[RESEND RFC PATCH v2 0/4] enable menu-driven boot device selection
This patch series adds the menu-driven boot device selection. This menu also provides the functionality to add and delete Boot#### variable, and edit the BootOrder variable.
This menu appears with the command "bootefi bootmgr", the menu structure is as follows.
* Menu structure [Boot Manager] -> select Boot#### to boot [Boot Manager Maintenance] - [Add Boot Option] -> add new Boot#### variable - [Delete Boot Option] -> delete existing Boot#### variable - [Change Boot Order] -> update BootOrder variable
* Things to consider - eliminate EFI_CALLs - replacement of ANSI_CLEAR_CONSOLE
* Remaining items - Support of adding Boot#### other than block device(e.g. network) - error notification
Masahisa Kojima (4): efi_loader: add menu-driven boot device selection lib/charset: add u16_strlcat() function test: unit test for u16_strlcat() efi_loader: add menu-driven UEFI Boot Variable maintenance
cmd/bootmenu.c | 145 ----- common/menu.c | 137 ++++ include/charset.h | 15 + include/efi_loader.h | 27 + include/menu.h | 20 + lib/charset.c | 20 + lib/efi_loader/Kconfig | 20 + lib/efi_loader/efi_bootmgr.c | 1105 ++++++++++++++++++++++++++++++++- lib/efi_loader/efi_boottime.c | 55 +- lib/efi_loader/efi_console.c | 81 +++ lib/efi_loader/efi_file.c | 74 ++- test/unicode_ut.c | 45 ++ 12 files changed, 1548 insertions(+), 196 deletions(-)
This patch enables the menu-driven boot device selection. User can select the Boot#### included in BootOrder variable.
If user quits thie menu, or the selected Boot#### fails to boot, efi bootmgr continues to boot in accordance with BootOrder variable.
This commit also moves the user input handling from cmd/bootmenu.c to common/menu.c to reuse it from efi boot menu.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v2: - move user input handling from cmd/bootmenu.c to common/menu.c - keyboard buffer is drained before asking question in common/menu.c::bootmenu_autoboot_loop() - Add EFI_BOOT_MENU_DELAY Kconfig option to set delay for autoboot and disable autoboot - remove unnecessary "autoboot" member in struc efi_bootmgr_menu
cmd/bootmenu.c | 145 ------------ common/menu.c | 137 ++++++++++++ include/menu.h | 20 ++ lib/efi_loader/Kconfig | 20 ++ lib/efi_loader/efi_bootmgr.c | 418 ++++++++++++++++++++++++++++++++++- 5 files changed, 592 insertions(+), 148 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 409ef9a848..f9fdebc450 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -33,21 +33,6 @@ struct bootmenu_entry { struct bootmenu_entry *next; /* next menu entry (num+1) */ };
-struct bootmenu_data { - int delay; /* delay for autoboot */ - int active; /* active menu entry */ - int count; /* total count of menu entries */ - struct bootmenu_entry *first; /* first menu entry */ -}; - -enum bootmenu_key { - KEY_NONE = 0, - KEY_UP, - KEY_DOWN, - KEY_SELECT, - KEY_QUIT, -}; - static char *bootmenu_getoption(unsigned short int n) { char name[MAX_ENV_SIZE]; @@ -81,136 +66,6 @@ static void bootmenu_print_entry(void *data) puts(ANSI_COLOR_RESET); }
-static void bootmenu_autoboot_loop(struct bootmenu_data *menu, - enum bootmenu_key *key, int *esc) -{ - int i, c; - - if (menu->delay > 0) { - printf(ANSI_CURSOR_POSITION, menu->count + 5, 1); - printf(" Hit any key to stop autoboot: %2d ", menu->delay); - } - - while (menu->delay > 0) { - for (i = 0; i < 100; ++i) { - if (!tstc()) { - WATCHDOG_RESET(); - mdelay(10); - continue; - } - - menu->delay = -1; - c = getchar(); - - switch (c) { - case '\e': - *esc = 1; - *key = KEY_NONE; - break; - case '\r': - *key = KEY_SELECT; - break; - case 0x3: /* ^C */ - *key = KEY_QUIT; - break; - default: - *key = KEY_NONE; - break; - } - - break; - } - - if (menu->delay < 0) - break; - - --menu->delay; - printf("\b\b\b%2d ", menu->delay); - } - - printf(ANSI_CURSOR_POSITION, menu->count + 5, 1); - puts(ANSI_CLEAR_LINE); - - if (menu->delay == 0) - *key = KEY_SELECT; -} - -static void bootmenu_loop(struct bootmenu_data *menu, - enum bootmenu_key *key, int *esc) -{ - int c; - - if (*esc == 1) { - if (tstc()) { - c = getchar(); - } else { - WATCHDOG_RESET(); - mdelay(10); - if (tstc()) - c = getchar(); - else - c = '\e'; - } - } else { - while (!tstc()) { - WATCHDOG_RESET(); - mdelay(10); - } - c = getchar(); - } - - switch (*esc) { - case 0: - /* First char of ANSI escape sequence '\e' */ - if (c == '\e') { - *esc = 1; - *key = KEY_NONE; - } - break; - case 1: - /* Second char of ANSI '[' */ - if (c == '[') { - *esc = 2; - *key = KEY_NONE; - } else { - /* Alone ESC key was pressed */ - *key = KEY_QUIT; - *esc = (c == '\e') ? 1 : 0; - } - break; - case 2: - case 3: - /* Third char of ANSI (number '1') - optional */ - if (*esc == 2 && c == '1') { - *esc = 3; - *key = KEY_NONE; - break; - } - - *esc = 0; - - /* ANSI 'A' - key up was pressed */ - if (c == 'A') - *key = KEY_UP; - /* ANSI 'B' - key down was pressed */ - else if (c == 'B') - *key = KEY_DOWN; - /* other key was pressed */ - else - *key = KEY_NONE; - - break; - } - - /* enter key was pressed */ - if (c == '\r') - *key = KEY_SELECT; - - /* ^C was pressed */ - if (c == 0x3) - *key = KEY_QUIT; -} - static char *bootmenu_choice_entry(void *data) { struct bootmenu_data *menu = data; diff --git a/common/menu.c b/common/menu.c index 5fb2ffbd06..786e45f217 100644 --- a/common/menu.c +++ b/common/menu.c @@ -4,11 +4,14 @@ * Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved. */
+#include <ansi.h> #include <common.h> #include <cli.h> #include <malloc.h> #include <errno.h> +#include <linux/delay.h> #include <linux/list.h> +#include <watchdog.h>
#include "menu.h"
@@ -418,3 +421,137 @@ int menu_destroy(struct menu *m)
return 1; } + +void bootmenu_autoboot_loop(struct bootmenu_data *menu, + enum bootmenu_key *key, int *esc) +{ + int i, c; + + if (menu->delay > 0) { + /* flush input */ + while (tstc()) + getchar(); + + printf(ANSI_CURSOR_POSITION, menu->count + 5, 1); + printf(" Hit any key to stop autoboot: %2d ", menu->delay); + } + + while (menu->delay > 0) { + for (i = 0; i < 100; ++i) { + if (!tstc()) { + WATCHDOG_RESET(); + mdelay(10); + continue; + } + + menu->delay = -1; + c = getchar(); + + switch (c) { + case '\e': + *esc = 1; + *key = KEY_NONE; + break; + case '\r': + *key = KEY_SELECT; + break; + case 0x3: /* ^C */ + *key = KEY_QUIT; + break; + default: + *key = KEY_NONE; + break; + } + + break; + } + + if (menu->delay < 0) + break; + + --menu->delay; + printf("\b\b\b%2d ", menu->delay); + } + + printf(ANSI_CURSOR_POSITION, menu->count + 5, 1); + puts(ANSI_CLEAR_LINE); + + if (menu->delay == 0) + *key = KEY_SELECT; +} + +void bootmenu_loop(struct bootmenu_data *menu, + enum bootmenu_key *key, int *esc) +{ + int c; + + if (*esc == 1) { + if (tstc()) { + c = getchar(); + } else { + WATCHDOG_RESET(); + mdelay(10); + if (tstc()) + c = getchar(); + else + c = '\e'; + } + } else { + while (!tstc()) { + WATCHDOG_RESET(); + mdelay(10); + } + c = getchar(); + } + + switch (*esc) { + case 0: + /* First char of ANSI escape sequence '\e' */ + if (c == '\e') { + *esc = 1; + *key = KEY_NONE; + } + break; + case 1: + /* Second char of ANSI '[' */ + if (c == '[') { + *esc = 2; + *key = KEY_NONE; + } else { + /* Alone ESC key was pressed */ + *key = KEY_QUIT; + *esc = (c == '\e') ? 1 : 0; + } + break; + case 2: + case 3: + /* Third char of ANSI (number '1') - optional */ + if (*esc == 2 && c == '1') { + *esc = 3; + *key = KEY_NONE; + break; + } + + *esc = 0; + + /* ANSI 'A' - key up was pressed */ + if (c == 'A') + *key = KEY_UP; + /* ANSI 'B' - key down was pressed */ + else if (c == 'B') + *key = KEY_DOWN; + /* other key was pressed */ + else + *key = KEY_NONE; + + break; + } + + /* enter key was pressed */ + if (c == '\r') + *key = KEY_SELECT; + + /* ^C was pressed */ + if (c == 0x3) + *key = KEY_QUIT; +} diff --git a/include/menu.h b/include/menu.h index ad5859437e..e74616cae8 100644 --- a/include/menu.h +++ b/include/menu.h @@ -35,4 +35,24 @@ int menu_default_choice(struct menu *m, void **choice); */ int menu_show(int bootdelay);
+struct bootmenu_data { + int delay; /* delay for autoboot */ + int active; /* active menu entry */ + int count; /* total count of menu entries */ + struct bootmenu_entry *first; /* first menu entry */ +}; + +enum bootmenu_key { + KEY_NONE = 0, + KEY_UP, + KEY_DOWN, + KEY_SELECT, + KEY_QUIT, +}; + +void bootmenu_autoboot_loop(struct bootmenu_data *menu, + enum bootmenu_key *key, int *esc); +void bootmenu_loop(struct bootmenu_data *menu, + enum bootmenu_key *key, int *esc); + #endif /* __MENU_H__ */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index e5e35fe51f..a3fb8b2a75 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -39,6 +39,26 @@ config CMD_BOOTEFI_BOOTMGR via UEFI variables Boot####, BootOrder, and BootNext. This enables the 'bootefi bootmgr' command.
