[PATCH v6 0/8] Add MV88E6xxx DSA driver and use on gwventana
This series adds a DSA driver for the MV88E6xxx based on drivers/net/phy/mv88e61xx and uses it in the gwventana_gw5904_defconfig.
The hope is that the other three boards that use the MV88E61xx driver can move to this as well eventually so that we can remove the non-dm driver and the 4 Kconfig options it requires.
The MV88E6xxx has an MDIO interface thus DM_MDIO must be used so support for a UCLASS_MDIO driver is added to the fec_mxc ethernet driver in a way that allows a fallback to the previous non DM_MDIO case as there are many boards out there using this driver that define DM_MDIO but do not have the required dt props for a DM_MDIO driver which would cause a regression.
Additionally some other patches are here suggested by Vladimir: - ensure MDIO children are scanned on post-bind is needed - sanity check DSA driver required ops are present - allow DSA drivers to not require xmit/recv functions - remove unecessary xmit/recv functions from ksz9477 driver
v6: - update commit messages - squash accidently change to mv88e6xxx driver into previous patch - remove unused dt label for cpu port - removed unnecessary semicolon - update commit msg (s/MV88E61xx/MV88E6xxx) - remove GbE from commit msg and Kconfig desc - squash accidental change from patch 7 into patch 6 - added error print on failure to read switch id - mv88e6xxx_probe: - check for switch enabled - remove unused variable enabled - remove unnecessary call to dsa_set_tagging - port_probe: - new function to configure phy features by calling phy_config - port_enable: - only enable energy-detect sensing on phy ports - add phy/cmode verification mistmatch warning - remove mv88e6xxx_fixed_port_setup() - always force link up for fixed ports - always set SERDES mode regardless of cpu port - remove unnecessary setting of CPUDEST - port_disable: - remove pointless error check - removed unnecessary priv data for mdio controller - fix indentation - change variable name for clarity
v5: - fix typo in defconfig update - added support for MV88E6320 - added Fabio's rb tag
v4: - use standard Linux internal MDIO dt structure - use PHY_FIXED_ID define - rename to mv88e6xxx - sort includes alphabetically - remove dsa term from function names - reduce indentation level and remove unecessary code in of probe_mdio function - rename pdev to mdev to represent mdio device
v3: - fix mdios node in dt - add Vladimir's rb tag's
v2: - added Ramon's rb tag's to first two patches - add patches for dsa-uclass to sanity check ops and make xmit/recv optional - fec: fix fallback for non conforming DM_MDIO dts - mv88e61xx: - rebase on v2022.07-rc2 (use ofnode_get_phy_node) - remove unused commented out fields from struct - remove unused PORT_MASK macro - remove phy from priv struct name - refactor code from original drivers/net/phy/mv88e61xx with suggestions from review to consolidate some functions into mv88e61xx_dsa_port_enable - remove unecessary skiping of disabling of CPU port - remove unecessary dev_set_parent_priv - remove unnecessary static init flag - replace debug with a dev_warn if switch device-id unsupported - remove unnecessary xmit/recv functions as we rely on the fact that only a single port is active instead of mangling packets
Tested on a Gateworks GW5904 which has a Marvell 88E6176 switch hanging off the IMX6 FEC.
Best Regards,
Tim
Tim Harvey (8): net: mdio-uclass: scan for dm mdio children on post-bind net: dsa: move cpu port probe to dsa_post_probe net: dsa: ensure dsa driver has proper ops net: dsa: allow rcv() and xmit() to be optional net: ksz9477: remove unnecessary xmit and recv functions net: fec: add support for DM_MDIO net: add MV88E61xx DSA driver board: gw_ventana: enable MV88E61XX DSA support
arch/arm/dts/imx6qdl-gw5904.dtsi | 32 +- board/gateworks/gw_ventana/gw_ventana.c | 50 +- configs/gwventana_gw5904_defconfig | 7 +- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/fec_mxc.c | 90 ++- drivers/net/ksz9477.c | 23 - drivers/net/mv88e6xxx.c | 832 ++++++++++++++++++++++++ net/dsa-uclass.c | 55 +- net/mdio-uclass.c | 4 + 10 files changed, 1029 insertions(+), 72 deletions(-) create mode 100644 drivers/net/mv88e6xxx.c
If a DM_MDIO driver is used we need to scan the subnodes as well.
Signed-off-by: Tim Harvey tharvey@gateworks.com Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - no changes v5: - added Fabio's rb tag v4: - no changes v3: - no changes v2: - added Ramon's rb tag --- net/mdio-uclass.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 4401492ca015..d80037d0ac71 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -49,7 +49,11 @@ static int dm_mdio_post_bind(struct udevice *dev) return -EINVAL; }
+#if CONFIG_IS_ENABLED(OF_REAL) + return dm_scan_fdt_dev(dev); +#else return 0; +#endif }
int dm_mdio_read(struct udevice *mdio_dev, int addr, int devad, int reg)
In order to ensure that a DSA driver probe gets called before dsa_ops->port_probe move the port_probe of the cpu_port to a post-probe function.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - removed unnecessary semicolon v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: - added Ramon's rb tag --- net/dsa-uclass.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index 5b7046432ff3..5759cedcbec3 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -466,7 +466,6 @@ static int dsa_pre_probe(struct udevice *dev) { struct dsa_pdata *pdata = dev_get_uclass_plat(dev); struct dsa_priv *priv = dev_get_uclass_priv(dev); - struct dsa_ops *ops = dsa_get_ops(dev); int err;
priv->num_ports = pdata->num_ports; @@ -482,6 +481,15 @@ static int dsa_pre_probe(struct udevice *dev) if (err) return err;
+ return 0; +} + +static int dsa_post_probe(struct udevice *dev) +{ + struct dsa_priv *priv = dev_get_uclass_priv(dev); + struct dsa_ops *ops = dsa_get_ops(dev); + int err; + /* Simulate a probing event for the CPU port */ if (ops->port_probe) { err = ops->port_probe(dev, priv->cpu_port, @@ -498,6 +506,7 @@ UCLASS_DRIVER(dsa) = { .name = "dsa", .post_bind = dsa_post_bind, .pre_probe = dsa_pre_probe, + .post_probe = dsa_post_probe, .per_device_auto = sizeof(struct dsa_priv), .per_device_plat_auto = sizeof(struct dsa_pdata), .per_child_plat_auto = sizeof(struct dsa_port_pdata),
Add a function to sanity check a dsa driver having proper ops.
Suggested-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - no changes v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: new patch --- net/dsa-uclass.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index 5759cedcbec3..211a991cdd0d 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -342,6 +342,19 @@ U_BOOT_DRIVER(dsa_port) = { .plat_auto = sizeof(struct eth_pdata), };
+static int dsa_sanitize_ops(struct udevice *dev) +{ + struct dsa_ops *ops = dsa_get_ops(dev); + + if ((!ops->xmit || !ops->rcv) && + (!ops->port_enable && !ops->port_disable)) { + dev_err(dev, "Packets cannot be steered to ports\n"); + return -EINVAL; + } + + return 0; +} + /* * This function mostly deals with pulling information out of the device tree * into the pdata structure. @@ -358,6 +371,10 @@ static int dsa_post_bind(struct udevice *dev) if (!ofnode_valid(node)) return -ENODEV;
+ err = dsa_sanitize_ops(dev); + if (err) + return err; + pdata->master_node = ofnode_null();
node = ofnode_find_subnode(node, "ports");
Allow rcv() and xmit() dsa driver ops to be optional in case a driver does not care to mangle a packet as in U-Boot only one network port is enabled at a time and thus no packet mangling is necessary.
