[U-Boot] [PATCH V0] omap-common: move early UART clock setup to board.c
This patch moves the setup_clocks_for_console()-call from preloader_console_init() to s_init(). This is done to use the same implementation for OMAP3 and OMAP4
For discussion see: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/104120
This is based on the following patches: - New SPL framework - OMAP4 SPL Both are already in u-boot-ti repo.
Simon Schwarz (1): omap-common: move early UART clock setup to s_init
arch/arm/cpu/armv7/omap-common/spl.c | 1 - arch/arm/cpu/armv7/omap4/board.c | 1 + 2 files changed, 1 insertions(+), 1 deletions(-)
Moves the early UART clock setup setup_clocks_for_console() from preloader_console_init() to s_init() of OMAP4.
Signed-off-by: Simon Schwarz simonschwarzcor@gmail.com --- arch/arm/cpu/armv7/omap-common/spl.c | 1 - arch/arm/cpu/armv7/omap4/board.c | 1 + 2 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index d177652..d380b3e 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -259,7 +259,6 @@ void preloader_console_init(void) gd->flags |= GD_FLG_RELOC; gd->baudrate = CONFIG_BAUDRATE;
- setup_clocks_for_console(); serial_init(); /* serial communications setup */
/* Avoid a second "U-Boot" coming from this string */ diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 5943d61..a9e90de 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -196,6 +196,7 @@ void s_init(void) watchdog_init(); set_mux_conf_regs(); #ifdef CONFIG_SPL_BUILD + setup_clocks_for_console(); preloader_console_init(); #endif prcm_init();
Hi Simon,
Am 28.07.2011 11:22, schrieb Simon Schwarz:
I recommend putting this in your 'devkit8000 nand_spl support' series before the current '2/5 omap-common: add nand_spl support' and remove the '#ifdef CONFIG_OMAP34XX' in that patch. Albert how do you think about this?
I recommend adding some comment for preloader_console_init() saying 'this requires UART clocks to be enabled before' in this patch.
regards
Andreas Bießmann
Hi Andreas,
On 07/28/2011 11:44 AM, Andreas Bießmann wrote:
Hi Simon,
Since no one objected: I will do this in the next version.
Signed-off-by: Simon Schwarzsimonschwarzcor@gmail.com
Will do.
regards
Andreas Bießmann
Regards Simon
Dear Simon Schwarz,
In message 1311844938-17278-2-git-send-email-simonschwarzcor@gmail.com you wrote:
I'm unhappy about the subject. not to mention again that you posted another (empty) patch with basicly the same subject line, but you say "omap-common:" in the subject, while the code looks to be OMAP4 specific? This is kind of misleading.
Dear Wolfgang Denk,
On 07/28/2011 03:04 PM, Wolfgang Denk wrote:
Dear Simon Schwarz,
In message1311844938-17278-2-git-send-email-simonschwarzcor@gmail.com you wrote:
Reason: omap-common because it is a omap-common change - the omap4 part is just to fix it up for the SOC which is using it already.
So maybe deleting setup_clocks_for_console() would have been a better subject, sorry.
Regards Simon Schwarz
Dear Simon Schwarz,
In message 1311844938-17278-1-git-send-email-simonschwarzcor@gmail.com you wrote:
- New SPL framework
There is no patch in this file anywhere.
Also, please omit the "V0" part in the subject, it makes no sense.
Finally, please don't use the same subject for several changes.
Dear Wolfgang Denk,
On 07/28/2011 03:02 PM, Wolfgang Denk wrote:
Dear Simon Schwarz,
In message1311844938-17278-1-git-send-email-simonschwarzcor@gmail.com you wrote:
- New SPL framework
No cover-letter for patch series - bad idea - noted.
ok.
Andreas Bießmann
Simon Schwarz
