[U-Boot] __mmc_get_env_addr() is not being called?
I'm running v2011.12-rc1 (with one missing usdhc patch applied) on mx6qarm2 board, and seeing a problem. When I install u-boot on a blank SD card, it boots fine with messge "*** Warning - bad CRC, using default environment" seen as expected. But once I run command 'save' to write envs to the card, the card stop booting.
I tracked the issue a little bit, and found __mmc_get_env_addr() does not get called at all. Therefore when I run 'save' for the first time, the envs are written to offset 0 of the card, which in turn overwrites the boot image.
I have not figured out why it does. But the following change fixes the problem for me.
diff --git a/common/env_mmc.c b/common/env_mmc.c index 8441c77..3832fe4 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -46,13 +46,11 @@ DECLARE_GLOBAL_DATA_PTR; #define CONFIG_ENV_OFFSET 0 #endif
-static int __mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) +static int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) { *env_addr = CONFIG_ENV_OFFSET; return 0; } -int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) - __attribute__((weak, alias("__mmc_get_env_addr")));
Any comment on why the change fixes the problem is appreciated.
On 16/12/2011 06:54, Shawn Guo wrote:
Hi Shawn,
The function is declared weak, this means that a specific architecture could implement its own version. The reason why it does not work is that there is a specific implementation in board/freescale/sdhc_boot.c, and the mmc_get_env_addr() in this file is taken instead of the default when CONFIG_ENV_IS_IN_MMC (as in our case) is set. Instead of your proposal, we should surround mmc_get_env_addr() in sdhc_boot.c with something like #ifndef CONFIG_MX6Q, or check if we can reuse this function, that really does not use CONFIG_ENV_OFFSET at all.
I put Jason (board maintainer) in CC - Jason, what do mind ? Do you get the same issue when you tested the board ?
Best regards, Stefano Babic
2011/12/16 Stefano Babic sbabic@denx.de:
Hi Shawn,
Stefano, I saw the issue. Fabio's patch can fix the i.mx28evk issue, but can't fix the following platforms:
11 144 include/configs/efikamx.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 12 86 include/configs/mx51evk.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 13 58 include/configs/mx53ard.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 14 68 include/configs/mx53evk.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 15 51 include/configs/mx53loco.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 16 58 include/configs/mx53smd.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 17 48 include/configs/mx6qarm2.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 18 48 include/configs/mx6qsabrelite.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC 20 105 include/configs/vision2.h <<CONFIG_FSL_ESDHC>> #define CONFIG_FSL_ESDHC
The commit 97039ab98 (env_mmc: Allow board code to override the environment address) break the i.mx5/6 boards support.
BR, Jason
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de ===================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
This is the same behavior I saw on mx28evk as well and I sent this patch to fix it: http://lists.denx.de/pipermail/u-boot/2011-November/111448.html
The weak function was introduced by this commit: http://git.denx.de/?p=u-boot.git;a=commitdiff;h=97039ab98c551c7860bc0977d684...
which breaks non CONFIG_FSL_ESDHC users.
Regards,
Fabio Estevam
Ok, I see - the patch is more related to Freescale SOCs as to the MMC, and it is sometimes unknown who whould pick it up.
Andy, not CONFIG_FSL_ESDHC means IMX users - if you do not complain, I merge it into u-boot-imx.
Thanks, Stefano
Thanks, Stefano
If I'm reading the patch correct it will break things (or I'm not sure which patch you're referring to). How would the PPC specific version ever get called?
- k
Thanks, Stefano
Yes, I was too optimistic with the patch, I have myself seen that the patch then break PowerPC boards.
Reading sdhc_boot.c, this file is not strictly related to PowerPC or IMX hardware, but where u-boot image is stored on PowerPC code.
This is like a specific feature, but there is not a specific CONFIG_ for it. In fact, in board/freescale/common/Makefile the file is always compiled if CONFIG_RAMBOOT_PBL (not significant for imx) is not set if the environment is in MMC:
ifndef CONFIG_RAMBOOT_PBL COBJS-$(CONFIG_ENV_IS_IN_MMC) += sdhc_boot.o endif
What about to have a specific CONFIG_FSL_* for this file ? It can be defined for PowerPC boards, and it will not for IMX. Any thoughts ?
Stefano
Thanks, Stefano
I agree with this option. Also Cced: Chang-Ming.Huang@freescale.com
Stefano
participants (6)
Fabio Estevam
Jason Hui
Jason Liu
Kumar Gala
Shawn Guo
Stefano Babic