Suggested-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - no changes v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: new patch --- net/dsa-uclass.c | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index 211a991cdd0d..eba8347ae21a 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -131,16 +131,14 @@ static void dsa_port_stop(struct udevice *pdev) * We copy the frame to a stack buffer where we have reserved headroom and * tailroom space. Headroom and tailroom are set to 0. */ -static int dsa_port_send(struct udevice *pdev, void *packet, int length) +static int dsa_port_mangle_packet(struct udevice *pdev, void *packet, int length) { + struct dsa_port_pdata *port_pdata = dev_get_parent_plat(pdev); struct udevice *dev = dev_get_parent(pdev); struct dsa_priv *priv = dev_get_uclass_priv(dev); int head = priv->headroom, tail = priv->tailroom; - struct udevice *master = dsa_get_master(dev); struct dsa_ops *ops = dsa_get_ops(dev); uchar dsa_packet_tmp[PKTSIZE_ALIGN]; - struct dsa_port_pdata *port_pdata; - int err;
if (length + head + tail > PKTSIZE_ALIGN) return -EINVAL; @@ -152,10 +150,21 @@ static int dsa_port_send(struct udevice *pdev, void *packet, int length) /* copy back to preserve original buffer alignment */ memcpy(packet, dsa_packet_tmp, length);
- port_pdata = dev_get_parent_plat(pdev); - err = ops->xmit(dev, port_pdata->index, packet, length); - if (err) - return err; + return ops->xmit(dev, port_pdata->index, packet, length); +} + +static int dsa_port_send(struct udevice *pdev, void *packet, int length) +{ + struct udevice *dev = dev_get_parent(pdev); + struct udevice *master = dsa_get_master(dev); + struct dsa_ops *ops = dsa_get_ops(dev); + int err; + + if (ops->xmit) { + err = dsa_port_mangle_packet(pdev, packet, length); + if (err) + return err; + }
return eth_get_ops(master)->send(master, packet, length); } @@ -172,7 +181,7 @@ static int dsa_port_recv(struct udevice *pdev, int flags, uchar **packetp) int length, port_index, err;
length = eth_get_ops(master)->recv(master, flags, packetp); - if (length <= 0) + if (length <= 0 || !ops->rcv) return length;
Hi Tim,
v6:
- no changes
v5:
v4:
- no changes
v3:
v2: new patch
Should the tests be updated for this?
Hi Simon,
On Mon, Oct 10, 2022 at 04:25:29PM -0600, Simon Glass wrote:
Hi Tim,
Patch 3/8 serves as a runtime validation for this change. I don't believe that adding something more to test/dm/dsa.c is warranted, and I don't see exactly what can be added, either.
Remove the unnecessary xmit and recv functions.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - no changes v5: - added Fabio's rb tag v4: - no changes v3: - added Vladimir's rb tag v2: new patch --- drivers/net/ksz9477.c | 23 ----------------------- 1 file changed, 23 deletions(-)
diff --git a/drivers/net/ksz9477.c b/drivers/net/ksz9477.c index ed8f1895cb12..fb5c76c600be 100644 --- a/drivers/net/ksz9477.c +++ b/drivers/net/ksz9477.c @@ -62,7 +62,6 @@
struct ksz_dsa_priv { struct udevice *dev; - int active_port; };
static inline int ksz_read8(struct udevice *dev, u32 reg, u8 *val) @@ -382,9 +381,6 @@ static int ksz_port_enable(struct udevice *dev, int port, struct phy_device *phy data8 |= SW_START; ksz_write8(priv->dev, REG_SW_OPERATION, data8);
- /* keep track of current enabled non-cpu port */ - priv->active_port = port; - return 0; }
@@ -413,28 +409,9 @@ static void ksz_port_disable(struct udevice *dev, int port, struct phy_device *p */ }
-static int ksz_xmit(struct udevice *dev, int port, void *packet, int length) -{ - dev_dbg(dev, "%s P%d %d\n", __func__, port + 1, length); - - return 0; -} - -static int ksz_recv(struct udevice *dev, int *port, void *packet, int length) -{ - struct ksz_dsa_priv *priv = dev_get_priv(dev); - - dev_dbg(dev, "%s P%d %d\n", __func__, priv->active_port + 1, length); - *port = priv->active_port; - - return 0; -}; - static const struct dsa_ops ksz_dsa_ops = { .port_enable = ksz_port_enable, .port_disable = ksz_port_disable, - .xmit = ksz_xmit, - .rcv = ksz_recv, };
static int ksz_probe_mdio(struct udevice *dev)
Add support for DM_MDIO by registering a UCLASS_MDIO driver and attempting to use it. This is necessary if wanting to use a DSA driver for example hanging off of the FEC MAC.
Care is taken to fallback to non DM_MDIO mii bus as several boards define DM_MDIO without having the proper device-tree configuration necessary such as an mdio subnode, a phy-mode prop, and either a valid phy-handle prop or fixed-phy subnode which will cause dm_eth_phy_connect() to fail.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - no changes v5: - added Fabio's rb tag v4: - no changes v3: - no changes v2: - fix fallback mechanism for legacy dt's that do not have phy-handle and mdio subnode --- drivers/net/fec_mxc.c | 90 ++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 88 insertions(+), 2 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index bbc4434ddb9e..7057472710fa 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -30,6 +30,8 @@ #include <asm/arch/imx-regs.h> #include <asm/mach-imx/sys_proto.h> #include <asm-generic/gpio.h> +#include <dm/device_compat.h> +#include <dm/lists.h>
#include "fec_mxc.h" #include <eth_phy.h> @@ -1026,6 +1028,81 @@ struct mii_dev *fec_get_miibus(ulong base_addr, int dev_id) return bus; }
+#ifdef CONFIG_DM_MDIO +struct dm_fec_mdio_priv { + struct ethernet_regs *regs; +}; + +static int dm_fec_mdio_read(struct udevice *dev, int addr, int devad, int reg) +{ + struct dm_fec_mdio_priv *priv = dev_get_priv(dev); + + return fec_mdio_read(priv->regs, addr, reg); +} + +static int dm_fec_mdio_write(struct udevice *dev, int addr, int devad, int reg, u16 data) +{ + struct dm_fec_mdio_priv *priv = dev_get_priv(dev); + + return fec_mdio_write(priv->regs, addr, reg, data); +} + +static const struct mdio_ops dm_fec_mdio_ops = { + .read = dm_fec_mdio_read, + .write = dm_fec_mdio_write, +}; + +static int dm_fec_mdio_probe(struct udevice *dev) +{ + struct dm_fec_mdio_priv *priv = dev_get_priv(dev); + + priv->regs = (struct ethernet_regs *)ofnode_get_addr(dev_ofnode(dev->parent)); + + return 0; +} + +U_BOOT_DRIVER(fec_mdio) = { + .name = "fec_mdio", + .id = UCLASS_MDIO, + .probe = dm_fec_mdio_probe, + .ops = &dm_fec_mdio_ops, + .priv_auto = sizeof(struct dm_fec_mdio_priv), +}; + +static int dm_fec_bind_mdio(struct udevice *dev) +{ + struct udevice *mdiodev; + const char *name; + ofnode mdio; + int ret = -ENODEV; + + /* for a UCLASS_MDIO driver we need to bind and probe manually + * for an internal MDIO bus that has no dt compatible of its own + */ + ofnode_for_each_subnode(mdio, dev_ofnode(dev)) { + name = ofnode_get_name(mdio); + + if (strcmp(name, "mdio")) + continue; + + ret = device_bind_driver_to_node(dev, "fec_mdio", + name, mdio, &mdiodev); + if (ret) { + printf("%s bind %s failed: %d\n", __func__, name, ret); + break; + } + + /* need to probe it as there is no compatible to do so */ + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, mdio, &mdiodev); + if (!ret) + return 0; + printf("%s probe %s failed: %d\n", __func__, name, ret); + } + + return ret; +} +#endif + static int fecmxc_read_rom_hwaddr(struct udevice *dev) { struct fec_priv *priv = dev_get_priv(dev); @@ -1089,7 +1166,7 @@ static int device_get_phy_addr(struct fec_priv *priv, struct udevice *dev)
static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) { - struct phy_device *phydev; + struct phy_device *phydev = NULL; int addr;
addr = device_get_phy_addr(priv, dev); @@ -1097,7 +1174,10 @@ static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) addr = CONFIG_FEC_MXC_PHYADDR; #endif
- phydev = phy_connect(priv->bus, addr, dev, priv->interface); + if (IS_ENABLED(CONFIG_DM_MDIO)) + phydev = dm_eth_phy_connect(dev); + if (!phydev) + phydev = phy_connect(priv->bus, addr, dev, priv->interface); if (!phydev) return -ENODEV;
@@ -1228,6 +1308,12 @@ static int fecmxc_probe(struct udevice *dev)
priv->dev_id = dev_seq(dev);
+ if (IS_ENABLED(CONFIG_DM_MDIO)) { + ret = dm_fec_bind_mdio(dev); + if (ret && ret != -ENODEV) + return ret; + } + #ifdef CONFIG_DM_ETH_PHY bus = eth_phy_get_mdio_bus(dev); #endif
Add a DSA driver for the MV88E6xxx compatible Ethernet switches.
