[U-Boot] [PATCH v2 0/4] armv8/fsl-layerscape: add dwc3 gadget driver support
Adds support for dwc3 gadget driver for ARM v8 platform of layerscape series. Currently this patch has been tested for LS1043A
Rajat Srivastava (3): usb: dwc3: Add helper functions to enable snooping and burst settings armv8/fsl-layerscape: add dwc3 gadget driver support armv8/fsl-layerscape: enable dwc3 gadget driver support
Rajesh Bhagat (1): usb: ums: support multiple controllers using controller_index
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 93 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 6 ++ cmd/usb_mass_storage.c | 2 +- drivers/usb/dwc3/core.c | 45 +++++++++++ drivers/usb/dwc3/core.h | 7 ++ drivers/usb/gadget/f_mass_storage.c | 11 ++- include/configs/ls1043aqds.h | 15 ++++ include/usb_mass_storage.h | 2 +- 8 files changed, 177 insertions(+), 4 deletions(-)
Adds a new field in fsg_common namely controller_index to support multiple controllers usb gadget support.
Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- Changes for v2: - Changes type of fsg_main_thread argument to unsigned int
cmd/usb_mass_storage.c | 2 +- drivers/usb/gadget/f_mass_storage.c | 11 +++++++++-- include/usb_mass_storage.h | 2 +- 3 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index b05913a..bf80d37 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -214,7 +214,7 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, while (1) { usb_gadget_handle_interrupts(controller_index);
- rc = fsg_main_thread(NULL); + rc = fsg_main_thread(controller_index); if (rc) { /* Check I/O error */ if (rc == -EIO) diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index 1ecb92a..27ca5fe 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -362,6 +362,7 @@ struct fsg_common { char inquiry_string[8 + 16 + 4 + 1];
struct kref ref; + unsigned int controller_index; };
struct fsg_config { @@ -691,7 +692,7 @@ static int sleep_thread(struct fsg_common *common) k = 0; }
- usb_gadget_handle_interrupts(0); + usb_gadget_handle_interrupts(common->controller_index); } common->thread_wakeup_needed = 0; return rc; @@ -2402,10 +2403,14 @@ static void handle_exception(struct fsg_common *common)
-int fsg_main_thread(void *common_) +int fsg_main_thread(unsigned int controller_index) { int ret; struct fsg_common *common = the_fsg_common; + + /* update the controller_index */ + common->controller_index = controller_index; + /* The main loop */ do { if (exception_in_progress(common)) { @@ -2476,6 +2481,7 @@ static struct fsg_common *fsg_common_init(struct fsg_common *common,
common->ops = NULL; common->private_data = NULL; + common->controller_index = 0;
common->gadget = gadget; common->ep0 = gadget->ep0; @@ -2770,6 +2776,7 @@ int fsg_add(struct usb_configuration *c)
fsg_common->ops = NULL; fsg_common->private_data = NULL; + fsg_common->controller_index = 0;
the_fsg_common = fsg_common;
diff --git a/include/usb_mass_storage.h b/include/usb_mass_storage.h index 8229f62..f21cc7a 100644 --- a/include/usb_mass_storage.h +++ b/include/usb_mass_storage.h @@ -28,6 +28,6 @@ struct ums {
int fsg_init(struct ums *ums_devs, int count); void fsg_cleanup(void); -int fsg_main_thread(void *); +int fsg_main_thread(unsigned int); int fsg_add(struct usb_configuration *c); #endif /* __USB_MASS_STORAGE_H__ */
Hi Rajat,
First of all, sorry for late reply. I was not in the office.
