[U-Boot] Compiling with arm-eabi and YAFFS2
U-Boot 2009.08 fails to compile with the arm-eabi compiler (V4.1.0 and V4.3.1) when YAFFS2 support is enabled (CONFIG_YAFFS2 defined as 1). It reports undefined symbols. (JFFS2 support compiles successfully.)
Having investigated, it appears that a work around is to create dummy functions as follows:
#ifdef CONFIG_YAFFS2 /* * These stub functions are needed when using the arm-eabi compiler with YAFFS2 * support. This is a complete hack and will probably need to be revised. * (Chris Isbell 23rd October 2009.) */ void abort(void) {
void __exidx_start(void) {
void __exidx_end(void) {
} #endif
For convenience, I included these temporarily with my board-specific initialisation code - which is clearly not a good place.
Has anyone else run into this problem and is there a more elegant solution?
Thanks,
- These stub functions are needed when using the arm-eabi compiler with
YAFFS2
- support. This is a complete hack and will probably need to be revised.
- (Chris Isbell 23rd October 2009.)
} #endif
Which board are you using ? Can you supply the $(CROSS_COMPILE)-gcc -v ?
Thanks Tom
Thanks,
YAFFS2
} #endif
Thanks Tom
Thanks,
Tom,
Board is Ronetix PM9263.
The gcc version is reported as:
Using built-in specs. Target: arm-eabi Configured with: /home/jingyu/projects/gcc/android-toolchain/gcc-4.4.0/configure --prefix=/usr/local --target=arm-eabi --host=i686-pc-linux-gnu --build=i686-pc-linux-gnu --enable-languages=c,c++ --with-gmp=/home/jingyu/projects/gcc/toolchain_build/obj/temp-install --with-mpfr=/home/jingyu/projects/gcc/toolchain_build/obj/temp-install --disable-libssp --enable-threads --disable-nls --disable-libmudflap --disable-libgomp --disable-libstdc__-v3 --disable-sjlj-exceptions --disable-shared --with-float=soft --with-fpu=vfp --with-arch=armv5te --enable-target-optspace --with-abi=aapcs --with-gcc-version=4.4.0 --with-binutils-version=2.19 --with-arch=armv5te --with-sysroot=/home/jingyu/projects/gcc/toolchain_build/cupcake_rel_root --with-gmp-version=4.2.4 --with-mpfr-version=2.4.1 --with-gdb-version=6.6 --program-transform-name='s,^,arm-eabi-,' Thread model: single gcc version 4.4.0 (GCC)
(I am using the tool chain from the Google Android V1.5 open source project - http://source.android.com/download.)
Thanks,
Chris.
if u use eabi compiler to compile u-boot,there r some error. why not use abi compiler for u-boot.it can compile successful
2009/10/26 Chris Isbell chris.isbell@cdsrail.com
YAFFS2
revised.
} #endif
Thanks Tom
Thanks,
Tom,
Thanks,
Chris.
-- Chris Isbell Systems Integration Manager, CDSRail Fareham, Hampshire, UK. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
In my android work. I use a separate compiler for the u-boot and kernel, the Code Sourcery arm lite edition. http://www.codesourcery.com/sgpp/editions.html#lite
Please try this. Tom
YAFFS2
revised.
} #endif
Thanks Tom
Thanks,
Tom,
Thanks,
Chris.
YAFFS2
revised.
} #endif
Thanks Tom
Thanks,
Tom,
Thanks,
Chris.
Tom, Jello,
I am trying to keep to a single tool chain to compile everything; this is less to maintain and less to go wrong. With the crude changes I have made, U-Boot compiles and works with the standard Google Android tool chain. It would be nice to find a more elegant solution, but I can live with what I have. Hopefully my posting may also assist others who also encounter this problem.
Thanks,
Chris.
Chris Isbell
Jello huang
Tom
