[PATCH v2 1/4] ARM: dts: imx: Make DRAM coding GPIOs available before relocation on Data Modul i.MX8M Mini/Plus eDM SBC
The DRAM configuration GPIO straps must be accessible in SPL and before relocation because the GPIOs are sampled both in U-Boot SPL as well as early on in U-Boot proper. The already present bootph-pre-ram DT property made the GPIO controllers available in SPL, but not early on in U-Boot proper, which made gpio_request_list_by_name_nodev() in board dmo_get_memcfg() fail. Add missing bootph-some-ram DT property to all GPIO controllers which are referenced in dmo,ram-coding-gpios DT property to make those GPIO controllers available early in U-Boot proper as well.
Fixes: 8c103c33fb14 ("dm: dts: Convert driver model tags to use new schema") Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- NOTE: For v2025.01 --- V2: Switch from bootph-all which covers TPL as well to bootph-some-ram which covers only U-Boot pre-reloc phase --- arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi | 1 + arch/arm/dts/imx8mp-data-modul-edm-sbc-u-boot.dtsi | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi b/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi index a235e088fa4..fb6951026d9 100644 --- a/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi @@ -77,6 +77,7 @@
&gpio2 { bootph-pre-ram; + bootph-some-ram;
dsi-reset-hog { bootph-pre-ram; diff --git a/arch/arm/dts/imx8mp-data-modul-edm-sbc-u-boot.dtsi b/arch/arm/dts/imx8mp-data-modul-edm-sbc-u-boot.dtsi index 805b5f57955..1e82e718b8f 100644 --- a/arch/arm/dts/imx8mp-data-modul-edm-sbc-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-data-modul-edm-sbc-u-boot.dtsi @@ -64,6 +64,7 @@
&gpio3 { bootph-pre-ram; + bootph-some-ram;
bl-enable-hog { bootph-pre-ram; @@ -92,6 +93,7 @@
&gpio4 { bootph-pre-ram; + bootph-some-ram;
In case gpio_request_list_by_name_nodev() in board dmo_get_memcfg() returns error code, pick a safe default DRAM configuration instead of bailing out with some sort of hang() or panic(). The BIT(2)|BIT(0) strap option is the lowest known option of 2 GiB , use that.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- NOTE: For v2025.01 --- V2: No change --- board/data_modul/common/common.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/data_modul/common/common.c b/board/data_modul/common/common.c index b5f83908771..9e35dc5d6cb 100644 --- a/board/data_modul/common/common.c +++ b/board/data_modul/common/common.c @@ -47,6 +47,9 @@ u8 dmo_get_memcfg(void) "dmo,ram-coding-gpios", gpio, ARRAY_SIZE(gpio), GPIOD_IS_IN); + if (ret < 0) + return BIT(2) | BIT(0); + for (i = 0; i < ret; i++) memcfg |= !!dm_gpio_get_value(&(gpio[i])) << i;
The current A/B switching preparatory altbootcmd is confusing to users, replace it with plain 'run bootcmd' which can be replaced by proper A/B switching altbootcmd when the matching updater is added on top of the platform. By default, keep the boot counter incrementing, but do not do any A/B partition switching.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- NOTE: For v2025.01 --- V2: No change --- include/configs/imx8mm_data_modul_edm_sbc.h | 2 +- include/configs/imx8mp_data_modul_edm_sbc.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index d323f84ac7a..57ecb5e2190 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -34,7 +34,7 @@ #define CFG_SYS_FSL_ESDHC_ADDR 0
#define CFG_EXTRA_ENV_SETTINGS \ - "altbootcmd=setenv devpart 2 && run bootcmd ; reset\0" \ + "altbootcmd=run bootcmd\0" \ "bootlimit=3\0" \ "devtype=mmc\0" \ "devpart=1\0" \ diff --git a/include/configs/imx8mp_data_modul_edm_sbc.h b/include/configs/imx8mp_data_modul_edm_sbc.h index f953847ce05..de5bdd30e18 100644 --- a/include/configs/imx8mp_data_modul_edm_sbc.h +++ b/include/configs/imx8mp_data_modul_edm_sbc.h @@ -24,7 +24,7 @@ #define FEC_QUIRK_ENET_MAC
Deduplicate defconfigs for all Data Modul i.MX8M eDM SBC systems by factoring out the common parts into generic imx8m_data_modul.config and including those using the #include <configs/...> preprocessor macro in the current set of board specific defconfigs. The preprocessor macro is applicable to defconfigs as well.
