Re: [U-Boot-Users] 83xx address translation: is it really necessary?
I'm adding support for a new 83xx board, the 8349E-mITX. For some
reason, turning on address translation causes the board to halt.
enable_addr_trans: /* enable address translation */ mfmsr r5 ori r5, r5, (MSR_IR | MSR_DR) mtmsr r5 isync blr
As soon as the mtmsr is executed, everything stops.
I also have this problem. Skipping address translation solves this problem. I also wonder, "why do we enable address translation at all?"\
-J.Mann
There is a performance improvement from using address translation. You need to make sure you are setting up the BATs properly for your address map.
- kumar
Can you explain that? Obviously, just translating the addresses can't improve performance, especially since the translated addresses have the same numerical value, so there must be some side-effect.
Well, I'm using the same BATs as the 8349EMDS, so I don't know what the right BATs are.
On Aug 7, 2006, at 3:39 PM, Timur Tabi wrote:
Can you explain that? Obviously, just translating the addresses can't improve performance, especially since the translated addresses have the same numerical value, so there must be some side- effect.
If you dont do address translation you can't set the WIMG settings for the various regions of memory. For example you can't mark normal memory as cacheable.
Is the physical memory map the same on the ITX as it is on the 8349EMDS?
- kumar
Beats me.
The EMDS has this for the BATs:
#define CFG_PCI1_MEM_BASE 0x80000000 #define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE #define CFG_PCI1_MEM_SIZE 0x10000000 /* 256M */ #define CFG_PCI1_MMIO_BASE 0x90000000 #define CFG_PCI1_MMIO_PHYS CFG_PCI1_MMIO_BASE #define CFG_PCI1_MMIO_SIZE 0x10000000 /* 256M */ #define CFG_PCI1_IO_BASE 0x00000000 #define CFG_PCI1_IO_PHYS 0xE2000000 #define CFG_PCI1_IO_SIZE 0x00100000 /* 1M */
#define CFG_PCI2_MEM_BASE 0xA0000000 #define CFG_PCI2_MEM_PHYS CFG_PCI2_MEM_BASE #define CFG_PCI2_MEM_SIZE 0x10000000 /* 256M */ #define CFG_PCI2_MMIO_BASE 0xB0000000 #define CFG_PCI2_MMIO_PHYS CFG_PCI2_MMIO_BASE #define CFG_PCI2_MMIO_SIZE 0x10000000 /* 256M */ #define CFG_PCI2_IO_BASE 0x00000000 #define CFG_PCI2_IO_PHYS 0xE2100000 #define CFG_PCI2_IO_SIZE 0x00100000 /* 1M */
Question #1: Why is CFG_PCI1_MEM_PHYS the same as CFG_PCI1_MEM_BASE, but CFG_PCI1_IO_PHYS is not the same as CFG_PCI1_IO_BASE?
I'm porting the ITX support from an older U-Boot (1.1.3) that was written by another group. This is what they have:
#define CFG_PCI1_MEM_BASE 0x80000000 #define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE #define CFG_PCI1_MEM_SIZE 0x20000000 /* 512M */ #define CFG_PCI1_IO_BASE 0x00000000 #define CFG_PCI1_IO_PHYS 0xe2000000 #define CFG_PCI1_IO_SIZE 0x1000000 /* 16M */
#define CFG_PCI2_MEM_BASE 0xA0000000 #define CFG_PCI2_MEM_PHYS CFG_PCI2_MEM_BASE #define CFG_PCI2_MEM_SIZE 0x20000000 /* 512M */ #define CFG_PCI2_IO_BASE 0x00000000 #define CFG_PCI2_IO_PHYS 0xe3000000 #define CFG_PCI2_IO_SIZE 0x1000000 /* 16M */
As you can see, some numbers are different, and some are missing. I had to guess what value to use for CFG_PCI1_MMIO_BASE, etc.
I don't know why the PCI sizes are larger on the ITX than on the EMDS. I have no documentation that tells me what these numbers should be.
On Aug 7, 2006, at 5:44 PM, Timur Tabi wrote:
Beats me.
Ask me this at lunch one day, its easier to explain in person.
Its because I reworked the memory map to support both PCI Memory (prefetchable) and MMIO (non-prefetchable) windows.
I'd rework the ITX to match the current EMDS. Also, does the ITX actually have PCI2 accessible or connected to anything?
- kumar
Yes, SATA.
I finally got it working. I had to make three changes:
1. Change CFG_INIT_RAM_ADDR from 0xe4010000 (I don't know where that number came from) to 0xFD000000, which is what the EMDS uses.
2. Change the CFG_PCIxxx constants to be the same as the EMDS.
3. Change CFG_HID2 from 0 to HID2_HBE
In other words, I am using an MPC8349ITX.h that originally worked with U-Boot 1.1.3, and all of the above constants were wrong for 1.1.4. I need to merge in the values from the EMDS rather than keep them.
Jeff Mann
Kumar Gala
Timur Tabi