Changes for v2:
if (rc) { /* Check I/O error */ if (rc == -EIO)rc = fsg_main_thread(controller_index);
struct kref ref;
- unsigned int controller_index;
usb_gadget_handle_interrupts(common->controller_index); } common->thread_wakeup_needed = 0; return rc; @@ -2402,10 +2403,14 @@ static void handle_exception(struct fsg_common *common) /*-------------------------------------------------------------------------*/
- /* update the controller_index */
- common->controller_index = controller_index;
- /* The main loop */ do { if (exception_in_progress(common)) {
@@ -2476,6 +2481,7 @@ static struct fsg_common *fsg_common_init(struct fsg_common *common, common->ops = NULL; common->private_data = NULL;
Acked-by: Lukasz Majewski l.majewski@samsung.com
Adds helper functions to enable snooping and outstanding burst beat settings.
Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- Changes in v2: - Removes SoC specific flags and added helper functions
drivers/usb/dwc3/core.c | 45 +++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/dwc3/core.h | 7 +++++++ 2 files changed, 52 insertions(+)
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index 85cc96a..0b3c596 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -599,6 +599,51 @@ static void dwc3_core_exit_mode(struct dwc3 *dwc)
#define DWC3_ALIGN_MASK (16 - 1)
+void dwc3_core_incr_burst_enable(int index, int btype_incr_val, + int breq_limit) +{ + struct dwc3 *dwc; + u32 reg; + + list_for_each_entry(dwc, &dwc3_list, list) { + if (dwc->index != index) + continue; + + /* + * Change burst beat and outstanding pipelined + * transfers requests + */ + reg = dwc3_readl(dwc->regs, DWC3_GSBUSCFG0); + reg = (reg & ~DWC3_INCR_BTYPE_MASK) | btype_incr_val; + dwc3_writel(dwc->regs, DWC3_GSBUSCFG0, reg); + + reg = dwc3_readl(dwc->regs, DWC3_GSBUSCFG1); + reg = (reg & ~DWC3_BREQ_LIMIT_MASK) | (breq_limit << 8); + dwc3_writel(dwc->regs, DWC3_GSBUSCFG1, reg); + break; + } +} + +void dwc3_core_set_snooping(int index, bool snoop) +{ + struct dwc3 *dwc; + u32 reg; + + list_for_each_entry(dwc, &dwc3_list, list) { + if (dwc->index != index) + continue; + + /* Enable/Disable snooping */ + reg = dwc3_readl(dwc->regs, DWC3_GSBUSCFG0); + if (snoop) + reg = reg | DWC3_SNOOP_ENABLE; + else + reg = reg & ~DWC3_SNOOP_ENABLE; + dwc3_writel(dwc->regs, DWC3_GSBUSCFG0, reg); + break; + } +} + /** * dwc3_uboot_init - dwc3 core uboot initialization code * @dwc3_dev: struct dwc3_device containing initialization data diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index 72d2fcd..455e7fa 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -593,6 +593,13 @@ struct dwc3_hwparams { /* HWPARAMS7 */ #define DWC3_RAM1_DEPTH(n) ((n) & 0xffff)
+/* GSBUSCFG0 */ +#define DWC3_SNOOP_ENABLE (0x22220000) +#define DWC3_INCR_BTYPE_MASK (0xff) + +/* GSBUSCFG1 */ +#define DWC3_BREQ_LIMIT_MASK (0xf00) + struct dwc3_request { struct usb_request request; struct list_head list;
Changes in v2:
int breq_limit)
- struct dwc3 *dwc;
- u32 reg;
- list_for_each_entry(dwc, &dwc3_list, list) {
Why is this iterating over a list of all controllers ? Should this be enabled on per-controller basis by some DT prop ?
continue;
break;
- struct dwc3 *dwc;
- u32 reg;
continue;
if (snoop)
else
break;
- dwc3_uboot_init - dwc3 core uboot initialization code
- @dwc3_dev: struct dwc3_device containing initialization data
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Monday, June 06, 2016 6:24 PM To: Rajat Srivastava rajat.srivastava@nxp.com; u-boot@lists.denx.de Cc: l.majewski@samsung.com; sjg@chromium.org; albert.u.boot@aribaud.net; prabhakar@freescale.com; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; michal.simek@xilinx.com; felipe.balbi@linux.intel.com Subject: Re: [PATCH v2 2/4] usb: dwc3: Add helper functions to enable snooping and burst settings
Changes in v2:
int breq_limit)
- struct dwc3 *dwc;
- u32 reg;
Hello Marek,
This function has to be called from Soc specific code to pass some register settings. And dwc pointer would not be available there. Hence, index is passed to determine dwc pointer.
