This series allows rpi to boot a compressed Ubuntu kernel with ~100MB ramdisk, by expanding the available space.
It also tidies up some strange behaviour with the provided FDT, where a separate pointer is maintained to it, even though U-Boot has copied it and placed it in its own space. This avoids strange bugs where it accidentally gets overwritten when loading a file into memory.
The patch to expand the devicetree was dropped, meaning that people should be careful to unset fdt_addr in the environment.
Changes in v3: - Add to the existing comment block - Update the comment block with the new values, including compression
Changes in v2: - Add new patch to make myself an rpi maintainer - Add new patch to set bootm_size - Add new patch to drop fdt_high and initrd_high - Drop patch to allow expanding the devicetree during relocation
Simon Glass (5): rpi: Add myself to the list of maintainers rpi: Set bootm_size to 512MB rpi: Drop fdt_high and initrd_high rpi: Update environment to support booti and large initrd rpi: Use the U-Boot control FDT for fdt_addr
MAINTAINERS | 1 + board/raspberrypi/rpi/rpi.c | 20 ++++++++----------- board/raspberrypi/rpi/rpi.env | 37 +++++++++++++++++++---------------- 3 files changed, 29 insertions(+), 29 deletions(-)
Add my own name to the list, since existing maintainers are fairly busy.
(no changes since v2)
MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 8c6c0c2a4bc..4b9bb9ef3f1 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -210,6 +210,7 @@ N: aspeed ARM BROADCOM BCM283X / BCM27XX M: Matthias Brugger mbrugger@suse.com M: Peter Robinson pbrobinson@gmail.com +M: Simon Glass sjg@chromium.org S: Maintained F: arch/arm/dts/bcm283* F: arch/arm/mach-bcm283x/
Simon,
Please don't send multiple versions of patch series back to back.
There's been 3 versions of this patch in less than one working day. You wonder why we're busy, I can't get to one version of you patch set before you send another 12 versions.... It's generally considered, at least in the kernel community, you should only be sending a version of a patch set once a week to allow all discussion to complete, and then only sending it if all concerns are resolved.
Peter
Changes in v2:
diff --git a/MAINTAINERS b/MAINTAINERS index 8c6c0c2a4bc..4b9bb9ef3f1 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -210,6 +210,7 @@ N: aspeed ARM BROADCOM BCM283X / BCM27XX M: Matthias Brugger mbrugger@suse.com M: Peter Robinson pbrobinson@gmail.com +M: Simon Glass sjg@chromium.org S: Maintained F: arch/arm/dts/bcm283* F: arch/arm/mach-bcm283x/ -- 2.34.1
Set this option so that all boot images stay within the bottom 512MB of memory. This should allow us to drop the fdt_high and initrd_high options.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Suggested-by: Tom Rini trini@konsulko.com ---
Changes in v2: - Add new patch to set bootm_size
board/raspberrypi/rpi/rpi.env | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.env b/board/raspberrypi/rpi/rpi.env index 30228285edd..a327fccc77f 100644 --- a/board/raspberrypi/rpi/rpi.env +++ b/board/raspberrypi/rpi/rpi.env @@ -60,7 +60,12 @@ dfu_alt_info+=zImage fat 0 1 * Even with the smallest possible CPU-GPU memory split of the CPU getting * only 64M, the remaining 25M starting at 0x02700000 should allow quite * large initrds before they start colliding with U-Boot. + * + * Limit bootm_size to 512MB so that all boot images stay within the bottom + * 512MB of memory */ +bootm_size=0x20000000 + #ifdef CONFIG_ARM64 fdt_high=ffffffffffffffff initrd_high=ffffffffffffffff
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Simon Glass Sent: Tuesday, December 10, 2024 4:55 AM To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Rini trini@konsulko.com; Stephen Warren swarren@wwwdotorg.org; Stephen Warren swarren@nvidia.com; Matthias Brugger mbrugger@suse.com; Simon Glass sjg@chromium.org; Peter Robinson pbrobinson@gmail.com Subject: [PATCH v3 2/5] rpi: Set bootm_size to 512MB
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Jaehoon Chung jh80.chung@samsung.com
Changes in v3:
Changes in v2:
- Even with the smallest possible CPU-GPU memory split of the CPU getting
- only 64M, the remaining 25M starting at 0x02700000 should allow quite
- large initrds before they start colliding with U-Boot.