Cc: Marek Behún marek.behun@nic.cz Cc: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - update commit msg (s/MV88E61xx/MV88E6xxx) - remove GbE from commit msg and Kconfig desc - squash accidental change from patch 7 into patch 6 - added error print on failure to read switch id - mv88e6xxx_probe: - check for switch enabled - remove unused variable enabled - remove unnecessary call to dsa_set_tagging - port_probe: - new function to configure phy features by calling phy_config - port_enable: - only enable energy-detect sensing on phy ports - add phy/cmode verification mistmatch warning - remove mv88e6xxx_fixed_port_setup() - always force link up for fixed ports - always set SERDES mode regardless of cpu port - remove unnecessary setting of CPUDEST - port_disable: - remove pointless error check - removed unnecessary priv data for mdio controller - fix indentation - change variable name for clarity v5: - added support for MV88E6320 - added Fabio's rb tag v4: - rename to mv88e6xxx - sort includes alphabetically - remove dsa term from function names - reduce indentation level and remove unecessary code in of probe_mdio function - rename pdev to mdev to represent mdio device v3: - Added Vladimir's rb tag v2: - rebase on v2022.07-rc1 (use ofnode_get_phy_node) - remove unused commented out fields from struct - remove unused PORT_MASK macro - remove phy from priv struct name - refactor code from original drivers/net/phy/mv88e61xx with suggestions from review to consolidate some functions into mv88e61xx_dsa_port_enable - remove unecessary skiping of disabling of CPU port - remove unecessary dev_set_parent_priv - remove unnecessary static init flag - replace debug with a dev_warn if switch device-id unsupported - remove unnecessary xmit/recv functions as we rely on the fact that only a single port is active instead of mangling packets --- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/mv88e6xxx.c | 832 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 840 insertions(+) create mode 100644 drivers/net/mv88e6xxx.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6bbbadc5eef3..67f23917f42c 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -438,6 +438,13 @@ config KSZ9477 This driver implements a DSA switch driver for the KSZ9477 family of GbE switches using the I2C interface.
+config MV88E6XXX + bool "Marvell MV88E6xxx Ethernet switch DSA driver" + depends on DM_DSA && DM_MDIO + help + This driver implements a DSA switch driver for the MV88E6xxx family + of Ethernet switches using the MDIO interface + config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" depends on ARCH_KIRKWOOD || ARCH_ORION5X diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 96b7678e9882..f05fd58e3fa7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -59,6 +59,7 @@ obj-$(CONFIG_MEDIATEK_ETH) += mtk_eth.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o obj-$(CONFIG_MT7620_ETH) += mt7620-eth.o obj-$(CONFIG_MT7628_ETH) += mt7628-eth.o +obj-$(CONFIG_MV88E6XXX) += mv88e6xxx.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVMDIO) += mvmdio.o obj-$(CONFIG_MVNETA) += mvneta.o diff --git a/drivers/net/mv88e6xxx.c b/drivers/net/mv88e6xxx.c new file mode 100644 index 000000000000..6aef8ab9f5bc --- /dev/null +++ b/drivers/net/mv88e6xxx.c @@ -0,0 +1,832 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 + * Gateworks Corporation <www.gateworks.com> + * Tim Harvey tharvey@gateworks.com + * + * (C) Copyright 2015 + * Elecsys Corporation <www.elecsyscorp.com> + * Kevin Smith kevin.smith@elecsyscorp.com + * + * Original driver: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + */ + +/* + * DSA driver for mv88e6xxx ethernet switches. + * + * This driver configures the mv88e6xxx for basic use as a DSA switch. + * + * This driver was adapted from drivers/net/phy/mv88e61xx and tested + * on the mv88e6176 via an SGMII interface. + */ + +#include <bitfield.h> +#include <common.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/of_extra.h> +#include <linux/delay.h> +#include <miiphy.h> +#include <net/dsa.h> + +/* Device addresses */ +#define DEVADDR_PHY(p) (p) +#define DEVADDR_SERDES 0x0F + +/* SMI indirection registers for multichip addressing mode */ +#define SMI_CMD_REG 0x00 +#define SMI_DATA_REG 0x01 + +/* Global registers */ +#define GLOBAL1_STATUS 0x00 +#define GLOBAL1_CTRL 0x04 +#define GLOBAL1_MON_CTRL 0x1A + +/* Global 2 registers */ +#define GLOBAL2_REG_PHY_CMD 0x18 +#define GLOBAL2_REG_PHY_DATA 0x19 +#define GLOBAL2_REG_SCRATCH 0x1A + +/* Port registers */ +#define PORT_REG_STATUS 0x00 +#define PORT_REG_PHYS_CTRL 0x01 +#define PORT_REG_SWITCH_ID 0x03 +#define PORT_REG_CTRL 0x04 +#define PORT_REG_VLAN_MAP 0x06 +#define PORT_REG_VLAN_ID 0x07 +#define PORT_REG_LED_CTRL 0x16 + +/* Phy registers */ +#define PHY_REG_CTRL1 0x10 +#define PHY_REG_STATUS1 0x11 +#define PHY_REG_PAGE 0x16 + +/* Serdes registers */ +#define SERDES_REG_CTRL_1 0x10 + +/* Phy page numbers */ +#define PHY_PAGE_COPPER 0 +#define PHY_PAGE_SERDES 1 + +/* Register fields */ +#define GLOBAL1_CTRL_SWRESET BIT(15) + +#define GLOBAL1_MON_CTRL_CPUDEST_SHIFT 4 +#define GLOBAL1_MON_CTRL_CPUDEST_WIDTH 4 + +#define PORT_REG_STATUS_SPEED_SHIFT 8 +#define PORT_REG_STATUS_SPEED_10 0 +#define PORT_REG_STATUS_SPEED_100 1 +#define PORT_REG_STATUS_SPEED_1000 2 + +#define PORT_REG_STATUS_CMODE_MASK 0xF +#define PORT_REG_STATUS_CMODE_SGMII 0xa +#define PORT_REG_STATUS_CMODE_1000BASE_X 0x9 +#define PORT_REG_STATUS_CMODE_100BASE_X 0x8 +#define PORT_REG_STATUS_CMODE_RGMII 0x7 +#define PORT_REG_STATUS_CMODE_RMII 0x5 +#define PORT_REG_STATUS_CMODE_RMII_PHY 0x4 +#define PORT_REG_STATUS_CMODE_GMII 0x3 +#define PORT_REG_STATUS_CMODE_MII 0x2 +#define PORT_REG_STATUS_CMODE_MIIPHY 0x1 + +#define PORT_REG_PHYS_CTRL_RGMII_DELAY_RXCLK BIT(15) +#define PORT_REG_PHYS_CTRL_RGMII_DELAY_TXCLK BIT(14) +#define PORT_REG_PHYS_CTRL_PCS_AN_EN BIT(10) +#define PORT_REG_PHYS_CTRL_PCS_AN_RST BIT(9) +#define PORT_REG_PHYS_CTRL_FC_VALUE BIT(7) +#define PORT_REG_PHYS_CTRL_FC_FORCE BIT(6) +#define PORT_REG_PHYS_CTRL_LINK_VALUE BIT(5) +#define PORT_REG_PHYS_CTRL_LINK_FORCE BIT(4) +#define PORT_REG_PHYS_CTRL_DUPLEX_VALUE BIT(3) +#define PORT_REG_PHYS_CTRL_DUPLEX_FORCE BIT(2) +#define PORT_REG_PHYS_CTRL_SPD1000 BIT(1) +#define PORT_REG_PHYS_CTRL_SPD100 BIT(0) +#define PORT_REG_PHYS_CTRL_SPD_MASK (BIT(1) | BIT(0)) + +#define PORT_REG_CTRL_PSTATE_SHIFT 0 +#define PORT_REG_CTRL_PSTATE_WIDTH 2 + +#define PORT_REG_VLAN_ID_DEF_VID_SHIFT 0 +#define PORT_REG_VLAN_ID_DEF_VID_WIDTH 12 + +#define PORT_REG_VLAN_MAP_TABLE_SHIFT 0 +#define