[U-Boot-Users] How console redirection is done
Can anybody say me in which part of uboot console redirection configuration is done. i.e.,how console redirection to serial port is done in the uboot.
I am sorry, I can not understand the question. U-boot always outputs to serial port. If you would like to change to another serial port look at the configuration file corresponding to your board under include/configs.
Hi Ori,
thank you for your reply. Actually how the console redirection is done in the uboot, ie., how it is implemented in the code. In which file of Uboot the module that will do console redirection is present ?
-- Ori Idan
On 7/13/07, yasosyaso yasothabalanr@gmail.com wrote:
Can anybody say me in which part of uboot console redirection configuration is done. i.e.,how console redirection to serial port is done in the uboot. -- View this message in context: http://www.nabble.com/How-console-redirection-is-done-tf4072301.html#a115733... Sent from the Uboot - Users mailing list archive at Nabble.com.
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
"Ori Idan" ori@helicontech.co.il wrote in message news:65487840707122317ve675e94x222e48968a8a730b@mail.gmail.com...
That's not exactly true. After the initial console (bootup) you can use more than serial.
There are a few functions like drv_lcd_init in lcd.c that create a device_t structure -- in my version they're all called within devices_init in common/devices.c during boot. This defines a putc, puts, getc, and tstc to handle I/O character by character. Once you call device_register() it will available to the system. Using the environment variables stdin, stdout, and stderr you can choose which device is active, and console.c calls the appropriate function pointer. Set the variable and you can be printing on the LCD instead.
Of course all this can be changed with a million CONFIG_ parameters, and it is a little strange if you have several consoles available and no default.
-joey
-joey
Actually here I want to do console redirection through USB port.
To do that first I want to know how serial console redirection is done in the UBOOT code. i.e., how in uboot the "serial console redirection" is implemented.
For console redirection there should be some code, somewhere in the UBoot. I want to know how and where(in file,in which function) the console redirection is implemented. [I have found how the configuration is done for console redirection]
Thanks yaso
-joey
Joey Oravec
Ori Idan
yasosyaso
