[PATCH 11/16] lib: enable lzma decompression support for SPL build
This patch enables LZMA decompression support for SPL build
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- lib/Kconfig | 5 +++++ lib/Makefile | 1 + 2 files changed, 6 insertions(+)
diff --git a/lib/Kconfig b/lib/Kconfig index 965cf7bc03..2f38e37802 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -418,6 +418,11 @@ config SPL_LZ4 fast compression and decompression speed. It belongs to the LZ77 family of byte-oriented compression schemes.
+config SPL_LZMA + bool "Enable LZMA decompression support for SPL build" + help + This enables support for LZMA compression altorithm for SPL boot. + config SPL_LZO bool "Enable LZO decompression support in SPL" help diff --git a/lib/Makefile b/lib/Makefile index 1fb650cd90..8e51eec01c 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -64,6 +64,7 @@ obj-$(CONFIG_$(SPL_)ZLIB) += zlib/ obj-$(CONFIG_$(SPL_)ZSTD) += zstd/ obj-$(CONFIG_$(SPL_)GZIP) += gunzip.o obj-$(CONFIG_$(SPL_)LZO) += lzo/ +obj-$(CONFIG_$(SPL_)LZMA) += lzma/ obj-$(CONFIG_$(SPL_)LZ4) += lz4_wrapper.o
obj-$(CONFIG_LIBAVB) += libavb/
+config SPL_LZMA
- bool "Enable LZMA decompression support for SPL build"
- help
%s/altorithm/algorithm/g
Why do we need yet another algorithm for compression?
Doesn't Zstandard provide a much faster decompression? Cf. https://sites.google.com/site/powturbo/home/web-compression
Best regards
Heinrich
- config SPL_LZO bool "Enable LZO decompression support in SPL" help
+config SPL_LZMA
- help
Best regards
Heinrich
Hi Heinrich,
I need an algorithm with the maximum compression ratio to reduce the size of the u-boot payload as much as possible.
I believe currently lzma and xz are the best choices. Refer to: https://catchchallenger.first-world.info/wiki/Quick_Benchmark:_Gzip_vs_Bzip2...
Although they will take longer time for compression and decompression, considering that the u-boot payload is usually small (<= 1MiB), there will not be significant effect on decompression time.
Best Regards,
Weijie
+config SPL_LZMA
- help
Best regards
Heinrich
Hi Heinrich,
Where does zstd fall in the list however? Can you please try that and report back? Thanks!
+config SPL_LZMA
- help
Best regards
Heinrich
Hi Heinrich,
My purpose is to reduce the size of u-boot binary, and my plan is to compress the payload and the SPL decompress it at runtime. I need smallest size here, not fastest decompression speed.
So there are two points must be taken into consideration: the size of the decompressor (i.e. u-boot-spl.bin) and the size of the compressed payload (u-boot.bin.gz/bz2/...).
Below is my test results, including all compression algorithms supported by uImage, plus zstd:
Platform: mips - mt7628
Uncompressed size of u-boot.bin: 302736 (295KiB)
Commands for compression: gzip -c -f -k -9 bzip2 -c -f -k -9 lzma -c -z -k -9 lzop -c -f -9 lz4 -f -9 zstd --ultra -f
Results: algo. | spl.bin size | compressed size | % of uncomp | total size ------------------------------------------------------------------------ gzip | 26232 (25.6K) | 141207 (137KiB) | 46.64% | 167439 (163KiB) ------------------------------------------------------------------------ bzip2 | 30616 (29.8K) | 135403 (132KiB) | 44.72% | 166019 (162KiB) ------------------------------------------------------------------------ lzma | 18920 (18.4K) | 112660 (110KiB) | 37.21% | 131580 (128KiB) ------------------------------------------------------------------------ lzo | 13288 (12.9K) | 152409 (148KiB) | 50.34% | 165697 (161KiB) ------------------------------------------------------------------------ lz4 | 12408 (12.1K) | 167311 (163KiB) | 55.27% | 179719 (175KiB) ------------------------------------------------------------------------ zstd | 44824 (43.7K) | 149765 (146KiB) | 49.47% | 194589 (190KiB)
As you can see lzma has the best compression ratio. The is the reason I chose lzma here.
Best Regards
+config SPL_LZMA
- help
Best regards
Heinrich
Hi Heinrich,
Thanks, that's exactly the kind of data I was looking for.
Weijie Gao
