[U-Boot] [PATCH v2] Allow AM335x MPU core clock speed to be specified in the board config file
Allow AM335x MPU core clock speed to be specified in the board config file. To use, add the following to the board's config file:-
#define V_MPUCLK <desired clock freq in Hz>
Signed-off-by: Mark Jackson mpfj@newflow.co.uk --- Changes in v2: - Tweaked after comments from Peter Korsgaard
arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h index d748dd2..f1a8aa7 100644 --- a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h @@ -21,8 +21,11 @@
#define OSC (V_OSCK/1000000)
-/* MAIN PLL Fdll = 550 MHZ, */ -#define MPUPLL_M 550 +/* MAIN PLL Fdll = 550 MHZ, by default */ +#ifndef V_MPUCLK +#define V_MPUCLK 550000000 +#endif +#define MPUPLL_M (V_MPUCLK/1000000) #define MPUPLL_N (OSC-1) #define MPUPLL_M2 1
"Mark" == Mark Jackson mpfj-list@mimc.co.uk writes:
Mark> Allow AM335x MPU core clock speed to be specified in the board config file. Mark> To use, add the following to the board's config file:-
Mark> #define V_MPUCLK <desired clock freq in Hz>
Mark> Signed-off-by: Mark Jackson mpfj@newflow.co.uk Mark> --- Mark> Changes in v2: Mark> - Tweaked after comments from Peter Korsgaard
Mark> arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 7 +++++-- Mark> 1 file changed, 5 insertions(+), 2 deletions(-)
Mark> diff --git a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h Mark> index d748dd2..f1a8aa7 100644 Mark> --- a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h Mark> +++ b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h Mark> @@ -21,8 +21,11 @@
Mark> #define OSC (V_OSCK/1000000)
Mark> -/* MAIN PLL Fdll = 550 MHZ, */ Mark> -#define MPUPLL_M 550 Mark> +/* MAIN PLL Fdll = 550 MHZ, by default */
It would be good to fix MHZ -> MHz while we're at it. Otherwise it looks good.
Acked-by: Peter Korsgaard jacmet@sunsite.dk
Mark> +#ifndef V_MPUCLK Mark> +#define V_MPUCLK 550000000 Mark> +#endif Mark> +#define MPUPLL_M (V_MPUCLK/1000000) Mark> #define MPUPLL_N (OSC-1) Mark> #define MPUPLL_M2 1
Mark> -- Mark> 1.7.9.5
Mark> _______________________________________________ Mark> U-Boot mailing list Mark> U-Boot@lists.denx.de Mark> http://lists.denx.de/mailman/listinfo/u-boot
Dear Mark Jackson,
If this is a configurable option, it should be CONFIG_SYS_V_MPUCLK instead.
Also, this new config option must be documented in the README.
On 04/03/13 00:27, Wolfgang Denk wrote:
Dear Mark Jackson,
No problem ... I'll post a v3.
Mark Jackson
Peter Korsgaard
