[U-Boot] [PATCH 0/3] sunxi: display: Add overscan correction
Hi Anatolij, Ian,
This series sits on top of the composite video out series Ian has just reviewed.
The first 2 patches are preparation patches adding support for stride != width to the cfbconsole code. Anatolij, can you either merge these 2 through your tree, or give us your ack for merging these through the sunxi tree ?
Thanks & Regards,
Hans
The passed in width is always VIDEO_COLS. This is a preparation patch for adding stride != width support to the cfbconsole code.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- drivers/video/cfb_console.c | 21 ++++++++------------- 1 file changed, 8 insertions(+), 13 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 7f2ddc1..d122ef7 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1826,20 +1826,16 @@ int video_display_bitmap(ulong bmp_image, int x, int y) static int video_logo_xpos; static int video_logo_ypos;
-static void plot_logo_or_black(void *screen, int width, int x, int y, \ - int black); +static void plot_logo_or_black(void *screen, int x, int y, int black);
-static void logo_plot(void *screen, int width, int x, int y) +static void logo_plot(void *screen, int x, int y) { - plot_logo_or_black(screen, width, x, y, 0); + plot_logo_or_black(screen, x, y, 0); }
static void logo_black(void) { - plot_logo_or_black(video_fb_address, \ - VIDEO_COLS, \ - video_logo_xpos, \ - video_logo_ypos, \ + plot_logo_or_black(video_fb_address, video_logo_xpos, video_logo_ypos, 1); }
@@ -1858,11 +1854,11 @@ U_BOOT_CMD( " " );
-static void plot_logo_or_black(void *screen, int width, int x, int y, int black) +static void plot_logo_or_black(void *screen, int x, int y, int black) {
int xcount, i; - int skip = (width - VIDEO_LOGO_WIDTH) * VIDEO_PIXEL_SIZE; + int skip = (VIDEO_COLS - VIDEO_LOGO_WIDTH) * VIDEO_PIXEL_SIZE; int ycount = video_logo_height; unsigned char r, g, b, *logo_red, *logo_blue, *logo_green; unsigned char *source; @@ -1880,7 +1876,7 @@ static void plot_logo_or_black(void *screen, int width, int x, int y, int black) y = max(0, (int)(VIDEO_VISIBLE_ROWS - VIDEO_LOGO_HEIGHT + y + 1)); #endif /* CONFIG_SPLASH_SCREEN_ALIGN */
- dest = (unsigned char *)screen + (y * width + x) * VIDEO_PIXEL_SIZE; + dest = (unsigned char *)screen + (y * VIDEO_COLS + x) * VIDEO_PIXEL_SIZE;
#ifdef CONFIG_VIDEO_BMP_LOGO source = bmp_logo_bitmap; @@ -2009,8 +2005,7 @@ static void *video_logo(void) } #endif /* CONFIG_SPLASH_SCREEN */
- logo_plot(video_fb_address, VIDEO_COLS, - video_logo_xpos, video_logo_ypos); + logo_plot(video_fb_address, video_logo_xpos, video_logo_ypos);
#ifdef CONFIG_SPLASH_SCREEN_ALIGN /*
Acked-by: Anatolij Gustschin agust@denx.de
cfbconsole currently assumes that the width and stride of the framebuffer are the same, in most places where stride matters it uses a VIDEO_LINE_LEN helper macro.
