[U-Boot] USE_HOSTCC in lib/rsa/rsa-verify.c
Hi Simon,
Could you please explain the used of #ifndef(USE_HOSTCC) in the rsa_verify_key function in rsa-verify.c? I've written a HW hashing driver and need to use the software mod-exp function as we don't have a hardware driver for this (yet.) I get all kinds of compilation errors if USE_HOSTCC is explicitely defined (say in a config header.) You're advice would be appreciated.
Regards,
Andre.
Hi Andre,
On 28 June 2015 at 19:03, Andre Wolokita andre.wolokita@analog.com wrote:
Hi Simon,
It's there to allow the host compiler to build it - I think it is used by the fit_check_sign tool to check that the signature matches.
You shouldn't define USE_HOSTCC unless you are building host tools. If you are building for a target then it should use the target compiler.
Regards,
Andre.
-- Andre Wolokita (andre.wolokita@analog.com) Design Engineer, Analog Devices Australia Pty Ltd Unit 3, 97 Lewis Road, Wantirna, Victoria, 3152, AUSTRALIA Direct: +61 3 9881 9933 Main: +61 3 9881 9999 Fax: +61 3 9881 9988 Web: www.analog.com/au
Embedded & Digital Signal Processing Software.
This communication is proprietary and confidential.
Probably not!
Andre Wolokita
