[U-Boot] [PATCH v3 0/9] USB: Gadget & DFU related fixes
Third take of USB + DFU updates.
Changelog for the pendants:
changes from v2: * Handle large transfers properly take #2 * Different method of avoid double linking of usb gadget & usb ether.
changes from v1: * Properly terminate terminate string list. * Handle large transfers properly take #1
Pantelis Antoniou (9): usb: Fix bug when both DFU & ETHER are defined g_dnl: Issue connect/disconnect as appropriate g_dnl: Properly terminate string list. dfu: Only perform DFU board_usb_init() for TRATS dfu: Fix crash when wrong number of arguments given dfu: Send correct DFU response from composite_setup dfu: Properly zero out timeout value dfu: Add a partition type target dfu: Support larger than memory transfers.
common/cmd_dfu.c | 5 +- drivers/dfu/dfu.c | 244 ++++++++++++++++++++++++++++-------- drivers/dfu/dfu_mmc.c | 109 ++++++++++++---- drivers/usb/gadget/Makefile | 8 +- drivers/usb/gadget/composite.c | 27 ++++ drivers/usb/gadget/ep0.c | 1 + drivers/usb/gadget/f_dfu.c | 9 +- drivers/usb/gadget/g_dnl.c | 12 +- include/configs/am335x_evm.h | 1 + include/configs/am3517_evm.h | 1 + include/configs/h2200.h | 1 + include/configs/omap3_beagle.h | 1 + include/configs/s5p_goni.h | 1 + include/configs/s5pc210_universal.h | 1 + include/configs/trats.h | 1 + include/dfu.h | 21 +++- 16 files changed, 356 insertions(+), 87 deletions(-)
When both CONFIG_USB_GADGET & CONFIG_USB_ETHER are defined the makefile links objects twice.
The cleanest way to fix is to use a new define, CONFIG_USB_UTIL which must be defined when either CONFIG_USB_ETHER or CONFIG_USB_GADGET are defined.
All affected boards have been modified as well.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/usb/gadget/Makefile | 8 ++++++-- include/configs/am335x_evm.h | 1 + include/configs/am3517_evm.h | 1 + include/configs/h2200.h | 1 + include/configs/omap3_beagle.h | 1 + include/configs/s5p_goni.h | 1 + include/configs/s5pc210_universal.h | 1 + include/configs/trats.h | 1 + 8 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 040eaba..167f24f 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -25,15 +25,19 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libusb_gadget.o
+# required for both USB_GADGET & USB_ETHER +ifdef CONFIG_USB_UTIL +COBJS-y += epautoconf.o config.o usbstring.o +endif + # new USB gadget layer dependencies ifdef CONFIG_USB_GADGET -COBJS-y += epautoconf.o config.o usbstring.o COBJS-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o COBJS-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o COBJS-$(CONFIG_DFU_FUNCTION) += f_dfu.o endif ifdef CONFIG_USB_ETHER -COBJS-y += ether.o epautoconf.o config.o usbstring.o +COBJS-y += ether.o COBJS-$(CONFIG_USB_ETH_RNDIS) += rndis.o COBJS-$(CONFIG_MV_UDC) += mv_udc.o COBJS-$(CONFIG_CPU_PXA25X) += pxa25x_udc.o diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ab9549b..ee19e54 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -278,6 +278,7 @@
#ifdef CONFIG_MUSB_GADGET #define CONFIG_USB_ETHER +#define CONFIG_USB_UTIL #define CONFIG_USB_ETH_RNDIS #endif /* CONFIG_MUSB_GADGET */
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index ba15325..3aedff3 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -123,6 +123,7 @@ #ifdef CONFIG_MUSB_GADGET #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_ETHER +#define CONFIG_USB_UTIL #define CONFIG_USB_ETH_RNDIS #endif /* CONFIG_MUSB_GADGET */
diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 516a26e..fc27bf0 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -170,6 +170,7 @@
#define CONFIG_USB_GADGET_PXA2XX #define CONFIG_USB_ETHER +#define CONFIG_USB_UTIL #define CONFIG_USB_ETH_SUBSET
#define CONFIG_USBNET_DEV_ADDR "de:ad:be:ef:00:01" diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 12d65f2..04fbb5d 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -123,6 +123,7 @@ #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_TWL4030_USB 1 #define CONFIG_USB_ETHER +#define CONFIG_USB_UTIL #define CONFIG_USB_ETHER_RNDIS
/* USB EHCI */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 56e8347..1e180ade 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -231,6 +231,7 @@ #define CONFIG_I2C_MULTI_BUS #define CONFIG_SYS_MAX_I2C_BUS 7 #define CONFIG_USB_GADGET +#define CONFIG_USB_UTIL #define CONFIG_USB_GADGET_S3C_UDC_OTG #define CONFIG_USB_GADGET_DUALSPEED
diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 894f38b..07ab884 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -258,6 +258,7 @@ #define CONFIG_POWER_MAX8998
diff --git a/include/configs/trats.h b/include/configs/trats.h index 355029e..7c2c875 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -245,6 +245,7 @@ #define CONFIG_POWER_BATTERY #define CONFIG_POWER_BATTERY_TRATS #define CONFIG_USB_GADGET +#define CONFIG_USB_UTIL #define CONFIG_USB_GADGET_S3C_UDC_OTG #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 2
Dear Pantelis Antoniou,
Quick google [1]
http://old.nabble.com/if-defined%28a%29-%7C%7C-defined%28b%29-td26806006.htm...
