[U-Boot] [PATCH v3 1/1] test/py: provide example scripts for integrating qemu
The necessary parameters for running Python tests on qemu are tedious to find.
The patch adds a complete example for running the Python tests for qemu-x86_defconfig on an X86 system.
Cc: Stephen Warren swarren@nvidia.com Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 Move the example into the correct section. Consider comments by Stephen. v2 Include all necessary information to run tests for qemu-x86_defconfig in a separate chapter. --- test/py/README.md | 81 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 81 insertions(+)
diff --git a/test/py/README.md b/test/py/README.md index 829c7efbb2..80e26a3460 100644 --- a/test/py/README.md +++ b/test/py/README.md @@ -330,6 +330,87 @@ CROSS_COMPILE=arm-none-eabi- \ ./test/py/test.py --bd seaboard --build ```
+#### Running tests for qemu-x86_defconfig on an x86 system + +We build u-boot.rom with + + export BUILD_ROM=y + make mrproper + make qemu-x86_defconfig + make + +We create directories `$HOME/ubtest/bin` and `$HOME/ubtest/py` for the script +files below and `../tftp` for the tftp server. + +We copy helloworld.efi to the tftp directory. + + cp lib/efi_loader/helloworld.efi ../tftp/ + +This file is used by the test_efi_loader.py test case. + +In the `$HOME/ubtest/bin` directory we create: + +File `u-boot-test-console` chmod 755 + + #!/bin/sh + touch /tmp/u-boot-monitor-socket + exec qemu-system-x86_64 -bios u-boot.rom -nographic -netdev \ + user,id=eth0,tftp=../tftp,net=192.168.76.0/24,dhcpstart=192.168.76.9 \ + -device e1000,netdev=eth0 -machine pc-i440fx-2.8 \ + -monitor unix:/tmp/u-boot-monitor-socket,server,nowait + +This script is executed when the tests commence. It starts qemu with a network +and a tftp server enabled. The control console is directed to the Unix socket +`/tmp/u-boot-monitor-socket`. + +File `u-boot-test-flash` chmod 755 + + #!/bin/sh + echo ... u-boot-test-flash ... + +This script serves to initialize the board. Nothing needs to be done here as we +pass u-boot.rom as a parameter in `u-boot-test-console`. + +File `u-boot-test-quit` chmod 755 + + #!/bin/sh + echo quit | socat - UNIX-CONNECT:/tmp/u-boot-monitor-socket + +This script is called when all tests are completed. The `quit` command is +passed to the qemu control console to terminate the qemu session. + +File `u-boot-test-reset` chmod 755 + + #!/bin/sh + echo system_reset | socat - UNIX-CONNECT:/tmp/u-boot-monitor-socket + true + +This script is called when a board reset is needed. The `system_reset` command +is passed to the qemu control console to reboot the qemu instance. The script +has to return true or the tests will fail. + +In the `$HOME/ubtest/py` directory we create file `u_boot_boardenv_qemu_x86.py` + + env__net_dhcp_server = True + env__efi_loader_helloworld_file = { + "fn": "helloworld.efi", + "size": 4298, + "crc32": "55d96ef8", + } + +The parameter `env__net_dhcp_server` enables the network tests. The parameter +`env__efi_loader_helloworld_file` is needed to make the file `helloworld.efi` +available which is loaded from the tftp server in `test_efi_loader.py`. + +The fields size and crc32 have to be updated to match the actual values. The +`crc32` command can be used to determine the latter. + +We now can run the Python tests with + + export PATH=$HOME/ubtest/bin:/usr/bin:/bin + export PYTHONPATH=$HOME/ubtest/py + ./test/py/test.py --bd=qemu-x86 --build-dir=. + ## Writing tests
Please refer to the pytest documentation for details of writing pytest tests.
- export BUILD_ROM=y
- make mrproper
- make qemu-x86_defconfig
- make
Nit: I'd rather write that as:
BUILD_ROM=y make
That way, we don't have to set BUILD_ROM permanently in the current shell's environment, so it won't affect anything else that's done later in the shell.
To avoid polluting the source tree with build results, why not build with O=./build-qemu-x86, and use that as the --build-dir argument to test/py?
Why not $HOME/ubtest/tftp? The meaning of "../tftp" can change depending on current directory.
- #!/bin/sh
- touch /tmp/u-boot-monitor-socket
This creates a regular file not a socket. I believe you can remove this command.
Ah, there's a race condition here. By the time u-boot-test-reset is run the first time, qemu typically hasn't run far enough to create /tmp/u-boot-monitor-socket, and so u-boot-test-reset fails to open it. If I fix that by making u-boot-test-reset wait until the control socket actually does exist, then test/py fails because it sees two signon messages from U-Boot and thinks it crashed; one from when qemu started and booted U-Boot, and one because the first invocation of u-boot-test-reset resets the system which causes another signon to appear. Perhaps this is why Tom Rini's test/py+qemu integration spawns a new instance of qemu every time u-boot-test-console is run, and make u-boot-test-reset a no-op.