- Limit bootm_size to 512MB so that all boot images stay within the bottom
- 512MB of memory
#ifdef CONFIG_ARM64 fdt_high=ffffffffffffffff initrd_high=ffffffffffffffff -- 2.34.1
How does this work for a device with < 256Mb of RAM? There's a number of the original RPi series that have 256Mb of RAM and that equates to less than that due to reservations for the vendor firmware.
Changes in v3:
Changes in v2:
bottom
- 512MB of memory
I based this on the previous thread that said they all have 512MiB minimum, but I guess that's just the newer ones that are 64bit too.
Top of my head? It's been a decade, but I _think_ as part of the relocation we see that we don't have memory a base+512MiB and so go with lower, but I wouldn't make any wager on it and would rather test (which can also be done easy enough on another board, just set the limit to more memory than exists, see where we relocate things to). I'll try and try that out soon'ish, just neck deep in a few other tasks atm.
Hi Peter,
Looking at boot_relocate_fdt(), this is just a maximum, and lmb is used to allocate the FDT / cmdline. So this patch shouldn't affect that.
But the later patch to move the ramdisk up will cause problems. Based on the comment, a 256MB (I assume you mean) device can have as little as 64MB of RAM available to the ARM core, which is not enough to load a ramdisk from the new start-address of about 90MB.
I found an old rpi1 which I could hook up to my lab, perhaps. Could you point me to a distro-image that boots OK on that, ideally with only 64MB available?
Changes in v3:
Changes in v2:
- 512MB of memory
Hi Peter,
On Wed, 11 Dec 2024 at 10:26, Simon Glass sjg@chromium.org wrote:
Hi Peter,
Well I set it up with Raspbian. It seems to boot OK into the kernel. But unfortunately I only have a 512MB device.
"When I were a lad, we had hard drives of 20MB and were grateful for it!"
Changes in v3:
Changes in v2:
- 512MB of memory
These are not needed now since there is a bootm_size setting to keep things within the lower part of memory.
Drop them.
Changes in v2: - Add new patch to drop fdt_high and initrd_high
board/raspberrypi/rpi/rpi.env | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.env b/board/raspberrypi/rpi/rpi.env index a327fccc77f..9b9fad82828 100644 --- a/board/raspberrypi/rpi/rpi.env +++ b/board/raspberrypi/rpi/rpi.env @@ -66,13 +66,6 @@ dfu_alt_info+=zImage fat 0 1 */ bootm_size=0x20000000
-#ifdef CONFIG_ARM64 -fdt_high=ffffffffffffffff -initrd_high=ffffffffffffffff -#else -fdt_high=ffffffff -initrd_high=ffffffff -#endif kernel_addr_r=0x00080000 scriptaddr=0x02400000 pxefile_addr_r=0x02500000
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Simon Glass Sent: Tuesday, December 10, 2024 4:55 AM To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Rini trini@konsulko.com; Stephen Warren swarren@wwwdotorg.org; Stephen Warren swarren@nvidia.com; Matthias Brugger mbrugger@suse.com; Simon Glass sjg@chromium.org; Peter Robinson pbrobinson@gmail.com Subject: [PATCH v3 3/5] rpi: Drop fdt_high and initrd_high
Drop them.
Changes in v2:
-#ifdef CONFIG_ARM64 -fdt_high=ffffffffffffffff -initrd_high=ffffffffffffffff -#else -fdt_high=ffffffff -initrd_high=ffffffff -#endif kernel_addr_r=0x00080000 scriptaddr=0x02400000 pxefile_addr_r=0x02500000 -- 2.34.1
The existing values don't provide for decompressing an arm64 boot-image. Add those values and move things apart a bit so that a 50MB kernel can be accommodated.