This won't work?
Best regards, Marek Vasut
Hi Marek,
Quick google [1]
This won't work?
Somehow I missed that. Makes some kind of (awful) sense. Updated patch incoming...
Call usb_gadget_connect/usb_gadget_disconnect in g_dnl_bind/g_dnl_unbind.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/usb/gadget/g_dnl.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 7d87050..25da733 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -83,7 +83,12 @@ static struct usb_gadget_strings *g_dnl_composite_strings[] = {
static int g_dnl_unbind(struct usb_composite_dev *cdev) { - debug("%s\n", __func__); + struct usb_gadget *gadget = cdev->gadget; + + debug("%s: calling usb_gadget_disconnect for " + "controller '%s'\n", shortname, gadget->name); + usb_gadget_disconnect(gadget); + return 0; }
@@ -153,6 +158,10 @@ static int g_dnl_bind(struct usb_composite_dev *cdev) device_desc.bcdDevice = __constant_cpu_to_le16(0x9999); }
+ debug("%s: calling usb_gadget_connect for " + "controller '%s'\n", shortname, gadget->name); + usb_gadget_connect(gadget); + return 0;
error:
Well, not terminating the list causes very interesting crashes. As in changing the vendor & product ID crashes. Fun.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/usb/gadget/g_dnl.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 25da733..a5a4c1f 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -69,6 +69,7 @@ static struct usb_device_descriptor device_desc = { static struct usb_string g_dnl_string_defs[] = { { 0, manufacturer, }, { 1, product, }, + { } /* end of list */ };
static struct usb_gadget_strings g_dnl_string_tab = {
USB initialization shouldn't happen for all the boards.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- common/cmd_dfu.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/cmd_dfu.c b/common/cmd_dfu.c index 01d6b3a..327c738 100644 --- a/common/cmd_dfu.c +++ b/common/cmd_dfu.c @@ -55,7 +55,10 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) goto done; }
+#ifdef CONFIG_TRATS board_usb_init(); +#endif + g_dnl_register(s); while (1) { if (ctrlc())
Can this "board_usb_init()" _please_ be renamed?
Fix obvious crash when not enough arguments are given to the dfu command.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- common/cmd_dfu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_dfu.c b/common/cmd_dfu.c index 327c738..83ef324 100644 --- a/common/cmd_dfu.c +++ b/common/cmd_dfu.c @@ -50,7 +50,7 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (ret) return CMD_RET_FAILURE;
- if (strcmp(argv[3], "list") == 0) { + if (argc > 3 && strcmp(argv[3], "list") == 0) { dfu_show_entities(); goto done; }
DFU is a bit peculiar. It needs to hook to composite setup and return it's function descriptor.
So when get-descriptor request comes with a type of DFU_DT_FUNC we iterate over the configs, and functions, and when we find the DFU function we call the setup method which is prepared to return the appropriate function descriptor.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/usb/gadget/composite.c | 27 +++++++++++++++++++++++++++ drivers/usb/gadget/ep0.c | 1 + drivers/usb/gadget/f_dfu.c | 6 ++++-- 3 files changed, 32 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index ebb5131..6496436 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -773,6 +773,33 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) if (value >= 0) value = min(w_length, (u16) value); break; + +#ifdef CONFIG_DFU_FUNCTION + /* DFU is mighty weird */ + case DFU_DT_FUNC: + w_value &= 0xff; + list_for_each_entry(c, &cdev->configs, list) { + if (w_value != 0) { + w_value--; + continue; + } + + list_for_each_entry(f, &c->functions, list) { + + /* DFU function only */ + if (strcmp(f->name, "dfu") != 0) + continue; + + value = f->setup(f, ctrl); + goto dfu_func_done; + } + } +dfu_func_done: + if (value >= 0) + value = min(w_length, (u16) value); + break; +#endif + default: goto unknown; } diff --git a/drivers/usb/gadget/ep0.c b/drivers/usb/gadget/ep0.c index aa8f916..971d846 100644 --- a/drivers/usb/gadget/ep0.c +++ b/drivers/usb/gadget/ep0.c @@ -221,6 +221,7 @@ static int ep0_get_descriptor (struct usb_device_instance *device, break;
case USB_DESCRIPTOR_TYPE_CONFIGURATION: + case USB_DESCRIPTOR_TYPE_OTHER_SPEED_CONFIGURATION: { struct usb_configuration_descriptor *configuration_descriptor; diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index 10547e3..6494f5e 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -534,8 +534,10 @@ dfu_handle(struct usb_function *f, const struct usb_ctrlrequest *ctrl) value = min(len, (u16) sizeof(dfu_func)); memcpy(req->buf, &dfu_func, value); } - } else /* DFU specific request */ - value = dfu_state[f_dfu->dfu_state] (f_dfu, ctrl, gadget, req); + return value; + } + + value = dfu_state[f_dfu->dfu_state] (f_dfu, ctrl, gadget, req);
if (value >= 0) { req->length = value;
Hi Pantelis,
Sorry, but could you be more informative here? Have you had any non standard problems? I wonder why dfu-util on my linux works OK without this patch?