We are using dwc3 driver with non DT support.
Best Regards, Rajesh Bhagat
continue;
break;
+void dwc3_core_set_snooping(int index, bool snoop) {
- struct dwc3 *dwc;
- u32 reg;
continue;
if (snoop)
else
break;
- @dwc3_dev: struct dwc3_device containing initialization data diff
-- Best regards, Marek Vasut
Changes in v2:
int breq_limit)
- struct dwc3 *dwc;
- u32 reg;
Hello Marek,
That's real unfortunate.
continue;
break;
- struct dwc3 *dwc;
- u32 reg;
continue;
if (snoop)
else
break;
Changes in v2:
int breq_limit)
struct dwc3 *dwc;
u32 reg;
Ick - can this be converted to use driver model?
continue;
break;
struct dwc3 *dwc;
u32 reg;
continue;
if (snoop)
else
break;
struct dwc3_request { struct usb_request request; struct list_head list; -- 2.6.2.198.g614a2ac
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Friday, June 10, 2016 6:05 AM To: Rajat Srivastava rajat.srivastava@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Lukasz Majewski l.majewski@samsung.com; Marek VaĊĦut marex@denx.de; Albert ARIBAUD albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar@freescale.com; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Michal Simek michal.simek@xilinx.com; felipe.balbi@linux.intel.com Subject: Re: [PATCH v2 2/4] usb: dwc3: Add helper functions to enable snooping and burst settings
Changes in v2:
int breq_limit) {
struct dwc3 *dwc;
u32 reg;
Hello Simon,
We have not moved to use driver model yet :( . Is it possible to pass these register settings by some other mechanism ?
continue;
break;
struct dwc3 *dwc;
u32 reg;
continue;
if (snoop)
else
break;
Hi Rajesh,
Changes in v2:
int breq_limit) {
struct dwc3 *dwc;
u32 reg;
Hello Simon,
Not that I know of - is there any reason not to convert to driver model now?
continue;
break;
struct dwc3 *dwc;
u32 reg;
continue;
if (snoop)
else
break;
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Friday, June 17, 2016 9:22 AM To: Rajesh Bhagat rajesh.bhagat@nxp.com Cc: Rajat Srivastava rajat.srivastava@nxp.com; U-Boot Mailing List <u- boot@lists.denx.de>; Lukasz Majewski l.majewski@samsung.com; Marek VaĊĦut marex@denx.de; Albert ARIBAUD albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar@freescale.com; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Michal Simek michal.simek@xilinx.com; felipe.balbi@linux.intel.com Subject: Re: [PATCH v2 2/4] usb: dwc3: Add helper functions to enable snooping and burst settings
Hi Rajesh,
Changes in v2:
int breq_limit) {
struct dwc3 *dwc;
u32 reg;
Hello Simon,
Hello Simon,
Reason is, the dwc3 driver itself as not moved to CONFIG_DM_USB, and seems to be in progress by patch "driver model bring-up of dwc3 usb peripheral" (sent by Mugunthan V N).