PORT_REG_VLAN_MAP_TABLE_WIDTH 11 + +#define SERDES_REG_CTRL_1_FORCE_LINK BIT(10) + +/* Field values */ +#define PORT_REG_CTRL_PSTATE_DISABLED 0 +#define PORT_REG_CTRL_PSTATE_FORWARD 3 + +#define PHY_REG_CTRL1_ENERGY_DET_OFF 0 +#define PHY_REG_CTRL1_ENERGY_DET_SENSE_PULSE 1 +#define PHY_REG_CTRL1_ENERGY_DET_SENSE_ONLY 2 +#define PHY_REG_CTRL1_ENERGY_DET_SENSE_XMIT 3 + +/* PHY Status Register */ +#define PHY_REG_STATUS1_SPEED 0xc000 +#define PHY_REG_STATUS1_GBIT 0x8000 +#define PHY_REG_STATUS1_100 0x4000 +#define PHY_REG_STATUS1_DUPLEX 0x2000 +#define PHY_REG_STATUS1_SPDDONE 0x0800 +#define PHY_REG_STATUS1_LINK 0x0400 +#define PHY_REG_STATUS1_ENERGY 0x0010 + +/* + * Macros for building commands for indirect addressing modes. These are valid + * for both the indirect multichip addressing mode and the PHY indirection + * required for the writes to any PHY register. + */ +#define SMI_BUSY BIT(15) +#define SMI_CMD_CLAUSE_22 BIT(12) +#define SMI_CMD_CLAUSE_22_OP_READ (2 << 10) +#define SMI_CMD_CLAUSE_22_OP_WRITE (1 << 10) + +#define SMI_CMD_READ (SMI_BUSY | SMI_CMD_CLAUSE_22 | \ + SMI_CMD_CLAUSE_22_OP_READ) +#define SMI_CMD_WRITE (SMI_BUSY | SMI_CMD_CLAUSE_22 | \ + SMI_CMD_CLAUSE_22_OP_WRITE) + +#define SMI_CMD_ADDR_SHIFT 5 +#define SMI_CMD_ADDR_WIDTH 5 +#define SMI_CMD_REG_SHIFT 0 +#define SMI_CMD_REG_WIDTH 5 + +/* Defines for Scratch and Misc Registers */ +#define SCRATCH_UPDATE BIT(15) +#define SCRATCH_ADDR_SHIFT 8 +#define SCRATCH_ADDR_WIDTH 7 + +/* Scratch registers */ +#define SCRATCH_ADDR_GPIO0DIR 0x62 /* GPIO[7:0] direction 1=input */ +#define SCRATCH_ADDR_GPIO1DIR 0x63 /* GPIO[14:8] direction 1=input */ +#define SCRATCH_ADDR_GPIO0DATA 0x64 /* GPIO[7:0] data */ +#define SCRATCH_ADDR_GPIO1DATA 0x65 /* GPIO[14:8] data */ +#define SCRATCH_ADDR_GPIO0CTRL 0x68 /* GPIO[1:0] control */ +#define SCRATCH_ADDR_GPIO1CTRL 0x69 /* GPIO[3:2] control */ + +/* ID register values for different switch models */ +#define PORT_SWITCH_ID_6020 0x0200 +#define PORT_SWITCH_ID_6070 0x0700 +#define PORT_SWITCH_ID_6071 0x0710 +#define PORT_SWITCH_ID_6096 0x0980 +#define PORT_SWITCH_ID_6097 0x0990 +#define PORT_SWITCH_ID_6172 0x1720 +#define PORT_SWITCH_ID_6176 0x1760 +#define PORT_SWITCH_ID_6220 0x2200 +#define PORT_SWITCH_ID_6240 0x2400 +#define PORT_SWITCH_ID_6250 0x2500 +#define PORT_SWITCH_ID_6320 0x1150 +#define PORT_SWITCH_ID_6352 0x3520 + +struct mv88e6xxx_priv { + int smi_addr; + int id; + int port_count; /* Number of switch ports */ + int port_reg_base; /* Base of the switch port registers */ + u8 global1; /* Offset of Switch Global 1 registers */ + u8 global2; /* Offset of Switch Global 2 registers */ + u8 phy_ctrl1_en_det_shift; /* 'EDet' bit field offset */ + u8 phy_ctrl1_en_det_width; /* Width of 'EDet' bit field */ + u8 phy_ctrl1_en_det_ctrl; /* 'EDet' control value */ +}; + +static inline int smi_cmd(int cmd, int addr, int reg) +{ + cmd = bitfield_replace(cmd, SMI_CMD_ADDR_SHIFT, SMI_CMD_ADDR_WIDTH, + addr); + cmd = bitfield_replace(cmd, SMI_CMD_REG_SHIFT, SMI_CMD_REG_WIDTH, reg); + return cmd; +} + +static inline int smi_cmd_read(int addr, int reg) +{ + return smi_cmd(SMI_CMD_READ, addr, reg); +} + +static inline int smi_cmd_write(int addr, int reg) +{ + return smi_cmd(SMI_CMD_WRITE, addr, reg); +} + +/* Wait for the current SMI indirect command to complete */ +static int mv88e6xxx_smi_wait(struct udevice *dev, int smi_addr) +{ + int val; + u32 timeout = 100; + + do { + val = dm_mdio_read(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_CMD_REG); + if (val >= 0 && (val & SMI_BUSY) == 0) + return 0; + + mdelay(1); + } while (--timeout); + + dev_err(dev, "SMI busy timeout\n"); + return -ETIMEDOUT; +} + +/* + * The mv88e6xxx has three types of addresses: the smi bus address, the device + * address, and the register address. The smi bus address distinguishes it on + * the smi bus from other PHYs or switches. The device address determines + * which on-chip register set you are reading/writing (the various PHYs, their + * associated ports, or global configuration registers). The register address + * is the offset of the register you are reading/writing. + * + * When the mv88e6xxx is hardware configured to have address zero, it behaves in + * single-chip addressing mode, where it responds to all SMI addresses, using + * the smi address as its device address. This obviously only works when this + * is the only chip on the SMI bus. This allows the driver to access device + * registers without using indirection. When the chip is configured to a + * non-zero address, it only responds to that SMI address and requires indirect + * writes to access the different device addresses. + */ +static int mv88e6xxx_reg_read(struct udevice *dev, int addr, int reg) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int smi_addr = priv->smi_addr; + int res; + + /* In single-chip mode, the device can be addressed directly */ + if (smi_addr == 0) + return dm_mdio_read(dev->parent, addr, MDIO_DEVAD_NONE, reg); + + /* Wait for the bus to become free */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + /* Issue the read command */ + res = dm_mdio_write(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_CMD_REG, + smi_cmd_read(addr, reg)); + if (res < 0) + return res; + + /* Wait for the read command to complete */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + /* Read the data */ + res = dm_mdio_read(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_DATA_REG); + if (res < 0) + return res; + + return bitfield_extract(res, 0, 16); +} + +/* See the comment above mv88e6xxx_reg_read */ +static int mv88e6xxx_reg_write(struct udevice *dev, int addr, int reg, u16 val) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int smi_addr = priv->smi_addr; + int res; + + /* In single-chip mode, the device can be addressed directly */ + if (smi_addr == 0) + return dm_mdio_write(dev->parent, addr, MDIO_DEVAD_NONE, reg, val); + + /* Wait for the bus to become free */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + /* Set the data to write */ + res = dm_mdio_write(dev->parent, smi_addr, MDIO_DEVAD_NONE, + SMI_DATA_REG, val); + if (res < 0) + return res; + + /* Issue the write command */ + res = dm_mdio_write(dev->parent, smi_addr, MDIO_DEVAD_NONE, SMI_CMD_REG, + smi_cmd_write(addr, reg)); + if (res < 0) + return res; + + /* Wait for the write command to complete */ + res = mv88e6xxx_smi_wait(dev, smi_addr); + if (res < 0) + return res; + + return 0; +} + +static int mv88e6xxx_phy_wait(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int val; + u32 timeout = 