+config EFI_BOOT_MENU + bool "UEFI Boot Menu driven boot device selection" + default n + help + Select this option if you want to enable the menu driven boot device + selection. This menu provides the functionality to select a boot + option to start, and allow users to edit Boot#### and BootOrder. + If this menu is enabled, CLI can be disabled if the system boots + via UEFI variable Boot#### and BootOrder. + +config EFI_BOOT_MENU_DELAY + int "delay in seconds before automatically booting in UEFI Boot Menu" + default 10 + range -1 2147483647 + help + Delay before automatically booting in accordance with + "BootOrder" variable. + set to 0 to autoboot with no delay. + set to -1 to disable autoboot. + config EFI_SETUP_EARLY bool
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 8c04ecbdc8..bbb3fac5bd 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -7,10 +7,12 @@
#define LOG_CATEGORY LOGC_EFI
+#include <ansi.h> #include <common.h> #include <charset.h> #include <log.h> #include <malloc.h> +#include <menu.h> #include <efi_loader.h> #include <efi_variable.h> #include <asm/unaligned.h> @@ -22,14 +24,400 @@ static const struct efi_runtime_services *rs; * bootmgr implements the logic of trying to find a payload to boot * based on the BootOrder + BootXXXX variables, and then loading it. * - * TODO detecting a special key held (f9?) and displaying a boot menu - * like you would get on a PC would be clever. - * * TODO if we had a way to write and persist variables after the OS * has started, we'd also want to check OsIndications to see if we * should do normal or recovery boot. */
+#define EFI_BOOTMGR_MENU_ENTRY_NUM_MAX 1024 + +typedef efi_status_t (*efi_bootmenu_entry_func)(void *data, bool *exit); + +/** + * struct efi_bootmgr_menu_entry - menu entry structure + * + * @menu_index: menu entry index + * @title: title of entry + * @key: unique key + * @bootmgr_menu: pointer to the menu structure + * @next: pointer to the next entry + * @func: callback function to be called when this entry is selected + * @data: data to be passed to the callback function + */ +struct efi_bootmgr_menu_entry { + u32 menu_index; + u16 *title; + char key[6]; + struct efi_bootmgr_menu *bootmgr_menu; + struct efi_bootmgr_menu_entry *next; + efi_bootmenu_entry_func func; + void *data; +}; + +/** + * struct efi_bootmgr_menuy - bootmgr menu structure + * + * @delay: delay for autoboot + * @active: active menu entry index + * @count: total count of menu entry + * @first: pointer to the first menu entry + */ +struct efi_bootmgr_menu { + int delay; + int active; + int count; + struct efi_bootmgr_menu_entry *first; +}; + +struct efi_bootmgr_menu_item { + u16 *title; + efi_bootmenu_entry_func func; + void *data; +}; + +struct efi_bootmgr_boot_selection_data { + u16 bootorder_index; + void *load_option; + int *selected; +}; + +static efi_status_t efi_bootmgr_process_boot_selected(void *data, bool *exit); +static efi_status_t efi_bootmgr_process_boot_selection(void *data, bool *exit); + +static struct efi_bootmgr_menu_item bootmgr_menu_items[] = { + {u"Boot Manager", efi_bootmgr_process_boot_selection}, + {u"Quit", NULL}, +}; + +static void efi_bootmgr_menu_print_entry(void *data) +{ + struct efi_bootmgr_menu_entry *entry = data; + int reverse = (entry->bootmgr_menu->active == entry->menu_index); + + /* TODO: support scroll or page for many entries */ + + /* + * Move cursor to line where the entry will be drown (entry->count) + * First 3 lines contain bootmgr menu header + one empty line + * For the last "Quit" entry, add one empty line + */ + if (entry->menu_index == (entry->bootmgr_menu->count - 1)) + printf(ANSI_CURSOR_POSITION, entry->menu_index + 5, 1); + else + printf(ANSI_CURSOR_POSITION, entry->menu_index + 4, 1); + + puts(" "); + + if (reverse) + puts(ANSI_COLOR_REVERSE); + + printf("%ls", entry->title); + + if (reverse) + puts(ANSI_COLOR_RESET); +} + +static void efi_bootmgr_menu_display_statusline(struct menu *m) +{ + struct efi_bootmgr_menu_entry *entry; + struct efi_bootmgr_menu *bootmgr_menu; + + if (menu_default_choice(m, (void *)&entry) < 0) + return; + + bootmgr_menu = entry->bootmgr_menu; + + printf(ANSI_CURSOR_POSITION, 1, 1); + puts(ANSI_CLEAR_LINE); + printf(ANSI_CURSOR_POSITION, 2, 1); + puts(" *** U-Boot EFI Boot Manager ***"); + puts(ANSI_CLEAR_LINE_TO_END); + printf(ANSI_CURSOR_POSITION, 3, 1); + puts(ANSI_CLEAR_LINE); + + /* First 3 lines are bootmgr_menu header + 2 empty lines between entries */ + printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 5, 1); + puts(ANSI_CLEAR_LINE); + printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 6, 1); + puts(" Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit"); + puts(ANSI_CLEAR_LINE_TO_END); + printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 7, 1); + puts(ANSI_CLEAR_LINE); +} + +static char *efi_bootmgr_menu_choice_entry(void *data) +{ + int i; + int esc = 0; + struct efi_bootmgr_menu_entry *iter; + enum bootmenu_key key = KEY_NONE; + struct efi_bootmgr_menu *bootmgr_menu = data; + + while (1) { + if (bootmgr_menu->delay >= 0) { + /* Autoboot was not stopped */ + bootmenu_autoboot_loop((struct bootmenu_data *)bootmgr_menu, &key, &esc); + } else { + /* Some key was pressed, so autoboot was stopped */ + bootmenu_loop((struct bootmenu_data *)bootmgr_menu, &key, &esc); + } + + if (bootmgr_menu->delay == 0) + key = KEY_QUIT; + + switch (key) { + case KEY_UP: + if (bootmgr_menu->active > 0) + --bootmgr_menu->active; + /* no menu key selected, regenerate menu */ + return NULL; + case KEY_DOWN: + if (bootmgr_menu->active < bootmgr_menu->count - 1) + ++bootmgr_menu->active; + /* no menu key selected, regenerate menu */ + return NULL; + case KEY_SELECT: + iter = bootmgr_menu->first; + for (i = 0; i < bootmgr_menu->active; ++i) + iter = iter->next; + return iter->key; + case KEY_QUIT: + /* Quit by choosing the last entry */ + iter = bootmgr_menu->first; + while (iter->next) + iter = iter->next; + return iter->key; + default: + break; + } + } + + /* never happens */ + debug("bootmgr menu: this should not happen"); + return NULL; +} + +static void efi_bootmgr_menu_destroy(struct efi_bootmgr_menu *bootmgr_menu) +{ + struct efi_bootmgr_menu_entry *next; + struct efi_bootmgr_menu_entry *iter = bootmgr_menu->first; + + while (iter) { + next = iter->next; + free(iter); + iter = next; + } + free(bootmgr_menu); +} + +/** + * efi_bootmgr_process_common() - main handler for uefi bootmgr menu + * + * Construct the structures required to show the menu, then handle + * the user input intracting with u-boot menu functions. + * + * @items: pointer to the structure of each menu entry + * @count: the number of menu entry + * @delay: delay for autoboot/autoselect + * Return: status code + */ +static efi_status_t efi_bootmgr_process_common(struct efi_bootmgr_menu_item *items, + int count, int delay) +{ + u32 i; + bool exit = false; + efi_status_t ret; + struct menu *menu; + void *choice = NULL; + struct efi_bootmgr_menu_entry *entry; + struct efi_bootmgr_menu *bootmgr_menu; + struct efi_bootmgr_menu_entry *iter = NULL; + + if (count > EFI_BOOTMGR_MENU_ENTRY_NUM_MAX) + return EFI_OUT_OF_RESOURCES; + + bootmgr_menu = calloc(1, sizeof(struct efi_bootmgr_menu)); + if (!bootmgr_menu) + return EFI_OUT_OF_RESOURCES; + + bootmgr_menu->delay = delay; + bootmgr_menu->active = 0; + bootmgr_menu->first = NULL; + + for (i = 0; i < count; i++) { + entry = calloc(1, sizeof(struct efi_bootmgr_menu_entry)); + if (!entry) { + ret = EFI_LOAD_ERROR; + goto out; + } + + entry->menu_index = i; + entry->title = items->title; + snprintf(entry->key, sizeof(entry->key), "%04X", i); + entry->bootmgr_menu = bootmgr_menu; + entry->func = items->func; + entry->data = items->data; + entry->next = NULL; + + if (!iter) + bootmgr_menu->first = entry; + else + iter->next = entry; + + iter = entry; + items++; + } + bootmgr_menu->count = count; + + menu = menu_create(NULL, 0, 1, efi_bootmgr_menu_display_statusline, + efi_bootmgr_menu_print_entry, efi_bootmgr_menu_choice_entry, + bootmgr_menu); + if (!menu) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + for (entry = bootmgr_menu->first; entry; entry = entry->next) { + if (!menu_item_add(menu, entry->key, entry)) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + } + + menu_default_set(menu, bootmgr_menu->first->key); + + while (!exit) { + puts(ANSI_CURSOR_HIDE); + puts(ANSI_CLEAR_CONSOLE); + printf(ANSI_CURSOR_POSITION, 