[PATCH] rockchp: firefly-rk3399: enable CONFIG_USB_DWC3
To fix below build error: drivers/usb/host/built-in.o: In function `xhci_dwc3_remove': drivers/usb/host/xhci-dwc3.c:174: undefined reference to `dwc3_shutdown_phy' drivers/usb/host/built-in.o: In function `xhci_dwc3_probe': drivers/usb/host/xhci-dwc3.c:130: undefined reference to `dwc3_setup_phy'
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
configs/firefly-rk3399_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 5181510aac..cf030f923c 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y @@ -23,7 +24,6 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -54,6 +54,7 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y
Kever Yang