^^^^^^ - please explain this "wiredness".
I don't recall such a hacks in linux kernel composite.c (any special #ifdef). Am I missing something important in DFU?
Does your device have any special requirement, so you need this hack?
I generally don't like the idea to "patch" composite gadget code with #ifdefs for special function. Please convince me.
case DFU_DT_FUNC:
w_value &= 0xff;
if (w_value != 0) {
w_value--;
continue;
if (strcmp(f->name,
"dfu") != 0)
continue;
goto dfu_func_done;
+dfu_func_done:
if (value >= 0)
break;
- default: goto unknown; }
- case USB_DESCRIPTOR_TYPE_OTHER_SPEED_CONFIGURATION:
^^^^^^^^^^^^^- why do you need that?
gadget, req);
return value;
req);
Why do you change state even after receiving req_type == USB_TYPE_STANDARD? I would expect to change the dfu state only when DFU specific request appears.
Hi Lukasz,
On Dec 10, 2012, at 7:11 PM, Lukasz Majewski wrote:
Hi Pantelis,
I have absolutely no idea why it works at your side.
At our side it just didn't work at all without the patches.
If I had to guess maybe your gadget h/w takes care of replying properly for the DFU case.
It doesn't work otherwise. I have no idea why you think I would be hacking around there if the thing worked at all. And trust me on that, it just doesn't without those patches, not to mention the way it unceremoniously blows up if you transfer anything larger than the buffer set aside originally.
The way I see it, instead of complaining you should be rejoicing since now DFU will be used in an actual production environment.
More users == less bugs.
When I get a few free cycles I will post a tcpdump capture of the DFU USB transaction hanging.
case DFU_DT_FUNC:
w_value &= 0xff;
if (w_value != 0) {
w_value--;
continue;
if (strcmp(f->name,
"dfu") != 0)
continue;
goto dfu_func_done;
+dfu_func_done:
if (value >= 0)
break;
gadget, req);
return value;
req);
-- Best regards,
Lukasz Majewski
Samsung Poland R&D Center | Linux Platform Group
Regards
-- Pantelis
Pantelis,
Hi Lukasz,
Hi Pantelis,
I'm not complaining. I try to resolve the problem, since this can make dfu support better at u-boot.
Moreover I'm aware that USB is tricky, so I want to understand your problem.
Tomorrow I will prepare output of USB Ellisys analizer on my side, so we could get clue what is going on.
I'm really happy, that you have posted patches for NAND flashing.
Without your determination at debugging, problem with buffer overflow wouldn't be discovered.
We "only" needs to share knowledge and provide solution acceptable for community and us.
I'm open.
Yes, please.
case DFU_DT_FUNC:
w_value &= 0xff;
list) {
if (w_value != 0) {
w_value--;
continue;
if (strcmp(f->name,
"dfu") != 0)
continue;
goto dfu_func_done;
+dfu_func_done:
if (value >= 0)
value);
break;
gadget, req);
return value;
req);
-- Best regards,
Lukasz Majewski
Regards
-- Pantelis
Regards, Lukasz Majewski
Dear Lukasz Majewski,
Pantelis,
Hm hm ... I suspect it'd be nice to have a separate DFU custodian. That'd leverage some burden from me. I like that idea. I wonder if it'd be nice to start building such bigger net of custodians.
Hm ?
Hi Marek,
Pantelis,
I think,that this (political) decision shall be made by Wolfgang or Tom.
Hm ?
No problem from my side. I would be honored to be DFU maintainer (as part of USB subsystem).
Dear Marek Vasut,
I'm not sure about what the limit for a managable number of custodians might be. If the number grows too far, we need additional levels in the hierarchy, concentrators of some kind - similar to what Albert is doing for ARM.
My gut feeling is that we are not close to any such limit yet, on the other hand I seriously doubt that somethign like DFU really needs the formal establishment of a custodian. Who are the regular users and who the developers of this piece of code?
PS: I'm always surprised how the random generator manages to pick the perfectly fitting quote for my signature :-)
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Pantelis,
So long as everyone involved plays nice, we have a maintainer of the code (Lukasz) and another user / developer of the code (Pantelis). I don't think we need to go full on custodian right now. Lukasz is reviewing and trying to understand what Pantelis is seeing since we're seeing some odd issues on the second platform to add DFU support.
- -- Tom
Dear Tom Rini,
Pantelis,
WFM, but it'd leverage burden from me. And I honestly dont understand the DFU as much as Lukasz does.
On 12/12/12 12:55, Marek Vasut wrote:
Dear Tom Rini,
Pantelis,
That's fine. Lean on maintainers as much as they're agreeable to. I'm sure (well, I hope and assume) Lukasz would like to ack anything DFU related that goes in and if you don't want to pull for u-boot-usb until he does, that's fine and good with me.
