[U-Boot] [PATCH 1/3] spi: fsl_qspi: fix an error of using GENMASK
This commit fixes the change of bad490a24212c068c5b718b9189f47ea4075d078.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- drivers/spi/fsl_qspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index ed39114..d8d37cd 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -24,7 +24,7 @@ DECLARE_GLOBAL_DATA_PTR; #define TX_BUFFER_SIZE 0x40 #endif
-#define OFFSET_BITS_MASK GENMASK(24, 0) +#define OFFSET_BITS_MASK GENMASK(23, 0)
#define FLASH_STATUS_WEL 0x02
This patch fixes the following compile warning: drivers/spi/fsl_qspi.c: In function 'fsl_qspi_probe': drivers/spi/fsl_qspi.c:937:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] priv->regs = (struct fsl_qspi_regs *)plat->reg_base; ^ Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index d8d37cd..755cc27 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -931,7 +931,7 @@ static int fsl_qspi_probe(struct udevice *bus)
dm_spi_bus->max_hz = plat->speed_hz;
- priv->regs = (struct fsl_qspi_regs *)plat->reg_base; + priv->regs = (struct fsl_qspi_regs *)(unsigned long)plat->reg_base; priv->flags = plat->flags;
priv->speed_hz = plat->speed_hz;
Gong Qianyu