100; + + do { + val = mv88e6xxx_reg_read(dev, priv->global2, GLOBAL2_REG_PHY_CMD); + if (val >= 0 && (val & SMI_BUSY) == 0) + return 0; + + mdelay(1); + } while (--timeout); + + return -ETIMEDOUT; +} + +static int mv88e6xxx_phy_read_indirect(struct udevice *dev, int phyad, int devad, int reg) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int res; + + /* Issue command to read */ + res = mv88e6xxx_reg_write(dev, priv->global2, + GLOBAL2_REG_PHY_CMD, + smi_cmd_read(phyad, reg)); + + /* Wait for data to be read */ + res = mv88e6xxx_phy_wait(dev); + if (res < 0) + return res; + + /* Read retrieved data */ + return mv88e6xxx_reg_read(dev, priv->global2, + GLOBAL2_REG_PHY_DATA); +} + +static int mv88e6xxx_phy_write_indirect(struct udevice *dev, int phyad, + int devad, int reg, u16 data) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int res; + + /* Set the data to write */ + res = mv88e6xxx_reg_write(dev, priv->global2, + GLOBAL2_REG_PHY_DATA, data); + if (res < 0) + return res; + /* Issue the write command */ + res = mv88e6xxx_reg_write(dev, priv->global2, + GLOBAL2_REG_PHY_CMD, + smi_cmd_write(phyad, reg)); + if (res < 0) + return res; + + /* Wait for command to complete */ + return mv88e6xxx_phy_wait(dev); +} + +/* Wrapper function to make calls to phy_read_indirect simpler */ +static int mv88e6xxx_phy_read(struct udevice *dev, int phy, int reg) +{ + return mv88e6xxx_phy_read_indirect(dev, DEVADDR_PHY(phy), + MDIO_DEVAD_NONE, reg); +} + +/* Wrapper function to make calls to phy_write_indirect simpler */ +static int mv88e6xxx_phy_write(struct udevice *dev, int phy, int reg, u16 val) +{ + return mv88e6xxx_phy_write_indirect(dev, DEVADDR_PHY(phy), + MDIO_DEVAD_NONE, reg, val); +} + +static int mv88e6xxx_port_read(struct udevice *dev, u8 port, u8 reg) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + return mv88e6xxx_reg_read(dev, priv->port_reg_base + port, reg); +} + +static int mv88e6xxx_port_write(struct udevice *dev, u8 port, u8 reg, u16 val) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + return mv88e6xxx_reg_write(dev, priv->port_reg_base + port, reg, val); +} + +static int mv88e6xxx_set_page(struct udevice *dev, u8 phy, u8 page) +{ + return mv88e6xxx_phy_write(dev, phy, PHY_REG_PAGE, page); +} + +static int mv88e6xxx_get_switch_id(struct udevice *dev) +{ + int res; + + res = mv88e6xxx_port_read(dev, 0, PORT_REG_SWITCH_ID); + if (res < 0) { + dev_err(dev, "Failed to read switch ID: %d\n", res); + return res; + } + return res & 0xfff0; +} + +static bool mv88e6xxx_6352_family(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + switch (priv->id) { + case PORT_SWITCH_ID_6172: + case PORT_SWITCH_ID_6176: + case PORT_SWITCH_ID_6240: + case PORT_SWITCH_ID_6352: + return true; + } + return false; +} + +static int mv88e6xxx_get_cmode(struct udevice *dev, u8 port) +{ + int res; + + res = mv88e6xxx_port_read(dev, port, PORT_REG_STATUS); + if (res < 0) + return res; + return res & PORT_REG_STATUS_CMODE_MASK; +} + +static int mv88e6xxx_switch_reset(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int time_ms; + int val; + u8 port; + + /* Disable all ports */ + for (port = 0; port < priv->port_count; port++) { + val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL); + if (val < 0) + return val; + val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT, + PORT_REG_CTRL_PSTATE_WIDTH, + PORT_REG_CTRL_PSTATE_DISABLED); + val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val); + if (val < 0) + return val; + } + + /* Wait 2 ms for queues to drain */ + udelay(2000); + + /* Reset switch */ + val = mv88e6xxx_reg_read(dev, priv->global1, GLOBAL1_CTRL); + if (val < 0) + return val; + val |= GLOBAL1_CTRL_SWRESET; + val = mv88e6xxx_reg_write(dev, priv->global1, GLOBAL1_CTRL, val); + if (val < 0) + return val; + + /* Wait up to 1 second for switch to reset complete */ + for (time_ms = 1000; time_ms; time_ms--) { + val = mv88e6xxx_reg_read(dev, priv->global1, GLOBAL1_CTRL); + if (val >= 0 && ((val & GLOBAL1_CTRL_SWRESET) == 0)) + break; + udelay(1000); + } + if (!time_ms) + return -ETIMEDOUT; + + return 0; +} + +static int mv88e6xxx_serdes_init(struct udevice *dev) +{ + int val; + + val = mv88e6xxx_set_page(dev, DEVADDR_SERDES, PHY_PAGE_SERDES); + if (val < 0) + return val; + + /* Power up serdes module */ + val = mv88e6xxx_phy_read(dev, DEVADDR_SERDES, MII_BMCR); + if (val < 0) + return val; + val &= ~(BMCR_PDOWN); + val = mv88e6xxx_phy_write(dev, DEVADDR_SERDES, MII_BMCR, val); + if (val < 0) + return val; + + return 0; +} + +/* + * This function is used to pre-configure the required register + * offsets, so that the indirect register access to the PHY registers + * is possible. This is necessary to be able to read the PHY ID + * while driver probing or in get_phy_id(). The globalN register + * offsets must be initialized correctly for a detected switch, + * otherwise detection of the PHY ID won't work! + */ +static int mv88e6xxx_priv_reg_offs_pre_init(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + + /* + * Initial 'port_reg_base' value must be an offset of existing + * port register, then reading the ID should succeed. First, try + * to read via port registers with device address 0x10 (88E6096 + * and compatible switches). + */ + priv->port_reg_base = 0x10; + priv->id = mv88e6xxx_get_switch_id(dev); + if (priv->id != 0xfff0) { + priv->global1 = 0x1B; + priv->global2 = 0x1C; + return 0; + } + + /* + * Now try via port registers with device address 0x08 + * (88E6020 and compatible switches). + */ + priv->port_reg_base = 0x08; + priv->id = mv88e6xxx_get_switch_id(dev); + if (priv->id != 0xfff0) { + priv->global1 = 0x0F; + priv->global2 = 0x07; + return 0; + } + + dev_warn(dev, "%s Unknown ID 0x%x\n", __func__, priv->id); + + return -ENODEV; +} + +static int mv88e6xxx_mdio_read(struct udevice *dev, int addr, int devad, int reg) +{ + return mv88e6xxx_phy_read_indirect(dev->parent, DEVADDR_PHY(addr), + MDIO_DEVAD_NONE, reg); +} + +static int mv88e6xxx_mdio_write(struct udevice *dev, int addr, int devad, + int reg, u16 val) +{ + return mv88e6xxx_phy_write_indirect(dev->parent, DEVADDR_PHY(addr), + MDIO_DEVAD_NONE, reg, val); +} + +static const struct mdio_ops mv88e6xxx_mdio_ops = { + .read = mv88e6xxx_mdio_read, + .write = mv88e6xxx_mdio_write, +}; + +static int mv88e6xxx_mdio_bind(struct udevice *dev) +{ + char name[32]; + static int num_devices; + + sprintf(name, "mv88e6xxx-mdio-%d", num_devices++); + device_set_name(dev, name); + + return 0; +} + +U_BOOT_DRIVER(mv88e6xxx_mdio) = { + .name = "mv88e6xxx_mdio", + .id = UCLASS_MDIO, + .ops = &mv88e6xxx_mdio_ops, + .bind = mv88e6xxx_mdio_bind, + .plat_auto = sizeof(struct mdio_perdev_priv), +}; + +static int mv88e6xxx_port_probe(struct udevice *dev, int port, struct phy_device *phy) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int supported; + + switch (priv->id) { + case PORT_SWITCH_ID_6020: + case PORT_SWITCH_ID_6070: + case PORT_SWITCH_ID_6071: + supported = PHY_BASIC_FEATURES | SUPPORTED_MII; + break; + default: + supported = PHY_GBIT_FEATURES; + break; + } + + phy->supported &= supported; + phy->advertising &= supported; + + return phy_config(phy); +} + +static int mv88e6xxx_port_enable(struct udevice *dev, int port, struct phy_device *phy) +{ + struct dsa_pdata *dsa_pdata = dev_get_uclass_plat(dev); + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int val, ret; + + dev_dbg(dev, "%s P%d phy:0x%08x %s\n", __func__, port, + phy->phy_id, phy_string_for_interface(phy->interface)); + + /* + * Enable energy-detect sensing on PHY, used to determine when a PHY + * port is physically connected + */ + if (port != dsa_pdata->cpu_port) { + val = mv88e6xxx_phy_read(dev, port, PHY_REG_CTRL1); + if (val < 0) + return val; + val = bitfield_replace(val, priv->phy_ctrl1_en_det_shift, + priv->phy_ctrl1_en_det_width, + priv->phy_ctrl1_en_det_ctrl); + val = mv88e6xxx_phy_write(dev, port, PHY_REG_CTRL1, val); + if (val < 0) + return val; + } + + /* enable port */ + val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL); + if (val < 0) + return val; + val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT, + PORT_REG_CTRL_PSTATE_WIDTH, + PORT_REG_CTRL_PSTATE_FORWARD); + val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val); + if (val < 0) + return val; + + /* configure RGMII delays for fixed link */ + if (phy->phy_id == PHY_FIXED_ID) { + /* Physical Control register: Table 62 */ + val = mv88e6xxx_port_read(dev, port, PORT_REG_PHYS_CTRL); + + /* RGMII delays */ + val &= ~(PORT_REG_PHYS_CTRL_RGMII_DELAY_RXCLK || + PORT_REG_PHYS_CTRL_RGMII_DELAY_TXCLK); + if (phy->interface == PHY_INTERFACE_MODE_RGMII_ID || + phy->interface == PHY_INTERFACE_MODE_RGMII_RXID) + val |= PORT_REG_PHYS_CTRL_RGMII_DELAY_RXCLK; + if (phy->interface == PHY_INTERFACE_MODE_RGMII_ID || + phy->interface == PHY_INTERFACE_MODE_RGMII_TXID) + val |= PORT_REG_PHYS_CTRL_RGMII_DELAY_TXCLK; + /* Force Link */ + val |= PORT_REG_PHYS_CTRL_LINK_VALUE | + PORT_REG_PHYS_CTRL_LINK_FORCE; + + ret = mv88e6xxx_port_write(dev, port, PORT_REG_PHYS_CTRL, val); + if (ret < 0) + return ret; + } + + if (mv88e6xxx_6352_family(dev)) { + val = mv88e6xxx_get_cmode(dev, dsa_pdata->cpu_port); + if (val < 0) + return val; + /* initialize serdes */ + if (val == PORT_REG_STATUS_CMODE_100BASE_X || + val == PORT_REG_STATUS_CMODE_1000BASE_X || + val == PORT_REG_STATUS_CMODE_SGMII) { + ret = mv88e6xxx_serdes_init(dev); + if (ret < 0) + return ret; + } + /* validate interface type */ + if (phy->phy_id == PHY_FIXED_ID) { + switch (phy->interface) { + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_RGMII_ID: + if (val != PORT_REG_STATUS_CMODE_RGMII) + goto mismatch; + break; + case PHY_INTERFACE_MODE_1000BASEX: + if (val != PORT_REG_STATUS_CMODE_1000BASE_X) + goto mismatch; + break; +mismatch: + default: + dev_err(dev, "Mismatched PHY mode %s on port %d!\n", + phy_string_for_interface(phy->interface), port); + break; + } + } + } + + return phy_startup(phy); +} + +static void mv88e6xxx_port_disable(struct udevice *dev, int port, struct phy_device *phy) +{ + int val; + + dev_dbg(dev, "%s P%d phy:0x%x\n", __func__, port, phy->phy_id); + + val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL); + val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT, + PORT_REG_CTRL_PSTATE_WIDTH, + PORT_REG_CTRL_PSTATE_DISABLED); + val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val); +} + +static const struct dsa_ops mv88e6xxx_dsa_ops = { + .port_probe = mv88e6xxx_port_probe, + .port_enable = mv88e6xxx_port_enable, + .port_disable = mv88e6xxx_port_disable, +}; + +/* bind and probe the switch mdios */ +static int mv88e6xxx_probe_mdio(struct udevice *dev) +{ + struct udevice *mdev; + const char *name; + ofnode node; + int ret; + + /* bind phy ports of mdio child node to mv88e6xxx_mdio device */ + node = dev_read_subnode(dev, "mdio"); + if (!ofnode_valid(node)) + return 0; + + name = ofnode_get_name(node); + ret = device_bind_driver_to_node(dev, + "mv88e6xxx_mdio", + name, node, NULL); + if (ret) { + dev_err(dev, "failed to bind %s: %d\n", name, ret); + } else { + /* need to probe it as there is no compatible to do so */ + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, node, &mdev); + if (ret) + dev_err(dev, "failed to probe %s: %d\n", name, ret); + } + + return ret; +} + +static int mv88e6xxx_probe(struct udevice *dev) +{ + struct mv88e6xxx_priv *priv = dev_get_priv(dev); + int ret; + + if (ofnode_valid(dev_ofnode(dev)) && + !ofnode_is_enabled(dev_ofnode(dev))) { + dev_dbg(dev, "switch disabled\n"); + return -ENODEV; + } + + /* probe internal mdio bus */ + ret = mv88e6xxx_probe_mdio(dev); + if (ret) + return ret; + + ret = mv88e6xxx_priv_reg_offs_pre_init(dev); + if (ret) + return ret; + + dev_dbg(dev, "ID=0x%x PORT_BASE=0x%02x GLOBAL1=0x%02x GLOBAL2=0x%02x\n", + priv->id, priv->port_reg_base, priv->global1, priv->global2); + switch (priv->id) { + case PORT_SWITCH_ID_6096: + case PORT_SWITCH_ID_6097: + case PORT_SWITCH_ID_6172: + case PORT_SWITCH_ID_6176: + case PORT_SWITCH_ID_6240: + case PORT_SWITCH_ID_6352: + priv->port_count = 11; + priv->phy_ctrl1_en_det_shift = 8; + priv->phy_ctrl1_en_det_width = 2; + priv->phy_ctrl1_en_det_ctrl = + PHY_REG_CTRL1_ENERGY_DET_SENSE_XMIT; + break; + case PORT_SWITCH_ID_6020: + case PORT_SWITCH_ID_6070: + case PORT_SWITCH_ID_6071: + case PORT_SWITCH_ID_6220: + case PORT_SWITCH_ID_6250: + case PORT_SWITCH_ID_6320: + priv->port_count = 7; + priv->phy_ctrl1_en_det_shift = 14; + priv->phy_ctrl1_en_det_width = 1; + priv->phy_ctrl1_en_det_ctrl = + PHY_REG_CTRL1_ENERGY_DET_SENSE_PULSE; + break; + default: + return -ENODEV; + } + + ret = mv88e6xxx_switch_reset(dev); + if (ret < 0) + return ret; + + return 0; +} + +static const struct udevice_id mv88e6xxx_ids[] = { + { .compatible = "marvell,mv88e6085" }, + { } +}; + +U_BOOT_DRIVER(mv88e6xxx) = { + .name = "mv88e6xxx", + .id = UCLASS_DSA, + .of_match = mv88e6xxx_ids, + .probe = mv88e6xxx_probe, + .ops = &mv88e6xxx_dsa_ops, + .priv_auto = sizeof(struct mv88e6xxx_priv), +};
Cc: Marek BehĂșn marek.behun@nic.cz Cc: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de
v6:
really?
