TPM: remove duplicate definitions
With the recent change to tpm-v2.h, some enums are now defined twice and tpm2_tis_spi.c fails to build. Unfortunately I fear removing the defines from tpm_tis.h, like in this diff, will break the TPMv1 drivers tpm_tis_infineon.c and pm_tis_st33zp24_i2c.c, which depend on those defines. Maybe they should be added to tpm-v1.h as well? Or maybe they should be moved from tpm-v2.h to tpm_tis.h? I have no solution.
Signed-off-by: Patrick Wildt patrick@blueri.se
diff --git a/drivers/tpm/tpm_tis.h b/drivers/tpm/tpm_tis.h index 947585f8e3..4043f1aeaf 100644 --- a/drivers/tpm/tpm_tis.h +++ b/drivers/tpm/tpm_tis.h @@ -113,19 +113,4 @@ struct tpm_cmd_t { */ #define MAX_COUNT_LONG 50
-enum tis_access { - TPM_ACCESS_VALID = 0x80, - TPM_ACCESS_ACTIVE_LOCALITY = 0x20, - TPM_ACCESS_REQUEST_PENDING = 0x04, - TPM_ACCESS_REQUEST_USE = 0x02, -}; - -enum tis_status { - TPM_STS_VALID = 0x80, - TPM_STS_COMMAND_READY = 0x40, - TPM_STS_GO = 0x20, - TPM_STS_DATA_AVAIL = 0x10, - TPM_STS_DATA_EXPECT = 0x08, -}; - #endif
Hi Patrick,
There is a tpm_common.h so they could go in there perhaps.
Patrick Wildt
