[U-Boot] [PATCH] fdt: Add function to alloc phandle values
If we are creating reference (handles) to nodes in a device tree we need to first create a new phandle in node and this needs a new phandle value. So we search through the whole dtb to find the max phandle value and return the next greater value for a new phandle allocation.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- common/fdt_support.c | 16 ++++++++++++++++ include/fdt_support.h | 1 + 2 files changed, 17 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 718b635..30c662a 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1151,4 +1151,20 @@ int fdt_node_offset_by_compat_reg(void *blob, const char *compat, return -FDT_ERR_NOTFOUND; }
+/** + * fdt_alloc_phandle: Return next free phandle value + * + * @blob: ptr to device tree + */ +int fdt_alloc_phandle(void *blob) +{ + int offset, len, phandle = 0; + const u32 *val; + for (offset = fdt_next_node(blob, -1, NULL); offset >= 0; + offset = fdt_next_node(blob, offset, NULL)) { + val = fdt_getprop(blob, offset, "linux,phandle", &len); + if (val) phandle = max(*val, phandle); + }
+ return phandle + 1; +} diff --git a/include/fdt_support.h b/include/fdt_support.h index 54af9fe..871ef45 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -86,6 +86,7 @@ void fdt_del_node_and_alias(void *blob, const char *alias); u64 fdt_translate_address(void *blob, int node_offset, const u32 *in_addr); int fdt_node_offset_by_compat_reg(void *blob, const char *compat, phys_addr_t compat_off); +int fdt_alloc_phandle(void *blob);
#endif /* ifdef CONFIG_OF_LIBFDT */ #endif /* ifndef __FDT_SUPPORT_H */
const u32 *val;
return phandle + 1;
If you incorporate my patch titled, "libfdt: introduce function fdt_get_max_phandle", you can simplify this function.
Wolfgang rejected that patch because I didn't include any code that called fdt_get_max_phandle(). I see you're doing the same thing here with fdt_alloc_phandle(). It will be interesting to see if Wolfgang rejects your patch.
Hello.
- fdt_alloc_phandle: Return next free phandle value
- @blob: ptr to device tree
- int offset, len, phandle = 0;
- const u32 *val;
Shouldn't there be an emoty line after declarations?
You indented the above 3 lines with spaces, other with tabs.
Another space-indented line...
WBR, Sergei
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Hopefully fixed white space issues
common/fdt_support.c | 18 ++++++++++++++++++ include/fdt_support.h | 1 + 2 files changed, 19 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 718b635..65751aa 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1151,4 +1151,22 @@ int fdt_node_offset_by_compat_reg(void *blob, const char *compat, return -FDT_ERR_NOTFOUND; }
+ for (offset = fdt_next_node(blob, -1, NULL); offset >= 0; + offset = fdt_next_node(blob, offset, NULL)) { + val = fdt_getprop(blob, offset, "linux,phandle", &len); + if (val) + phandle = max(*val, phandle); + } + + return phandle + 1; +} diff --git a/include/fdt_support.h b/include/fdt_support.h index 54af9fe..871ef45 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -86,6 +86,7 @@ void fdt_del_node_and_alias(void *blob, const char *alias); u64 fdt_translate_address(void *blob, int node_offset, const u32 *in_addr); int fdt_node_offset_by_compat_reg(void *blob, const char *compat, phys_addr_t compat_off); +int fdt_alloc_phandle(void *blob);
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Try this whitespace cleanup again
diff --git a/common/fdt_support.c b/common/fdt_support.c index 718b635..166f5e1 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1151,4 +1151,22 @@ int fdt_node_offset_by_compat_reg(void *blob, const char *compat, return -FDT_ERR_NOTFOUND; }
+/** + * fdt_alloc_phandle: Return next free phandle value + * + * @blob: ptr to device tree + */ +int fdt_alloc_phandle(void *blob) +{ + int offset, len, phandle = 0; + const u32 *val; + + for (offset = fdt_next_node(blob, -1, NULL); offset >= 0; + offset = fdt_next_node(blob, offset, NULL)) { + val = fdt_getprop(blob, offset, "linux,phandle", &len); + if (val) + phandle = max(*val, phandle); + }
I still think you should merge my fdt_get_max_phandle() function into this patch. The two functions are related and can share code.
I'm replacing fdt_get_max_phandle w/fdt_alloc_phandle in our tree's. As what we are doing is allocating a phandle value.
- k
Signed-off-by: Kumar Galagalak@kernel.crashing.org
Acked-by: Gerald Van Baren vanbaren@cideas.com
Best regards, gvb
- Try this whitespace cleanup again
Best regards, gvb
applied to 85xx
- k
Jerry Van Baren
Kumar Gala
Sergei Shtylyov
Timur Tabi