This commit changes the few places not using VIDEO_LINE_LEN to also use VIDEO_LINE_LEN, and protects the default VIDEO_LINE_LEN with a #ifndef guard, allowing the boards config.h to override and, and thus support cases where stride != width.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- drivers/video/cfb_console.c | 72 +++++++++++++++++++++++---------------------- 1 file changed, 37 insertions(+), 35 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index d122ef7..30e0317 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -283,9 +283,10 @@ void console_cursor(int state);
#define VIDEO_COLS VIDEO_VISIBLE_COLS #define VIDEO_ROWS VIDEO_VISIBLE_ROWS -#define VIDEO_SIZE (VIDEO_ROWS*VIDEO_COLS*VIDEO_PIXEL_SIZE) -#define VIDEO_PIX_BLOCKS (VIDEO_SIZE >> 2) -#define VIDEO_LINE_LEN (VIDEO_COLS*VIDEO_PIXEL_SIZE) +#ifndef VIDEO_LINE_LEN +#define VIDEO_LINE_LEN (VIDEO_COLS * VIDEO_PIXEL_SIZE) +#endif +#define VIDEO_SIZE (VIDEO_ROWS * VIDEO_LINE_LEN) #define VIDEO_BURST_LEN (VIDEO_COLS/8)
#ifdef CONFIG_VIDEO_LOGO @@ -1306,7 +1307,7 @@ static int display_rle8_bitmap(struct bmp_image *img, int xoff, int yoff, struct palette p[256]; struct bmp_color_table_entry cte; int green_shift, red_off; - int limit = VIDEO_COLS * VIDEO_ROWS; + int limit = (VIDEO_LINE_LEN / VIDEO_PIXEL_SIZE) * VIDEO_ROWS; int pixels = 0;
x = 0; @@ -1314,7 +1315,8 @@ static int display_rle8_bitmap(struct bmp_image *img, int xoff, int yoff, ncolors = __le32_to_cpu(img->header.colors_used); bpp = VIDEO_PIXEL_SIZE; fbp = (unsigned char *) ((unsigned int) video_fb_address + - (((y + yoff) * VIDEO_COLS) + xoff) * bpp); + (y + yoff) * VIDEO_LINE_LEN + + xoff * bpp);
bm = (uchar *) img + __le32_to_cpu(img->header.data_offset);
@@ -1368,8 +1370,8 @@ static int display_rle8_bitmap(struct bmp_image *img, int xoff, int yoff, y--; fbp = (unsigned char *) ((unsigned int) video_fb_address + - (((y + yoff) * VIDEO_COLS) + - xoff) * bpp); + (y + yoff) * VIDEO_LINE_LEN + + xoff * bpp); continue; case 1: /* end of bitmap data marker */ @@ -1381,8 +1383,8 @@ static int display_rle8_bitmap(struct bmp_image *img, int xoff, int yoff, y -= bm[3]; fbp = (unsigned char *) ((unsigned int) video_fb_address + - (((y + yoff) * VIDEO_COLS) + - x + xoff) * bpp); + (y + yoff) * VIDEO_LINE_LEN + + xoff * bpp); bm += 4; break; default: @@ -1561,7 +1563,7 @@ int video_display_bitmap(ulong bmp_image, int x, int y)
bmap = (uchar *) bmp + le32_to_cpu(bmp->header.data_offset); fb = (uchar *) (video_fb_address + - ((y + height - 1) * VIDEO_COLS * VIDEO_PIXEL_SIZE) + + ((y + height - 1) * VIDEO_LINE_LEN) + x * VIDEO_PIXEL_SIZE);
#ifdef CONFIG_VIDEO_BMP_RLE8 @@ -1597,7 +1599,7 @@ int video_display_bitmap(ulong bmp_image, int x, int y) cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * + fb -= VIDEO_LINE_LEN + width * VIDEO_PIXEL_SIZE; } break; @@ -1628,8 +1630,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) *fb++ = *bmap++; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF__8BIT_332RGB: @@ -1642,8 +1644,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_15BIT_555RGB: @@ -1666,8 +1668,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) #endif } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_16BIT_565RGB: @@ -1680,8 +1682,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_32BIT_X888RGB: @@ -1694,8 +1696,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_24BIT_888RGB: @@ -1708,8 +1710,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) cte.blue); } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; } @@ -1728,8 +1730,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_15BIT_555RGB: @@ -1751,8 +1753,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_16BIT_565RGB: @@ -1765,8 +1767,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_32BIT_X888RGB: @@ -1779,8 +1781,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; case GDF_24BIT_888RGB: @@ -1793,8 +1795,8 @@ int video_display_bitmap(ulong bmp_image, int x, int y) bmap += 3; } bmap += padded_line; - fb -= (VIDEO_VISIBLE_COLS + width) * - VIDEO_PIXEL_SIZE; + fb -= VIDEO_LINE_LEN + width * + VIDEO_PIXEL_SIZE; } break; default: @@ -1858,7 +1860,7 @@ static void plot_logo_or_black(void *screen, int x, int y, int black) {
int xcount, i; - int skip = (VIDEO_COLS - VIDEO_LOGO_WIDTH) * VIDEO_PIXEL_SIZE; + int skip = VIDEO_LINE_LEN - VIDEO_LOGO_WIDTH * VIDEO_PIXEL_SIZE; int ycount = video_logo_height; unsigned char r, g, b, *logo_red, *logo_blue, *logo_green; unsigned char *source; @@ -1876,7 +1878,7 @@ static void plot_logo_or_black(void *screen, int x, int y, int black) y = max(0, (int)(VIDEO_VISIBLE_ROWS - VIDEO_LOGO_HEIGHT + y + 1)); #endif /* CONFIG_SPLASH_SCREEN_ALIGN */
- dest = (unsigned char *)screen + (y * VIDEO_COLS + x) * VIDEO_PIXEL_SIZE; + dest = (unsigned char *)screen + y * VIDEO_LINE_LEN + x * VIDEO_PIXEL_SIZE;
Add support for making the visual area of the framebuffer smaller and drawing a black border around it. This is intended for use with overscanning monitors (esp. with composite video out), to avoid part of the picture being invisible.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- doc/README.video | 5 +++++ drivers/video/sunxi_display.c | 48 +++++++++++++++++++++++++++++++++--------- include/configs/sunxi-common.h | 1 + 3 files changed, 44 insertions(+), 10 deletions(-)
diff --git a/doc/README.video b/doc/README.video index 4f7a4b5..62ac17b 100644 --- a/doc/README.video +++ b/doc/README.video @@ -68,6 +68,11 @@ The sunxi u-boot driver supports the following video-mode options: overrides the xres, yres and refresh from the video-mode env. variable. Defaults to edid=1.
+- overscan_x/overscan_y=<int> - Set x/y overscan value + This configures a black border on the left and right resp. top and bottom + to deal with overscanning displays. Defaults to overscan_x=32 and + overscan_y=20 for composite monitors, 0 for other monitors. + For example to always use the hdmi connector, even if no cable is inserted, using edid info when available and otherwise initalizing it at 1024x768@60Hz, use: "setenv video-mode sunxi:1024x768-24@60,monitor=dvi,hpd=0,edid=1". diff --git a/drivers/video/sunxi_display.c b/drivers/video/sunxi_display.c index 1868185..1449e0d 100644 --- a/drivers/video/sunxi_display.c +++ b/drivers/video/sunxi_display.c @@ -19,6 +19,7 @@ #include <fdtdec.h> #include <fdt_support.h> #include <i2c.h> +#include <malloc.h> #include <video_fb.h> #include "videomodes.h" #include "hitachi_tx18d42vm_lcd.h" @@ -51,6 +52,7 @@ struct sunxi_display { GraphicDevice graphic_device; enum sunxi_monitor monitor; unsigned int depth; + unsigned int fb_addr; unsigned int fb_size; } sunxi_display;
@@ -1297,9 +1299,10 @@ void *video_hw_init(void) #ifdef CONFIG_VIDEO_HDMI int ret, hpd, hpd_delay, edid; #endif + int i, overscan_offset, overscan_x, overscan_y; + unsigned int fb_dma_addr; char mon[16]; char *lcd_mode = CONFIG_VIDEO_LCD_MODE; - int i;
memset(&sunxi_display, 0, sizeof(struct sunxi_display));
@@ -1310,6 +1313,8 @@ void *video_hw_init(void) hpd_delay = video_get_option_int(options, "hpd_delay", 500); edid = video_get_option_int(options, "edid", 1); #endif + overscan_x = video_get_option_int(options, "overscan_x", -1); + overscan_y = video_get_option_int(options, "overscan_y", -1); sunxi_display.monitor = sunxi_get_default_mon(true); video_get_option_string(options, "monitor", mon, sizeof(mon), sunxi_get_mon_desc(sunxi_display.monitor)); @@ -1386,8 +1391,20 @@ void *video_hw_init(void) break; }