- -- Tom
Hi Pantelis,
Please find attached output from USB ellisys analizer.
(It is possible to download WinXP based program to view logs without USB analizer box).
What I see in the current implementation stalls on GetDescriptor (Class: 0x21),but afterwards transmission is performed.
Hi Lukasz,
I bet transmission is performed, but with the default settings of dfu. The DFU function descriptor is completely ignored.
An easy way to verify it is to check if the DFU version of the device is the same one as the one stored in the descriptor. Same with the transmission block size.
It might work, but only by accident.
I sure hope I'll have time today to send my captures as well.
Regards
-- Pantelis
On Dec 11, 2012, at 1:02 PM, Lukasz Majewski wrote:
Hi Pantelis,
-- Best regards,
Lukasz Majewski
Samsung Poland R&D Center | Linux Platform Group <DFU_mainline_trats.tar>
On Tue, 11 Dec 2012, Lukasz Majewski wrote:
Hi Pantelis,
is it really appropriate to post 8M of output to a mailing list? what's wrong with pastebin?
rday
Dear Robert P. J. Day,
Hi Pantelis,
:rageface:
http://www.ietf.org/rfc/rfc1855.txt
rday
Hi Pantelis,
Or run u-boot in qemu and tunnel it through usbmon :p
Hi Lukasz,
Since log itself waits for moderator approval, I will be more precise:
1. dfu-util version 0.1+svnexported
2. u-boot-denx master branch:
SHA1: d987274e214cbfc7a56504fb3f0575fc6d2c587a
Zero out timeout value; letting it filled with undefined values ends up with the dfu host hanging.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/usb/gadget/f_dfu.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index 6494f5e..c15585c 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -164,6 +164,9 @@ static void handle_getstatus(struct usb_request *req)
/* send status response */ dstat->bStatus = f_dfu->dfu_status; + dstat->bwPollTimeout[0] = 0; + dstat->bwPollTimeout[1] = 0; + dstat->bwPollTimeout[2] = 0; dstat->bState = f_dfu->dfu_state; dstat->iString = 0; }
Dealing with raw block numbers with the dfu is very annoying. Introduce a partition method.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/dfu/dfu_mmc.c | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 5d504df..083d745 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -21,6 +21,7 @@
#include <common.h> #include <malloc.h> +#include <errno.h> #include <dfu.h>
enum dfu_mmc_op { @@ -153,6 +154,10 @@ int dfu_read_medium_mmc(struct dfu_entity *dfu, void *buf, long *len)
int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *s) { + int dev, part; + struct mmc *mmc; + block_dev_desc_t *blk_dev; + disk_partition_t partinfo; char *st;
dfu->dev_type = DFU_DEV_MMC; @@ -166,8 +171,34 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *s) dfu->layout = DFU_FS_FAT; } else if (!strcmp(st, "ext4")) { dfu->layout = DFU_FS_EXT4; + } else if (!strcmp(st, "part")) { + + dfu->layout = DFU_RAW_ADDR; + + dev = simple_strtoul(s, &s, 10); + s++; + part = simple_strtoul(s, &s, 10); + + mmc = find_mmc_device(dev); + if (mmc == NULL || mmc_init(mmc)) { + printf("%s: could not find mmc device #%d!\n", __func__, dev); + return -ENODEV; + } + + blk_dev = &mmc->block_dev; + if (get_partition_info(blk_dev, part, &partinfo) != 0) { + printf("%s: could not find partition #%d on mmc device #%d!\n", + __func__, part, dev); + return -ENODEV; + } + + dfu->data.mmc.lba_start = partinfo.start; + dfu->data.mmc.lba_size = partinfo.size; + dfu->data.mmc.lba_blk_size = partinfo.blksz; + } else { printf("%s: Memory layout (%s) not supported!\n", __func__, st); + return -ENODEV; }
if (dfu->layout == DFU_FS_EXT4 || dfu->layout == DFU_FS_FAT) {
We didn't support upload/download larger than available memory. This is pretty bad when you have to update your root filesystem for example.
This patch removes the limitation (and the crashes when you transfered any file larger than 4MB). On top of that reduces the huge dfu buffer from 4MB to just 64K, which was over the top.
The sequence number is a 16 bit counter; make sure we handle rollover correctly. This fixes the wrong transfers for large (> 256MB) images.
