[U-Boot] [PATCH] net: designware: Zap CONFIG_DW_AUTONEG
This symbol is not used anywhere, so remove it. For spear600, remove it from the board file, since the symbol is not defined for spear600 either.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Joe Hershberger joe.hershberger@ni.com --- board/spear/spear600/spear600.c | 3 --- include/configs/axs101.h | 5 ----- include/configs/sunxi-common.h | 1 - 3 files changed, 9 deletions(-)
diff --git a/board/spear/spear600/spear600.c b/board/spear/spear600/spear600.c index fc0918f..858a9ca 100644 --- a/board/spear/spear600/spear600.c +++ b/board/spear/spear600/spear600.c @@ -48,9 +48,6 @@ int board_eth_init(bd_t *bis)
#if defined(CONFIG_ETH_DESIGNWARE) u32 interface = PHY_INTERFACE_MODE_MII; -#if defined(CONFIG_DW_AUTONEG) - interface = PHY_INTERFACE_MODE_GMII; -#endif if (designware_initialize(CONFIG_SPEAR_ETHBASE, interface) >= 0) ret++; #endif diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 650d97d..3d6e94f 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -100,11 +100,6 @@ #define CONFIG_PHY_GIGE
/* - * Ethernet configuration - */ -#define CONFIG_DW_AUTONEG - -/* * Commands still not supported in Kconfig */ #define CONFIG_CMD_FAT diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index da6ab61..d826a5b 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -309,7 +309,6 @@ extern int soft_i2c_gpio_scl; #endif
#ifdef CONFIG_SUNXI_GMAC -#define CONFIG_DW_AUTONEG #define CONFIG_PHY_GIGE /* GMAC can use gigabit PHY */ #define CONFIG_PHY_ADDR 1 #define CONFIG_MII /* MII PHY management */
Applied, thanks.
Best regards, Marek Vasut
Bin Meng
