[U-Boot-Users] [PATCH] CFI: synchronize command offsets with Linux CFI driver
Fixes non-working CFI Flash on the Inka4x0 board.
Signed-off-by: Bartlomiej Sieka tur@semihalf.com --- This patch differs from what is being done by the Linux CFI driver in that it uses 0x05 as the interface code for x16/x32 chips, per "Common Flash Memory Interface Publication 100" dated December 1.
Tested on the following Flash chips: x8 (interface 0x00) in 8 bit mode x8/x16 (interface 0x02) in 8 bit mode x8/x16 (interface 0x02) in 16 bit mode
The patch should be applied on top of commit 81b20ccc2d795ae9a1199db5a50ad9c28d1e4d22 in the u-boot-cfi-flash repo.
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 66754cd..b748a9f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1231,9 +1231,26 @@ static int flash_detect_cfi (flash_info_t * info) debug ("port %d bits chip %d bits\n", info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); - /* this probably only works if info->interface == FLASH_CFI_X8X16 */ - info->addr_unlock1 = (info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555; - info->addr_unlock2 = (info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA; + + /* calculate command offsets as in the Linux driver */ + info->addr_unlock1 = 0x555; + info->addr_unlock2 = 0x2aa; + + /* + * modify the unlock address if we are + * in compatibility mode + */ + if ( /* x8/x16 in x8 mode */ + ((info->chipwidth == FLASH_CFI_BY8) && + (info->interface == FLASH_CFI_X8X16)) || + /* x16/x32 in x16 mode */ + ((info->chipwidth == FLASH_CFI_BY16) && + (info->interface == FLASH_CFI_X16X32))) + { + info->addr_unlock1 = 0xaaa; + info->addr_unlock2 = 0x555; + } + info->name = "CFI conformant"; return 1; } diff --git a/include/flash.h b/include/flash.h index 6e252cc..2ed1e20 100644 --- a/include/flash.h +++ b/include/flash.h @@ -80,6 +80,7 @@ typedef struct { #define FLASH_CFI_X8 0x00 #define FLASH_CFI_X16 0x01 #define FLASH_CFI_X8X16 0x02 +#define FLASH_CFI_X16X32 0x05
/* convert between bit value and numeric value */ #define CFI_FLASH_SHIFT_WIDTH 3
Why not like this:
if (((info->chipwidth == FLASH_CFI_BY8) && (info->interface == FLASH_CFI_X8X16)) || ((info->chipwidth == FLASH_CFI_BY16) && (info->interface == FLASH_CFI_X16X32))) { /* * Compatibility mode: * x8/x16 in x8 mode or * x16/x32 in x16 mode */ info->addr_unlock1 = 0xaaa; info->addr_unlock2 = 0x555; } else { /* default */ info->addr_unlock1 = 0x555; info->addr_unlock2 = 0x2aa; }
Thanks.
Best regards, Stefan
Stefan Roese wrote: [...]
Why not like this:
I copied the code from Linux CFI driver and kept it as is (modulo #define names). I'm fine with either of the two forms, although I think that there is some benefit in keeping borrowed code as intact as possible.
Regards, Bartlomiej
Why not like this:
Ahh, I see. Even this ugly "{" in the next line is present in the Linux code.
Right. So if nobody else protests here, I'll add your original version to the cfi repo soon.
Thanks.
I have a little problem while detecting the manufacturer and device IDs on a Spansion/AMD S29GL256N. It's a x8/x16 flash and set to run in x8 mode. When u-boot is trying to do the unlock sequence and retrieve the manufacturer and device IDs, since info->portwidth is still 2, it's writing to addrs 0x1554, 0xAAA, 0x1554 instead of addrs 0xaaa, 0x555, 0xaaa. I modified the code to temporary set info->portwidth to 1 before doing the unlock seq and retrieving the manufacturer & device IDs and then restore it back, then the ID retrievals work. Does anyone see the same problem as I do?
Thanks Donald
0x555;
0x2AA;
SF.Net email is sponsored by: Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://sourceforge.net/services/buy/index.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Bartlomiej Sieka
Hoi-Ho Chan
Stefan Roese
