT91C_BASE_SPI->SPI_TNCR = pDesc->tx_data_size ; + } + + /* arm simple, non interrupt dependent timer */ + reset_timer_masked(); + timeout = 0; + + AT91C_BASE_SPI->SPI_PTCR = AT91C_PDC_TXTEN + AT91C_PDC_RXTEN; + while(!(AT91C_BASE_SPI->SPI_SR & AT91C_SPI_RXBUFF) && ((timeout = get_timer_masked() ) < CFG_SPI_WRITE_TOUT)); + AT91C_BASE_SPI->SPI_PTCR = AT91C_PDC_TXTDIS + AT91C_PDC_RXTDIS; + pDesc->state = IDLE; + + if (timeout >= CFG_SPI_WRITE_TOUT){ + printf("Error Timeout\n\r"); + return DATAFLASH_ERROR; + } + + return DATAFLASH_OK; +} + +#if (CONFIG_COMMANDS & CFG_CMD_SPI) + +void at91c_spi_serialdataflash_chipselect(int cs) +{ + if (cs) + { + AT91C_BASE_SPI->SPI_MR &= 0xFFF0FFFF; + AT91C_BASE_SPI->SPI_MR |= ((AT91C_SPI_PCS0_SERIAL_DATAFLASH<<16) & AT91C_SPI_PCS); + } +} + +void at91c_spi_dataflashcard_chipselect(int cs) +{ + if (cs) + { + AT91C_BASE_SPI->SPI_MR &= 0xFFF0FFFF; + AT91C_BASE_SPI->SPI_MR |= ((AT91C_SPI_PCS3_DATAFLASH_CARD<<16) & AT91C_SPI_PCS); + } +} + +/* + * The SPI command uses this table of functions for controlling the SPI + * chip selects: it calls the appropriate function to control the SPI + * chip selects. + */ + +spi_chipsel_type at91_standard_spi_chipsel[] = { + at91c_spi_serialdataflash_chipselect, + at91c_spi_dataflashcard_chipselect +}; + +int at91_standard_spi_chipsel_cnt = sizeof(at91_standard_spi_chipsel) / + sizeof(at91_standard_spi_chipsel[0]); + +/*----------------------------------------------------------------------- + * SPI transfer + * see spi.h for mor information +/*-----------------------------------------------------------------------*/ + +int spi_xfer(spi_chipsel_type chipsel, int bitlen, uchar *dout, uchar *din) +{ + int timeout; + int bytelen = (bitlen + 7) / 8; + AT91PS_DataflashDesc pDesc; + + if (chipsel) chipsel(1); /* select the target chip */ + printf("%d\n",bytelen); + + AT91C_BASE_SPI->SPI_PTCR = AT91C_PDC_TXTDIS + AT91C_PDC_RXTDIS; + + /* Initialize the Next Transmit and Next Receive Pointer */ + AT91C_BASE_SPI->SPI_RNPR = (unsigned int) din ; + AT91C_BASE_SPI->SPI_TNPR = (unsigned int) dout; + + /* Intialize the Next Transmit and Next Receive Counters */ + AT91C_BASE_SPI->SPI_RNCR = bytelen; + AT91C_BASE_SPI->SPI_TNCR = bytelen; + + /* arm simple, non interrupt dependent timer */ + reset_timer_masked(); + timeout = 0; + + AT91C_BASE_SPI->SPI_PTCR = AT91C_PDC_TXTEN + AT91C_PDC_RXTEN; + while (!(AT91C_BASE_SPI->SPI_SR & AT91C_SPI_RXBUFF) && ((timeout = get_timer_masked() ) < CFG_SPI_WRITE_TOUT)); + AT91C_BASE_SPI->SPI_PTCR = AT91C_PDC_TXTDIS + AT91C_PDC_RXTDIS; + if (timeout >= CFG_SPI_WRITE_TOUT){ + return 1; + } + if (chipsel) chipsel(0); /* deselect the target chip */ + + return 0; +} +#endif /* CMD_SPI */ + +#endif
----- Original Message ----- From: "Jens Scharsig" esw@bus-elektronik.de To: u-boot-users@lists.sourceforge.net Sent: Tuesday, June 12, 2007 10:30 AM Subject: [U-Boot-Users] [PATCH] SPI command support for ARM AT91rm9200
DESCRIPTION
Applying this patch will crash existing AT91RM9200 boards since the subroutines will be defined in two files. board/<board>/at45.c must not be built.
Also, it is not recommended to run the SPI faster than 5 Mbps unless you really know what you are doing.
The at45split patch is still in the patch queue, and Peter said he should be able to review it this week.
Best Regards Ulf Samuelsson
Ok,I use the split patch at this time. I will update my patch, if your patch availible in git tree.
Regards Jens
Jens Scharsig
Ulf Samuelsson