Also utilize a variable to handle initialization, so that we don't rely on just the counter sent by the host.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/dfu/dfu.c | 244 +++++++++++++++++++++++++++++++++++++++----------- drivers/dfu/dfu_mmc.c | 82 +++++++++++------ include/dfu.h | 21 ++++- 3 files changed, 264 insertions(+), 83 deletions(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index e8477fb..fb9b417 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -44,90 +44,228 @@ static int dfu_find_alt_num(const char *s) static unsigned char __aligned(CONFIG_SYS_CACHELINE_SIZE) dfu_buf[DFU_DATA_BUF_SIZE];
+static int dfu_write_buffer_flush(struct dfu_entity *dfu) +{ + long w_size; + int ret; + + /* flush size? */ + w_size = dfu->i_buf - dfu->i_buf_start; + if (w_size == 0) + return 0; + + /* update CRC32 */ + dfu->crc = crc32(dfu->crc, dfu->i_buf_start, w_size); + + ret = dfu->write_medium(dfu, dfu->offset, dfu->i_buf_start, &w_size); + if (ret) + debug("%s: Write error!\n", __func__); + + /* point back */ + dfu->i_buf = dfu->i_buf_start; + + /* update offset */ + dfu->offset += w_size; + + puts("#"); + + return ret; +} + int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) { - static unsigned char *i_buf; - static int i_blk_seq_num; - long w_size = 0; int ret = 0; + int tret; + + debug("%s: name: %s buf: 0x%p size: 0x%x p_num: 0x%x " + "offset: 0x%llx bufoffset: 0x%x\n", + __func__, dfu->name, buf, size, blk_seq_num, dfu->offset, + dfu->i_buf - dfu->i_buf_start); + + if (!dfu->inited) { + /* initial state */ + dfu->crc = 0; + dfu->offset = 0; + dfu->i_blk_seq_num = 0; + dfu->i_buf_start = dfu_buf; + dfu->i_buf_end = dfu_buf + sizeof(dfu_buf); + dfu->i_buf = dfu->i_buf_start; + + dfu->inited = 1; + }
- debug("%s: name: %s buf: 0x%p size: 0x%x p_num: 0x%x i_buf: 0x%p\n", - __func__, dfu->name, buf, size, blk_seq_num, i_buf); + if (dfu->i_blk_seq_num != blk_seq_num) { + printf("%s: Wrong sequence number! [%d] [%d]\n", + __func__, dfu->i_blk_seq_num, blk_seq_num); + return -1; + }
- if (blk_seq_num == 0) { - i_buf = dfu_buf; - i_blk_seq_num = 0; + /* DFU 1.1 standard says: + * The wBlockNum field is a block sequence number. It increments each + * time a block is transferred, wrapping to zero from 65,535. It is used + * to provide useful context to the DFU loader in the device." + * + * This means that it's a 16 bit counter that roll-overs at + * 0xffff -> 0x0000. By having a typical 4K transfer block + * we roll-over at exactly 256MB. Not very fun to debug. + * + * Handling rollover, and having an inited variable, + * makes things work. + */ + + /* handle rollover */ + dfu->i_blk_seq_num = (dfu->i_blk_seq_num + 1) & 0xffff; + + /* flush buffer if overflow */ + if ((dfu->i_buf + size) > dfu->i_buf_end) { + tret = dfu_write_buffer_flush(dfu); + if (ret == 0) + ret = tret; }
- if (i_blk_seq_num++ != blk_seq_num) { - printf("%s: Wrong sequence number! [%d] [%d]\n", - __func__, i_blk_seq_num, blk_seq_num); + /* we should be in buffer now (if not then size too large) */ + if ((dfu->i_buf + size) > dfu->i_buf_end) { + printf("%s: Wrong size! [%d] [%d] - %d\n", + __func__, dfu->i_blk_seq_num, blk_seq_num, size); return -1; }
- memcpy(i_buf, buf, size); - i_buf += size; + memcpy(dfu->i_buf, buf, size); + dfu->i_buf += size;
+ /* if end or if buffer full flush */ + if (size == 0 || (dfu->i_buf + size) > dfu->i_buf_end) { + tret = dfu_write_buffer_flush(dfu); + if (ret == 0) + ret = tret; + } + + /* end? */ if (size == 0) { - /* Integrity check (if needed) */ - debug("%s: %s %d [B] CRC32: 0x%x\n", __func__, dfu->name, - i_buf - dfu_buf, crc32(0, dfu_buf, i_buf - dfu_buf)); + debug("%s: DFU complete CRC32: 0x%x\n", __func__, dfu->crc);
- w_size = i_buf - dfu_buf; - ret = dfu->write_medium(dfu, dfu_buf, &w_size); - if (ret) - debug("%s: Write error!\n", __func__); + printf("\nDownload complete (CRC32 0x%04x)\n", dfu->crc); + + /* clear everything */ + dfu->crc = 0; + dfu->offset = 0; + dfu->i_blk_seq_num = 0; + dfu->i_buf_start = dfu_buf; + dfu->i_buf_end = dfu_buf + sizeof(dfu_buf); + dfu->i_buf = dfu->i_buf_start; + + dfu->inited = 0;
- i_blk_seq_num = 0; - i_buf = NULL; - return ret; }
