[U-Boot] [PATCH] SPL: Limit image name print length
If image name is longer than 32 bytes, then it will be truncated. This will remove '\0' at the end of the line, so printf will go out of string limit.
Signed-off-by: Taras Kondratiuk taras@ti.com Reviewed-by: Tom Rini trini@ti.com --- common/spl/spl.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index ff9ba7b..861ca0a 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -108,8 +108,9 @@ void spl_parse_image_header(const struct image_header *header) } spl_image.os = image_get_os(header); spl_image.name = image_get_name(header); - debug("spl: payload image: %s load addr: 0x%x size: %d\n", - spl_image.name, spl_image.load_addr, spl_image.size); + debug("spl: payload image: %.*s load addr: 0x%x size: %d\n", + sizeof(spl_image.name), spl_image.name, + spl_image.load_addr, spl_image.size); } else { /* Signature not found - assume u-boot.bin */ debug("mkimage signature not found - ih_magic = %x\n",
Taras Kondratiuk
