[U-Boot] [PATCH v4] at91: Add support for Bluewater Systems Snapper 9G45 module
Snapper 9G45 is a ARM9-based CPU module with 1GB NAND and 128MB DDR SDRAM. This patch includes NAND and Ethernet support.
Signed-off-by: Simon Glass sglass@bluewatersys.com --- Changes in v2: - Removed unneeded i2c config - Added machine type define
Changes in v3: - Use CONFIG_MACH_TYPE instead of custom code - Reduce PHY reset delay to minimum required
Changes in v4: - Add MAINTAINERS entry and update Snapper boards since Ryan has moved - Fix ip= bootarg error - Remove I2C as this is not needed
MAINTAINERS | 3 +- board/bluewater/snapper9g45/Makefile | 43 ++++++++ board/bluewater/snapper9g45/snapper9g45.c | 151 +++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/snapper9g45.h | 157 +++++++++++++++++++++++++++++ 5 files changed, 354 insertions(+), 1 deletions(-) create mode 100644 board/bluewater/snapper9g45/Makefile create mode 100644 board/bluewater/snapper9g45/snapper9g45.c create mode 100644 include/configs/snapper9g45.h
diff --git a/MAINTAINERS b/MAINTAINERS index 576fea8..c12ee54 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -300,10 +300,11 @@ Dan Malek dan@embeddedalley.com stxssa MPC85xx stxxtc MPC8xx
-Ryan Mallon ryan@bluewatersys.com +Simon Glass sglass@bluewatersys.com
snapper9260 ARM926EJS (AT91SAM9260 SoC) snapper9g20 ARM926EJS (AT91SAM9G20 SoC) + snapper9g45 ARM926EJS (AT91SAM9G45 SoC)
Eran Man eran@nbase.co.il
diff --git a/board/bluewater/snapper9g45/Makefile b/board/bluewater/snapper9g45/Makefile new file mode 100644 index 0000000..9016e5a --- /dev/null +++ b/board/bluewater/snapper9g45/Makefile @@ -0,0 +1,43 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += snapper9g45.o + +SRCS := $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/bluewater/snapper9g45/snapper9g45.c b/board/bluewater/snapper9g45/snapper9g45.c new file mode 100644 index 0000000..4e5afb1 --- /dev/null +++ b/board/bluewater/snapper9g45/snapper9g45.c @@ -0,0 +1,151 @@ +/* + * (C) Copyright 2011 Bluewater Systems Ltd + * Author: Andre Renaud andre@bluewatersys.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9g45_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hardware.h> +#include <net.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void macb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + /* Enable clock */ + writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + + /* + * Disable pull-up on: + * RXDV (PA15) => PHY normal mode (not Test mode) / CRSDV + * ERX0 (PA12) => PHY ADDR0 / RXD0 + * ERX1 (PA13) => PHY ADDR1 => PHYADDR = 0x0 / RXD1 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA12) | + pin_to_mask(AT91_PIN_PA13), + &pioa->pudr); + + /* Need to reset PHY -> needs 100us, so use minimum reset period */ + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + + /* The phy internal reset take 21ms */ + mdelay(21); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA12) | + pin_to_mask(AT91_PIN_PA13), + &pioa->puer); + + at91_macb_hw_init(); +} + +static void nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Enable CS3 as NAND/SmartMedia */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} + +int board_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + /* Enable PIO clocks */ + writel((1 << ATMEL_ID_PIOA) | + (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC | + (1 << ATMEL_ID_PIODE)), &pmc->pcer); + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + /* Initialise peripherals */ + at91_seriald_hw_init(); + nand_hw_init(); + + macb_hw_init(); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + return macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x1b); +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} diff --git a/boards.cfg b/boards.cfg index 604becf..b6123c2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -94,6 +94,7 @@ at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 +snapper9g45 arm arm926ejs snapper9g45 bluewater at91 snapper9g45:AT91SAM9G45 sbc35_a9g20_nandflash arm arm926ejs sbc35_a9g20 calao at91 sbc35_a9g20:AT91SAM9G20,SYS_USE_NANDFLASH sbc35_a9g20_eeprom arm arm926ejs sbc35_a9g20 calao at91 sbc35_a9g20:AT91SAM9G20,SYS_USE_EEPROM tny_a9g20_nandflash arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9G20,SYS_USE_NANDFLASH diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h new file mode 100644 index 0000000..30181ad --- /dev/null +++ b/include/configs/snapper9g45.h @@ -0,0 +1,157 @@ +/* + * Bluewater Systems Snapper 9G45 modules + * + * (C) Copyright 2011 Bluewater Systems + * Author: Andre Renaud andre@bluewatersys.com + * Author: Ryan Mallon ryan@bluewatersys.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* SoC type is defined in boards.cfg */ +#include <asm/hardware.h> +#include <asm/sizes.h> + +#define CONFIG_SYS_TEXT_BASE 0x70000000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_HZ 1000 + +/* CPU */ +#define CONFIG_ARCH_CPU_INIT + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_FIT + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS6 +#define CONFIG_SYS_SDRAM_SIZE (128 * 1024 * 1024) /* 128MB */ +#define CONFIG_SYS_INIT_SP_ADDR (ATMEL_BASE_SRAM + 0x1000 - \ + GENERATED_GBL_DATA_SIZE) + +/* Mem test settings */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + (1024 * 1024)) + +/* NAND flash */ +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 /*0x40000000*/ +#define CONFIG_SYS_NAND_DBW_8 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* AD21 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) /* AD22 */ +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC8 + +/* Ethernet */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_TFTP_PORT +#define CONFIG_TFTP_TSIZE + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW +#define CONFIG_DOS_PARTITION +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* _UHP_OHCI_BASE */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE + +/* GPIOs and IO expander */ +#define CONFIG_AT91_LEGACY +#define CONFIG_ATMEL_LEGACY +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_GPIO_PULLUP 1 + +/* UARTs/Serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } +#define CONFIG_SYS_PROMPT "Snapper> " + +/* Boot options */ +#define CONFIG_SYS_LOAD_ADDR 0x71000000 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* Environment settings */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (512 << 10) +#define CONFIG_ENV_SIZE (256 << 10) +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BOOTARGS "console=ttyS0,115200 ip=dhcp" + +/* Console settings */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_EXTBDINFO +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* U-Boot memory settings */ +#define CONFIG_SYS_MALLOC_LEN (1 << 20) +#define CONFIG_STACKSIZE (256 << 10) +#define CONFIG_MACH_TYPE 2817 + +/* Command line configuration */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_FAT +#undef CONFIG_CMD_GPIO +#define CONFIG_CMD_USB +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND + +#endif
Dear Simon Glass,
are you still interested getting this in mainline? It does not apply cleanly on current u-boot-atmel HEAD, please rebase on top of current u-boot-atmel. And please fix the minor changes commented later on.
Changes in v2:
Changes in v3:
Changes in v4:
- snapper9g45 ARM926EJS (AT91SAM9G45 SoC)
really?
- $(call cmd_link_o_target, $(OBJS))
- (C) Copyright 2011 Bluewater Systems Ltd
- Author: Andre Renaud andre@bluewatersys.com
- project.
- MA 02111-1307 USA
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
--------------------------------------------------^ I haven't seen such an alignment somewhere in u-boot and I personally dislike it. It is OK in that case here cause the types have almost the same length, but how about a +20 char type vs. a int? So could you please change this to '(<type><one blank>*)'?
- struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
- struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC;
- unsigned long erstl;
- /* Enable clock */
- writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
- writel(pin_to_mask(AT91_PIN_PA15) |
&pioa->pudr);
- /* Need to reset PHY -> needs 100us, so use minimum reset period */
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK;
- writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0) |
- writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr);
- /* Wait for end hardware reset */
- while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL))
- /* Restore NRST value */
- writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr);
- /* The phy internal reset take 21ms */
- mdelay(21);
- /* Re-enable pull-up */
&pioa->puer);
- at91_macb_hw_init();
- struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC;
-------------------------------------------------------^ please only one blank here.
- struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- unsigned long csa;
- /* Enable CS3 as NAND/SmartMedia */
- csa = readl(&matrix->ebicsa);
- csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA;
- writel(csa, &matrix->ebicsa);
- /* Configure SMC CS3 for NAND/SmartMedia */
- writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);
- writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) |
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7),
&smc->cs[3].cycle);
- writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE |
&smc->cs[3].mode);
- /* Configure RDY/BSY */
- at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
- /* Enable NandFlash */
- at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1);
- /* Enable PIO clocks */
- writel((1 << ATMEL_ID_PIOA) |
- /* Address of boot parameters */
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- /* Initialise peripherals */
- at91_seriald_hw_init();
- nand_hw_init();
- macb_hw_init();
- return macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x1b);
- gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE,
- Bluewater Systems Snapper 9G45 modules
- Author: Ryan Mallon ryan@bluewatersys.com
- project.
- MA 02111-1307 USA
You do not use the (prohibited) sz macros in here, so please remove the asm/sizes.h
--------------------------------------------------------------------^ only one blank here, please.
Is this really required? I guess not, can you please also have a look for snapper9260 regarding the CONFIG_AT91_LEGACY?
This may be still required, please check and remove if not. If it is required ... patches for removing the need for CONFIG_ATMEL_LEGACY are expected wistfully.
Please remove, we have a generic definition now.
I see you use two different styles to define the sizes (here the shift type and the multiply type above). Don't get me wrong, it is ok to do so. But I ask myself if it was intended to do so or just a copy from somewhere and never touched cause they worked.
I didn't saw this define before, a grep showed up that is only used in ppc and m68k, so please remove.
Please remove, this is the default value.
Please remove, CONFIG_STACKSIZE is not used anywhere (except avr32 ...)
Please do not undef the bdinfo command, it is a real useful command and every u-boot should provide it.
You defined CONFIG_SYS_NO_FLASH, so CONFIG_CMD_IMLS should not defined here, please remove.
Who defined CONFIG_CMD_GPIO before?
Best regards
Andreas Bießmann
Andreas Bießmann