1, 1); + + if (menu_get_choice(menu, &choice)) { + entry = choice; + if (entry->func) + ret = entry->func(entry->data, &exit); + + /* last entry "Quit" is selected, exit this menu */ + if (entry->menu_index == (entry->bootmgr_menu->count - 1)) { + ret = EFI_ABORTED; + break; + } + } + } + +out: + menu_destroy(menu); + efi_bootmgr_menu_destroy(bootmgr_menu); + + puts(ANSI_CLEAR_CONSOLE); + printf(ANSI_CURSOR_POSITION, 1, 1); + puts(ANSI_CURSOR_SHOW); + + return ret; +} + +static efi_status_t efi_bootmgr_show_boot_selection(u16 *bootorder, efi_uintn_t count, + int *selected) +{ + u32 i; + efi_status_t ret; + efi_uintn_t size; + void *load_option; + struct efi_load_option lo; + u16 varname[] = u"Boot####"; + struct efi_bootmgr_menu_item *menu_item, *iter; + + menu_item = calloc(count + 1, sizeof(struct efi_bootmgr_menu_item)); + if (!menu_item) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + iter = menu_item; + for (i = 0; i < count; i++) { + efi_create_indexed_name(varname, sizeof(varname), + "Boot", bootorder[i]); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + continue; + + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) { + log_warning("Invalid load option for %ls\n", varname); + free(load_option); + continue; + } + + if (lo.attributes & LOAD_OPTION_ACTIVE) { + struct efi_bootmgr_boot_selection_data *info; + + info = calloc(1, sizeof(struct efi_bootmgr_boot_selection_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + info->bootorder_index = i; + info->load_option = load_option; + info->selected = selected; + iter->title = lo.label; + iter->func = efi_bootmgr_process_boot_selected; + iter->data = info; + iter++; + } + } + + /* add "Quit" entry */ + iter->title = u"Quit"; + iter->func = NULL; + iter->data = NULL; + count += 1; + + ret = efi_bootmgr_process_common(menu_item, count, -1); + +out: + iter = menu_item; + for (i = 0; i < count - 1; i++, iter++) { + free(((struct efi_bootmgr_boot_selection_data *)iter->data)->load_option); + free(iter->data); + } + + free(menu_item); + + return ret; +} + +static efi_status_t efi_bootmgr_process_boot_selected(void *data, bool *exit) +{ + struct efi_bootmgr_boot_selection_data *info = data; + + *exit = true; + + if (info) + *info->selected = info->bootorder_index; + + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmgr_process_boot_selection(void *data, bool *exit) +{ + u16 *bootorder; + efi_status_t ret; + efi_uintn_t num, size; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) + return EFI_NOT_FOUND; + + num = size / sizeof(u16); + ret = efi_bootmgr_show_boot_selection(bootorder, num, data); + if (ret == EFI_SUCCESS) + *exit = true; + + free(bootorder); + + return ret; +} + /** * try_load_entry() - try to load image for boot option * @@ -177,6 +565,30 @@ efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options) } }
+ if (IS_ENABLED(CONFIG_EFI_BOOT_MENU)) { + int selected; + + bootmgr_menu_items[0].data = &selected; + ret = efi_bootmgr_process_common(bootmgr_menu_items, + ARRAY_SIZE(bootmgr_menu_items), + CONFIG_EFI_BOOT_MENU_DELAY); + if (ret == EFI_SUCCESS) { + /* bootorder may be updated in the bootmgr menu */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) { + log_info("BootOrder not defined\n"); + goto error; + } + ret = try_load_entry(bootorder[selected], handle, load_options); + free(bootorder); + if (ret == EFI_SUCCESS) + return ret; + + log_err("Failed to start the selected entry(Boot%04X)\n", + bootorder[selected]); + } + } + /* BootOrder */ bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); if (!bootorder) {
With the series applied and CONFIG_EFI_BOOT_MENU=y I first see a line "Hit any key to stop autoboot:" with a count down and then the UEFI menu with a countdown. This duplication of countdowns does not make sense.
This is the content of the new menu:
Boot Manager Boot Manager maintenance
Quit
When selecting " Boot Manager maintenance" I see a second menu:
Add Boot Option Delete Boot Option Change Boot Order
Quit
When I select "Add Boot Option" the system (qemu_arm64_defconfig) simply hangs.
Why do we need the first menu? Compare it to your laptop experience when pressing the boot menu key (often <F12> or <F8>).
Can't we have a simple countdown:
"Hit any key for boot menu"
If a key is hit show a menu showing the different boot options and the distro-boot devices:
Debian (0001) Ubuntu (0002) SATA(1) SATA(2) NVMe(1) Boot manager settings Command line
Simon has proposed a patch series "Initial implementation of standard boot", https://patchwork.ozlabs.org/project/uboot/list/?series=281745&state=*. I think the proposed menu would have to iterate through all active boot methods.
Changes in v2:
- KEY_NONE = 0,
- KEY_UP,
- KEY_DOWN,
- KEY_SELECT,
- KEY_QUIT,
- int i, c;
if (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
continue;
menu->delay = -1;
c = getchar();
switch (c) {
case '\e':
*esc = 1;
*key = KEY_NONE;
break;
case '\r':
*key = KEY_SELECT;
break;
case 0x3: /* ^C */
*key = KEY_QUIT;
break;
default:
*key = KEY_NONE;
break;
break;
break;
--menu->delay;
*key = KEY_SELECT;
- int c;
- if (*esc == 1) {
if (tstc()) {
c = getchar();
} else {
WATCHDOG_RESET();
mdelay(10);
if (tstc())
c = getchar();
else
c = '\e';
- } else {
while (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
c = getchar();
- switch (*esc) {
- case 0:
if (c == '\e') {
*esc = 1;
*key = KEY_NONE;
break;
- case 1:
if (c == '[') {
*esc = 2;
*key = KEY_NONE;
} else {
*key = KEY_QUIT;
break;
- case 2:
- case 3:
*esc = 3;
*key = KEY_NONE;
break;
*esc = 0;
if (c == 'A')
*key = KEY_UP;
else if (c == 'B')
*key = KEY_DOWN;
else
*key = KEY_NONE;
break;
- if (c == '\r')
*key = KEY_SELECT;
- if (c == 0x3)
*key = KEY_QUIT;
- Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
common/menu.c is only compiled if CONFIG_MENU=y but CONFIG_EFI_BOOT_MENU does not select it. So depending on configuration this simply does not link:
lib/efi_loader/efi_bootmgr.c:315: undefined reference to `menu_create' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.c:330: undefined reference to `menu_default_set' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.c:351: undefined reference to `menu_destroy' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.c:324: undefined reference to `menu_item_add' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.c:337: undefined reference to `menu_get_choice' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.o: in function `efi_bootmgr_menu_choice_entry': lib/efi_loader/efi_bootmgr.c:202: undefined reference to `bootmenu_autoboot_loop' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.c:205: undefined reference to `bootmenu_loop' aarch64-linux-gnu-ld.bfd: lib/efi_loader/efi_bootmgr.o: in function `efi_bootmgr_menu_display_statusline': lib/efi_loader/efi_bootmgr.c:168: undefined reference to `menu_default_choice
#include "menu.h"
return 1; }
- int i, c;
/* flush input */
while (tstc())
getchar();
if (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
continue;
menu->delay = -1;
c = getchar();
switch (c) {
case '\e':
*esc = 1;
*key = KEY_NONE;
break;
case '\r':
*key = KEY_SELECT;
break;
case 0x3: /* ^C */
*key = KEY_QUIT;
break;
default:
*key = KEY_NONE;
break;
break;
break;
--menu->delay;
*key = KEY_SELECT;
- int c;
- if (*esc == 1) {
if (tstc()) {
c = getchar();
} else {
WATCHDOG_RESET();
mdelay(10);
if (tstc())
c = getchar();
else
c = '\e';
- } else {
while (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
c = getchar();
- switch (*esc) {
- case 0:
if (c == '\e') {
*esc = 1;
*key = KEY_NONE;
break;
- case 1:
if (c == '[') {
*esc = 2;
*key = KEY_NONE;
} else {
*key = KEY_QUIT;
break;
- case 2:
- case 3:
*esc = 3;
*key = KEY_NONE;
break;
*esc = 0;
if (c == 'A')
*key = KEY_UP;
else if (c == 'B')
*key = KEY_DOWN;
else
*key = KEY_NONE;
break;
- if (c == '\r')
*key = KEY_SELECT;
- if (c == 0x3)
*key = KEY_QUIT;
- KEY_NONE = 0,
- KEY_UP,
- KEY_DOWN,
- KEY_SELECT,
- KEY_QUIT,
- #endif /* __MENU_H__ */
- bool "UEFI Boot Menu driven boot device selection"
- default n
- help
We end up with these symbols for menus:
CONFIG_MENU CONFIG_AUTOBOOT_MENUKEY CONFIG_AUTOBOOT_MENU_SHOW CONFIG_BOOTDELAY CONFIG_EFI_BOOT_MENU CONFIG_EFI_BOOT_MENU_DELAY
Defining both CONFIG_AUTOBOOT_MENU_SHOW and CONFIG_EFI_BOOT_MENU does not make much sense. Same for CONFIG_BOOTDELAY and CONFIG_EFI_BOOT_MENU_DELAY. Please, unifiy the settings.
