[U-Boot-Users] [PATCH 2/3] OneNAND support (take #2)
OneNAND support at U-Boot
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/drivers/onenand/Makefile b/drivers/onenand/Makefile new file mode 100644 index 0000000..5d7a471 --- /dev/null +++ b/drivers/onenand/Makefile @@ -0,0 +1,44 @@ +# +# Copyright (C) 2005-2007 Samsung Electronics. +# Kyungmin Park kyungmin.park@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libonenand.a + +COBJS := onenand_base.o onenand_bbt.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/drivers/onenand/onenand_bbt.c b/drivers/onenand/onenand_bbt.c new file mode 100644 index 0000000..5a610ee --- /dev/null +++ b/drivers/onenand/onenand_bbt.c @@ -0,0 +1,265 @@ +/* + * linux/drivers/mtd/onenand/onenand_bbt.c + * + * Bad Block Table support for the OneNAND driver + * + * Copyright(c) 2005-2007 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * TODO: + * Split BBT core and chip specific BBT. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <common.h> + +#ifdef CONFIG_CMD_ONENAND + +#include <linux/mtd/compat.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/onenand.h> +#include <malloc.h> + +#include <asm/errno.h> + +/** + * check_short_pattern - [GENERIC] check if a pattern is in the buffer + * @param buf the buffer to search + * @param len the length of buffer to search + * @param paglen the pagelength + * @param td search pattern descriptor + * + * Check for a pattern at the given place. Used to search bad block + * tables and good / bad block identifiers. Same as check_pattern, but + * no optional empty check and the pattern is expected to start + * at offset 0. + */ +static int check_short_pattern(uint8_t * buf, int len, int paglen, + struct nand_bbt_descr *td) +{ + int i; + uint8_t *p = buf; + + /* Compare the pattern */ + for (i = 0; i < td->len; i++) { + if (p[i] != td->pattern[i]) + return -1; + } + return 0; +} + +/** + * create_bbt - [GENERIC] Create a bad block table by scanning the device + * @param mtd MTD device structure + * @param buf temporary buffer + * @param bd descriptor for the good/bad block search pattern + * @param chip create the table for a specific chip, -1 read all chips. + * Applies only if NAND_BBT_PERCHIP option is set + * + * Create a bad block table by scanning the device + * for the given good/bad block identify pattern + */ +static int create_bbt(struct mtd_info *mtd, uint8_t * buf, + struct nand_bbt_descr *bd, int chip) +{ + struct onenand_chip *this = mtd->priv; + struct bbm_info *bbm = this->bbm; + int i, j, numblocks, len, scanlen; + int startblock; + loff_t from; + size_t readlen, ooblen; + + printk(KERN_INFO "Scanning device for bad blocks\n"); + + len = 1; + + /* We need only read few bytes from the OOB area */ + scanlen = ooblen = 0; + readlen = bd->len; + + /* chip == -1 case only */ + /* Note that numblocks is 2 * (real numblocks) here; + * see i += 2 below as it makses shifting and masking less painful + */ + numblocks = mtd->size >> (bbm->bbt_erase_shift - 1); + startblock = 0; + from = 0; + + for (i = startblock; i < numblocks;) { + int ret; + + for (j = 0; j < len; j++) { + size_t retlen; + + /* No need to read pages fully, + * just read required OOB bytes */ + ret = onenand_read_oob(mtd, + from + j * mtd->oobblock + + bd->offs, readlen, &retlen, + &buf[0]); + + if (ret && ret != -EAGAIN) { + printk("ret = %d\n", ret); + return ret; + } + + if (check_short_pattern + (&buf[j * scanlen], scanlen, mtd->oobblock, bd)) { + bbm->bbt[i >> 3] |= 0x03 << (i & 0x6); + printk(KERN_WARNING + "Bad eraseblock %d at 0x%08x\n", i >> 1, + (unsigned int)from); + break; + } + } + i += 2; + from += (1 << bbm->bbt_erase_shift); + } + + return 0; +} + +/** + * onenand_memory_bbt - [GENERIC] create a memory based bad block table + * @param mtd MTD device structure + * @param bd descriptor for the good/bad block search pattern + * + * The function creates a memory based bbt by scanning the device + * for manufacturer / software marked good / bad blocks + */ +static inline int onenand_memory_bbt(struct mtd_info *mtd, + struct nand_bbt_descr *bd) +{ + unsigned char data_buf[MAX_ONENAND_PAGESIZE]; + + bd->options &= ~NAND_BBT_SCANEMPTY; + return create_bbt(mtd, data_buf, bd, -1); +} + +/** + * onenand_isbad_bbt - [OneNAND Interface] Check if a block is bad + * @param mtd MTD device structure + * @param offs offset in the device + * @param allowbbt allow access to bad block table region + */ +static int onenand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt) +{ + struct onenand_chip *this = mtd->priv; + struct bbm_info *bbm = this->bbm; + int block; + uint8_t res; + + /* Get block number * 2 */ + block = (int)(offs >> (bbm->bbt_erase_shift - 1)); + res = (bbm->bbt[block >> 3] >> (block & 0x06)) & 0x03; + + DEBUG(MTD_DEBUG_LEVEL2, + "onenand_isbad_bbt: bbt info for offs 0x%08x: (block %d) 0x%02x\n", + (unsigned int)offs, block >> 1, res); + + switch ((int)res) { + case 0x00: + return 0; + case 0x01: + return 1; + case 0x02: + return allowbbt ? 0 : 1; + } + + return 1; +} + +/** + * onenand_scan_bbt - [OneNAND Interface] scan, find, read and maybe create bad block table(s) + * @param mtd MTD device structure + * @param bd descriptor for the good/bad block search pattern + * + * The function checks, if a bad block table(s) is/are already + * available. If not it scans the device for manufacturer + * marked good / bad blocks and writes the bad block table(s) to + * the selected place. + * + * The bad block table memory is allocated here. It must be freed + * by calling the onenand_free_bbt function. + * + */ +int onenand_scan_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd) +{ + struct onenand_chip *this = mtd->priv; + struct bbm_info *bbm = this->bbm; + int len, ret = 0; + + len = mtd->size >> (this->erase_shift + 2); + /* Allocate memory (2bit per block) */ + bbm->bbt = malloc(len); + if (!bbm->bbt) { + printk(KERN_ERR "onenand_scan_bbt: Out of memory\n"); + return -ENOMEM; + } + /* Clear the memory bad block table */ + memset(bbm->bbt, 0x00, len); + + /* Set the bad block position */ + bbm->badblockpos = ONENAND_BADBLOCK_POS; + + /* Set erase shift */ + bbm->bbt_erase_shift = this->erase_shift; + + if (!bbm->isbad_bbt) + bbm->isbad_bbt = onenand_isbad_bbt; + + /* Scan the device to build a memory based bad block table */ + if ((ret = onenand_memory_bbt(mtd, bd))) { + printk(KERN_ERR + "onenand_scan_bbt: Can't scan flash and build the RAM-based BBT\n"); + free(bbm->bbt); + bbm->bbt = NULL; + } + + return ret; +} + +/* + * Define some generic bad / good block scan pattern which are used + * while scanning a device for factory marked good / bad blocks. + */ +static uint8_t scan_ff_pattern[] = { 0xff, 0xff }; + +static struct nand_bbt_descr largepage_memorybased = { + .options = 0, + .offs = 0, + .len = 2, + .pattern = scan_ff_pattern, +}; + +/** + * onenand_default_bbt - [OneNAND Interface] Select a default bad block table for the device + * @param mtd MTD device structure + * + * This function selects the default bad block table + * support for the device and calls the onenand_scan_bbt function + */ +int onenand_default_bbt(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + struct bbm_info *bbm; + + this->bbm = malloc(sizeof(struct bbm_info)); + if (!this->bbm) + return -ENOMEM; + + bbm = this->bbm; + + memset(bbm, 0, sizeof(struct bbm_info)); + + /* 1KB page has same configuration as 2KB page */ + if (!bbm->badblock_pattern) + bbm->badblock_pattern = &largepage_memorybased; + + return onenand_scan_bbt(mtd, bbm->badblock_pattern); +} + +#endif /* CFG_CMD_ONENAND */
Kyungmin Park