- return ret; + return ret = 0 ? size : ret; +} + +static int dfu_read_buffer_fill(struct dfu_entity *dfu, void *buf, int size) +{ + long chunk; + int ret, readn; + + readn = 0; + while (size > 0) { + + /* get chunk that can be read */ + chunk = min(size, dfu->b_left); + /* consume */ + if (chunk > 0) { + memcpy(buf, dfu->i_buf, chunk); + dfu->crc = crc32(dfu->crc, buf, chunk); + dfu->i_buf += chunk; + dfu->b_left -= chunk; + size -= chunk; + buf += chunk; + readn += chunk; + } + + /* all done */ + if (size > 0) { + /* no more to read */ + if (dfu->r_left == 0) + break; + + dfu->i_buf = dfu->i_buf_start; + dfu->b_left = dfu->i_buf_end - dfu->i_buf_start; + + /* got to read, but buffer is empty */ + if (dfu->b_left > dfu->r_left) + dfu->b_left = dfu->r_left; + ret = dfu->read_medium(dfu, dfu->offset, dfu->i_buf, + &dfu->b_left); + if (ret != 0) { + debug("%s: Read error!\n", __func__); + return ret; + } + dfu->offset += dfu->b_left; + dfu->r_left -= dfu->b_left; + + puts("#"); + } + } + + return readn; }
int dfu_read(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) { - static unsigned char *i_buf; - static int i_blk_seq_num; - static long r_size; - static u32 crc; int ret = 0;
debug("%s: name: %s buf: 0x%p size: 0x%x p_num: 0x%x i_buf: 0x%p\n", - __func__, dfu->name, buf, size, blk_seq_num, i_buf); - - if (blk_seq_num == 0) { - i_buf = dfu_buf; - ret = dfu->read_medium(dfu, i_buf, &r_size); - debug("%s: %s %ld [B]\n", __func__, dfu->name, r_size); - i_blk_seq_num = 0; - /* Integrity check (if needed) */ - crc = crc32(0, dfu_buf, r_size); + __func__, dfu->name, buf, size, blk_seq_num, dfu->i_buf); + + if (!dfu->inited) { + ret = dfu->read_medium(dfu, 0, NULL, &dfu->r_left); + if (ret != 0) { + debug("%s: failed to get r_left\n", __func__); + return ret; + } + + debug("%s: %s %ld [B]\n", __func__, dfu->name, dfu->r_left); + + dfu->i_blk_seq_num = 0; + dfu->crc = 0; + dfu->offset = 0; + dfu->i_buf_start = dfu_buf; + dfu->i_buf_end = dfu_buf + sizeof(dfu_buf); + dfu->i_buf = dfu->i_buf_start; + dfu->b_left = 0; + + dfu->inited = 1; }
- if (i_blk_seq_num++ != blk_seq_num) { + if (dfu->i_blk_seq_num != blk_seq_num) { printf("%s: Wrong sequence number! [%d] [%d]\n", - __func__, i_blk_seq_num, blk_seq_num); + __func__, dfu->i_blk_seq_num, blk_seq_num); return -1; } + /* handle rollover */ + dfu->i_blk_seq_num = (dfu->i_blk_seq_num + 1) & 0xffff;
- if (r_size >= size) { - memcpy(buf, i_buf, size); - i_buf += size; - r_size -= size; - return size; - } else { - memcpy(buf, i_buf, r_size); - i_buf += r_size; - debug("%s: %s CRC32: 0x%x\n", __func__, dfu->name, crc); - puts("UPLOAD ... done\nCtrl+C to exit ...\n"); + ret = dfu_read_buffer_fill(dfu, buf, size); + if (ret < 0) { + printf("%s: Failed to fill buffer\n", __func__); + return -1; + } + + if (ret < size) { + debug("%s: %s CRC32: 0x%x\n", __func__, dfu->name, dfu->crc); + puts("\nUPLOAD ... done\nCtrl+C to exit ...\n");
- i_buf = NULL; - i_blk_seq_num = 0; - crc = 0; - return r_size; + dfu->i_blk_seq_num = 0; + dfu->crc = 0; + dfu->offset = 0; + dfu->i_buf_start = dfu_buf; + dfu->i_buf_end = dfu_buf + sizeof(dfu_buf); + dfu->i_buf = dfu->i_buf_start; + dfu->b_left = 0; + + dfu->inited = 0; } + return ret; }
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 083d745..29a2c2e 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -22,6 +22,7 @@ #include <common.h> #include <malloc.h> #include <errno.h> +#include <div64.h> #include <dfu.h>
enum dfu_mmc_op { @@ -30,35 +31,48 @@ enum dfu_mmc_op { };
static int mmc_block_op(enum dfu_mmc_op op, struct dfu_entity *dfu, - void *buf, long *len) + u64 offset, void *buf, long *len) { char cmd_buf[DFU_CMD_BUF_SIZE]; + u32 blk_start, blk_count;
- sprintf(cmd_buf, "mmc %s 0x%x %x %x", - op == DFU_OP_READ ? "read" : "write", - (unsigned int) buf, - dfu->data.mmc.lba_start, - dfu->data.mmc.lba_size); - - if (op == DFU_OP_READ) + /* if buf == NULL return total size of the area */ + if (buf == NULL) { *len = dfu->data.mmc.lba_blk_size * dfu->data.mmc.lba_size; + return 0; + } + + blk_start = dfu->data.mmc.lba_start + + (u32)lldiv(offset, dfu->data.mmc.lba_blk_size); + blk_count = *len / dfu->data.mmc.lba_blk_size; + if (blk_start + blk_count > + dfu->data.mmc.lba_start + dfu->data.mmc.lba_size) { + debug("%s: block_op out of bounds\n", __func__); + return -1; + } + + sprintf(cmd_buf, "mmc %s %p %x %x", + op == DFU_OP_READ ? "read" : "write", + buf, blk_start, blk_count);
debug("%s: %s 0x%p\n", __func__, cmd_buf, cmd_buf); return run_command(cmd_buf, 0); }