To solve this, I was going to say:
a) Add -S to the qemu command. This causes qemu to perform all initialization (e.g. creating/opening the monitor socket) but doesn't actually allow the target to run. This prevents the undesired immediate boot of the system.
b) Add the following to the top of u-boot-test-reset so that it waits for the monitor socket to exist before attempting to use it:
for i in $(seq 50); do if [ -f /tmp/u-boot-monitor-socket ]; then break fi sleep 0.1 done
c) Make u-boot-test-reset send U-Boot command "c" to start U-Boot executing instead of or in additionk to "system_reset" to cause a reset.
However, none of that is necessary. u-boot-test-console is re-executed every time test/py wants to connect to the target, which happens (a) when test/py starts the first test, and (b) any time a test fails, and test/py wants to clear all state and reconnect to the target (e.g. the console command might have failed rather than the target, so the console command is restarted too). As such, there's no need to implement u-boot-test-reset at all with qemu; just make it a complete no-op. That way, you also don't need qemu's -monitor at all.
- exec qemu-system-x86_64 -bios u-boot.rom -nographic -netdev \
Is machine version 2.8 strictly necessary? The qemu packaged in Ubuntu 14.04 doesn't support that version, which restricts the usefulness of the example. Can version 2.0 work for example? It seems to work fine for me. My qemu supports the following i440fx:
qemu-system-x86_64 -machine help | grep i440fx pc-i440fx-2.0 Standard PC (i440FX + PIIX, 1996) pc-i440fx-1.4 Standard PC (i440FX + PIIX, 1996) pc-i440fx-1.5 Standard PC (i440FX + PIIX, 1996) pc Ubuntu 14.04 PC (i440FX + PIIX, 1996) (alias of pc-i440fx-trusty) pc-i440fx-trusty Ubuntu 14.04 PC (i440FX + PIIX, 1996) (default) pc-i440fx-1.7 Standard PC (i440FX + PIIX, 1996) pc-i440fx-1.5-saucy Standard PC (i440FX + PIIX, 1996) (alias of pc-i440fx-1.5-qemu-kvm) pc-i440fx-1.5-qemu-kvm Standard PC (i440FX + PIIX, 1996) pc-i440fx-1.6 Standard PC (i440FX + PIIX, 1996)
- #!/bin/sh
- echo quit | socat - UNIX-CONNECT:/tmp/u-boot-monitor-socket
test/py doesn't run u-boot-test-quit. Do you have a local change that makes it do that? My knee-jerk reaction is that it's OK to enhance test/py to run such a script, but let's not document it in the example until it does. That said, I'd assume qemu should exit as soon as test/py exits since stdin will go away, so this shouldn't actually be needed in this case.
- #!/bin/sh
- echo system_reset | socat - UNIX-CONNECT:/tmp/u-boot-monitor-socket
- true
As mentioned previously, the true doesn't appear to be required, and hides legitimate errors.
Since the file mode is mentioned for all the other files, let's mention it here too.
- env__net_dhcp_server = True
- env__efi_loader_helloworld_file = {
"size": 4298,
Why not have Python determine those values automatically? Here's a snippet from my uboot-test-hooks repo that does that. Since people will simply be copy-and-pasting the example, it shouldn't matter that it's non-trivial:
{ "fn": file_name, "size": os.path.getsize(file_full), "crc32": hex(binascii.crc32(open(file_full, 'rb').read()) & \ 0xffffffff)[2:], }
- export PATH=$HOME/ubtest/bin:/usr/bin:/bin
Let's not hard-code /usr/bin:/bin; some people may rely on binaries elsewhere. Also I know that the recently added gpt tests rely on sgdisk which is in sbin on my system at least. Also quote to avoid issues with spaces in path names. How about:
PATH="$HOME/ubtest/bin:$PATH"
- export PYTHONPATH=$HOME/ubtest/py
People might have PYTHONPATH set already (e.g. if using a virtualenv or having installed some packages in their home directory). How about:
PYTHONPATH="$HOME/ubtest/py:$PYTHONPATH"
- ./test/py/test.py --bd=qemu-x86 --build-dir=.
As above, I'd suggest setting environment variables just for the one command rather than permanently changing them:
PATH="$HOME/ubtest/bin:$PATH" \ PYTHONPATH="$HOME/ubtest/py:$PYTHONPATH" \ ./test/py/test.py --bd=qemu-x86 --build-dir=./build-qemu-x86
BUILD_ROM=y make
Building in the source tree is the default for U-Boot. Why should we make the example more complicated?
I can give it a try.
Why make the example more complicated?
