[PATCH] wdt: designware: fix timeout calculation due to expecting KHz
The timeout calculation is based on the clk being in KHz but the clk api returns the clk value in Hz. Convert this to KHz to calculate the correct timeout value.
Signed-off-by: Jack Mitchell ml@embed.me.uk --- drivers/watchdog/designware_wdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/watchdog/designware_wdt.c b/drivers/watchdog/designware_wdt.c index 12f09a7a39..7caa6c550c 100644 --- a/drivers/watchdog/designware_wdt.c +++ b/drivers/watchdog/designware_wdt.c @@ -130,7 +130,7 @@ static int designware_wdt_probe(struct udevice *dev) if (ret) return ret;
- priv->clk_khz = clk_get_rate(&clk); + priv->clk_khz = clk_get_rate(&clk) / 1000; if (!priv->clk_khz) return -EINVAL; #else
- priv->clk_khz = clk_get_rate(&clk) / 1000; if (!priv->clk_khz) return -EINVAL;
#else
Thanks for submitting this. I believe it is a duplicate of [1].
--Sean
[1] https://patchwork.ozlabs.org/project/uboot/patch/20200909210420.243190-4-sea...
Jack Mitchell
Sean Anderson
