[U-Boot-Users] FW: CUSTODIANS: List of open issues / not applied patches
-----Original Message----- From: Peter Pearse [mailto:peter.pearse@arm.com] Sent: 10 January 2008 10:58 To: 'Wolfgang Denk' Subject: RE: [U-Boot-Users] CUSTODIANS: List of open issues / not applied patches
ACK
Regards
Peter
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Wolfgang Denk Sent: 09 January 2008 21:36 To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] CUSTODIANS: List of open issues /
not applied
patches
Hello everybody,
this is a heads-up especially for all custodians...
Please review the following list of postings / patches that
- to the
best of my knowledge - habve not been processed yet; at least I did not mark them as rejected, nor did I find them in the
current U-Boot
tree.
If possible, please apply and send pull requests ASAP! Thanks.
[It would be helpful to me if you could include my private
message ID
(the number in column 1) when referring to one of these
postings;
thanks.]
9799 09/18 urwithsughosh@gma Re: [U-Boot-Users] [PATCH]: Reset issue fix on mpc85xx 9804 09/18 Jason Jin [PATCH] fsl_pci_init Fix command register initialization issue. 9952 09/24 Anatolij Gustschi [U-Boot-Users] [PATCH] Add Fujitsu CoralP/Lime video driver 9967 09/24 Troy Kisky Re: [U-Boot-Users] PATCH - Fix oob data copied into supplied buffer 9969 09/25 Shinya Kuribayash Re: [U-Boot-Users] [MIPS] Make mips_io_port_base more generic 10068 09/28 Vasiliy Leoenenko [PATCH] M18 flash (Sibley) support (attempt 2) 10078 09/28 Dan Wilson [U-Boot-Users] [PATCH] tsec.c patch for receiver reset 10081 09/29 Shinya Kuribayash [MIPS] Make mips_io_port_base more generic 10159 10/04 Vlad Lungu [U-Boot-Users] [PATCH] Target support for qemu -M mips 10281 10/10 Vlad Lungu [PATCH] Fixed pcnet io_base 10282 10/10 Vlad Lungu [PATCH] Added Am79C970A chip id to pcnet 10397 10/12 Tony Li [U-Boot-Users] [PATCH] mpc83xx: Add ATM makefile entry for MPC8360EM 10676 10/22 Anton Vorontsov [U-Boot-Users] [PATCH] MPC8568E-MDS: reset UCCs to use them reliably 10686 10/23 Shinya Kuribayash Re: [U-Boot-Users] [PATCH 1/1] Fix mips_io_port_base multiple declar 10690 10/22 Anton Vorontsov [U-Boot-Users] [PATCH] MPC8568E-MDS: set up QE pario for UART1 10810 10/25
Johannes Stezenba
[U-Boot-Users] [patch 0/3] KB9202 CodeSourcery ARM EABI toolchain bu 11193 11/07 llandre [U-Boot-Users] [PATCH] ARM optimized memcpy/memmove routines 11230 11/09 "Martin Krause" RE: [U-Boot-Users] [PATCH] TQM5200B: update MTD partition layout 11473 11/19 Matthias Fuchs Re: [U-Boot-Users] flash hardware protection with CFI driver does no 11522 11/20 stefano babic [U-Boot-Users] [PATCH] Fix gcc issues in pxa-regs.h 11523 11/20 stefano babic [U-Boot-Users] [PATCH] MMC for PXA 27X (resubmit) 11635 11/23 sivaji [U-Boot-Users] MPC8548 problem in Boot Sequencer mode 11911 12/01 Daniel Mack Re: [U-Boot-Users] [PATCH] add support for Toradex Colibri module 11928 12/03 Yoshihiro Shimoda [PATCH] serial_sh: Add support for SH7720 11929 12/03 Yoshihiro Shimoda [PATCH] sh: Add support SH3
and SH7720
11930 12/03 Yoshihiro Shimoda [PATCH] Add support for MS7720RP02 board 12002 12/06 Ladislav Michl [U-Boot-Users] [PATCH] ARM: Fix at91rm9200dk base address 12003 12/06 Ladislav Michl [U-Boot-Users] [PATCH] ARM: AT91RM9200 based boards config cleanup 12007 12/07 Ladislav Michl [U-Boot-Users] [PATCH] ARM: Board voiceblue update 12044 12/08 Jean-Christophe P Re: [U-Boot-Users] PATCH:
add support
for MII-connected ethernet swi 12046 12/08 Jean-Christophe P Re: [U-Boot-Users] PATCH: ixp42x UART: support 230400bps, enable RTS 12057 12/09 Jean-Christophe P Re: [U-Boot-Users] PATCH:
add support
for MII-connected ethernet swi 12096 12/10 Jean-Christophe P [U-Boot-Users] [PATCH] bf537-stamp: remove already defined is_zero_e 12257 12/13 Jean-Christophe P [U-Boot-Users] [PATCH] Nios2: remove common/cmd_bdinfo.c unused vari 12382 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function on 12383 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM926: Remove compiler warning: target C 12384 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM: I2C Init function call in lib_arm/bo 12385 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM926: Display Ethernet info in do_bdinf 12390 12/19 Kumar Gala [U-Boot-Users] [PATCH] Reworked FSL Book-E TLB macros to be more rea 12392 12/19 Joakim Tjernlund Re: [U-Boot-Users] 83xx, FSL_UEC reducing boot latency, printf causi 12393 12/19 Stefan Roese [U-Boot-Users] fdt chosen node handling 12394 12/19 Joakim Tjernlund Re: [U-Boot-Users] 83xx, FSL_UEC reducing boot