Best regards
Heinrich
- int "delay in seconds before automatically booting in UEFI Boot Menu"
- default 10
- range -1 2147483647
- help
- config EFI_SETUP_EARLY bool
- bootmgr implements the logic of trying to find a payload to boot
- based on the BootOrder + BootXXXX variables, and then loading it.
- TODO detecting a special key held (f9?) and displaying a boot menu
- like you would get on a PC would be clever.
- TODO if we had a way to write and persist variables after the OS
- has started, we'd also want to check OsIndications to see if we
- should do normal or recovery boot.
- struct efi_bootmgr_menu_entry - menu entry structure
- @menu_index: menu entry index
- @title: title of entry
- @key: unique key
- @bootmgr_menu: pointer to the menu structure
- @next: pointer to the next entry
- @func: callback function to be called when this entry is selected
- @data: data to be passed to the callback function
- u32 menu_index;
- u16 *title;
- char key[6];
- struct efi_bootmgr_menu *bootmgr_menu;
- struct efi_bootmgr_menu_entry *next;
- efi_bootmenu_entry_func func;
- void *data;
- struct efi_bootmgr_menuy - bootmgr menu structure
- @delay: delay for autoboot
- @active: active menu entry index
- @count: total count of menu entry
- @first: pointer to the first menu entry
- int delay;
- int active;
- int count;
- struct efi_bootmgr_menu_entry *first;
- u16 *title;
- void *data;
- u16 bootorder_index;
- void *load_option;
- int *selected;
- {u"Boot Manager", efi_bootmgr_process_boot_selection},
- {u"Quit", NULL},
- struct efi_bootmgr_menu_entry *entry = data;
- int reverse = (entry->bootmgr_menu->active == entry->menu_index);
- /* TODO: support scroll or page for many entries */
- if (entry->menu_index == (entry->bootmgr_menu->count - 1))
- else
- puts(" ");
- if (reverse)
- printf("%ls", entry->title);
- if (reverse)
- struct efi_bootmgr_menu_entry *entry;
- if (menu_default_choice(m, (void *)&entry) < 0)
return;
- bootmgr_menu = entry->bootmgr_menu;
- printf(ANSI_CURSOR_POSITION, 1, 1);
- printf(ANSI_CURSOR_POSITION, 2, 1);
- puts(" *** U-Boot EFI Boot Manager ***");
- puts(ANSI_CLEAR_LINE_TO_END);
- printf(ANSI_CURSOR_POSITION, 3, 1);
- /* First 3 lines are bootmgr_menu header + 2 empty lines between entries */
- printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 5, 1);
- printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 6, 1);
- puts(" Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit");
- printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 7, 1);
- int i;
- int esc = 0;
- struct efi_bootmgr_menu_entry *iter;
- enum bootmenu_key key = KEY_NONE;
- struct efi_bootmgr_menu *bootmgr_menu = data;
- while (1) {
} else {
key = KEY_QUIT;
switch (key) {
case KEY_UP:
return NULL;
case KEY_DOWN:
return NULL;
case KEY_SELECT:
iter = iter->next;
return iter->key;
case KEY_QUIT:
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
- /* never happens */
- debug("bootmgr menu: this should not happen");
- return NULL;
- struct efi_bootmgr_menu_entry *iter = bootmgr_menu->first;
- while (iter) {
next = iter->next;
free(iter);
iter = next;
- free(bootmgr_menu);
- efi_bootmgr_process_common() - main handler for uefi bootmgr menu
- Construct the structures required to show the menu, then handle
- the user input intracting with u-boot menu functions.
- @items: pointer to the structure of each menu entry
- @count: the number of menu entry
- @delay: delay for autoboot/autoselect
- Return: status code
- u32 i;
- bool exit = false;
- efi_status_t ret;
- struct menu *menu;
- void *choice = NULL;
- struct efi_bootmgr_menu_entry *iter = NULL;
- if (count > EFI_BOOTMGR_MENU_ENTRY_NUM_MAX)
- bootmgr_menu = calloc(1, sizeof(struct efi_bootmgr_menu));
- if (!bootmgr_menu)
- bootmgr_menu->delay = delay;
- bootmgr_menu->active = 0;
- bootmgr_menu->first = NULL;
- for (i = 0; i < count; i++) {
if (!entry) {
goto out;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
items++;
- bootmgr_menu->count = count;
- menu = menu_create(NULL, 0, 1, efi_bootmgr_menu_display_statusline,
bootmgr_menu);
- if (!menu) {
goto out;
- for (entry = bootmgr_menu->first; entry; entry = entry->next) {
goto out;
- menu_default_set(menu, bootmgr_menu->first->key);
- while (!exit) {
entry = choice;
if (entry->func)
ret = EFI_ABORTED;
break;
+out:
- menu_destroy(menu);
- efi_bootmgr_menu_destroy(bootmgr_menu);
- puts(ANSI_CLEAR_CONSOLE);
- puts(ANSI_CURSOR_SHOW);
- return ret;
int *selected)
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
- struct efi_load_option lo;
- u16 varname[] = u"Boot####";
- struct efi_bootmgr_menu_item *menu_item, *iter;
- menu_item = calloc(count + 1, sizeof(struct efi_bootmgr_menu_item));
- if (!menu_item) {
goto out;
- iter = menu_item;
if (!load_option)
continue;
free(load_option);
continue;
if (!info) {
goto out;
iter->data = info;
iter++;
- /* add "Quit" entry */
- iter->title = u"Quit";
- iter->func = NULL;
- iter->data = NULL;
- count += 1;
- ret = efi_bootmgr_process_common(menu_item, count, -1);
+out:
- iter = menu_item;
- for (i = 0; i < count - 1; i++, iter++) {
free(iter->data);
- free(menu_item);
- return ret;
- struct efi_bootmgr_boot_selection_data *info = data;
- *exit = true;
- if (info)
- return EFI_SUCCESS;
- u16 *bootorder;
- efi_status_t ret;
- efi_uintn_t num, size;
- bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size);
- if (!bootorder)
- num = size / sizeof(u16);
- ret = efi_bootmgr_show_boot_selection(bootorder, num, data);
- if (ret == EFI_SUCCESS)
*exit = true;
- free(bootorder);
- return ret;
- try_load_entry() - try to load image for boot option
- if (IS_ENABLED(CONFIG_EFI_BOOT_MENU)) {
int selected;
if (!bootorder) {
goto error;
free(bootorder);
return ret;
- /* BootOrder */ bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); if (!bootorder) {
Hi Heinrich,
Thank you for your review. I agree, this duplication does not make sense.
Anyway, my primary goal is to disable CLI, user can select the UEFI boot option("Boot####" variable) to boot the system, and user can edit the UEFI boot option("Boot####" and "BootOrder") through the menu.
I now realize that my patch series probably do not work without CLI, and hooking the "bootefi bootmgr" command to show the new efi bootmenu is probably wrong. I will investigate further.
Boot Manager Boot Manager maintenance Quit
Add Boot Option Delete Boot Option Change Boot Order Quit
Sorry, there is something wrong on my code. I will try to reproduce.
Yes, I could skip the first menu.
The current scope of this patch series are disabling CLI and booting the system with UEFI boot option. I will check what I can do for distro-boot.
Changes in v2:
KEY_NONE = 0,
KEY_UP,
KEY_DOWN,
KEY_SELECT,
KEY_QUIT,
int i, c;
if (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
continue;
menu->delay = -1;
c = getchar();
switch (c) {
case '\e':
*esc = 1;
*key = KEY_NONE;
break;
case '\r':
*key = KEY_SELECT;
break;
case 0x3: /* ^C */
*key = KEY_QUIT;
break;
default:
*key = KEY_NONE;
break;
break;
break;
--menu->delay;
*key = KEY_SELECT;
int c;
if (*esc == 1) {
if (tstc()) {
c = getchar();
} else {
WATCHDOG_RESET();
mdelay(10);
if (tstc())
c = getchar();
else
c = '\e';
} else {
while (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
c = getchar();
switch (*esc) {
case 0:
if (c == '\e') {
*esc = 1;
*key = KEY_NONE;
break;
case 1:
if (c == '[') {
*esc = 2;
*key = KEY_NONE;
} else {
*key = KEY_QUIT;
break;
case 2:
case 3:
*esc = 3;
*key = KEY_NONE;
break;
*esc = 0;
if (c == 'A')
*key = KEY_UP;
else if (c == 'B')
*key = KEY_DOWN;
else
*key = KEY_NONE;
break;
if (c == '\r')
*key = KEY_SELECT;
if (c == 0x3)
*key = KEY_QUIT;
I will fix this.
#include "menu.h"
return 1;
int i, c;
/* flush input */
while (tstc())
getchar();
if (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
continue;
menu->delay = -1;
c = getchar();
switch (c) {
case '\e':
*esc = 1;
*key = KEY_NONE;
break;
case '\r':
*key = KEY_SELECT;
break;
case 0x3: /* ^C */
*key = KEY_QUIT;
break;
default:
*key = KEY_NONE;
break;
break;
break;
--menu->delay;
*key = KEY_SELECT;
int c;
if (*esc == 1) {
if (tstc()) {
c = getchar();
} else {
WATCHDOG_RESET();
mdelay(10);
if (tstc())
c = getchar();
else
c = '\e';
} else {
while (!tstc()) {
WATCHDOG_RESET();
mdelay(10);
c = getchar();
switch (*esc) {
case 0:
if (c == '\e') {
*esc = 1;
*key = KEY_NONE;
break;
case 1:
if (c == '[') {
*esc = 2;
*key = KEY_NONE;
} else {
*key = KEY_QUIT;
break;
case 2:
case 3:
*esc = 3;
*key = KEY_NONE;
break;
*esc = 0;
if (c == 'A')
*key = KEY_UP;
else if (c == 'B')
*key = KEY_DOWN;
else
*key = KEY_NONE;
break;
if (c == '\r')
*key = KEY_SELECT;
if (c == 0x3)
*key = KEY_QUIT;
KEY_NONE = 0,
KEY_UP,
KEY_DOWN,
KEY_SELECT,
KEY_QUIT,
default n
help
I will consider how I can unify these options.
