[U-Boot] [PATCH 2/2] powerpc/t104xrdb: Add T1042RDB_PI board support
T1042RDB_PI is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture™ processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market.
T1042RDB_PI is similar to T1040RDB board with few differences like it has video interface, supports T1042 personality
T1042RDB_PI board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: — PCI — SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs — Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - Other IO - Two Serial ports - ProfiBus port - Four I2C ports
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- Based on u-boot-mpc85xx/next branch.
board/freescale/t104xrdb/README | 38 ++ boards.cfg | 1 + include/configs/T1042RDB_PI.h | 709 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 748 insertions(+), 0 deletions(-) create mode 100644 include/configs/T1042RDB_PI.h
diff --git a/board/freescale/t104xrdb/README b/board/freescale/t104xrdb/README index e8848ee..2cd8219 100644 --- a/board/freescale/t104xrdb/README +++ b/board/freescale/t104xrdb/README @@ -4,6 +4,10 @@ The T1040RDB is a Freescale reference board that hosts the T1040 SoC (and variants). Variants inclued T1042 presonality of T1040, in which case T1040RDB can also be called T1042RDB.
+The T1042RDB_PI is a Freescale reference board that hosts the T1042 SoC. +(a personality of T1040 SoC). The board is similar to T1040RDB but is +designed specially with low power features targeted for Printing Image Market. + T1040 SoC Overview ------------------ The QorIQ T1040/T1042 processor support four integrated 64-bit e5500 PA @@ -97,6 +101,40 @@ T1040RDB board Overview - Two Serial ports - Four I2C ports
+T1042RDB_PI board Overview +------------------------- + - SERDES Connections, 8 lanes information: + 1, 2, 3, 4 : PCIe x4 slot + 5: mini PCIe connector + 6: mini PCIe connector + 7: NA + 8: SATA connector + - DDR Controller + - Supports rates of up to 1600 MHz data-rate + - Supports one DDR3LP UDIMM/RDIMMs, of single-, dual- or quad-rank types. + - IFC/Local Bus + - NAND flash: 1GB 8-bit NAND flash + - NOR: 128MB 16-bit NOR Flash + - Ethernet + - Two on-board RGMII 10/100/1G ethernet ports. + - CPLD + - Clocks + - System and DDR clock (SYSCLK, “DDRCLK”) + - SERDES clocks + - Video + - DIU supports video at up to 1280x1024x32bpp + - Power Supplies + - USB + - Supports two USB 2.0 ports with integrated PHYs + - Two type A ports with 5V@1.5A per port. + - SDHC + - SDHC/SDXC connector + - SPI + - On-board 64MB SPI flash + - Other IO + - Two Serial ports + - Four I2C ports + Memory map ----------- The addresses in brackets are physical addresses. diff --git a/boards.cfg b/boards.cfg index 33714fe..b040b66 100644 --- a/boards.cfg +++ b/boards.cfg @@ -959,6 +959,7 @@ Active powerpc mpc85xx - freescale t4qds Active powerpc mpc85xx - freescale t4qds T4240QDS_SRIO_PCIE_BOOT T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - Active powerpc mpc85xx - freescale t1040qds T1040QDS T1040QDS:PPC_T1040 Naveen Burmi NaveenBurmi@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1040RDB T1040RDB:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI T1042RDB_PI:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD controlcenterd:36BIT,SDCARD Dirk Eibach eibach@gdsys.de Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD_DEVELOP controlcenterd:36BIT,SDCARD,DEVELOP Dirk Eibach eibach@gdsys.de Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER controlcenterd:TRAILBLAZER,SPIFLASH Dirk Eibach eibach@gdsys.de diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h new file mode 100644 index 0000000..0d0296a --- /dev/null +++ b/include/configs/T1042RDB_PI.h @@ -0,0 +1,709 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * T1042RDB_PI board configuration file + */ +#define CONFIG_T104xRDB +#define CONFIG_T1042RDB_PI +#define CONFIG_PHYS_64BIT + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_E500MC /* BOOKE e500mc family */ +#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ +#define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ +#define CONFIG_MP /* support multiple processors */ + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ +#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS +#define CONFIG_FSL_IFC /* Enable IFC Support */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_PCIE1 /* PCIE controler 1 */ +#define CONFIG_PCIE2 /* PCIE controler 2 */ +#define CONFIG_PCIE3 /* PCIE controler 3 */ +#define CONFIG_PCIE4 /* PCIE controler 4 */ + +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + +#ifndef CONFIG_SYS_NO_FLASH +#if defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (512 * 1105) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif +#else /* CONFIG_SYS_NO_FLASH */ +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 66666666 + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_SYS_CACHE_STASHING +#define CONFIG_BACKSIDE_L2_CACHE +#define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_DDR_ECC +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#define CONFIG_ENABLE_36BIT_PHYS + +#define CONFIG_ADDR_MAP +#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ + +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 + +#define CONFIG_SYS_DCSRBAR 0xf0000000 +#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull + +/* + * DDR Setup + */ +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) + +#define CONFIG_DDR_SPD +#define CONFIG_SYS_DDR_RAW_TIMING +#define CONFIG_FSL_DDR3 + +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS 0x51 + +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_FLASH_BASE 0xe8000000 +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) + +#define CONFIG_SYS_NOR_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1A) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} + +/* CPLD on IFC */ +#define CONFIG_SYS_CPLD_BASE 0xffdf0000 +#define CONFIG_SYS_CPLD_BASE_PHYS (0xf00000000ull | CONFIG_SYS_CPLD_BASE) +#define CONFIG_SYS_CSPR2 (CSPR_PHYS_ADDR(CONFIG_SYS_CPLD_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK2 IFC_AMASK(64*1024) +#define CONFIG_SYS_CSOR2 0x0 +/* CPLD Timing parameters for IFC CS2 */ +#define CONFIG_SYS_CS2_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS2_FTIM1 (FTIM1_GPCM_TACO(0x0e) | \ + FTIM1_GPCM_TRAD(0x1f)) +#define CONFIG_SYS_CS2_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS2_FTIM3 0x0 + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) + +#define CONFIG_SYS_NAND_CSPR_EXT (0xf) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ + | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ + | CSOR_NAND_SPRZ_224/* Spare size = 224 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_DDR_LAW 11 +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) + +#if defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R + +#define CONFIG_HWCONFIG + +/* define to use L1 as initial stack */ +#define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +/* Serial Port - controlled on board with jumper J8 + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) +#define CONFIG_SERIAL_MULTI /* Enable both serial ports */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_FSL /* Use FSL common I2C driver */ +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed in Hz */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_SPEED 400000 /* I2C speed in Hz */ +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x119000 + +/* I2C bus multiplexer */ +#define I2C_MUX_PCA_ADDR 0x70 + +/* + * RTC configuration + */ +#define RTC +#define CONFIG_RTC_DS1337 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 + +/*DVI encoder*/ +#define CONFIG_HDMI_ENCODER_I2C_ADDR 0x75 + +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +#ifdef CONFIG_PCI +/* controller 1, direct to uli, tgtid 3, Base address 20000 */ +#ifdef CONFIG_PCIE1 +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#endif + +/* controller 2, Slot 2, tgtid 2, Base address 201000 */ +#ifdef CONFIG_PCIE2 +#define CONFIG_SYS_PCIE2_MEM_VIRT 0x90000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc10000000ull +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#endif + +/* controller 3, Slot 1, tgtid 1, Base address 202000 */ +#ifdef CONFIG_PCIE3 +#define CONFIG_SYS_PCIE3_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc20000000ull +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#endif + +/* controller 4, Base address 203000 */ +#ifdef CONFIG_PCIE4 +#define CONFIG_SYS_PCIE4_MEM_VIRT 0xb0000000 +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc30000000ull +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE4_IO_VIRT 0xf8030000 +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ +#endif + +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_E1000 + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_PCI */ + +/* SATA */ +#define CONFIG_FSL_SATA_V2 +#ifdef CONFIG_FSL_SATA_V2 +#define CONFIG_LIBATA +#define CONFIG_FSL_SATA + +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_SATA1 +#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA + +#define CONFIG_LBA48 +#define CONFIG_CMD_SATA +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#endif + +/* +* USB +*/ +#define CONFIG_HAS_FSL_DR_USB + +#ifdef CONFIG_HAS_FSL_DR_USB +#define CONFIG_USB_EHCI + +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 +#endif +#endif + +#define CONFIG_MMC + +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 25 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 25 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME + +/* Default address of microcode for the Linux Fman driver */ +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 545KB (1089 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif /* CONFIG_NOBQFMAN */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_TERANETICS +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x10 +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x11 +#endif + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x10 +#define CONFIG_SYS_FM1_DTSEC6_PHY_ADDR 0x11 +#define CONFIG_SYS_FM1_10GEC1_PHY_ADDR 4 + +#define CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR 0x1c +#define CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR 0x1d +#define CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR 0x1e +#define CONFIG_SYS_FM1_DTSEC4_RISER_PHY_ADDR 0x1f + +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Environment + */ +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SETEXPR + +#ifdef CONFIG_PCI +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server*/ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /*-1 disables auto-boot*/ + +#define CONFIG_BAUDRATE 115200 + +#define __USB_PHY_TYPE utmi + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \ + "bank_intlv=cs0_cs1;" \ + "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t1040rdb_pi/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t1040rdb_pi/t1040rdb_pi.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#endif + +#endif /* __CONFIG_H */
Don't copy and paste random stuff without understanding it.
-Scott
Priyanka Jain
Scott Wood