latency, printf causi 12395 12/19 "Gururaja Hebbar Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function on 12396 12/19 Dirk Behme Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function on 12404 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: arm920/s3c24xx: IRQ demulitplexer callba 12405 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: arm920t: Allow use of 'gd' pointer from 12408 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: s3c24xx: Multiple serial port support 12412 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: S3C24x0 SoC NAND controller support 12510 12/22 Jean-Christophe P [U-Boot-Users] [PATCH 1/1] qemu-mips: active HUSH PARSER, AUTO_COMPL 12548 12/25 Anton Vorontsov [U-Boot-Users] [PATCH] mpc83xx: UEC: add support for Broadcom BCM548 12549 12/25 Anton Vorontsov [U-Boot-Users] [PATCH] mpc83xx: add support for the MPC8360E-RDK 12602 12/27 Wolfgang Denk [U-Boot-Users] [PATCH] OMAP5912: fix FIFO handling in UART driver 12818 01/04 Jon Loeliger [U-Boot-Users] [PATCH] Convert MPC8610HPCD to use libfdt. 12820 01/04 Timur Tabi Re: [U-Boot-Users] [PATCH] 8610: Fix lingering compile warnings. 12859 01/07 Timur Tabi [U-Boot-Users] [PATCH v2] 85xx: add ability to upload QE firmware 12866 01/07 Kumar Gala Re: [U-Boot-Users] [PATCH] MPC85xx KGDB support 12870 01/08 Kumar Gala [U-Boot-Users] [PATCH] 85xx: Remove cache config from configs.h 12934 01/08 Ben Warren [U-Boot-Users] [PATCH] Fix Ethernet init() return codes 12938 01/08 Ben Warren [U-Boot-Users] [PATCH V2] Fix Ethernet init() return codes.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk &
Detlev Zundel
HRB 165235 Munich, Office: Kirchenstr.5, D-82194
Groebenzell, Germany
Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Applying computer technology is simply finding
the right
wrench to pound in the correct screw.
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.n
et/marketplace
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
In message 000401c85396$9bee3aa0$9a4d010a@Emea.Arm.com you wrote:
ACK
I have to admit that I don't really understand what you want to tell us. Does that we will see a pull request for u-boot-arm soon?
Wolfgang Here's the status of the unapplied ARM patches (in your list), sorry it took so long.
10810 10/25 Johannes Stezenba [U-Boot-Users] [patch 0/3] KB9202 CodeSourcery ARM EABI toolchain bu Declined - compiler specific plus code change required, rather than #define change Full ARM compile option patch to come mov r0, r0, #constant patch to come
11193 11/07 llandre [U-Boot-Users] [PATCH] ARM optimized memcpy/memmove routines In test - currently still contains kernel depencies
12002 12/06 Ladislav Michl [U-Boot-Users] [PATCH] ARM: Fix at91rm9200dk base address Ready @ git://linux-arm.org/u-boot-armdev.git#071206_at91_base
12003 12/06 Ladislav Michl [U-Boot-Users] [PATCH] ARM: AT91RM9200 based boards config cleanup Ready @ git://linux-arm.org/u-boot-armdev.git#071206_at91_bdinfo
12007 12/07 Ladislav Michl [U-Boot-Users] [PATCH] ARM: Board voiceblue update Ready @ git://linux-arm.org/u-boot-armdev.git#071212_voiceblue
12382 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function on * 12383 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM926: Remove compiler warning: target C * 12384 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM: I2C Init function call in lib_arm/bo * All still under consideration 12385 12/18 Hebbar Re: [U-Boot-Users] [PATCH] ARM926: Display Ethernet info in do_bdinf * I believe some will be covered 12395 12/19 "Gururaja Hebbar Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function on * my the compiler options patch 12396 12/19 Dirk Behme Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function on *
12404 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: arm920/s3c24xx: IRQ demulitplexer callba Ready @ git://linux-arm.org/u-boot-armdev.git#071219_s3c2410_irq
12405 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: arm920t: Allow use of 'gd' pointer from Ready @ git://linux-arm.org/u-boot-armdev.git#071219_s3c24_gd
12408 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: s3c24xx: Multiple serial port support Ready @ git://linux-arm.org/u-boot-armdev.git#071219_s3c24_serial
12412 12/19 Harald Welte [U-Boot-Users] [PATCH] ARM: S3C24x0 SoC NAND controller support Ready @ git://linux-arm.org/u-boot-armdev.git#071219_s3c24_nand
Harald and Ladislav's patches have all been checked to build with MAKEALL arm, mips, ppc
Would it be helpful if I made one branch with all (7) of their patches applied?
Regards
Peter
Peter Pearse