Thanks, Masahisa Kojima
Best regards
Heinrich
default 10
range -1 2147483647
help
- @key: unique key
u32 menu_index;
u16 *title;
char key[6];
void *data;
int delay;
int active;
int count;
u16 *title;
void *data;
void *load_option;
int *selected;
{u"Quit", NULL},
else
puts(" ");
if (reverse)
if (reverse)
return;
int i;
int esc = 0;
while (1) {
} else {
key = KEY_QUIT;
switch (key) {
case KEY_UP:
return NULL;
case KEY_DOWN:
return NULL;
case KEY_SELECT:
iter = iter->next;
return iter->key;
case KEY_QUIT:
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
/* never happens */
return NULL;
while (iter) {
next = iter->next;
free(iter);
iter = next;
free(bootmgr_menu);
u32 i;
bool exit = false;
efi_status_t ret;
struct menu *menu;
if (!bootmgr_menu)
if (!entry) {
goto out;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
items++;
bootmgr_menu);
if (!menu) {
goto out;
goto out;
while (!exit) {
entry = choice;
if (entry->func)
ret = EFI_ABORTED;
break;
+out:
menu_destroy(menu);
return ret;
int *selected)
u32 i;
efi_status_t ret;
efi_uintn_t size;
void *load_option;
if (!menu_item) {
goto out;
iter = menu_item;
if (!load_option)
continue;
free(load_option);
continue;
if (!info) {
goto out;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+out:
iter = menu_item;
free(iter->data);
free(menu_item);
return ret;
*exit = true;
if (info)
return EFI_SUCCESS;
u16 *bootorder;
efi_status_t ret;
if (!bootorder)
*exit = true;
free(bootorder);
return ret;
int selected;
if (!bootorder) {
goto error;
free(bootorder);
return ret;
Provide u16 string version of strlcat().
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v2: - implement u16_strlcat(with the destination buffer size in argument) instead of u16_strcat
include/charset.h | 15 +++++++++++++++ lib/charset.c | 20 ++++++++++++++++++++ 2 files changed, 35 insertions(+)
diff --git a/include/charset.h b/include/charset.h index b93d023092..dc5fc275ec 100644 --- a/include/charset.h +++ b/include/charset.h @@ -259,6 +259,21 @@ u16 *u16_strcpy(u16 *dest, const u16 *src); */ u16 *u16_strdup(const void *src);
+/** + * u16_strlcat() - Append a length-limited, %NUL-terminated string to another + * + * Append the src string to the dest string, overwriting the terminating + * null word at the end of dest, and then adds a terminating null word. + * It will append at most size - u16_strlen(dst) - 1 bytes, NUL-terminating the result. + * + * @dest: destination buffer (null terminated) + * @src: source buffer (null terminated) + * @size: destination buffer size in bytes + * Return: total size of the created string in bytes. + * If return value >= size, truncation occurred. + */ +size_t u16_strlcat(u16 *dest, const u16 *src, size_t size); + /** * utf16_to_utf8() - Convert an utf16 string to utf8 * diff --git a/lib/charset.c b/lib/charset.c index f44c58d9d8..f15d5df19a 100644 --- a/lib/charset.c +++ b/lib/charset.c @@ -428,6 +428,26 @@ u16 *u16_strdup(const void *src) return new; }
+size_t u16_strlcat(u16 *dest, const u16 *src, size_t size) +{ + size_t dstrlen = u16_strnlen(dest, size >> 1); + size_t dlen = dstrlen * sizeof(u16); + size_t len = u16_strlen(src) * sizeof(u16); + size_t ret = dlen + len; + + if (dlen >= size) + return ret; + + dest += dstrlen; + size -= dlen; + if (len >= size) + len = size - sizeof(u16); + + memcpy(dest, src, len); + dest[len >> 1] = u'\0'; + return ret; +} + /* Convert UTF-16 to UTF-8. */ uint8_t *utf16_to_utf8(uint8_t *dest, const uint16_t *src, size_t size) {
Hi Masahisa,
On Thu, 24 Feb 2022 at 18:31, Masahisa Kojima masahisa.kojima@linaro.org wrote:
Changes in v2:
nits below
- u16_strlcat() - Append a length-limited, %NUL-terminated string to another
- Append the src string to the dest string, overwriting the terminating
- null word at the end of dest, and then adds a terminating null word.
add
- It will append at most size - u16_strlen(dst) - 1 bytes, NUL-terminating the result.
- @dest: destination buffer (null terminated)
- @src: source buffer (null terminated)
- @size: destination buffer size in bytes
- Return: total size of the created string in bytes.
- utf16_to_utf8() - Convert an utf16 string to utf8
if (dlen >= size)
return ret;
dest += dstrlen;
size -= dlen;
if (len >= size)
blank line before final return
return ret;
/* Convert UTF-16 to UTF-8. */ uint8_t *utf16_to_utf8(uint8_t *dest, const uint16_t *src, size_t size) { -- 2.17.1
Hi Simon,
On Sat, 12 Mar 2022 at 11:24, Simon Glass sjg@chromium.org wrote:
Hi Masahisa,
Changes in v2:
nits below
add
if (dlen >= size)
return ret;
dest += dstrlen;
size -= dlen;
if (len >= size)
OK. Thank you for your review.
Regards, Masahisa Kojima
return ret;
Provide a unit test for function u16_strlcat().
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Newly created in v2.
test/unicode_ut.c | 45 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/test/unicode_ut.c b/test/unicode_ut.c index f2f63d5367..f79b0439bc 100644 --- a/test/unicode_ut.c +++ b/test/unicode_ut.c @@ -758,6 +758,51 @@ static int unicode_test_efi_create_indexed_name(struct unit_test_state *uts) UNICODE_TEST(unicode_test_efi_create_indexed_name); #endif
+static int unicode_test_u16_strlcat(struct unit_test_state *uts) +{ + u16 buf[11]; + u16 dest[] = u"U-Boot"; + u16 src[] = u"test"; + u16 expected[] = u"U-Boottest"; + u16 null_src = u'\0'; + size_t ret; + + memcpy(buf, dest, sizeof(dest)); + ret = u16_strlcat(buf, src, sizeof(buf)); + ut_asserteq(20, ret); + ut_assert(!unicode_test_u16_strcmp(buf, expected, 11)); + + /* dest is empty string */ + memset(buf, 0, sizeof(buf)); + ret = u16_strlcat(buf, src, sizeof(buf)); + ut_asserteq(8, ret); + ut_assert(!unicode_test_u16_strcmp(buf, src, 11)); + + /* src is empty string */ + memset(buf, 0, sizeof(buf)); + memcpy(buf, dest, sizeof(dest)); + ret = u16_strlcat(buf, &null_src, sizeof(buf)); + ut_asserteq(12, ret); + ut_assert(!unicode_test_u16_strcmp(buf, dest, 11)); + + /* size is smaller than dest size */ + memset(buf, 0, sizeof(buf)); + memcpy(buf, dest, sizeof(dest)); + ret = u16_strlcat(buf, src, 6); + ut_asserteq(14, ret); + ut_assert(!unicode_test_u16_strcmp(buf, dest, 11)); + + /* size is insufficient to append src string */ + memset(buf, 0, sizeof(buf)); + memcpy(buf, dest, sizeof(dest)); + ret = u16_strlcat(buf, src, 20); + ut_asserteq(20, ret); + ut_assert(!unicode_test_u16_strcmp(buf, u"U-Boottes", 11)); + + return 0; +} +UNICODE_TEST(unicode_test_u16_strlcat); + int do_ut_unicode(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { struct unit_test *tests = UNIT_TEST_SUITE_START(unicode_test);
This commit adds the menu-driven UEFI Boot Variable maintenance. User can add and delete the Boot#### variable, and update the BootOrder variable through menu operation.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v2: - enable utf8 user input for boot option name - create lib/efi_loader/efi_console.c::efi_console_get_u16_string() for utf8 user input handling - use u16_strlcat instead of u16_strcat - remove the EFI_CALLs, and newly create or expose the following xxx_int() functions. efi_locate_handle_buffer_int(), efi_open_volume_int(), efi_file_open_int(), efi_file_close_int(), efi_file_read_int() and efi_file_setpos_int(). Note that EFI_CALLs still exist for EFI_DEVICE_PATH_TO_TEXT_PROTOCOL and EFI_SIMPLE_TEXT_INPUT/OUTPUT_PROTOCOL - use efi_search_protocol() instead of calling locate_protocol() to get the device_path_to_text_protocol interface. - remove unnecessary puts(ANSI_CLEAR_LINE), this patch is still depends on puts(ANSI_CLEAR_CONSOLE) - skip SetVariable() if the bootorder is not changed
include/efi_loader.h | 27 ++ lib/efi_loader/efi_bootmgr.c | 687 ++++++++++++++++++++++++++++++++++ lib/efi_loader/efi_boottime.c | 55 +-- lib/efi_loader/efi_console.c | 81 ++++ lib/efi_loader/efi_file.c | 74 ++-- 5 files changed, 876 insertions(+), 48 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index e390d323a9..0623e0a707 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -278,6 +278,7 @@ extern const efi_guid_t efi_guid_loaded_image; extern const efi_guid_t efi_guid_loaded_image_device_path; extern const efi_guid_t efi_guid_device_path_to_text_protocol; extern const efi_guid_t efi_simple_file_system_protocol_guid; +extern const efi_guid_t efi_system_partition_guid; extern const efi_guid_t efi_file_info_guid; /* GUID for file system information */ extern const efi_guid_t efi_file_system_info_guid; @@ -310,6 +311,9 @@ extern const efi_guid_t efi_guid_firmware_management_protocol; extern const efi_guid_t efi_esrt_guid; /* GUID of the SMBIOS table */ extern const efi_guid_t smbios_guid; +/*GUID of console */ +extern const efi_guid_t efi_guid_text_input_protocol; +extern const efi_guid_t efi_guid_text_output_protocol;
extern char __efi_runtime_start[], __efi_runtime_stop[]; extern char __efi_runtime_rel_start[], __efi_runtime_rel_stop[]; @@ -998,4 +1002,27 @@ efi_status_t efi_esrt_populate(void); efi_status_t efi_load_capsule_drivers(void);
efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, u32 *sz); + +efi_status_t efi_locate_handle_buffer_int(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer); + +efi_status_t efi_open_volume_int(struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root); +efi_status_t efi_file_open_int(struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, + u64 attributes); +efi_status_t efi_file_close_int(struct efi_file_handle *file); +efi_status_t efi_file_read_int(struct efi_file_handle *this, + efi_uintn_t *buffer_size, void *buffer); +efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos); + +typedef efi_status_t (*efi_console_filter_func)(struct efi_input_key *key); +efi_status_t efi_console_get_u16_string + (struct efi_simple_text_input_protocol *cin, + struct efi_simple_text_output_protocol *cout, + u16 *buf, efi_uintn_t count, efi_console_filter_func filer_func, + int row, int col); + #endif /* _EFI_LOADER_H */ diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index bbb3fac5bd..b7d1fa6f4b 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -20,6 +20,9 @@ static const struct efi_boot_services *bs; static const struct efi_runtime_services *rs;
+static struct efi_simple_text_input_protocol *cin; +static struct efi_simple_text_output_protocol *cout; + /* * bootmgr implements the logic of trying to find a payload to boot * based on the BootOrder + BootXXXX variables, and then loading it. @@ -30,6 +33,9 @@ static const struct efi_runtime_services *rs; */
#define EFI_BOOTMGR_MENU_ENTRY_NUM_MAX 1024 +#define EFI_BOOTMGR_FILE_PATH_MAX 512 +#define EFI_BOOTMGR_BOOT_NAME_MAX 32 +#define EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL 6
@@ -83,12 +89,49 @@ struct efi_bootmgr_boot_selection_data {
static efi_status_t efi_bootmgr_process_boot_selected(void *data, bool *exit); static efi_status_t efi_bootmgr_process_boot_selection(void *data, bool *exit); +static efi_status_t efi_bootmgr_process_maintenance(void *data, bool *exit); +static efi_status_t efi_bootmgr_process_add_boot_option(void *data, bool *exit); +static efi_status_t efi_bootmgr_process_delete_boot_option(void *data, bool *exit); +static efi_status_t efi_bootmgr_process_change_boot_order(void *data, bool *exit);
static struct efi_bootmgr_menu_item bootmgr_menu_items[] = { {u"Boot Manager", efi_bootmgr_process_boot_selection}, + {u"Boot Manager maintenance", efi_bootmgr_process_maintenance}, {u"Quit", NULL}, };
+static struct efi_bootmgr_menu_item maintenance_menu_items[] = { + {u"Add Boot Option", efi_bootmgr_process_add_boot_option}, + {u"Delete Boot Option", efi_bootmgr_process_delete_boot_option}, + {u"Change Boot Order", efi_bootmgr_process_change_boot_order}, + {u"Quit", NULL}, +}; + +struct efi_bootmgr_boot_option { + struct efi_simple_file_system_protocol *current_volume; + struct efi_device_path *dp_volume; + u16 *current_path; + u16 *boot_name; + bool file_selected; +}; + +static const struct efi_device_path END = { + .type = DEVICE_PATH_TYPE_END, + .sub_type = DEVICE_PATH_SUB_TYPE_END, + .length = sizeof(END), +}; + +struct efi_bootmgr_volume_entry_data { + struct efi_bootmgr_boot_option *bo; + struct efi_simple_file_system_protocol *v; + struct efi_device_path *dp; +}; + +struct efi_bootmgr_file_entry_data { + struct efi_bootmgr_boot_option *bo; + struct efi_file_info *f; +}; + static void efi_bootmgr_menu_print_entry(void *data) { struct efi_bootmgr_menu_entry *entry = data; @@ -418,6 +461,646 @@ static efi_status_t efi_bootmgr_process_boot_selection(void *data, bool *exit) return ret; }
+static efi_status_t efi_bootmgr_volume_selected(void *data, bool *exit) +{ + struct efi_bootmgr_volume_entry_data *info = data; + + *exit = true; + + if (info) { + info->bo->current_volume = info->v; + info->bo->dp_volume = info->dp; + } + + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmgr_file_selected(void *data, bool *exit) +{ + struct efi_bootmgr_file_entry_data *info = data; + + *exit = true; + + if (!info) + return EFI_INVALID_PARAMETER; + + if (u16_strncmp(info->f->file_name, u".", 1) == 0 && + u16_strlen(info->f->file_name) == 1) { + /* stay current path */ + } else if (u16_strncmp(info->f->file_name, u"..", 2) == 0 && + u16_strlen(info->f->file_name) == 2) { + u32 i; + int len = u16_strlen(info->bo->current_path); + + for (i = len - 2; i > 0; i--) { + if (info->bo->current_path[i] == u'\') + break; + } + + if (i == 0) + info->bo->current_path[0] = u'\0'; + else + info->bo->current_path[i + 1] = u'\0'; + } else { + size_t new_len; + + new_len = u16_strlen(info->bo->current_path) + + u16_strlen(info->f->file_name) + 1; + if (new_len >= EFI_BOOTMGR_FILE_PATH_MAX) { /* TODO: try with 4K size */ + /* TODO: show error notification to user */ + log_err("file path is too long\n"); + return EFI_INVALID_PARAMETER; + } + u16_strlcat(info->bo->current_path, info->f->file_name, EFI_BOOTMGR_FILE_PATH_MAX); + if (info->f->attribute & EFI_FILE_DIRECTORY) { + if (new_len + 1 >= EFI_BOOTMGR_FILE_PATH_MAX) { + log_err("file path is too long\n"); + return EFI_INVALID_PARAMETER; + } + u16_strlcat(info->bo->current_path, u"\", EFI_BOOTMGR_FILE_PATH_MAX); + } else { + info->bo->file_selected = true; + } + } + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmgr_select_volume(struct efi_bootmgr_boot_option *bo) +{ + u16 *name; + u32 i; + efi_status_t ret; + efi_uintn_t count; + struct efi_handler *handler; + struct efi_device_path *device_path; + efi_handle_t *volume_handles = NULL; + struct efi_simple_file_system_protocol *v; + struct efi_device_path_to_text_protocol *text; + struct efi_bootmgr_menu_item *menu_item, *iter; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_system_partition_guid, + NULL, &count, (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_search_protocol(efi_root, &efi_guid_device_path_to_text_protocol, &handler); + if (ret != EFI_SUCCESS) + goto out1; + + ret = efi_protocol_open(handler, (void **)&text, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + goto out1; + + menu_item = calloc(count + 1, sizeof(struct efi_bootmgr_menu_item)); + if (!menu_item) { + ret = EFI_OUT_OF_RESOURCES; + goto out1; + } + + iter = menu_item; + for (i = 0; i < count; i++) { + struct efi_bootmgr_volume_entry_data *info; + + ret = efi_search_protocol(volume_handles[i], + &efi_simple_file_system_protocol_guid, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&v, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + name = EFI_CALL(text->convert_device_path_to_text(device_path, true, true)); + if (!name) { + ret = EFI_OUT_OF_RESOURCES; + goto out2; + } + + info = calloc(1, sizeof(struct efi_bootmgr_volume_entry_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto out2; + } + + info->v = v; + info->dp = device_path; + info->bo = bo; + iter->title = name; + iter->func = efi_bootmgr_volume_selected; + iter->data = info; + iter++; + } + + iter->title = u"Quit"; + iter->func = NULL; + iter->data = NULL; + count += 1; + + ret = efi_bootmgr_process_common(menu_item, count, -1); + +out2: + iter = menu_item; + for (i = 0; i < count - 1; i++) { + struct efi_bootmgr_volume_entry_data *p; + + p = (struct efi_bootmgr_volume_entry_data *)(iter->data); + efi_free_pool(iter->title); + free(p); + iter++; + } + + free(menu_item); + +out1: + efi_free_pool(volume_handles); + + return ret; +} + +static efi_status_t efi_bootmgr_select_file(struct efi_bootmgr_boot_option *bo, + struct efi_file_handle *root) +{ + char *buf; + u32 i; + char *dir_buf; + efi_uintn_t len; + efi_status_t ret; + efi_uintn_t size; + u32 count = 0; + struct efi_file_handle *f; + struct efi_file_info *ptr; + struct efi_bootmgr_menu_item *menu_item, *iter; + + buf = calloc(1, EFI_BOOTMGR_FILE_PATH_MAX); + if (!buf) + return EFI_OUT_OF_RESOURCES; + + while (!bo->file_selected) { + size = 0; + count = 0; + + ret = efi_file_open_int(root, &f, bo->current_path, EFI_FILE_MODE_READ, 0); + if (ret != EFI_SUCCESS) + return ret; + + /* calculate directory information total size */ + for (;;) { + len = EFI_BOOTMGR_FILE_PATH_MAX; + ret = efi_file_read_int(f, &len, buf); + if (ret != EFI_SUCCESS || len == 0) + break; + + size += len; + count++; + } + + dir_buf = calloc(1, size); + if (!dir_buf) { + efi_file_close_int(f); + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + menu_item = calloc(count + 1, sizeof(struct efi_bootmgr_menu_item)); + if (!menu_item) { + efi_file_close_int(f); + free(dir_buf); + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + /* read directory and construct menu structure */ + efi_file_setpos_int(f, 0); + iter = menu_item; + ptr = (struct efi_file_info *)dir_buf; + for (i = 0; i < count; i++) { + int name_len; + u16 *name; + struct efi_bootmgr_file_entry_data *info; + + len = size; + ret = efi_file_read_int(f, &len, ptr); + if (ret != EFI_SUCCESS || len == 0) + goto err; + + if (ptr->attribute & EFI_FILE_DIRECTORY) { + /* append u'/' at the end of directory name */ + name_len = u16_strsize(ptr->file_name) + sizeof(u16); + name = calloc(1, name_len); + if (!name) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + u16_strcpy(name, ptr->file_name); + name[u16_strlen(ptr->file_name)] = u'/'; + } else { + name_len = u16_strsize(ptr->file_name); + name = calloc(1, name_len); + if (!name) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + u16_strcpy(name, ptr->file_name); + } + + info = calloc(1, sizeof(struct efi_bootmgr_file_entry_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + info->f = ptr; + info->bo = bo; + iter->title = name; + iter->func = efi_bootmgr_file_selected; + iter->data = info; + iter++; + + size -= len; + ptr = (struct efi_file_info *)((char *)ptr + len); + } + + /* add "Quit" entry */ + iter->title = u"Quit"; + iter->func = NULL; + iter->data = NULL; + count += 1; + + ret = efi_bootmgr_process_common(menu_item, count, -1); +err: + efi_file_close_int(f); + iter = menu_item; + for (i = 0; i < count - 1; i++, iter++) { + free(iter->title); + free(iter->data); + } + + free(dir_buf); + free(menu_item); + + if (ret != EFI_SUCCESS) + break; + } + +out: + free(buf); + return ret; +} + +static efi_status_t efi_bootmgr_boot_add_enter_name(struct efi_bootmgr_boot_option *bo) +{ + efi_status_t ret; + + printf(ANSI_CURSOR_POSITION, 2, 1); + puts(" *** U-Boot EFI Boot Manager Menu ***"); + printf(ANSI_CURSOR_POSITION, 4, 1); + puts(" enter name:"); + + printf(ANSI_CURSOR_POSITION, 8, 1); + puts(" ENTER to complete, ESC/CTRL+C to quit"); + + ret = efi_console_get_u16_string(cin, cout, bo->boot_name, + EFI_BOOTMGR_BOOT_NAME_MAX, NULL, 4, 15); + + return ret; +} + +static efi_status_t allow_decimal(struct efi_input_key *key) +{ + if (u'0' <= key->unicode_char && key->unicode_char <= u'9') + return EFI_SUCCESS; + + return EFI_INVALID_PARAMETER; +} + +static efi_status_t efi_bootmgr_change_boot_order(int selected, int max, int *new) +{ + efi_status_t ret; + u16 new_order[EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL] = {0}; + + printf(ANSI_CURSOR_POSITION, 2, 1); + puts(" *** U-Boot EFI Boot Manager Menu ***"); + printf(ANSI_CURSOR_POSITION, 4, 1); + printf(" current boot order : %d", selected); + + printf(ANSI_CURSOR_POSITION, 6, 1); + printf(" new boot order(0 - %4d): ", max); + + printf(ANSI_CURSOR_POSITION, 8, 1); + puts(" ENTER to complete, ESC/CTRL+C to quit"); + + printf(ANSI_CURSOR_POSITION, 6, 29); + puts(ANSI_CURSOR_SHOW); + + for (;;) { + memset(new_order, 0, sizeof(new_order)); + ret = efi_console_get_u16_string(cin, cout, new_order, 6, allow_decimal, 6, 29); + if (ret == EFI_SUCCESS) { + int i; + int val = 0; + + for (i = 0; + i < u16_strnlen(new_order, EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL - 1); + i++) + val = (val * 10) + (new_order[i] - u'0'); + + if (val > max) + continue; + + *new = val; + return EFI_SUCCESS; + } else { + return ret; + } + } +} + +static efi_status_t efi_bootmgr_select_file_handler(struct efi_bootmgr_boot_option *bo) +{ + efi_status_t ret; + struct efi_file_handle *root; + + bo->file_selected = false; + + while (!bo->file_selected) { + bo->current_volume = NULL; + memset(bo->current_path, 0, sizeof(bo->current_path)); + + ret = efi_bootmgr_select_volume(bo); + if (ret != EFI_SUCCESS) + goto out; + + if (!bo->current_volume) + return EFI_INVALID_PARAMETER; + + ret = efi_open_volume_int(bo->current_volume, &root); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_bootmgr_select_file(bo, root); + + if (ret != EFI_SUCCESS) + goto out; + } + + ret = efi_bootmgr_boot_add_enter_name(bo); + +out: + return ret; +} + +static efi_status_t efi_bootmgr_process_maintenance(void *data, bool *exit) +{ + return efi_bootmgr_process_common(maintenance_menu_items, + ARRAY_SIZE(maintenance_menu_items), + -1); +} + +static efi_status_t efi_bootmgr_process_add_boot_option(void *data, bool *exit) +{ + u32 index; + void *p = NULL; + u16 var_name[9]; + char *buf = NULL; + efi_status_t ret; + char *iter = NULL; + u16 *bootorder = NULL; + u16 *new_bootorder = NULL; + struct efi_load_option lo; + efi_uintn_t dp_size, fp_size; + efi_uintn_t last, size, new_size; + struct efi_bootmgr_boot_option bo; + struct efi_device_path_file_path *fp; + + /* get unused Boot#### */ + for (index = 0; index <= 0xFFFF; index++) { + size = 0; + efi_create_indexed_name(var_name, sizeof(var_name), "Boot", index); + ret = efi_get_variable_int(var_name, &efi_global_variable_guid, + NULL, &size, NULL, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) + continue; + else + break; + } + + if (index >= 0xFFFF) + return EFI_OUT_OF_RESOURCES; + + efi_create_indexed_name(var_name, sizeof(var_name), "Boot", index); + + bo.current_path = calloc(1, EFI_BOOTMGR_FILE_PATH_MAX); + if (!bo.current_path) + goto out; + + bo.boot_name = calloc(1, EFI_BOOTMGR_BOOT_NAME_MAX * sizeof(u16)); + if (!bo.boot_name) + goto out; + + ret = efi_bootmgr_select_file_handler(&bo); + if (ret == EFI_ABORTED) + goto out; + + dp_size = efi_dp_size(bo.dp_volume); + fp_size = sizeof(struct efi_device_path) + + ((u16_strlen(bo.current_path) + 1) * sizeof(u16)); + buf = calloc(1, dp_size + fp_size + sizeof(END)); + if (!buf) + goto out; + + iter = buf; + memcpy(iter, bo.dp_volume, dp_size); + iter += dp_size; + + fp = (struct efi_device_path_file_path *)iter; + fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; + fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; + fp->dp.length = (u16)fp_size; + u16_strcpy(fp->str, bo.current_path); + iter += fp_size; + *((struct efi_device_path *)iter) = END; + + lo.file_path = (struct efi_device_path *)buf; + lo.file_path_length = efi_dp_size((struct efi_device_path *)buf) + sizeof(END); + lo.attributes = LOAD_OPTION_ACTIVE; + lo.optional_data = NULL; + lo.label = bo.boot_name; + + size = efi_serialize_load_option(&lo, (u8 **)&p); + if (!size) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, p, false); + if (ret != EFI_SUCCESS) + goto out; + + /* append new boot option */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + last = size / sizeof(u16); + new_size = size + sizeof(u16); + new_bootorder = calloc(1, new_size); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + memcpy(new_bootorder, bootorder, size); + new_bootorder[last] = (u16)index; + + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + new_size, new_bootorder, false); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(p); + free(buf); + free(bootorder); + free(new_bootorder); + free(bo.boot_name); + free(bo.current_path); + + return ret; +} + +static efi_status_t efi_bootmgr_process_delete_boot_option(void *data, bool *exit) +{ + int selected; + u16 *bootorder; + u16 var_name[9]; + efi_status_t ret; + efi_uintn_t num, size; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) { + ret = EFI_NOT_FOUND; + return ret; + } + + num = size / sizeof(u16); + ret = efi_bootmgr_show_boot_selection(bootorder, num, &selected); + if (ret == EFI_SUCCESS) { + /* delete selected boot option */ + efi_create_indexed_name(var_name, sizeof(var_name), + "Boot", bootorder[selected]); + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + 0, 0, NULL, false); + if (ret != EFI_SUCCESS) { + log_err("delete boot option(%ls) failed\n", var_name); + goto out; + } + + /* update BootOrder */ + memmove(&bootorder[selected], &bootorder[selected + 1], + (num - selected - 1) * sizeof(u16)); + size -= sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, bootorder, false); + if (ret != EFI_SUCCESS) + goto out; + } + +out: + free(bootorder); + + return ret; +} + +static efi_status_t efi_bootmgr_process_change_boot_order(void *data, bool *exit) +{ + int selected; + int new_order; + efi_status_t ret; + efi_uintn_t num, size; + u16 *bootorder = NULL; + u16 *new_bootorder = NULL; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) + return EFI_NOT_FOUND; + + num = size / sizeof(u16); + ret = efi_bootmgr_show_boot_selection(bootorder, num, &selected); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_bootmgr_change_boot_order(selected, num - 1, &new_order); + if (ret != EFI_SUCCESS) + goto out; + + new_bootorder = calloc(1, size); + if (!new_bootorder) + goto out; + + memcpy(new_bootorder, bootorder, size); + if (selected > new_order) { + new_bootorder[new_order] = bootorder[selected]; + memcpy(&new_bootorder[new_order + 1], &bootorder[new_order], + (selected - new_order) * sizeof(u16)); + } else if (selected < new_order) { + new_bootorder[new_order] = bootorder[selected]; + memcpy(&new_bootorder[selected], &bootorder[selected + 1], + (new_order - selected) * sizeof(u16)); + } else { + /* nothing to change */ + goto out; + } + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, new_bootorder, false); +out: + free(new_bootorder); + free(bootorder); + + return ret; +} + +efi_status_t efi_bootmgr_menu_init(void) +{ + efi_status_t ret; + struct efi_handler *handler; + + ret = efi_search_protocol(efi_root, &efi_guid_text_input_protocol, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_protocol_open(handler, (void **)&cin, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_search_protocol(efi_root, &efi_guid_text_output_protocol, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_protocol_open(handler, (void **)&cout, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + return ret; + + return ret; +} + /** * try_load_entry() - try to load image for boot option * @@ -568,6 +1251,10 @@ efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options) if (IS_ENABLED(CONFIG_EFI_BOOT_MENU)) { int selected;