continue;
break;
struct dwc3 *dwc;
u32 reg;
continue;
if (snoop)
else
break;
Hi Rajat,
Changes in v2:
int breq_limit)
- struct dwc3 *dwc;
- u32 reg;
continue;
8);
break;
- struct dwc3 *dwc;
- u32 reg;
continue;
if (snoop)
You can replace the above line with reg |= DWC3_SNOOP_ENABLE
else
The same here - req &= ~DWC3_SNOOP_ENABLE
break;
-----Original Message----- From: Lukasz Majewski [mailto:l.majewski@samsung.com] Sent: Thursday, June 23, 2016 8:23 PM To: Rajat Srivastava rajat.srivastava@nxp.com Cc: u-boot@lists.denx.de; sjg@chromium.org; marex@denx.de; albert.u.boot@aribaud.net; prabhakar@freescale.com; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; michal.simek@xilinx.com; felipe.balbi@linux.intel.com Subject: Re: [PATCH v2 2/4] usb: dwc3: Add helper functions to enable snooping and burst settings
Hi Rajat,
Changes in v2:
int breq_limit)
- struct dwc3 *dwc;
- u32 reg;
continue;
8);
break;
- struct dwc3 *dwc;
- u32 reg;
continue;
if (snoop)
Hello Lukasz,
Will take care in v3.
else
break;
-- Best regards,
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
Implements the dwc3 gadget driver support for LS1043 platform, and performs below operations: 1. Enables snooping support for DWC3 controller. 2. Enables cache coherency in LS1043 platform.
Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Reviewed-by: Lukasz Majewski l.majewski@samsung.com --- Changes in v2: - Moves DWC3 driver specific code to helper functions - Calls helper functions in SoC specific implementation
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 93 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 6 ++ 2 files changed, 99 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 0fb5c7f..cc07524 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -17,6 +17,10 @@ #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif +#include <usb.h> +#include <dwc3-uboot.h> +#include <linux/usb/xhci-fsl.h> +
DECLARE_GLOBAL_DATA_PTR;
@@ -318,9 +322,18 @@ void fsl_lsch2_early_init_f(void) #if defined(CONFIG_FSL_QSPI) && !defined(CONFIG_QSPI_BOOT) out_be32(&scfg->qspi_cfg, SCFG_QSPI_CLKSEL); #endif + /* Make SEC and USB reads and writes snoopable */ +#if defined(CONFIG_LS1043A) + setbits_be32(&scfg->snpcnfgcr, SCFG_SNPCNFGCR_SECRDSNP | + SCFG_SNPCNFGCR_SECWRSNP | SCFG_SNPCNFGCR_USB1RDSNP | + SCFG_SNPCNFGCR_USB1WRSNP | SCFG_SNPCNFGCR_USB2RDSNP | + SCFG_SNPCNFGCR_USB2WRSNP | SCFG_SNPCNFGCR_USB3RDSNP | + SCFG_SNPCNFGCR_USB3WRSNP); +#else /* Make SEC reads and writes snoopable */ setbits_be32(&scfg->snpcnfgcr, SCFG_SNPCNFGCR_SECRDSNP | SCFG_SNPCNFGCR_SECWRSNP); +#endif
/* * Enable snoop requests and DVM message requests for @@ -336,6 +349,86 @@ void fsl_lsch2_early_init_f(void) } #endif
+#ifdef CONFIG_USB_DWC3 + +#if defined(CONFIG_LS1043A) +static struct dwc3_device dwc3_device_data0 = { + .maximum_speed = USB_SPEED_HIGH, + .base = CONFIG_SYS_FSL_XHCI_USB1_ADDR, + .dr_mode = USB_DR_MODE_PERIPHERAL, + .index = 0, +}; + +static struct dwc3_device dwc3_device_data1 = { + .maximum_speed = USB_SPEED_HIGH, + .base = CONFIG_SYS_FSL_XHCI_USB2_ADDR, + .dr_mode = USB_DR_MODE_PERIPHERAL, + .index = 1, +}; + +static struct dwc3_device dwc3_device_data2 = { + .maximum_speed = USB_SPEED_HIGH, + .base = CONFIG_SYS_FSL_XHCI_USB3_ADDR, + .dr_mode = USB_DR_MODE_PERIPHERAL, + .index = 2, +}; + +int usb_gadget_handle_interrupts(int index) +{ + dwc3_uboot_handle_interrupt(index); + return 0; +} +#endif + +int board_usb_init(int index, enum usb_init_type init) +{ + switch (init) { + case USB_INIT_DEVICE: + switch (index) { +#if defined(CONFIG_LS1043A) + case 0: + dwc3_uboot_init(&dwc3_device_data0); + break; + case 