Changes in v3: - Update the comment block with the new values, including compression
board/raspberrypi/rpi/rpi.env | 27 ++++++++++++++++----------- 1 file changed, 16 insertions(+), 11 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.env b/board/raspberrypi/rpi/rpi.env index 9b9fad82828..9ac9d6768ca 100644 --- a/board/raspberrypi/rpi/rpi.env +++ b/board/raspberrypi/rpi/rpi.env @@ -48,28 +48,33 @@ dfu_alt_info+=zImage fat 0 1 * * scriptaddr and pxefile_addr_r can be pretty much anywhere that doesn't * conflict with something else. Reserving 1M for each of them at - * 0x02400000-0x02500000 and 0x02500000-0x02600000 should be plenty. + * 0x05400000-0x05500000 and 0x05500000-0x05600000 should be plenty. * * On ARM, both the DTB and any possible initrd must be loaded such that they * fit inside the lowmem mapping in Linux. In practice, this usually means not * more than ~700M away from the start of the kernel image but this number can * be larger OR smaller depending on e.g. the 'vmalloc=xxxM' command line * parameter given to the kernel. So reserving memory from low to high - * satisfies this constraint again. Reserving 1M at 0x02600000-0x02700000 for - * the DTB leaves rest of the free RAM to the initrd starting at 0x02700000. - * Even with the smallest possible CPU-GPU memory split of the CPU getting - * only 64M, the remaining 25M starting at 0x02700000 should allow quite - * large initrds before they start colliding with U-Boot. + * satisfies this constraint again. Reserving 1M at 0x05600000-0x05700000 for + * the DTB leaves rest of the free RAM to the initrd starting at 0x05700000. + * This means that the board must have at least 128MB of RAM available to + * U-Boot, more if the initrd is large. * - * Limit bootm_size to 512MB so that all boot images stay within the bottom + * For compressed kernels, the maximum size is just under 32MB, with an area for + * decompression at 0x02000000 with space for 52MB, which is plenty for current + * kernels. + * + * limit bootm_size to 512MB so that all boot images stay within the bottom * 512MB of memory */ bootm_size=0x20000000
kernel_addr_r=0x00080000 -scriptaddr=0x02400000 -pxefile_addr_r=0x02500000 -fdt_addr_r=0x02600000 -ramdisk_addr_r=0x02700000 +kernel_comp_addr_r=0x02000000 +kernel_comp_size=0x03400000 +scriptaddr=0x05400000 +pxefile_addr_r=0x05500000 +fdt_addr_r=0x05600000 +ramdisk_addr_r=0x05700000
boot_targets=mmc usb pxe dhcp
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Simon Glass Sent: Tuesday, December 10, 2024 4:55 AM To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Rini trini@konsulko.com; Stephen Warren swarren@wwwdotorg.org; Stephen Warren swarren@nvidia.com; Matthias Brugger mbrugger@suse.com; Simon Glass sjg@chromium.org; Peter Robinson pbrobinson@gmail.com Subject: [PATCH v3 4/5] rpi: Update environment to support booti and large initrd
Changes in v3:
- scriptaddr and pxefile_addr_r can be pretty much anywhere that doesn't
- conflict with something else. Reserving 1M for each of them at
- 0x02400000-0x02500000 and 0x02500000-0x02600000 should be plenty.
- 0x05400000-0x05500000 and 0x05500000-0x05600000 should be plenty.
- On ARM, both the DTB and any possible initrd must be loaded such that they
- fit inside the lowmem mapping in Linux. In practice, this usually means not
- more than ~700M away from the start of the kernel image but this number can
- be larger OR smaller depending on e.g. the 'vmalloc=xxxM' command line
- parameter given to the kernel. So reserving memory from low to high
- satisfies this constraint again. Reserving 1M at 0x02600000-0x02700000 for
- the DTB leaves rest of the free RAM to the initrd starting at 0x02700000.
- satisfies this constraint again. Reserving 1M at 0x05600000-0x05700000 for
- the DTB leaves rest of the free RAM to the initrd starting at 0x05700000.
- This means that the board must have at least 128MB of RAM available to
- U-Boot, more if the initrd is large.
- For compressed kernels, the maximum size is just under 32MB, with an area for
- decompression at 0x02000000 with space for 52MB, which is plenty for current
- kernels.
- limit bootm_size to 512MB so that all boot images stay within the bottom
- 512MB of memory
2.34.1
The fdt_addr variable is used in extlinux as a fallback devicetree if none is provided by the boot command.
The existing mechanism uses the devicetree provided to U-Boot, but in its original, unrelocated position. For the rpi_4 I am using, this is at 2b35ef00 which is not a convenient place in memory, if the ramdisk is large.
U-Boot already deals with this sort of problem by relocating the FDT to a safe address.
So use the control-FDT address instead.
Remove the existing comment, which is confusing, since the FDT is not actually passed unmodified to the kernel: U-Boot adds various things using its FDT-fixup mechanism.
Note that board_get_usable_ram_top() reduces the RAM top for boards with less RAM. This behaviour is left unchanged as there is no other mechanism for U-Boot to handle this.