+ /* Yes these defaults are quite high, overscan on composite sucks... */ + if (overscan_x == -1) + overscan_x = sunxi_is_composite() ? 32 : 0; + if (overscan_y == -1) + overscan_y = sunxi_is_composite() ? 20 : 0; + sunxi_display.fb_size = (mode->xres * mode->yres * 4 + 0xfff) & ~0xfff; + overscan_offset = (overscan_y * mode->xres + overscan_x) * 4; + /* We want to keep the fb_base for simplefb page aligned, where as + * the sunxi dma engines will happily accept an unaligned address. */ + if (overscan_offset) + sunxi_display.fb_size += 0x1000; + if (sunxi_display.fb_size > CONFIG_SUNXI_MAX_FB_SIZE) { printf("Error need %dkB for fb, but only %dkB is reserved\n", sunxi_display.fb_size >> 10, @@ -1395,25 +1412,37 @@ void *video_hw_init(void) return NULL; }
- printf("Setting up a %dx%d%s %s console\n", mode->xres, mode->yres, + printf("Setting up a %dx%d%s %s console (overscan %dx%d)\n", + mode->xres, mode->yres, (mode->vmode == FB_VMODE_INTERLACED) ? "i" : "", - sunxi_get_mon_desc(sunxi_display.monitor)); + sunxi_get_mon_desc(sunxi_display.monitor), + overscan_x, overscan_y);
gd->fb_base = gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size - sunxi_display.fb_size; sunxi_engines_init(); - sunxi_mode_set(mode, gd->fb_base - CONFIG_SYS_SDRAM_BASE); + + fb_dma_addr = gd->fb_base - CONFIG_SYS_SDRAM_BASE; + sunxi_display.fb_addr = gd->fb_base; + if (overscan_offset) { + fb_dma_addr += 0x1000 - (overscan_offset & 0xfff); + sunxi_display.fb_addr += (overscan_offset + 0xfff) & ~0xfff; + memset((void *)gd->fb_base, 0, sunxi_display.fb_size); + flush_cache(gd->fb_base, sunxi_display.fb_size); + } + sunxi_mode_set(mode, fb_dma_addr);
/* * These are the only members of this structure that are used. All the * others are driver specific. There is nothing to decribe pitch or * stride, but we are lucky with our hw. */ - graphic_device->frameAdrs = gd->fb_base; + graphic_device->frameAdrs = sunxi_display.fb_addr; graphic_device->gdfIndex = GDF_32BIT_X888RGB; graphic_device->gdfBytesPP = 4; - graphic_device->winSizeX = mode->xres; - graphic_device->winSizeY = mode->yres; + graphic_device->winSizeX = mode->xres - 2 * overscan_x; + graphic_device->winSizeY = mode->yres - 2 * overscan_y; + graphic_device->plnSizeX = mode->xres * graphic_device->gdfBytesPP;
return graphic_device; } @@ -1490,10 +1519,9 @@ int sunxi_simplefb_setup(void *blob) return ret; }
- ret = fdt_setup_simplefb_node(blob, offset, gd->fb_base, + ret = fdt_setup_simplefb_node(blob, offset, sunxi_display.fb_addr, graphic_device->winSizeX, graphic_device->winSizeY, - graphic_device->winSizeX * graphic_device->gdfBytesPP, - "x8r8g8b8"); + graphic_device->plnSizeX, "x8r8g8b8"); if (ret) eprintf("Cannot setup simplefb: Error setting properties\n");
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index a2cbcf5..83b6556 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -302,6 +302,7 @@ extern int soft_i2c_gpio_scl; #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_STD_TIMINGS #define CONFIG_I2C_EDID +#define VIDEO_LINE_LEN (pGD->plnSizeX)
/* allow both serial and cfb console. */ #define CONFIG_CONSOLE_MUX
+> > overscan_offset = (overscan_y * mode->xres + overscan_x) * 4; +> > /* We want to keep the fb_base for simplefb page aligned, where as +> > * the sunxi dma engines will happily accept an unaligned address. */ +> > if (overscan_offset) +> > > sunxi_display.fb_size += 0x1000;
Why plus 4K regardless of the magnitude of overscan_offset? What if it was 0x1004?