+ ret = efi_bootmgr_menu_init(); + if (ret != EFI_SUCCESS) + goto error; + bootmgr_menu_items[0].data = &selected; ret = efi_bootmgr_process_common(bootmgr_menu_items, ARRAY_SIZE(bootmgr_menu_items), diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 82128ac1d5..c3c5f299ee 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2454,32 +2454,13 @@ static efi_status_t EFIAPI efi_protocols_per_handle( return EFI_EXIT(EFI_SUCCESS); }
-/** - * efi_locate_handle_buffer() - locate handles implementing a protocol - * @search_type: selection criterion - * @protocol: GUID of the protocol - * @search_key: registration key - * @no_handles: number of returned handles - * @buffer: buffer with the returned handles - * - * This function implements the LocateHandleBuffer service. - * - * See the Unified Extensible Firmware Interface (UEFI) specification for - * details. - * - * Return: status code - */ -efi_status_t EFIAPI efi_locate_handle_buffer( - enum efi_locate_search_type search_type, - const efi_guid_t *protocol, void *search_key, - efi_uintn_t *no_handles, efi_handle_t **buffer) +efi_status_t efi_locate_handle_buffer_int(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer) { efi_status_t r; efi_uintn_t buffer_size = 0;
- EFI_ENTRY("%d, %pUs, %p, %p, %p", search_type, protocol, search_key, - no_handles, buffer); - if (!no_handles || !buffer) { r = EFI_INVALID_PARAMETER; goto out; @@ -2499,6 +2480,36 @@ efi_status_t EFIAPI efi_locate_handle_buffer( if (r == EFI_SUCCESS) *no_handles = buffer_size / sizeof(efi_handle_t); out: + return r; +} + +/** + * efi_locate_handle_buffer() - locate handles implementing a protocol + * @search_type: selection criterion + * @protocol: GUID of the protocol + * @search_key: registration key + * @no_handles: number of returned handles + * @buffer: buffer with the returned handles + * + * This function implements the LocateHandleBuffer service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * Return: status code + */ +efi_status_t EFIAPI efi_locate_handle_buffer(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer) +{ + efi_status_t r; + + EFI_ENTRY("%d, %pUs, %p, %p, %p", search_type, protocol, search_key, + no_handles, buffer); + + r = efi_locate_handle_buffer_int(search_type, protocol, search_key, + no_handles, buffer); + return EFI_EXIT(r); }
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index ba68a15017..f5002e1c99 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -5,6 +5,7 @@ * Copyright (c) 2016 Alexander Graf */
+#include <ansi.h> #include <common.h> #include <charset.h> #include <malloc.h> @@ -1312,3 +1313,83 @@ out_of_memory: printf("ERROR: Out of memory\n"); return r; } + +/** + * efi_console_get_u16_string() - get user input string + * + * @cin: protocol interface to EFI_SIMPLE_TEXT_INPUT_PROTOCOL + * @cout: protocol interface to EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL + * @buf: buffer to store user input string in UTF16 + * @size: buffer size including NULL terminator + * @filter_func: callback to filter user input + * @row: row number to locate user input form + * @col: column number to locate user input form + * Return: status code + */ +efi_status_t efi_console_get_u16_string(struct efi_simple_text_input_protocol *cin, + struct efi_simple_text_output_protocol *cout, + u16 *buf, efi_uintn_t size, + efi_console_filter_func filter_func, + int row, int col) +{ + efi_status_t ret; + efi_uintn_t len = 0; + struct efi_input_key key; + + printf(ANSI_CURSOR_POSITION, row, col); + puts(ANSI_CLEAR_LINE_TO_END); + puts(ANSI_CURSOR_SHOW); + + ret = EFI_CALL(cin->reset(cin, false)); + if (ret != EFI_SUCCESS) + return ret; + + for (;;) { + do { + ret = EFI_CALL(cin->read_key_stroke(cin, &key)); + mdelay(10); + } while (ret == EFI_NOT_READY); + + if (key.unicode_char == u'\b') { + if (len > 0) + buf[--len] = u'\0'; + + printf(ANSI_CURSOR_POSITION, row, col); + ret = EFI_CALL(cout->output_string(cout, buf)); + if (ret != EFI_SUCCESS) + return ret; + + puts(ANSI_CLEAR_LINE_TO_END); + continue; + } else if (key.unicode_char == u'\r') { + if (len == 0) /* no user input */ + continue; + + buf[len] = u'\0'; + return EFI_SUCCESS; + } else if (key.unicode_char == 0x3 || key.scan_code == 23) { + return EFI_ABORTED; + } else if (key.unicode_char < 0x20) { + /* ignore control codes other than Ctrl+C, '\r' and '\b' */ + continue; + } else if (key.scan_code != 0) { + /* only accept single ESC press for cancel */ + continue; + } + + if (filter_func) { + if (filter_func(&key) != EFI_SUCCESS) + continue; + } + + if (len >= (size - 1)) + continue; + + buf[len] = key.unicode_char; + len++; + printf(ANSI_CURSOR_POSITION, row, col); + ret = EFI_CALL(cout->output_string(cout, buf)); + if (ret != EFI_SUCCESS) + return ret; + } +} diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 7a7077e6d0..d2d7e8495d 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -246,10 +246,10 @@ error: return NULL; }
-static efi_status_t efi_file_open_int(struct efi_file_handle *this, - struct efi_file_handle **new_handle, - u16 *file_name, u64 open_mode, - u64 attributes) +efi_status_t efi_file_open_int(struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, + u64 attributes) { struct file_handle *fh = to_fh(this); efi_status_t ret; @@ -369,11 +369,17 @@ static efi_status_t file_close(struct file_handle *fh) return EFI_SUCCESS; }
-static efi_status_t EFIAPI efi_file_close(struct efi_file_handle *file) +efi_status_t efi_file_close_int(struct efi_file_handle *file) { struct file_handle *fh = to_fh(file); + + return file_close(fh); +} + +static efi_status_t EFIAPI efi_file_close(struct efi_file_handle *file) +{ EFI_ENTRY("%p", file); - return EFI_EXIT(file_close(fh)); + return EFI_EXIT(efi_file_close_int(file)); }
static efi_status_t EFIAPI efi_file_delete(struct efi_file_handle *file) @@ -562,8 +568,8 @@ static efi_status_t dir_read(struct file_handle *fh, u64 *buffer_size, return EFI_SUCCESS; }
-static efi_status_t efi_file_read_int(struct efi_file_handle *this, - efi_uintn_t *buffer_size, void *buffer) +efi_status_t efi_file_read_int(struct efi_file_handle *this, + efi_uintn_t *buffer_size, void *buffer) { struct file_handle *fh = to_fh(this); efi_status_t ret = EFI_SUCCESS; @@ -773,24 +779,11 @@ out: return EFI_EXIT(ret); }
-/** - * efi_file_setpos() - set current position in file - * - * This function implements the SetPosition service of the EFI file protocol. - * See the UEFI spec for details. - * - * @file: file handle - * @pos: new file position - * Return: status code - */ -static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, - u64 pos) +efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos) { struct file_handle *fh = to_fh(file); efi_status_t ret = EFI_SUCCESS;
- EFI_ENTRY("%p, %llu", file, pos); - if (fh->isdir) { if (pos != 0) { ret = EFI_UNSUPPORTED; @@ -812,6 +805,28 @@ static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, fh->offset = pos;
error: + return ret; +} + +/** + * efi_file_setpos() - set current position in file + * + * This function implements the SetPosition service of the EFI file protocol. + * See the UEFI spec for details. + * + * @file: file handle + * @pos: new file position + * Return: status code + */ +static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, + u64 pos) +{ + efi_status_t ret = EFI_SUCCESS; + + EFI_ENTRY("%p, %llu", file, pos); + + ret = efi_file_setpos_int(file, pos); + return EFI_EXIT(ret); }
@@ -1138,17 +1153,24 @@ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp) return f; }
+efi_status_t efi_open_volume_int(struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root) +{ + struct file_system *fs = to_fs(this); + + *root = file_open(fs, NULL, NULL, 0, 0); + + return EFI_SUCCESS; +} + static efi_status_t EFIAPI efi_open_volume(struct efi_simple_file_system_protocol *this, struct efi_file_handle **root) { - struct file_system *fs = to_fs(this);
EFI_ENTRY("%p, %p", this, root);
- *root = file_open(fs, NULL, NULL, 0, 0); - - return EFI_EXIT(EFI_SUCCESS); + return EFI_EXIT(efi_open_volume_int(this, root)); }
Masahisa Kojima