In version 2, it incorporates some changes to fdt_addr, etc. suggested by Tom, as well as adding myself as a maintainer.
Changes in v2: - Drop patch to allow expanding the devicetree during relocation
board/raspberrypi/rpi/rpi.c | 20 ++++++++------------ 1 file changed, 8 insertions(+), 12 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 9122f33d88d..8f6ab1b1b9b 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -3,6 +3,8 @@ * (C) Copyright 2012-2016 Stephen Warren */
+#define LOG_CATEGORY LOGC_BOARD + #include <config.h> #include <dm.h> #include <env.h> @@ -325,19 +327,10 @@ static void set_fdtfile(void) env_set("fdtfile", fdtfile); }
-/* - * If the firmware provided a valid FDT at boot time, let's expose it in - * ${fdt_addr} so it may be passed unmodified to the kernel. - */ +/* Allow U-Boot to use its control FDT with extlinux if one is not provided */ static void set_fdt_addr(void) { - if (env_get("fdt_addr")) - return; - - if (fdt_magic(fw_dtb_pointer) != FDT_MAGIC) - return; - - env_set_hex("fdt_addr", fw_dtb_pointer); + env_set_hex("fdt_addr", (ulong)gd->fdt_blob); }
/* @@ -572,7 +565,10 @@ int ft_board_setup(void *blob, struct bd_info *bd) { int node;
- update_fdt_from_fw(blob, (void *)fw_dtb_pointer); + if (blob == gd->fdt_blob) + log_debug("Same FDT: nothing to do\n"); + else + update_fdt_from_fw(blob, (void *)gd->fdt_blob);
node = fdt_node_offset_by_compatible(blob, -1, "simple-framebuffer"); if (node < 0)
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Simon Glass Sent: Tuesday, December 10, 2024 4:55 AM To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Rini trini@konsulko.com; Stephen Warren swarren@wwwdotorg.org; Stephen Warren swarren@nvidia.com; Matthias Brugger mbrugger@suse.com; Simon Glass sjg@chromium.org; Francois Berder fberder@outlook.fr; Ivan T. Ivanov iivanov@suse.de; Patrick Rudolph patrick.rudolph@9elements.com; Peter Robinson pbrobinson@gmail.com; Rasmus Villemoes rasmus.villemoes@prevas.dk Subject: [PATCH v3 5/5] rpi: Use the U-Boot control FDT for fdt_addr
Changes in v2:
- (C) Copyright 2012-2016 Stephen Warren
- If the firmware provided a valid FDT at boot time, let's expose it in
- ${fdt_addr} so it may be passed unmodified to the kernel.
return;
return;
- env_set_hex("fdt_addr", (ulong)gd->fdt_blob);
else
-- 2.34.1
And what about where extlinux isn't used?
Please re-word the above, it doesn't make sense to me, "the rpi_4 I am using" .... what about the other millions of RPis out there?
Don't remove it, re-word it so it's up to date.
The below looks irrelevant to the patch at hand, it looks like it should be in the cover letter.
Changes in v2:
return;
return;
else
update_fdt_from_fw(blob, (void *)gd->fdt_blob); node = fdt_node_offset_by_compatible(blob, -1,
"simple-framebuffer"); if (node < 0) -- 2.34.1
Hi Peter,
Do you have any comments on the code in this series?
Changes in v2:
return;
return;
else
update_fdt_from_fw(blob, (void *)gd->fdt_blob); node = fdt_node_offset_by_compatible(blob, -1, "simple-framebuffer"); if (node < 0)
-- 2.34.1
Hi Simon.
On Mon, 16 Dec 2024 at 00:27, Simon Glass sjg@chromium.org wrote:
Hi Peter,
I did already comment on it, please go back through your emails ;-)
Changes in v2:
in
provided */
return;
return;
else
if (node < 0)
-- 2.34.1
Hi Peter,
On Wed, 18 Dec 2024 at 09:26, Peter Robinson pbrobinson@gmail.com wrote:
Hi Simon.
Hi Peter,
The only thing I got was some comments about the commit message and the comment for set_fdt_addr(). I sent a new v4 here:
https://patchwork.ozlabs.org/project/uboot/patch/20241220003447.2913443-6-sj...
My question was really about whether you are happy with the code itself.
Jaehoon Chung
Peter Robinson
