[PATCH] bootstd: fix build error when CONFIG_MMC is disabled
This code assumes that CONFIG_MMC and it causes a build error when the config is disabled.
aarch64-linux-gnu-ld.bfd: test/boot/bootstd_common.o: in function `bootstd_test_check_mmc_hunter': test/boot/bootstd_common.c:83:(.text.bootstd_test_check_mmc_hunter+0x70): undefined reference to `_u_boot_list_2_bootdev_hunter_2_mmc_bootdev_hunter'
Fixes: 66e3dce78750 ("bootstd: Allow hunting for a bootdev by label") Signed-off-by: Dan Carpenter dan.carpenter@linaro.org --- test/boot/bootstd_common.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/test/boot/bootstd_common.c b/test/boot/bootstd_common.c index e71a2975c53c..cc97e255e5cb 100644 --- a/test/boot/bootstd_common.c +++ b/test/boot/bootstd_common.c @@ -74,6 +74,9 @@ int bootstd_test_check_mmc_hunter(struct unit_test_state *uts) struct bootstd_priv *std; uint seq;
+ if (!IS_ENABLED(CONFIG_MMC)) + return 0; + /* get access to the used hunters */ ut_assertok(bootstd_get_priv(&std));
Dan Carpenter