1: + dwc3_uboot_init(&dwc3_device_data1); + break; + case 2: + dwc3_uboot_init(&dwc3_device_data2); + break; +#endif + default: + printf("Invalid Controller Index\n"); + return -1; + } +#if defined(CONFIG_LS1043A) + dwc3_core_incr_burst_enable(index, 0xf, 0xf); + dwc3_core_set_snooping(index, true); +#endif + break; + default: + break; + } + + return 0; +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + switch (init) { + case USB_INIT_DEVICE: +#if defined(CONFIG_LS1043A) + dwc3_uboot_exit(index); +#endif + break; + default: + break; + } + return 0; +} +#endif + + + #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 57b99d4..13ba1a6 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -328,6 +328,12 @@ struct ccsr_gur {
#define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 #define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 +#define SCFG_SNPCNFGCR_USB1RDSNP 0x00200000 +#define SCFG_SNPCNFGCR_USB1WRSNP 0x00100000 +#define SCFG_SNPCNFGCR_USB2RDSNP 0x00008000 +#define SCFG_SNPCNFGCR_USB2WRSNP 0x00010000 +#define SCFG_SNPCNFGCR_USB3RDSNP 0x00002000 +#define SCFG_SNPCNFGCR_USB3WRSNP 0x00004000
/* Supplemental Configuration Unit */ struct ccsr_scfg {
- Enables snooping support for DWC3 controller.
- Enables cache coherency in LS1043 platform.
Changes in v2:
.index = 0,
.index = 1,
.index = 2,
+} +#endif
switch (init) {
switch (index) {
case 0:
break;
case 1:
break;
case 2:
break;
Can this use driver model? It seems odd to be adding new code like this.
default:
return -1;
break;
default:
break;
switch (init) {
break;
default:
break;
+} +#endif
/* Supplemental Configuration Unit */ struct ccsr_scfg { -- 2.6.2.198.g614a2ac
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Friday, June 10, 2016 6:05 AM To: Rajat Srivastava rajat.srivastava@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Lukasz Majewski l.majewski@samsung.com; Marek VaĊĦut marex@denx.de; Albert ARIBAUD albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar@freescale.com; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Michal Simek michal.simek@xilinx.com; felipe.balbi@linux.intel.com Subject: Re: [PATCH v2 3/4] armv8/fsl-layerscape: add dwc3 gadget driver support
Changes in v2:
/* Make SEC and USB reads and writes snoopable */ #if
+defined(CONFIG_LS1043A)
SCFG_SNPCNFGCR_USB3WRSNP); #else /* Make SEC reads and writes snoopable */ setbits_be32(&scfg->snpcnfgcr, SCFG_SNPCNFGCR_SECRDSNP | SCFG_SNPCNFGCR_SECWRSNP);
.index = 0,
.index = 1,
.index = 2,
+int usb_gadget_handle_interrupts(int index) {
+} +#endif
+int board_usb_init(int index, enum usb_init_type init) {
switch (init) {
switch (index) {
case 0:
break;
case 1:
break;
case 2:
break;
Hello Simon,
Will it be OK to pass below values in dwc3_uboot_init function instead, if DM is not used?
default:
return -1;
dwc3_core_set_snooping(index, true); #endif
break;
default:
break;
+int board_usb_cleanup(int index, enum usb_init_type init) {
switch (init) {
dwc3_uboot_exit(index); #endif
break;
default:
break;
+} +#endif
2.6.2.198.g614a2ac
Hi Rajat,
Changes in v2:
- /* Make SEC and USB reads and writes snoopable */
- setbits_be32(&scfg->snpcnfgcr, SCFG_SNPCNFGCR_SECRDSNP |
- .maximum_speed = USB_SPEED_HIGH,
- .base = CONFIG_SYS_FSL_XHCI_USB1_ADDR,
- .dr_mode = USB_DR_MODE_PERIPHERAL,
- .index = 0,
- .base = CONFIG_SYS_FSL_XHCI_USB2_ADDR,
- .index = 1,
- .base = CONFIG_SYS_FSL_XHCI_USB3_ADDR,
- .index = 2,
- dwc3_uboot_handle_interrupt(index);
+} +#endif
Are those usb related functions generic? To ask in another way, would it be possible to reuse those functions for other armv8 boards?
