[U-Boot] [RFC][PATCH 14/19] nand_fsl_nfc: get rid of local var
If we have -fPIC enabled, this var leads in one entry in the GOT. The result of this is that the image size is > 0x800.
Signed-off-by: Heiko Schocher hs@denx.de --- I tried to fix this in the u-boot.lds, but without success. If somebody knows, how to fix this without this patch, it would be great!
nand_spl/nand_boot_fsl_nfc.c | 14 ++++++++------ 1 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index 9720f6a..0543512 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -34,10 +34,9 @@ #include <asm/io.h> #include <fsl_nfc.h>
-struct fsl_nfc_regs *nfc; - static void nfc_wait_ready(void) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; uint32_t tmp;
while (!(readw(&nfc->nand_flash_config2) & NFC_INT)) @@ -51,6 +50,7 @@ static void nfc_wait_ready(void)
void nfc_nand_init(void) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; #if defined(MXC_NFC_V1_1) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1; @@ -82,6 +82,7 @@ void nfc_nand_init(void)
static void nfc_nand_command(unsigned short command) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; writew(command, &nfc->flash_cmd); writew(NFC_CMD, &nfc->nand_flash_config2); nfc_wait_ready(); @@ -89,6 +90,7 @@ static void nfc_nand_command(unsigned short command)
static void nfc_nand_page_address(unsigned int page_address) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; unsigned int page_count;
writew(0x00, &nfc->flash_add); @@ -122,6 +124,7 @@ static void nfc_nand_page_address(unsigned int page_address)
static void nfc_nand_data_output(void) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; int config1 = readw(&nfc->nand_flash_config1); #ifdef NAND_MXC_2K_MULTI_CYCLE int i; @@ -150,11 +153,13 @@ static void nfc_nand_data_output(void)
static int nfc_nand_check_ecc(void) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; return readw(&nfc->ecc_status_result); }
static int nfc_read_page(unsigned int page_address, unsigned char *buf) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; int i; u32 *src; u32 *dst; @@ -186,6 +191,7 @@ static int nfc_read_page(unsigned int page_address, unsigned char *buf)
static int is_badblock(int pagenumber) { + struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR; int page = pagenumber; u32 badblock; u32 *src; @@ -228,8 +234,6 @@ static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) unsigned int maxpages = CONFIG_SYS_NAND_SIZE / CONFIG_SYS_NAND_PAGE_SIZE;
- nfc = (void *)NFC_BASE_ADDR; - nfc_nand_init();
/* Convert to page number */ @@ -279,8 +283,6 @@ void nand_boot(void) { __attribute__((noreturn)) void (*uboot)(void);
- nfc = (void *)NFC_BASE_ADDR; - /* * CONFIG_SYS_NAND_U_BOOT_OFFS and CONFIG_SYS_NAND_U_BOOT_SIZE must * be aligned to full pages
Acked-by: Scott Wood scottwood@freescale.com
- struct fsl_nfc_regs *nfc = (void *)NFC_BASE_ADDR;
Alternatively, would this work at file scope?
static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR;
-Scott
Hello Scott,
Great tip! Thanks, this works also, I fix this in version 2
bye Heiko
If we have -fPIC enabled, this var leads in one entry in the GOT. The result of this is that the image size is > 0x800. So make it a "static const" and this brings the size again < 0x800
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Scott Wood scottwood@freescale.com ---
- changes since v1 add comment from Scott Wood: - make the var nfc static const
nand_spl/nand_boot_fsl_nfc.c | 6 +----- 1 files changed, 1 insertions(+), 5 deletions(-)
diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index 9720f6a..50d6ea9 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -34,7 +34,7 @@ #include <asm/io.h> #include <fsl_nfc.h>
-struct fsl_nfc_regs *nfc; +static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR;
static void nfc_wait_ready(void) { @@ -228,8 +228,6 @@ static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) unsigned int maxpages = CONFIG_SYS_NAND_SIZE / CONFIG_SYS_NAND_PAGE_SIZE;
/* Convert to page number */ @@ -279,8 +277,6 @@ void nand_boot(void) { __attribute__((noreturn)) void (*uboot)(void);
Heiko Schocher
Scott Wood