Also, what's the link between fb_base's alignment and fb_size which is implied by the comment?
-> > sunxi_mode_set(mode, gd->fb_base - CONFIG_SYS_SDRAM_BASE);
+> > fb_dma_addr = gd->fb_base - CONFIG_SYS_SDRAM_BASE; +> > sunxi_display.fb_addr = gd->fb_base; +> > if (overscan_offset) { +> > > fb_dma_addr += 0x1000 - (overscan_offset & 0xfff); +> > > sunxi_display.fb_addr += (overscan_offset + 0xfff) & ~0xfff; +> > > memset((void *)gd->fb_base, 0, sunxi_display.fb_size); +> > > flush_cache(gd->fb_base, sunxi_display.fb_size); +> > }
Hrm, I think this starts to answer, but I'm still not sure I follow, sorry.
- These are the only members of this structure that are used. All the
- others are driver specific. There is nothing to decribe pitch or
Pre-existing typo "describe".
If overscan offset is 0x1004 then we make the simplefb start point to fb_base + 0x2000:
sunxi_display.fb_addr = gd->fb_base sunxi_display.fb_addr += (overscan_offset + 0xfff) & ~0xfff
And make the dma engine start at fb_base + 0xffc:
fb_dma_addr = gd->fb_base fb_dma_addr += 0x1000 - (overscan_offset & 0xfff)
Notice how we make the dma_engine start at less then 0x1000 offset of fb_base, so making fb_size 0x1000 larger is enough.
Basically to page-align the start of the simplefb / sunxi_display.fb_addr we only need a single page, the rest we can get by offsetting sunxi_display.fb_addr from fb_base by a multiple of the page size.
To align we need a page extra size as the dma-engine may start at an offset of up-to a page-size from gd->fb_base and the dma-engine will dma a full framebuffer size, including the black borders.
Correct this is the answer, sorry for the tricky maths, this is the best solution without wasting a ton of memory with large overscans.
I hope the above explanation helps, if not keep asking.
Will fix,
Regards,
Hans
On Wed, 2015-08-12 at 14:44 +0200, Hans de Goede wrote:
[...big snip...]
It very much did, thanks.
Acked-by: Ian Campbell ijc@hellion.org.uk
On 08/12/2015 12:45 PM, Ian Campbell wrote:
<snip>
Actually part of the overscan patch series is adding support for pitch != width to the cfbconsole code, so that comment is no longer accurate, I've squashed a fix for the comment into the patch adding overscan support to drivers/video/sunxi_display.c
Regards,
Hans
Hi Hans,
On Wed, 5 Aug 2015 17:17:28 +0200 Hans de Goede hdegoede@redhat.com wrote: ...
I've replied with acks, please merge through the sunxi tree.
Thanks,
Anatolij
Anatolij Gustschin
Hans de Goede
Ian Campbell