- mv88e6xxx_probe:
- port_probe:
- port_enable:
really?
- int smi_addr;
- int id;
- int port_count; /* Number of switch ports */
- int port_reg_base; /* Base of the switch port registers */
- u8 global1; /* Offset of Switch Global 1 registers */
- u8 global2; /* Offset of Switch Global 2 registers */
- u8 phy_ctrl1_en_det_shift; /* 'EDet' bit field offset */
- u8 phy_ctrl1_en_det_width; /* Width of 'EDet' bit field */
- u8 phy_ctrl1_en_det_ctrl; /* 'EDet' control value */
If the convention in U-Boot is the same as in Linux (which it well may be, except for the fact that more things escape review), then you should avoid manually defining functions as inline in C files. The compiler will decide whether to inline or not regardless of what you specify here.
Although I wonder if these couldn't be in fact expressed more clearly using plain, boring old logical | and << operators as part of a macro.
- cmd = bitfield_replace(cmd, SMI_CMD_ADDR_SHIFT, SMI_CMD_ADDR_WIDTH,
addr);
- cmd = bitfield_replace(cmd, SMI_CMD_REG_SHIFT, SMI_CMD_REG_WIDTH, reg);
- return cmd;
- return smi_cmd(SMI_CMD_READ, addr, reg);
- return smi_cmd(SMI_CMD_WRITE, addr, reg);
- int val;
- u32 timeout = 100;
- do {
mdelay(1);
- } while (--timeout);
- dev_err(dev, "SMI busy timeout\n");
- return -ETIMEDOUT;
- int val;
- val = mv88e6xxx_set_page(dev, DEVADDR_SERDES, PHY_PAGE_SERDES);
- if (val < 0)
return val;
- /* Power up serdes module */
- val = mv88e6xxx_phy_read(dev, DEVADDR_SERDES, MII_BMCR);
- if (val < 0)
return val;
- val &= ~(BMCR_PDOWN);
- val = mv88e6xxx_phy_write(dev, DEVADDR_SERDES, MII_BMCR, val);
- if (val < 0)
return val;
- struct dsa_pdata *dsa_pdata = dev_get_uclass_plat(dev);
- struct mv88e6xxx_priv *priv = dev_get_priv(dev);
- int val, ret;
- dev_dbg(dev, "%s P%d phy:0x%08x %s\n", __func__, port,
- if (port != dsa_pdata->cpu_port) {
Can you test based on phy->interface == PHY_INTERFACE_MODE_INTERNAL? Support may come later for cascade ports, and those are ports without an internal PHY which are not CPU ports.
if (val < 0)
return val;
if (val < 0)
return val;
- /* enable port */
- val = mv88e6xxx_port_read(dev, port, PORT_REG_CTRL);
- if (val < 0)
return val;
- val = bitfield_replace(val, PORT_REG_CTRL_PSTATE_SHIFT,
- val = mv88e6xxx_port_write(dev, port, PORT_REG_CTRL, val);
- if (val < 0)
return val;
- /* configure RGMII delays for fixed link */
- if (phy->phy_id == PHY_FIXED_ID) {
I believe this code should really be executed only for RGMII ports. In other words, move it inside a function that gets called inside the switch (phy->interface) block you added below.
/* RGMII delays */
I find the style a bit chaotic when in other places you use bitfield_replace() but not everywhere.
/* Force Link */
if (ret < 0)
return ret;
- if (mv88e6xxx_6352_family(dev)) {
What gets handled by dsa_ops :: port_enable() should be a function of "int port", whereas dsa_pdata->cpu_port is an invariant of that.
Otherwise said, you check for the cmode of the CPU port for as many times as ports there are, and never for the other ports. Probably not what you intend.
if (val < 0)
return val;
Again, you call mv88e6xxx_serdes_init() 10 times on the CPU port. The point of getting the C_Mode per port was to avoid directly checking for dsa_pdata->cpu_port.
if (ret < 0)
return ret;
I think you mean here to validate the C_Mode only for ports not connected to internal PHYs. But SERDES/RGMII ports may also have PHYs, albeit external. You want to validate the C_Mode for them too. So this check must go. Please check for PHY_INTERFACE_MODE_INTERNAL, and avoid comparing it to the C_Mode in that case.
goto mismatch;
break;
goto mismatch;
break;
+mismatch:
default:
break;
- return phy_startup(phy);
Overall it looks better than v5, but I believe that it could use a bit more attention to detail.
Also, I don't work with Marvell hardware, so I'm not all that familiar with it. I understand this only supports the SERDES as seen on the 6176 (where there is a single SERDES port), but I would appreciate if someone could take a second look at the hardware configuration in the physical interface area.
On Wed, Oct 12, 2022 at 12:50 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
v6:
really?
will fix in v7 - I updated the long msg and missed updating the short msg
- mv88e6xxx_probe:
- port_probe:
- port_enable:
really?
The SERDES configuration on the 88E6352/88E6240/88E6176/88E6172 (which I have documentation for) is not in port specific registers so I think I should move that to the probe function for the switch.
int smi_addr;
int id;
The bitfield_replace came from the original drivers/net/phy/mv88e61xx.c but I also find it easier to read logical | and << operators so I'll change to that throughout for v7
addr);
return cmd;
int val;
u32 timeout = 100;
do {
mdelay(1);
return -ETIMEDOUT;
int val;
if (val < 0)
return val;
if (val < 0)
return val;
if (val < 0)
return val;
int val, ret;
In my config there are no ports with interface == PHY_INTERFACE_MODE_INTERNAL so I'm not sure what you mean here. What situations does that come up in?
if (val < 0)
return val;
if (val < 0)
return val;
/* enable port */
if (val < 0)
return val;
if (val < 0)
return val;
It makes sense to only do this for RGMII modes but I'll need to take it out of the if (mv88e61xx_6352_famiily()) as it looks like other switches that could be supported by this driver support RGMII interfaces.
/* RGMII delays */
I'll get rid of bitfield_replace and leave these as is
/* Force Link */
if (ret < 0)
return ret;
The original mv88e61xx driver initializes SERDES in mv88e61xx_set_cpu_port() called from mv88e61xx_switch_init() called from mv88e61xx_phy_config() for the cpu port PHY, only does this for the 6172/6176/6240/6352, and the registers are not port specific:
/* If CPU is connected to serdes, initialize serdes */ if (mv88e61xx_6352_family(phydev)) { val = mv88e61xx_get_cmode(phydev, CONFIG_MV88E61XX_CPU_PORT); if (val < 0) return val; if (val == PORT_REG_STATUS_CMODE_100BASE_X || val == PORT_REG_STATUS_CMODE_1000BASE_X || val == PORT_REG_STATUS_CMODE_SGMII) { val = mv88e61xx_serdes_init(phydev); if (val < 0) return val; } }
static int mv88e61xx_serdes_init(struct phy_device *phydev) { int val;
val = mv88e61xx_set_page(phydev, DEVADDR_SERDES, PHY_PAGE_SERDES); if (val < 0) return val;
/* Power up serdes module */ val = mv88e61xx_phy_read(phydev, DEVADDR_SERDES, MII_BMCR); if (val < 0) return val; val &= ~(BMCR_PDOWN); val = mv88e61xx_phy_write(phydev, DEVADDR_SERDES, MII_BMCR, val); if (val < 0) return val;
return 0; }
So I think the proper thing to do is move this SERDES init into my mv88e6xxx_probe function.
if (val < 0)
return val;
if (ret < 0)
return ret;
I think my flaw here was that I checked c_mode for the cpu port above as you pointed out:
Changing that to mv88e6xxx_get_cmode(dev, port) should resolve that but again I'm not sure where I would be seeing an interface mode of PHY_INTERFACE_MODE_INTERNAL
goto mismatch;
break;
goto mismatch;
break;
+mismatch:
default:
break;
The only hardware I have access to for testing has a MV88E6176 and the only register documentionat I have is from the '88E6352/88E6240/88E6176/88E6172 Functional Specification' which is what the driver considers the '6352 family' of Gigabit Ethernet switches. I did manage to find a Marvell 2020 Product Selector Guide [1] that does give an outline of the various switches between pages 15 and 17 but without register definitions for the other switches all I have to go off of is the original u-boot driver and perhaps the Linux driver.
