[U-Boot] [PATCH] dts: Kconfig: Fix help for SPL_OF_CONTROL
As initially this feature was implemented as a negative CONFIG and later it was redesigned to be positive the help text should be updated to reflect this change.
This commit updates the help text to match the current implementation.
Signed-off-by: Walter Lozano wlozano@collabora.com --- dts/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/dts/Kconfig b/dts/Kconfig index c9ab66cccc..424193dfad 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -44,7 +44,7 @@ config SPL_OF_CONTROL depends on SPL && OF_CONTROL help Some boards use device tree in U-Boot but only have 4KB of SRAM - which is not enough to support device tree. Enable this option to + which is not enough to support device tree. Disable this option to allow such boards to be supported by U-Boot SPL.
config TPL_OF_CONTROL
Signed-off-by: Walter Lozano wlozano@collabora.com Reviewed-by: Simon Glass sjg@chromium.org
Walter Lozano