-static inline int mmc_block_write(struct dfu_entity *dfu, void *buf, long *len) +static inline int mmc_block_write(struct dfu_entity *dfu, + u64 offset, void *buf, long *len) { - return mmc_block_op(DFU_OP_WRITE, dfu, buf, len); + return mmc_block_op(DFU_OP_WRITE, dfu, offset, buf, len); }
-static inline int mmc_block_read(struct dfu_entity *dfu, void *buf, long *len) +static inline int mmc_block_read(struct dfu_entity *dfu, + u64 offset, void *buf, long *len) { - return mmc_block_op(DFU_OP_READ, dfu, buf, len); + return mmc_block_op(DFU_OP_READ, dfu, offset, buf, len); }
static int mmc_file_op(enum dfu_mmc_op op, struct dfu_entity *dfu, - void *buf, long *len) + u64 offset, void *buf, long *len) { char cmd_buf[DFU_CMD_BUF_SIZE]; char *str_env; @@ -66,12 +80,17 @@ static int mmc_file_op(enum dfu_mmc_op op, struct dfu_entity *dfu,
switch (dfu->layout) { case DFU_FS_FAT: - sprintf(cmd_buf, "fat%s mmc %d:%d 0x%x %s %lx", + sprintf(cmd_buf, "fat%s mmc %d:%d 0x%x %s %lx %llx", op == DFU_OP_READ ? "load" : "write", dfu->data.mmc.dev, dfu->data.mmc.part, - (unsigned int) buf, dfu->name, *len); + (unsigned int) buf, dfu->name, *len, offset); break; case DFU_FS_EXT4: + if (offset != 0) { + debug("%s: Offset value %llx != 0 not supported!\n", + __func__, offset); + return -1; + } sprintf(cmd_buf, "ext4%s mmc %d:%d /%s 0x%x %ld", op == DFU_OP_READ ? "load" : "write", dfu->data.mmc.dev, dfu->data.mmc.part, @@ -80,6 +99,7 @@ static int mmc_file_op(enum dfu_mmc_op op, struct dfu_entity *dfu, default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, dfu_get_layout(dfu->layout)); + return -1; }
debug("%s: %s 0x%p\n", __func__, cmd_buf, cmd_buf); @@ -102,27 +122,30 @@ static int mmc_file_op(enum dfu_mmc_op op, struct dfu_entity *dfu, return ret; }
-static inline int mmc_file_write(struct dfu_entity *dfu, void *buf, long *len) +static inline int mmc_file_write(struct dfu_entity *dfu, + u64 offset, void *buf, long *len) { - return mmc_file_op(DFU_OP_WRITE, dfu, buf, len); + return mmc_file_op(DFU_OP_WRITE, dfu, offset, buf, len); }
-static inline int mmc_file_read(struct dfu_entity *dfu, void *buf, long *len) +static inline int mmc_file_read(struct dfu_entity *dfu, + u64 offset, void *buf, long *len) { - return mmc_file_op(DFU_OP_READ, dfu, buf, len); + return mmc_file_op(DFU_OP_READ, dfu, offset, buf, len); }
-int dfu_write_medium_mmc(struct dfu_entity *dfu, void *buf, long *len) +int dfu_write_medium_mmc(struct dfu_entity *dfu, + u64 offset, void *buf, long *len) { int ret = -1;
switch (dfu->layout) { case DFU_RAW_ADDR: - ret = mmc_block_write(dfu, buf, len); + ret = mmc_block_write(dfu, offset, buf, len); break; case DFU_FS_FAT: case DFU_FS_EXT4: - ret = mmc_file_write(dfu, buf, len); + ret = mmc_file_write(dfu, offset, buf, len); break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, @@ -132,17 +155,17 @@ int dfu_write_medium_mmc(struct dfu_entity *dfu, void *buf, long *len) return ret; }
-int dfu_read_medium_mmc(struct dfu_entity *dfu, void *buf, long *len) +int dfu_read_medium_mmc(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { int ret = -1;
switch (dfu->layout) { case DFU_RAW_ADDR: - ret = mmc_block_read(dfu, buf, len); + ret = mmc_block_read(dfu, offset, buf, len); break; case DFU_FS_FAT: case DFU_FS_EXT4: - ret = mmc_file_read(dfu, buf, len); + ret = mmc_file_read(dfu, offset, buf, len); break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, @@ -181,13 +204,15 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *s)
mmc = find_mmc_device(dev); if (mmc == NULL || mmc_init(mmc)) { - printf("%s: could not find mmc device #%d!\n", __func__, dev); + printf("%s: could not find mmc device #%d!\n", + __func__, dev); return -ENODEV; }
blk_dev = &mmc->block_dev; if (get_partition_info(blk_dev, part, &partinfo) != 0) { - printf("%s: could not find partition #%d on mmc device #%d!\n", + printf("%s: could not find partition #%d " + "on mmc device #%d!\n", __func__, part, dev); return -ENODEV; } @@ -209,5 +234,8 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *s) dfu->read_medium = dfu_read_medium_mmc; dfu->write_medium = dfu_write_medium_mmc;
+ /* initial state */ + dfu->inited = 0; + return 0; } diff --git a/include/dfu.h b/include/dfu.h index 5350d79..2847ef8 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -59,7 +59,7 @@ static inline unsigned int get_mmc_blk_size(int dev)