Best Regards,
Tim [1] https://jp.marvell.com/content/dam/marvell/en/psg/marvell_psg.pdf
Sorry for the late reply.
It's not in port specific registers for this switch family, because there's a single SERDES port. What you could do is you could do the SERDES initialization once per (this) switch in the per-port procedure, if the current port is a SERDES port according to the C_MODE. This would have to be done anyway for other switches. Anyway, what you did in v7 works too, you can leave it like that and others can refactor if needed (I think; I didn't look in too much detail yet).
int val, ret;
Ugh. Again the nasty Linux dt-binding legacy for this switch....
So normally, an Ethernet port has a phy-handle/fixed-link, and a phy-mode. For a port connected to an internal PHY, you should have phy-handle = <&phy> (which you do), and phy-mode = "internal" (which you don't). Linux supports skipping both the phy-handle and the phy-mode.
Sorry for not realizing this in time. This is again a thing so that U-Boot can know that you're operating on a port with an internal PHY, rather than hardcoding this based on the assumption that the SERDES port is the CPU port, and everything else has internal PHY (which assumes RGMII does not exist).
Add MV88E6XXX DSA support: - update dt to provide internal MDIO bus and port handles. U-Boot requires a more restrictive subset of the dt bindings required by Linux for the sake of simplifying code - update defconfig to remove old driver and enable new one - replace mv88e61xx_hw_reset weak override with board_phy_config support for register configuration that is outside the scope of the DSA driver
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@denx.de --- v6: - update commit message - squash accidently change to mv88e6xxx driver into previous patch - remove unused label for cpu port v5: - fix typo in defconfig s/MV88E61XX/MV88E6XXX - added Fabio's rb tag v4: - use standard Linux internal MDIO dt structure - use PHY_FIXED_ID define v3: - move mdio's mdio@0 subnode v2: no changes --- arch/arm/dts/imx6qdl-gw5904.dtsi | 32 +++++++++++++++- board/gateworks/gw_ventana/gw_ventana.c | 50 +++++++++---------------- configs/gwventana_gw5904_defconfig | 7 ++-- 3 files changed, 52 insertions(+), 37 deletions(-)
diff --git a/arch/arm/dts/imx6qdl-gw5904.dtsi b/arch/arm/dts/imx6qdl-gw5904.dtsi index 612b6e068e28..c0790183c013 100644 --- a/arch/arm/dts/imx6qdl-gw5904.dtsi +++ b/arch/arm/dts/imx6qdl-gw5904.dtsi @@ -212,6 +212,27 @@ compatible = "marvell,mv88e6085"; reg = <0>;
+ mdio { + #address-cells = <1>; + #size-cells = <0>; + + sw_phy0: ethernet-phy@0 { + reg = <0x0>; + }; + + sw_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + + sw_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + + sw_phy3: ethernet-phy@3 { + reg = <0x3>; + }; + }; + ports { #address-cells = <1>; #size-cells = <0>; @@ -219,27 +240,36 @@ port@0 { reg = <0>; label = "lan4"; + phy-handle = <&sw_phy0>; };
port@1 { reg = <1>; label = "lan3"; + phy-handle = <&sw_phy1>; };
port@2 { reg = <2>; label = "lan2"; + phy-handle = <&sw_phy2>; };
port@3 { reg = <3>; label = "lan1"; + phy-handle = <&sw_phy3>; };
port@5 { reg = <5>; - label = "cpu"; ethernet = <&fec>; + phy-mode = "rgmii-id"; + + fixed-link { + speed = <1000>; + full-duplex; + }; }; }; }; diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 99f52b9953e2..1c3da2c82707 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -83,44 +83,30 @@ int board_phy_config(struct phy_device *phydev) break; }
+ /* Fixed PHY: for GW5904/GW5909 this is Marvell 88E6176 GbE Switch */ + if (phydev->phy_id == PHY_FIXED_ID && + (board_type == GW5904 || board_type == GW5909)) { + struct mii_dev *bus = miiphy_get_dev_by_name("mdio"); + + puts("MV88E61XX "); + /* GPIO[0] output CLK125 for RGMII_REFCLK */ + bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x62 << 8) | 0xfe); + bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x68 << 8) | 7); + + /* Port 0-3 LED configuration: Table 80/82 */ + /* LED configuration: 7:4-green (8=Activity) 3:0 amber (8=Link) */ + bus->write(bus, 0x10, 0, 0x16, 0x8088); + bus->write(bus, 0x11, 0, 0x16, 0x8088); + bus->write(bus, 0x12, 0, 0x16, 0x8088); + bus->write(bus, 0x13, 0, 0x16, 0x8088); + } + if (phydev->drv->config) phydev->drv->config(phydev);
return 0; }
-#ifdef CONFIG_MV88E61XX_SWITCH -int mv88e61xx_hw_reset(struct phy_device *phydev) -{ - struct mii_dev *bus = phydev->bus; - - /* GPIO[0] output, CLK125 */ - debug("enabling RGMII_REFCLK\n"); - bus->write(bus, 0x1c /*MV_GLOBAL2*/, 0, - 0x1a /*MV_SCRATCH_MISC*/, - (1 << 15) | (0x62 /*MV_GPIO_DIR*/ << 8) | 0xfe); - bus->write(bus, 0x1c /*MV_GLOBAL2*/, 0, - 0x1a /*MV_SCRATCH_MISC*/, - (1 << 15) | (0x68 /*MV_GPIO01_CNTL*/ << 8) | 7); - - /* RGMII delay - Physical Control register bit[15:14] */ - debug("setting port%d RGMII rx/tx delay\n", CONFIG_MV88E61XX_CPU_PORT); - /* forced 1000mbps full-duplex link */ - bus->write(bus, 0x10 + CONFIG_MV88E61XX_CPU_PORT, 0, 1, 0xc0fe); - phydev->autoneg = AUTONEG_DISABLE; - phydev->speed = SPEED_1000; - phydev->duplex = DUPLEX_FULL; - - /* LED configuration: 7:4-green (8=Activity) 3:0 amber (8=Link) */ - bus->write(bus, 0x10, 0, 0x16, 0x8088); - bus->write(bus, 0x11, 0, 0x16, 0x8088); - bus->write(bus, 0x12, 0, 0x16, 0x8088); - bus->write(bus, 0x13, 0, 0x16, 0x8088); - - return 0; -} -#endif // CONFIG_MV88E61XX_SWITCH - #if defined(CONFIG_VIDEO_IPUV3) static void enable_hdmi(struct display_info_t const *dev) { diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index fb5870fa5803..50115b21e263 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -109,13 +109,12 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y -CONFIG_MV88E61XX_SWITCH=y -CONFIG_MV88E61XX_CPU_PORT=5 -CONFIG_MV88E61XX_PHY_PORTS=0xf -CONFIG_MV88E61XX_FIXED_PORTS=0x0 +CONFIG_PHY_FIXED=y CONFIG_DM_MDIO=y +CONFIG_DM_DSA=y CONFIG_E1000=y CONFIG_FEC_MXC=y +CONFIG_MV88E6XXX=y CONFIG_MII=y CONFIG_PCI=y CONFIG_PCIE_IMX=y
Tim Harvey
Vladimir Oltean
