[U-Boot] [PATCH v1] colibri_vf: fix ethernet by adding explicit phy node
The implicit fallback mechanism for searching the whole MDIO bus for at least one PHY has been gone with the following commit b882005a18de ("drivers/net/fec: phy_init: remove redundant logic"). This lead to the Ethernet driver erroring out as follows:
Net: Could not get PHY for FEC0: addr -19 eth-1: fec@400d1000 Colibri VFxx # dhcp Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 No ethernet found. Could not get PHY for FEC0: addr -19 Colibri VFxx #
This commit adds an explicit PHY node which makes it work again.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
arch/arm/dts/vf-colibri.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/vf-colibri.dtsi b/arch/arm/dts/vf-colibri.dtsi index 5ce17076e9..91ca4e4ddd 100644 --- a/arch/arm/dts/vf-colibri.dtsi +++ b/arch/arm/dts/vf-colibri.dtsi @@ -60,11 +60,24 @@ status = "okay"; };
+/* Ethernet */ &fec1 { phy-mode = "rmii"; + phy-handle = <ðphy1>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec1>; status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + max-speed = <100>; + reg = <1>; + }; + }; };
&i2c0 {
Marcel Ziswiler marcel@ziswiler.com schrieb am 28.03.2019 23:24:50:
Von: Marcel Ziswiler marcel@ziswiler.com An: u-boot@lists.denx.de Kopie: Hannes Schmelzer hannes.schmelzer@br-automation.com, Marcel
Ziswiler
marcel.ziswiler@toradex.com, Albert Aribaud
Stefan Agner stefan.agner@toradex.com Datum: 28.03.2019 23:25 Betreff: [PATCH v1] colibri_vf: fix ethernet by adding explicit phy node
Looks good to me, now the hardware is fully defined, which should be the normal case.
I will provide today a patch which "brings back" the fallback mechanism within the "phy-subsystem". This should be the starting point for the disussion if we need such fallback or if we want describe our hardware.
Reviewed-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
mdio {
#size-cells = <0>;
max-speed = <100>;
reg = <1>;
&i2c0 {
2.20.1
From: Marcel Ziswiler marcel.ziswiler@toradex.com The implicit fallback mechanism for searching the whole MDIO bus for at least one PHY has been gone with the following commit b882005a18de ("drivers/net/fec: phy_init: remove redundant logic"). This lead to the Ethernet driver erroring out as follows: Net: Could not get PHY for FEC0: addr -19 eth-1: fec@400d1000 Colibri VFxx # dhcp Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 Could not get PHY for FEC0: addr -19 No ethernet found. Could not get PHY for FEC0: addr -19 Colibri VFxx # This commit adds an explicit PHY node which makes it work again. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Hannes Schmelzer hannes.schmelzer@br-automation.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Best regards, Stefano Babic
Hannes Schmelzer
Igor Opaniuk
Marcel Ziswiler
sbabic@denx.de