#define DFU_NAME_SIZE 32 #define DFU_CMD_BUF_SIZE 128 -#define DFU_DATA_BUF_SIZE (1024*1024*4) /* 4 MiB */ +#define DFU_DATA_BUF_SIZE (1024*64) /* 64 KB (the huge buffer is overkill) */
struct dfu_entity { char name[DFU_NAME_SIZE]; @@ -73,10 +73,25 @@ struct dfu_entity { struct mmc_internal_data mmc; } data;
- int (*read_medium)(struct dfu_entity *dfu, void *buf, long *len); - int (*write_medium)(struct dfu_entity *dfu, void *buf, long *len); + int (*read_medium)(struct dfu_entity *dfu, + u64 offset, void *buf, long *len); + + int (*write_medium)(struct dfu_entity *dfu, + u64 offset, void *buf, long *len);
struct list_head list; + + /* on the fly state */ + u32 crc; + u64 offset; + int i_blk_seq_num; + u8 *i_buf; + u8 *i_buf_start; + u8 *i_buf_end; + long r_left; + long b_left; + + unsigned int inited : 1; };
int dfu_config_entities(char *s, char *interface, int num);
To be clear, patches 1-8 are good and we should take, but this one means we can't use FAT/EXT* partitions without more work. I would suggest that we set this part aside for a moment and perhaps limit transfers that are larget than RAM to RAW only where we can write in chunks today.
Hi Tom,
As fair as I remember, some additional work needs to be done with composite.c file (to remove nasty #ifdefs). There was a problem with newer version of dfu-utils (new handling of descriptors).
It is on top of my queue, but I'm currently buried with other work and need to postpone this.
However it is still on the back of my head and I push myself to fix this.
Hi Tom,
Guys, can you just tell me what I should drop from u-boot-usb to submit a pullRQ with the rest ? Otherwise I'll drop the whole DFU stuff and be done with it.
On 02/18/2013 05:01 AM, Lukasz Majewski wrote:
Hi Tom,
I thought it ended up being resolved. I'll have to re-read the thread again I guess.
- -- Tom
On Mon, Feb 18, 2013 at 11:01:42AM +0100, Lukasz Majewski wrote:
Hi Tom,
I see you and Pantelis talking about if some changes were really needed in composite.c or not, but nothing about dfu-utils. Were you objecting to the composite.c changes because you didn't need them, or because they in turn broke trats (can I get one of these somewhere?) The only other unresolved thing was about board_usb_init() which I think was settled on trats needing to change behavior.
Hi Tom,
First of all, sorry for late reply.
Hi Tom,
Changes in composite.c (adding some #ifdefs) were made because dfu-util developers made the significant change in descriptors handling between dfu-utils ver. 0.1 (which I've been using on my antic/test machine debian) and the newest dfu-utils (which Pantelis was using, and which is now available on recent debian).
To be honest the current DFU code (v2013.01) works with the dfu-utils ver 0.1 (the old one). It breaks with new one.
I'm objecting to adding a "quick hack style" #ifdefs to generic composite.c code. As fair as I remember this corrected code works with DFU, but I'd need to check if those composite.c changes will not break the UMS patches posted recently.
Regarding TRATS: It is an official Tizen development board (mobile phone): http://www.youtube.com/watch?v=ya7ucT1wzOA
It was distributed on some fair show, but I cannot tell how to obtain one.
As fair as I remember trats follows u-boot policy to enable things only when they are really needed. But I will not be stubborn here. On the end I might end up with a weak function (or enabling USB by default). I think, that this is a minor issue when compared to composite.c
My proposition: - Now we have middle of Feb, we can add Pantelis Patches, UMS patches to u-boot tree (from Marek's USB tree) and fix conflicts up till v2013.03 release. I can point two big sets of patches (related only to Samsung boards) floating around without a common "base": Pantelis DFU work and UMS support patches.
- I plan to work on composite/DFU (and potential UMS problems) at next week (up Friday I'm totally buried with other work)
changes from v2:
- Handle large transfers properly take #2
- Different method of avoid double linking of usb gadget & usb ether.
changes from v1:
- Properly terminate terminate string list.
- Handle large transfers properly take #1
I applied all but 1/9, that needs proper fixing.
participants (7)
Lukasz Majewski
Lukasz Majewski
Pantelis Antoniou
Robert P. J. Day
