[PATCH 1/2] mmc: fsl_esdhc_imx: use mmc_send_cmd instead of dm_mmc_send_cmd
Use mmc_send_cmd instead of dm_mmc_send_cmd. It doesn't need to distinguish this function.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/fsl_esdhc_imx.c | 2 +- drivers/mmc/mmc_private.h | 1 - include/mmc.h | 1 + 3 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index a4675838e58a..4f4a6a8c9934 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -865,7 +865,7 @@ static void esdhc_stop_tuning(struct mmc *mmc) cmd.cmdarg = 0; cmd.resp_type = MMC_RSP_R1b;
- dm_mmc_send_cmd(mmc->dev, &cmd, NULL); + mmc_send_cmd(mmc, &cmd, NULL); }
static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) diff --git a/drivers/mmc/mmc_private.h b/drivers/mmc/mmc_private.h index a0900e8cadd8..a6cd250d2935 100644 --- a/drivers/mmc/mmc_private.h +++ b/drivers/mmc/mmc_private.h @@ -12,7 +12,6 @@
#include <mmc.h>
-int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data); int mmc_send_status(struct mmc *mmc, unsigned int *status); int mmc_poll_for_busy(struct mmc *mmc, int timeout);
diff --git a/include/mmc.h b/include/mmc.h index 8600881705f4..7f8ba2b017ee 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -795,6 +795,7 @@ int mmc_initialize(struct bd_info *bis); int mmc_init_device(int num); int mmc_init(struct mmc *mmc); int mmc_send_tuning(struct mmc *mmc, u32 opcode, int *cmd_error); +int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data);
#if CONFIG_IS_ENABLED(MMC_UHS_SUPPORT) || \ CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) || \
Change to static about dm function. They can be used with wrapper functions.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/mmc-uclass.c | 24 ++++++++++++------------ include/mmc.h | 12 ------------ 2 files changed, 12 insertions(+), 24 deletions(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index d36aae367e7c..579d7a1406b3 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -15,7 +15,7 @@ #include <linux/compat.h> #include "mmc_private.h"
-int dm_mmc_get_b_max(struct udevice *dev, void *dst, lbaint_t blkcnt) +static int dm_mmc_get_b_max(struct udevice *dev, void *dst, lbaint_t blkcnt) { struct dm_mmc_ops *ops = mmc_get_ops(dev); struct mmc *mmc = mmc_get_mmc_dev(dev); @@ -31,7 +31,7 @@ int mmc_get_b_max(struct mmc *mmc, void *dst, lbaint_t blkcnt) return dm_mmc_get_b_max(mmc->dev, dst, blkcnt); }
-int dm_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, +static int dm_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, struct mmc_data *data) { struct mmc *mmc = mmc_get_mmc_dev(dev); @@ -53,7 +53,7 @@ int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) return dm_mmc_send_cmd(mmc->dev, cmd, data); }
-int dm_mmc_set_ios(struct udevice *dev) +static int dm_mmc_set_ios(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -67,7 +67,7 @@ int mmc_set_ios(struct mmc *mmc) return dm_mmc_set_ios(mmc->dev); }
-int dm_mmc_wait_dat0(struct udevice *dev, int state, int timeout_us) +static int dm_mmc_wait_dat0(struct udevice *dev, int state, int timeout_us) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -81,7 +81,7 @@ int mmc_wait_dat0(struct mmc *mmc, int state, int timeout_us) return dm_mmc_wait_dat0(mmc->dev, state, timeout_us); }
-int dm_mmc_get_wp(struct udevice *dev) +static int dm_mmc_get_wp(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -95,7 +95,7 @@ int mmc_getwp(struct mmc *mmc) return dm_mmc_get_wp(mmc->dev); }
-int dm_mmc_get_cd(struct udevice *dev) +static int dm_mmc_get_cd(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -110,7 +110,7 @@ int mmc_getcd(struct mmc *mmc) }
#ifdef MMC_SUPPORTS_TUNING -int dm_mmc_execute_tuning(struct udevice *dev, uint opcode) +static int dm_mmc_execute_tuning(struct udevice *dev, uint opcode) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -126,7 +126,7 @@ int mmc_execute_tuning(struct mmc *mmc, uint opcode) #endif
#if CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT) -int dm_mmc_set_enhanced_strobe(struct udevice *dev) +static int dm_mmc_set_enhanced_strobe(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -142,7 +142,7 @@ int mmc_set_enhanced_strobe(struct mmc *mmc) } #endif
-int dm_mmc_hs400_prepare_ddr(struct udevice *dev) +static int dm_mmc_hs400_prepare_ddr(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -157,7 +157,7 @@ int mmc_hs400_prepare_ddr(struct mmc *mmc) return dm_mmc_hs400_prepare_ddr(mmc->dev); }
-int dm_mmc_host_power_cycle(struct udevice *dev) +static int dm_mmc_host_power_cycle(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -171,7 +171,7 @@ int mmc_host_power_cycle(struct mmc *mmc) return dm_mmc_host_power_cycle(mmc->dev); }
-int dm_mmc_deferred_probe(struct udevice *dev) +static int dm_mmc_deferred_probe(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
@@ -186,7 +186,7 @@ int mmc_deferred_probe(struct mmc *mmc) return dm_mmc_deferred_probe(mmc->dev); }
-int dm_mmc_reinit(struct udevice *dev) +static int dm_mmc_reinit(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev);
diff --git a/include/mmc.h b/include/mmc.h index 7f8ba2b017ee..6f943e78b740 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -539,18 +539,6 @@ struct dm_mmc_ops {
#define mmc_get_ops(dev) ((struct dm_mmc_ops *)(dev)->driver->ops)
-int dm_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, - struct mmc_data *data); -int dm_mmc_set_ios(struct udevice *dev); -int dm_mmc_get_cd(struct udevice *dev); -int dm_mmc_get_wp(struct udevice *dev); -int dm_mmc_execute_tuning(struct udevice *dev, uint opcode); -int dm_mmc_wait_dat0(struct udevice *dev, int state, int timeout_us); -int dm_mmc_host_power_cycle(struct udevice *dev); -int dm_mmc_deferred_probe(struct udevice *dev); -int dm_mmc_reinit(struct udevice *dev); -int dm_mmc_get_b_max(struct udevice *dev, void *dst, lbaint_t blkcnt); - /* Transition functions for compatibility */ int mmc_set_ios(struct mmc *mmc); int mmc_getcd(struct mmc *mmc);
Jaehoon Chung