Please correct me if I'm wrong, but it seems that LS1043 is a single board. Maybe it would be better to place this code in a separate ./board/nxp/ls1043 directory?
- switch (init) {
- case USB_INIT_DEVICE:
switch (index) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
return -1;
break;
- default:
break;
- switch (init) {
break;
- default:
break;
+} +#endif
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 57b99d4..13ba1a6 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -328,6 +328,12 @@ struct ccsr_gur { #define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 #define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 +#define SCFG_SNPCNFGCR_USB1RDSNP 0x00200000 +#define SCFG_SNPCNFGCR_USB1WRSNP 0x00100000 +#define SCFG_SNPCNFGCR_USB2RDSNP 0x00008000 +#define SCFG_SNPCNFGCR_USB2WRSNP 0x00010000 +#define SCFG_SNPCNFGCR_USB3RDSNP 0x00002000 +#define SCFG_SNPCNFGCR_USB3WRSNP 0x00004000
-----Original Message----- From: Lukasz Majewski [mailto:l.majewski@samsung.com] Sent: Thursday, June 23, 2016 8:27 PM To: Rajat Srivastava rajat.srivastava@nxp.com Cc: u-boot@lists.denx.de; sjg@chromium.org; marex@denx.de; albert.u.boot@aribaud.net; prabhakar@freescale.com; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; michal.simek@xilinx.com; felipe.balbi@linux.intel.com Subject: Re: [PATCH v2 3/4] armv8/fsl-layerscape: add dwc3 gadget driver support
Hi Rajat,
Changes in v2:
++++++++++++++++++++++ .h | 6 ++ 2 files changed, 99 insertions(+)
- /* Make SEC and USB reads and writes snoopable */ #if
- .index = 0,
- .index = 1,
- .index = 2,
+} +#endif
Hello Lukasz,
We are planning to use the above code for all the armv8 boards, e.g. LS1043A and LS1012A as they use the same chasis. Hence kept the code in armv8 specific file instead of board files.
- switch (init) {
switch (index) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
return -1;
break;
- default:
break;
- switch (init) {
break;
- default:
break;
+} +#endif
-- Best regards,
Lukasz Majewski
Hi Rajesh,
Hi Rajat,
Changes in v2:
- .index = 0,
- .index = 1,
- .index = 2,
+} +#endif
Hello Lukasz,
Ok, thanks for clarification.
- switch (init) {
switch (index) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
return -1;
break;
- default:
break;
- switch (init) {
break;
- default:
break;
+} +#endif
-- Best regards,
Lukasz Majewski
Enables dwc3 gadget driver support on LS1043QDS platform.
Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- Changes in v2: - None
include/configs/ls1043aqds.h | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index af1f73d..8c99641 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -394,6 +394,21 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE + +#define CONFIG_USB_DWC3 +#define CONFIG_USB_DWC3_GADGET + +#define CONFIG_USB_GADGET +#define CONFIG_USB_FUNCTION_MASS_STORAGE +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_G_DNL_MANUFACTURER "NXP Semiconductor" +#define CONFIG_G_DNL_VENDOR_NUM 0x0471 +#define CONFIG_G_DNL_PRODUCT_NUM 0x1234 +#define CONFIG_USB_GADGET_DUALSPEED + +/* USB Gadget ums command */ +#define CONFIG_CMD_USB_MASS_STORAGE #endif
Hi Rajat,
Changes in v2:
- None
participants (6)
Lukasz Majewski
Rajat Srivastava
Rajesh Bhagat
york sun