Some test scripts explicitly reset U-Boot:
test/py/tests/test_fit.py:362: cons.restart_uboot() test/py/tests/test_fit.py:387: cons.restart_uboot() test/py/tests/test_fit.py:399: cons.restart_uboot() test/py/tests/test_fit.py:411: cons.restart_uboot() test/py/tests/test_fit.py:428: cons.restart_uboot() test/py/tests/test_vboot.py:70: cons.restart_uboot() test/py/tests/test_vboot.py:198: cons.restart_uboot() test/py/tests/test_efi_selftest.py:25: u_boot_console.restart_uboot();
It is time to upgrade your Linux distribution ;) I can change that to pc-i440fx-2.0.
I will remove u-boot-test-quit.
Without true all tests fail on my machine (Debian Stretch) which uses dash to implement /bin/sh. So we should keep it. It does no harm.
644
What does file_full refer to? I cannot find this string in U-Boot. Are the necessary packages imported when the python script is included? I doubt it. There is no string binascii in U-Boot.
We cannot hard code the full path to helloworld.efi here because the value of $HOME_PATH is not known.
I would prefer to keep the example simple.
I can change it.
Together with your suggestion below this is fine.
That makes sense.
Thank you for reviewing.
Best regards
Heinrich
- make mrproper
- make
BUILD_ROM=y make
Because it's a very simple change, that the user can simply copy/paste without any impact to the complexity of how they follow these steps, that helps avoid other problems, such as:
- Placing build results in the source tree which might confuse them later. (Hopefully .gitignore ignores them all though...)
- Interacting badly with the user's own decision to use O= when building themselves in other cases, if they've done that. Not using O= for the build will cause the build system to refuse to build with O= later until the user has deleted all the build results from the tree.
Of course, if the user has already built in-tree, I suppose that using O= in these examples won't work for them either:-(
I will point out that if you run "test/py/test.py --build ..." then test.py will automatically build U-Boot for you, and it will use an O= option based on the board name, and that value will be ./build-qemu-x86 in this case, which is part of the reason I suggested this change.
- #!/bin/sh
Because the example needs to work correctly. Without this step, it won't, except by accident, due to the race condition I mentioned.
Note that this is the kind of reason why I created the example repository for these scripts; users can just clone that repo and run anything that's there without the need for a README that describes how to create these files. (Almost, for qemu targets at least)
Perhaps an alternative would be to host some examples directly in the source tree. For example, we could create ${src}/test/py/hooks/ and just check in all the files there. That way, users wouldn't have to create them for simple qemu cases, and we wouldn't have to write a README to tell users how to create them.
Yes, and those all operate correctly if my suggestions are implemented. cons.restart_uboot() closes the stdin/stdout to the u-boot-console process, which causes qemu to exit, and then cons.restart_uboot() invokes a new instance of u-boot-console which creates a new qemu process. This restart process also happens if any test fails, so that subsequent tests start with a clean state, avoiding issues caused by previous failures.
I know you joked, but I do want to make sure you're aware that travis-ci.org (which runs U-Boot testing) runs the same OS I use, and that OS is supported until 2019, so we shouldn't do anything that prevents people using it. Once it's out of support, it's quite reasonable for U-Boot not to support it any more.
- #!/bin/sh
- true
No, we need to find out why it fails and fix that. If either echo or socat are returning a non-zero exit code, there's a bug in the example scripts that we must fix.
I suspect it's related to the race condition I mentioned re: when qemu creates the monitor socket (and whether it's a plain file as the example script creates, or it's re-created as a socket some time after qemu starts). The suggestions I gave in my email will solve that, and thus you won't need the true command.
"size": 4298,
file_full should be roughly just file_name. I copy/pasted that and forgot to update those lines. Actually, file_name is the name relative to the TFTP directory (the name that U-Boot will request over TFTP during the test) and file_full is a path-name that's valid on the host when the Python code is being parsed. The two can be the same if the current working directory is the TFTP server directory when the code is executed, but it's probably not.
binascii is part of the standard Python library. It's available anywhere that Python is available. Put the following at the top of the script:
import os import binascii
The code can work out where the TFTP directory is by taking the path of the Python code, and computing the TFTP directory name relative to that. Just a few lines of code. Possible code:
file_name = 'xxx' py_dir = os.path.dirname(__file__) hook_dir = os.path.dirname(door_py_dir) tftp_dir = os.path.join(hook_dir, 'tftp) full_name = os.path.join(tftp_dir, file_name)
There are different kinds of simple.
Keeping the code simple is a good general idea.
However, if you keep the code too simple, then the user will have to do all kinds of manual operations, such as manually substituting the correct file size and CRC32 values any time that file changes, instead of blinding copy/pasting the file content and forgetting about it. People will forget that, and then have to debug why the test is broken. I believe that making the act of running the tests as simple as possible is of higher priority than making the code as small/simple as possible. After all, people just blindly following the instructions don't absolutely have to read and understand every single line of code that they're pasting into the files.
Stephen Warren
