[PATCH 1/3] clk: imx: imx8mn: add enet clk
Add enet ref/timer/PHY_REF/root clk wich are required to make enet work properly
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com --- drivers/clk/imx/clk-imx8mn.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index eb43971ae6..103ba770ed 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -80,6 +80,17 @@ static const char *imx8mn_ahb_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_p static const char *imx8mn_enet_axi_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_250m", "sys_pll2_200m", "audio_pll1_out", "video_pll1_out", "sys_pll3_out", };
+#ifndef CONFIG_SPL_BUILD +static const char *imx8mn_enet_ref_sels[] = {"clock-osc-24m", "sys_pll2_125m", "sys_pll2_50m", "sys_pll2_100m", + "sys_pll1_160m", "audio_pll1_out", "video_pll1_out", "clk_ext4", }; + +static const char *imx8mn_enet_timer_sels[] = {"clock-osc-24m", "sys_pll2_100m", "audio_pll1_out", "clk_ext1", "clk_ext2", + "clk_ext3", "clk_ext4", "video_pll1_out", }; + +static const char *imx8mn_enet_phy_sels[] = {"clock-osc-24m", "sys_pll2_50m", "sys_pll2_125m", "sys_pll2_200m", + "sys_pll2_500m", "video_pll1_out", "audio_pll2_out", }; +#endif + static const char *imx8mn_nand_usdhc_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_200m", "sys_pll1_133m", "sys_pll3_out", "sys_pll2_250m", "audio_pll1_out", };
@@ -363,6 +374,14 @@ static int imx8mn_clk_probe(struct udevice *dev) clk_dm(IMX8MN_CLK_USDHC3_ROOT, imx_clk_gate4("usdhc3_root_clk", "usdhc3", base + 0x45e0, 0));
+/* clks not needed in SPL stage */ +#ifndef CONFIG_SPL_BUILD + clk_dm(IMX8MN_CLK_ENET_REF, imx8m_clk_composite("enet_ref", imx8mn_enet_ref_sels, base + 0xa980)); + clk_dm(IMX8MN_CLK_ENET_TIMER, imx8m_clk_composite("enet_timer", imx8mn_enet_timer_sels, base + 0xaa00)); + clk_dm(IMX8MN_CLK_ENET_PHY_REF, imx8m_clk_composite("enet_phy", imx8mn_enet_phy_sels, base + 0xaa80)); + clk_dm(IMX8MN_CLK_ENET1_ROOT, imx_clk_gate4("enet1_root_clk", "enet_axi", base + 0x40a0, 0)); +#endif + #ifdef CONFIG_SPL_BUILD struct clk *clkp, *clkp1;
Add set_parent callback, then assigned-clock-parents in dts could work properly
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index 103ba770ed..2abd9a3810 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -175,11 +175,30 @@ static int imx8mn_clk_enable(struct clk *clk) return __imx8mn_clk_enable(clk, 1); }
+static int imx8mn_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct clk *c, *cp; + int ret; + + debug("%s(#%lu), parent: %lu\n", __func__, clk->id, parent->id); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + ret = clk_get_by_id(parent->id, &cp); + if (ret) + return ret; + + return clk_set_parent(c, cp); +} + static struct clk_ops imx8mn_clk_ops = { .set_rate = imx8mn_clk_set_rate, .get_rate = imx8mn_clk_get_rate, .enable = imx8mn_clk_enable, .disable = imx8mn_clk_disable, + .set_parent = imx8mn_clk_set_parent, };
Enable ethernet on i.MX 8MN EVK
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com --- arch/arm/dts/imx8mn-ddr4-evk.dts | 2 ++ board/freescale/imx8mn_evk/imx8mn_evk.c | 36 +++++++++++++++++++++++++ configs/imx8mn_ddr4_evk_defconfig | 8 ++++++ include/configs/imx8mn_evk.h | 2 ++ 4 files changed, 48 insertions(+)
diff --git a/arch/arm/dts/imx8mn-ddr4-evk.dts b/arch/arm/dts/imx8mn-ddr4-evk.dts index 9b2c1727a8..53ce10b13d 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk.dts +++ b/arch/arm/dts/imx8mn-ddr4-evk.dts @@ -165,6 +165,8 @@ pinctrl-0 = <&pinctrl_fec1>; phy-mode = "rgmii-id"; phy-handle = <ðphy0>; + phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; + phy-reset-duration = <10>; fsl,magic-packet; status = "okay";
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index 4f33c0e7c9..9ff1dc8555 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -4,6 +4,10 @@ */
#include <common.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/clock.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -14,8 +18,40 @@ int dram_init(void) return 0; }
+#if IS_ENABLED(CONFIG_FEC_MXC) +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], 0x2000, 0); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + int board_init(void) { + if (IS_ENABLED(CONFIG_FEC_MXC)) + setup_fec(); + return 0; }
diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index e3f99896a6..0e21283d58 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -43,6 +43,9 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT2=y @@ -67,7 +70,12 @@ CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index ce73ca6b0a..bfc1a55637 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -149,4 +149,6 @@
#define CONFIG_SYS_I2C_SPEED 100000
+#define FEC_QUIRK_ENET_MAC + #endif
Hi Alifer,
Why have you sent those patches twice?
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index eb43971ae6..103ba770ed 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -80,6 +80,17 @@ static const char *imx8mn_ahb_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_p static const char *imx8mn_enet_axi_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_250m", "sys_pll2_200m", "audio_pll1_out", "video_pll1_out", "sys_pll3_out", }; +#ifndef CONFIG_SPL_BUILD +static const char *imx8mn_enet_ref_sels[] = {"clock-osc-24m", "sys_pll2_125m", "sys_pll2_50m", "sys_pll2_100m",
"sys_pll1_160m",
"clk_ext3",
"sys_pll2_500m",
static const char *imx8mn_nand_usdhc_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_200m", "sys_pll1_133m", "sys_pll3_out", "sys_pll2_250m", "audio_pll1_out", }; @@ -363,6 +374,14 @@ static int imx8mn_clk_probe(struct udevice *dev) clk_dm(IMX8MN_CLK_USDHC3_ROOT, imx_clk_gate4("usdhc3_root_clk", "usdhc3", base + 0x45e0, 0)); +/* clks not needed in SPL stage */ +#ifndef CONFIG_SPL_BUILD
- clk_dm(IMX8MN_CLK_ENET_REF, imx8m_clk_composite("enet_ref",
- clk_dm(IMX8MN_CLK_ENET_TIMER,
- clk_dm(IMX8MN_CLK_ENET_PHY_REF,
- clk_dm(IMX8MN_CLK_ENET1_ROOT,
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Alifer,
Hello Lukasz,
I'm sorry for that,
I was just curious if you made a v2 :-)
the first time I sent this patch I forgot to send to u-boot lists too, so I sent it again.
Regards, Alifer
Lukasz Majewski
Alifer Moraes
Lukasz Majewski
