[U-Boot] [PATCH] S5P: timer: replace bss variable by gd
Use the global data instead of bss variable, replace as follow. count_value -> timer_rate_hz timestamp -> timer_reset_value lastdec -> lastinc
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com cc: Heiko Schocher hs@denx.de --- arch/arm/cpu/armv7/s5p-common/timer.c | 48 +++++++++++++++------------------ 1 files changed, 22 insertions(+), 26 deletions(-)
diff --git a/arch/arm/cpu/armv7/s5p-common/timer.c b/arch/arm/cpu/armv7/s5p-common/timer.c index 651fd5d..0a1883f 100644 --- a/arch/arm/cpu/armv7/s5p-common/timer.c +++ b/arch/arm/cpu/armv7/s5p-common/timer.c @@ -28,6 +28,8 @@ #include <asm/arch/pwm.h> #include <asm/arch/clk.h>
+DECLARE_GLOBAL_DATA_PTR; + #define PRESCALER_1 (16 - 1) /* prescaler of timer 2, 3, 4 */ #define MUX_DIV_2 1 /* 1/2 period */ #define MUX_DIV_4 2 /* 1/4 period */ @@ -37,12 +39,6 @@
#define TCON_TIMER4_SHIFT 20
-static unsigned long count_value; - -/* Internal tick units */ -static unsigned long long timestamp; /* Monotonic incrementing timer */ -static unsigned long lastdec; /* Last decremneter snapshot */ - /* macro to read the 16 bit timer */ static inline struct s5p_timer *s5p_get_base_timer(void) { @@ -65,16 +61,16 @@ int timer_init(void) writel((PRESCALER_1 & 0xff) << 8, &timer->tcfg0); writel((MUX_DIV_2 & 0xf) << MUX4_DIV_SHIFT, &timer->tcfg1);
- /* count_value = 2085937.5(HZ) (per 1 sec)*/ - count_value = get_pwm_clk() / ((PRESCALER_1 + 1) * + /* timer_rate_hz = 2085937.5(HZ) (per 1 sec)*/ + gd->timer_rate_hz = get_pwm_clk() / ((PRESCALER_1 + 1) * (MUX_DIV_2 + 1));
- /* count_value / 100 = 20859.375(HZ) (per 10 msec) */ - count_value = count_value / 100; + /* timer_rate_hz / 100 = 20859.375(HZ) (per 10 msec) */ + gd->timer_rate_hz = gd->timer_rate_hz / 100;
/* set count value */ - writel(count_value, &timer->tcntb4); - lastdec = count_value; + writel(gd->timer_rate_hz, &timer->tcntb4); + gd->lastinc = gd->timer_rate_hz;
val = (readl(&timer->tcon) & ~(0x07 << TCON_TIMER4_SHIFT)) | TCON4_AUTO_RELOAD; @@ -85,7 +81,7 @@ int timer_init(void) /* start PWM timer 4 */ writel(val | TCON4_START, &timer->tcon);
- timestamp = 0; + gd->timer_reset_value = 0;
return 0; } @@ -105,7 +101,7 @@ unsigned long get_timer(unsigned long base)
void set_timer(unsigned long t) { - timestamp = t; + gd->timer_reset_value = t; }
/* delay x useconds */ @@ -114,7 +110,7 @@ void __udelay(unsigned long usec) struct s5p_timer *const timer = s5p_get_base_timer(); unsigned long tmo, tmp;
- count_value = readl(&timer->tcntb4); + gd->timer_rate_hz = readl(&timer->tcntb4);
if (usec >= 1000) { /* @@ -125,19 +121,19 @@ void __udelay(unsigned long usec) * 3. finish normalize. */ tmo = usec / 1000; - tmo *= (CONFIG_SYS_HZ * count_value / 10); + tmo *= (CONFIG_SYS_HZ * gd->timer_rate_hz / 10); tmo /= 1000; } else { /* else small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ * count_value / 10; + tmo = usec * CONFIG_SYS_HZ * gd->timer_rate_hz / 10; tmo /= (1000 * 1000); }
- /* get current timestamp */ + /* get current timer_reset_value */ tmp = get_timer(0);
/* if setting this fordward will roll time stamp */ - /* reset "advancing" timestamp to 0, set lastdec value */ + /* reset "advancing" timer_reset_value to 0, set lastinc value */ /* else, set advancing stamp wake up time */ if ((tmo + tmp + 1) < tmp) reset_timer_masked(); @@ -154,8 +150,8 @@ void reset_timer_masked(void) struct s5p_timer *const timer = s5p_get_base_timer();
/* reset time */ - lastdec = readl(&timer->tcnto4); - timestamp = 0; + gd->lastinc = readl(&timer->tcnto4); + gd->timer_reset_value = 0; }
unsigned long get_timer_masked(void) @@ -163,14 +159,14 @@ unsigned long get_timer_masked(void) struct s5p_timer *const timer = s5p_get_base_timer(); unsigned long now = readl(&timer->tcnto4);
- if (lastdec >= now) - timestamp += lastdec - now; + if (gd->lastinc >= now) + gd->timer_reset_value += gd->lastinc - now; else - timestamp += lastdec + count_value - now; + gd->timer_reset_value += gd->lastinc + gd->timer_rate_hz - now;
- lastdec = now; + gd->lastinc = now;
- return timestamp; + return gd->timer_reset_value; }
Dear Minkyu Kang,
I object against using variables wich have somewhat self-explanatory names for different purposes.
Dear Wolfgang Denk,
On 10 January 2011 01:14, Wolfgang Denk wd@denx.de wrote:
Dear Minkyu Kang,
Yes, I know. If so, do I have to add new variables at global_data? Maybe that is not good way too. How you think?
One more question, what is the purpose of tbl and tbu?
Thanks Minkyu Kang
Dear Minkyu Kang,
In message AANLkTikoZFrd9SYLg4v3AoqRFEd9bM0jpQQOi+Qzy6eg@mail.gmail.com you wrote:
I asked this several times before: ther eis currently ongoing efforts for aunified clock handling for ARM in the Linux kernel. Maybe we can benefit from this in any way?
tbl (time base, lower part) and tbu (time base, upper part) are the software representation of two 32 bit hardware registers available in Power Architecture systems, where they form a free-runnign 64 bit counter that starts automatically as soon as the CPU comes out of reeset.
There have been attempts to re-write the (sometimes somewhat obscure) timer implementations on ARM based on such a model.
Minkyu Kang
Minkyu Kang