This introduces no functional change, the resulting .config is almost identical for all Data Modul i.MX8M eDM SBC systems, except for slight alignment in DEBUG_UART and SYS_PBSIZE.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- NOTE: Would be nice to have in v2025.01 --- V2: - Add CONFIG_ARM and CONFIG_ARCH_IMX8M to each defconfig to make buildman recognize the defconfig as arm64 one - Sort the configs - Move DEBUG_UART and SYS_PBSIZE config into imx8m_data_modul.config --- configs/imx8m_data_modul.config | 221 +++++++++++++++ configs/imx8mm_data_modul_edm_sbc_defconfig | 256 ++--------------- configs/imx8mp_data_modul_edm_sbc_defconfig | 291 +++----------------- 3 files changed, 279 insertions(+), 489 deletions(-) create mode 100644 configs/imx8m_data_modul.config
diff --git a/configs/imx8m_data_modul.config b/configs/imx8m_data_modul.config new file mode 100644 index 00000000000..2164c754915 --- /dev/null +++ b/configs/imx8m_data_modul.config @@ -0,0 +1,221 @@ +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_INPUT is not set +# CONFIG_SPI_FLASH_UNLOCK_ALL is not set +# CONFIG_SPL_DM_USB is not set +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_ARCH_IMX8M=y +CONFIG_ARCH_MISC_INIT=y +CONFIG_ARM=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_BOOTCOMMAND="run dmo_update_env ; load ${devtype} ${devnum}:${devpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BKOPS_ENABLE=y +CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_BTRFS=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_CAT=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_DHCP6=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_FS_UUID=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_KASLRSEED=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MBR=y +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_CMD_PART=y +CONFIG_CMD_PING=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_PXE=y +CONFIG_CMD_READ=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_SHA1SUM=y +CONFIG_CMD_SMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_SYSBOOT=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TIME=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_UUID=y +CONFIG_CMD_WGET=y +CONFIG_CMD_XXD=y +CONFIG_CONSOLE_MUX=y +CONFIG_CRC32_VERIFY=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x30880000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DFU_MMC=y +CONFIG_DFU_MTD=y +CONFIG_DFU_RAM=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_TIMEOUT=y +CONFIG_DM_ETH_PHY=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_MDIO=y +CONFIG_DM_MTD=y +CONFIG_DM_PMIC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_THERMAL=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_OFFSET=0xFFFC0000 +CONFIG_ENV_OFFSET_REDUND=0xFFFC0000 +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FEC_MXC=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_FSL_CAAM=y +CONFIG_FSL_USDHC=y +CONFIG_GPIO_HOG=y +CONFIG_HASH_VERIFY=y +CONFIG_HUSH_PARSER=y +CONFIG_I2C_EEPROM=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_IMX_BOOTAUX=y +CONFIG_IMX_TMU=y +CONFIG_IMX_WATCHDOG=y +CONFIG_IPV6=y +CONFIG_IP_DEFRAG=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_MII=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_SPEED_MODE_SET=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MTD=y +CONFIG_MTDIDS_DEFAULT="nor0=flash@0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" +CONFIG_MXC_GPIO=y +CONFIG_MXC_SPI=y +CONFIG_MXC_UART=y +CONFIG_NETCONSOLE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_OF_CONTROL=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_BROADCOM=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_PROT_TCP_SACK=y +CONFIG_REGMAP=y +CONFIG_RGMII=y +CONFIG_RTC_M41T62=y +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SHA1SUM_VERIFY=y +CONFIG_SPI=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPL=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_GPIO=y +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_I2C=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_MMC=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_POWER=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_SYSRESET=y +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SYSCON=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 +CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_SYS_BOOTM_LEN=0x8000000 +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 +CONFIG_SYS_EEPROM_SIZE=16384 +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_SYS_MONITOR_LEN=1048576 +CONFIG_SYS_PBSIZE=2081 +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_TEXT_BASE=0x40200000 +CONFIG_TFTP_TSIZE=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_FUNCTION_ACM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Data Modul" +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_HUB_USB251XB=y +CONFIG_USB_STORAGE=y +CONFIG_USE_BOOTARGS=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_USE_PREBOOT=y +CONFIG_VERSION_VARIABLE=y diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig index 105fbfb4d9b..7c9d4ee1844 100644 --- a/configs/imx8mm_data_modul_edm_sbc_defconfig +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -1,242 +1,28 @@ +#include <configs/imx8m_data_modul.config> + CONFIG_ARM=y CONFIG_ARCH_IMX8M=y -CONFIG_TEXT_BASE=0x40200000 -CONFIG_SYS_MALLOC_LEN=0x1000000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SF_DEFAULT_SPEED=50000000 -CONFIG_ENV_SIZE=0x40000 -CONFIG_ENV_OFFSET=0xFFFC0000 -CONFIG_IMX_CONFIG="board/data_modul/imx8mm_edm_sbc/imximage.cfg" -CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mm-data-modul-edm-sbc" CONFIG_TARGET_IMX8MM_DATA_MODUL_EDM_SBC=y -CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_DM_RESET=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 -CONFIG_SPL_STACK=0x920000 -CONFIG_SPL_TEXT_BASE=0x7E1000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x910000 -CONFIG_SPL_BSS_MAX_SIZE=0x2000 -CONFIG_SYS_BOOTM_LEN=0x8000000 -CONFIG_SYS_LOAD_ADDR=0x60000000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_ENV_OFFSET_REDUND=0xFFFC0000 -CONFIG_IMX_BOOTAUX=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 -CONFIG_SPL_LOAD_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run dmo_update_env ; load ${devtype} ${devnum}:${devpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" -CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="run dmo_preboot" -CONFIG_DEFAULT_FDT_FILE="imx8mm-data-modul-edm-sbc.dtb" -CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_PBSIZE=2074 -CONFIG_CONSOLE_MUX=y -CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_LATE_INIT=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -CONFIG_SPL_LEGACY_IMAGE_FORMAT=y -CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 -CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 -CONFIG_SPL_SYS_MMCSD_RAW_MODE=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -CONFIG_SPL_I2C=y -CONFIG_SPL_POWER=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_WATCHDOG=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot=> " -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_BOOTM_PLAN9 is not set -# CONFIG_BOOTM_RTEMS is not set -# CONFIG_BOOTM_VXWORKS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_EXPORTENV is not set -CONFIG_CMD_ERASEENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -CONFIG_SYS_EEPROM_SIZE=16384 -CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 -CONFIG_CMD_MD5SUM=y -CONFIG_MD5SUM_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_SHA1SUM=y -CONFIG_SHA1SUM_VERIFY=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_GPT_RENAME=y -CONFIG_CMD_I2C=y -CONFIG_CMD_LSBLK=y -CONFIG_CMD_MBR=y -CONFIG_CMD_MMC=y -CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_MMC_SPEED_MODE_SET=y -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_READ=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_SDP=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_CAT=y -CONFIG_CMD_XXD=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_WGET=y -CONFIG_CMD_PXE=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_GETTIME=y -CONFIG_CMD_KASLRSEED=y -CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_UUID=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_SMC=y -CONFIG_HASH_VERIFY=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_FS_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y -CONFIG_MTDIDS_DEFAULT="nor0=flash@0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" -CONFIG_PARTITION_TYPE_GUID=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_PART=1 -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NETCONSOLE=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 -CONFIG_SPL_CLK_COMPOSITE_CCF=y -CONFIG_CLK_COMPOSITE_CCF=y -CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CI_UDC=y CONFIG_CLK_IMX8MM=y -CONFIG_FSL_CAAM=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_TIMEOUT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_MTD=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x20000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_GPIO_HOG=y -CONFIG_MXC_GPIO=y -CONFIG_DM_I2C=y -# CONFIG_INPUT is not set -CONFIG_USB_HUB_USB251XB=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_SPL_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_ES_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -# CONFIG_SPI_FLASH_UNLOCK_ALL is not set -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHYLIB=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_PHY_ATHEROS=y -CONFIG_PHY_BROADCOM=y -CONFIG_DM_MDIO=y -CONFIG_DM_ETH_PHY=y -CONFIG_FEC_MXC=y -CONFIG_RGMII=y -CONFIG_MII=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_IMX8M=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8M_POWER_DOMAIN=y -CONFIG_DM_PMIC=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-data-modul-edm-sbc" +CONFIG_DEFAULT_FDT_FILE="imx8mm-data-modul-edm-sbc.dtb" CONFIG_DM_PMIC_BD71837=y -CONFIG_SPL_DM_PMIC_BD71837=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_BD71837=y +CONFIG_IMX_CONFIG="board/data_modul/imx8mm_edm_sbc/imximage.cfg" +CONFIG_PHYLIB=y +CONFIG_PREBOOT="run dmo_preboot" +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BSS_START_ADDR=0x910000 +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_DM_PMIC_BD71837=y CONFIG_SPL_DM_REGULATOR_BD71837=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_RNG=y -CONFIG_DM_RTC=y -CONFIG_RTC_M41T62=y -CONFIG_DM_SERIAL=y -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_PSCI=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_TMU=y -CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Data Modul" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_CI_UDC=y -CONFIG_USB_FUNCTION_ACM=y -CONFIG_IMX_WATCHDOG=y +CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y +CONFIG_SPL_LEGACY_IMAGE_FORMAT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_STACK=0x920000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_SYS_LOAD_ADDR=0x60000000 diff --git a/configs/imx8mp_data_modul_edm_sbc_defconfig b/configs/imx8mp_data_modul_edm_sbc_defconfig index f809d23d6d2..ea8109bf049 100644 --- a/configs/imx8mp_data_modul_edm_sbc_defconfig +++ b/configs/imx8mp_data_modul_edm_sbc_defconfig @@ -1,271 +1,54 @@ +#include <configs/imx8m_data_modul.config> + CONFIG_ARM=y CONFIG_ARCH_IMX8M=y -CONFIG_TEXT_BASE=0x40200000 -CONFIG_SYS_MALLOC_LEN=0x1000000 -CONFIG_SYS_MALLOC_F_LEN=0x18000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SF_DEFAULT_SPEED=50000000 -CONFIG_ENV_SIZE=0x40000 -CONFIG_ENV_OFFSET=0xFFFC0000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mp-data-modul-edm-sbc" CONFIG_TARGET_IMX8MP_DATA_MODUL_EDM_SBC=y -CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_DM_RESET=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 -CONFIG_SPL_STACK=0x96fc00 -CONFIG_SPL_TEXT_BASE=0x920000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x96fc00 -CONFIG_SPL_BSS_MAX_SIZE=0x400 -CONFIG_SYS_BOOTM_LEN=0x8000000 -CONFIG_SYS_LOAD_ADDR=0x50000000 -CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_DEBUG_UART_BASE=0x30880000 -CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_ENV_OFFSET_REDUND=0xFFFC0000 -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_DEBUG_UART=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 -CONFIG_SPL_LOAD_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run dmo_update_env ; load ${devtype} ${devnum}:${devpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" -CONFIG_USE_PREBOOT=y +CONFIG_CLK_IMX8MP=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mp-data-modul-edm-sbc" CONFIG_DEFAULT_FDT_FILE="imx8mp-data-modul-edm-sbc.dtb" -CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_PBSIZE=2081 -CONFIG_CONSOLE_MUX=y -CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_MAX_SIZE=0x25000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_BOOTROM_SUPPORT=y -# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 -CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 -CONFIG_SPL_SYS_MMCSD_RAW_MODE=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_POWER=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x58000 -CONFIG_SPL_WATCHDOG=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot=> " -# CONFIG_BOOTM_NETBSD is not set -# CONFIG_BOOTM_PLAN9 is not set -# CONFIG_BOOTM_RTEMS is not set -# CONFIG_BOOTM_VXWORKS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_EXPORTENV is not set -CONFIG_CMD_ERASEENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -CONFIG_SYS_EEPROM_SIZE=16384 -CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 -CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 -CONFIG_CMD_MD5SUM=y -CONFIG_MD5SUM_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_SHA1SUM=y -CONFIG_SHA1SUM_VERIFY=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_GPT_RENAME=y -CONFIG_CMD_I2C=y -CONFIG_CMD_LSBLK=y -CONFIG_CMD_MBR=y -CONFIG_CMD_MMC=y -CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_MMC_SPEED_MODE_SET=y -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_READ=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_SDP=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_CAT=y -CONFIG_CMD_XXD=y -CONFIG_CMD_DHCP6=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_WGET=y -CONFIG_CMD_PXE=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_GETTIME=y -CONFIG_CMD_KASLRSEED=y -CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_UUID=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_SMC=y -CONFIG_HASH_VERIFY=y -CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_FS_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y -CONFIG_MTDIDS_DEFAULT="nor0=flash@0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" -CONFIG_PARTITION_TYPE_GUID=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_DM_USB_GADGET=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_PART=1 -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NETCONSOLE=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_TSIZE=y -CONFIG_PROT_TCP_SACK=y -CONFIG_IPV6=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 -CONFIG_SPL_CLK_COMPOSITE_CCF=y -CONFIG_CLK_COMPOSITE_CCF=y -CONFIG_SPL_CLK_IMX8MP=y -CONFIG_CLK_IMX8MP=y -CONFIG_FSL_CAAM=y +CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y CONFIG_IMX8M_DRAM_INLINE_ECC=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_TIMEOUT=y -CONFIG_DFU_MMC=y -CONFIG_DFU_MTD=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x20000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_GPIO_HOG=y -CONFIG_SPL_GPIO_HOG=y -CONFIG_MXC_GPIO=y -CONFIG_DM_I2C=y -# CONFIG_INPUT is not set CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y -CONFIG_USB_HUB_USB251XB=y -CONFIG_I2C_EEPROM=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_SPL_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_SPL_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_ES_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -# CONFIG_SPI_FLASH_UNLOCK_ALL is not set -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_PHY_ATHEROS=y -CONFIG_PHY_BROADCOM=y +CONFIG_PHY_IMX8MQ_USB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_DM_MDIO=y -CONFIG_DM_ETH_PHY=y -CONFIG_DWC_ETH_QOS=y -CONFIG_DWC_ETH_QOS_IMX=y -CONFIG_FEC_MXC=y -CONFIG_RGMII=y -CONFIG_MII=y -CONFIG_PHY_IMX8MQ_USB=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_PINCTRL_IMX8M=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8M_POWER_DOMAIN=y -CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y -CONFIG_DM_PMIC=y -CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_BSS_MAX_SIZE=0x400 +CONFIG_SPL_BSS_START_ADDR=0x96fc00 +CONFIG_SPL_CLK_IMX8MP=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 CONFIG_SPL_DM_PMIC_PCA9450=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_PCA9450=y CONFIG_SPL_DM_REGULATOR_PCA9450=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_RNG=y -CONFIG_DM_RTC=y -CONFIG_RTC_M41T62=y -CONFIG_DM_SERIAL=y -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_PSCI=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_TMU=y -CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y -CONFIG_USB_EHCI_HCD=y +CONFIG_SPL_DM_SPI=y +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_GPIO_HOG=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_SPL_MAX_SIZE=0x25000 +CONFIG_SPL_MMC_UHS_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_STACK=0x96fc00 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_TEXT_BASE=0x920000 +CONFIG_SYS_LOAD_ADDR=0x50000000 +CONFIG_SYS_MALLOC_F_LEN=0x18000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x58000 CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Data Modul" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_USB_FUNCTION_ACM=y CONFIG_USB_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETH_CDC=y -CONFIG_IMX_WATCHDOG=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_XHCI_HCD=y
NOTE: For v2025.01
Applied all for master, thanks.
Fabio Estevam
