[U-Boot] [PATCH 0/5] Add intermediate driver(cff driver) between flash & FPGA
This patchset adding intermediate driver called cff driver to support all the FPGA program operations between FPGA manager and flash.
Tien Fong Chee (5): arm: socfpga: Add checking function on searching boot device arm: socfpga: Add checking function on FPGA setting in FDT configs: socfpga: Add config for RBF loading from FAT fs arm: socfpga: Add intermediate driver between flash and FPGA manager arm: socfpga: Enable cff driver build
arch/arm/mach-socfpga/Kconfig | 7 + arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/cff.c | 581 +++++++++++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/cff.h | 40 ++ arch/arm/mach-socfpga/include/mach/misc.h | 20 + arch/arm/mach-socfpga/misc_arria10.c | 42 ++ include/configs/socfpga_arria10_socdk.h | 6 + 7 files changed, 697 insertions(+), 0 deletions(-) create mode 100644 arch/arm/mach-socfpga/cff.c create mode 100644 arch/arm/mach-socfpga/include/mach/cff.h
Function for checking boot device type, which is required for locating flash where U-boot image, FPGA design are stored.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/include/mach/misc.h | 19 +++++++++++++++++++ arch/arm/mach-socfpga/misc_arria10.c | 22 ++++++++++++++++++++++ 2 files changed, 41 insertions(+), 0 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 0b65783..b219aac 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -14,6 +14,24 @@ struct bsel { const char *name; };
+enum { + BOOT_DEVICE_RAM, + BOOT_DEVICE_MMC1, + BOOT_DEVICE_MMC2, + BOOT_DEVICE_MMC2_2, + BOOT_DEVICE_NAND, + BOOT_DEVICE_ONENAND, + BOOT_DEVICE_NOR, + BOOT_DEVICE_UART, + BOOT_DEVICE_SPI, + BOOT_DEVICE_USB, + BOOT_DEVICE_SATA, + BOOT_DEVICE_I2C, + BOOT_DEVICE_BOARD, + BOOT_DEVICE_DFU, + BOOT_DEVICE_NONE +}; + extern struct bsel bsel_str[];
#ifdef CONFIG_FPGA @@ -26,6 +44,7 @@ static inline void socfpga_fpga_add(void) {} unsigned int dedicated_uart_com_port(const void *blob); unsigned int shared_uart_com_port(const void *blob); unsigned int uart_com_port(const void *blob); +u32 boot_device(void); #endif
#endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c index 9d751f6..069a0a6 100644 --- a/arch/arm/mach-socfpga/misc_arria10.c +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -235,6 +235,28 @@ unsigned int uart_com_port(const void *blob) return shared_uart_com_port(blob); }
+u32 boot_device(void) +{ + const u32 bsel = readl(&sysmgr_regs->bootinfo); + + switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) { + case 0x1: /* FPGA (HPS2FPGA Bridge) */ + return BOOT_DEVICE_RAM; + case 0x2: /* NAND Flash (1.8V) */ + case 0x3: /* NAND Flash (3.0V) */ + return BOOT_DEVICE_NAND; + case 0x4: /* SD/MMC External Transceiver (1.8V) */ + case 0x5: /* SD/MMC Internal Transceiver (3.0V) */ + return BOOT_DEVICE_MMC1; + case 0x6: /* QSPI Flash (1.8V) */ + case 0x7: /* QSPI Flash (3.0V) */ + return BOOT_DEVICE_SPI; + default: + printf("Invalid boot device (bsel=%08x)!\n", bsel); + hang(); + } +} + /* * Print CPU information */
+enum {
- BOOT_DEVICE_RAM,
- BOOT_DEVICE_MMC1,
- BOOT_DEVICE_MMC2,
- BOOT_DEVICE_MMC2_2,
- BOOT_DEVICE_NAND,
- BOOT_DEVICE_ONENAND,
- BOOT_DEVICE_NOR,
- BOOT_DEVICE_UART,
- BOOT_DEVICE_SPI,
- BOOT_DEVICE_USB,
- BOOT_DEVICE_SATA,
- BOOT_DEVICE_I2C,
- BOOT_DEVICE_BOARD,
- BOOT_DEVICE_DFU,
- BOOT_DEVICE_NONE
Why do you have so many bootdevices here if half of them aren't supported/used ?
- const u32 bsel = readl(&sysmgr_regs->bootinfo);
- switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) {
This looks very similar to what is on Gen5 ?
- case 0x1: /* FPGA (HPS2FPGA Bridge) */
- case 0x2: /* NAND Flash (1.8V) */
- case 0x3: /* NAND Flash (3.0V) */
- case 0x4: /* SD/MMC External Transceiver (1.8V) */
- case 0x5: /* SD/MMC Internal Transceiver (3.0V) */
- case 0x6: /* QSPI Flash (1.8V) */
- case 0x7: /* QSPI Flash (3.0V) */
- default:
hang();
- Print CPU information
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 0b65783..b219aac 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -14,6 +14,24 @@ struct bsel { const char *name; }; +enum {
- BOOT_DEVICE_RAM,
- BOOT_DEVICE_MMC1,
- BOOT_DEVICE_MMC2,
- BOOT_DEVICE_NAND,
- BOOT_DEVICE_NOR,
- BOOT_DEVICE_UART,
- BOOT_DEVICE_SPI,
- BOOT_DEVICE_USB,
- BOOT_DEVICE_SATA,
- BOOT_DEVICE_I2C,
- BOOT_DEVICE_DFU,
- BOOT_DEVICE_NONE
Okay, i will reduce it, i refered this from spl.h
extern struct bsel bsel_str[]; #ifdef CONFIG_FPGA @@ -26,6 +44,7 @@ static inline void socfpga_fpga_add(void) {} unsigned int dedicated_uart_com_port(const void *blob); unsigned int shared_uart_com_port(const void *blob); unsigned int uart_com_port(const void *blob); +u32 boot_device(void); #endif #endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach- socfpga/misc_arria10.c index 9d751f6..069a0a6 100644 --- a/arch/arm/mach-socfpga/misc_arria10.c +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -235,6 +235,28 @@ unsigned int uart_com_port(const void *blob) return shared_uart_com_port(blob); } +u32 boot_device(void) +{
I refered from function spl_boot_device in spl.c . I copied the function here, because U-boot also need it.
- default:
bsel);
hang();
+enum {
- BOOT_DEVICE_RAM,
- BOOT_DEVICE_MMC1,
- BOOT_DEVICE_MMC2,
- BOOT_DEVICE_NAND,
- BOOT_DEVICE_NOR,
- BOOT_DEVICE_UART,
- BOOT_DEVICE_SPI,
- BOOT_DEVICE_USB,
- BOOT_DEVICE_SATA,
- BOOT_DEVICE_I2C,
- BOOT_DEVICE_DFU,
- BOOT_DEVICE_NONE
So can the same code used for gen5 be recycled on gen10 ?
- default:
bsel);
hang();
- BOOT_DEVICE_RAM,
- BOOT_DEVICE_MMC1,
- BOOT_DEVICE_MMC2,
- BOOT_DEVICE_NAND,
- BOOT_DEVICE_NOR,
- BOOT_DEVICE_UART,
- BOOT_DEVICE_SPI,
- BOOT_DEVICE_USB,
- BOOT_DEVICE_SATA,
- BOOT_DEVICE_I2C,
- BOOT_DEVICE_DFU,
- BOOT_DEVICE_NONE
Are you means SYSMGR_GET_BOOTINFO_BSEL? This is common #define shared between gen5 and gen10. If you means boot_device function, then gen5 doesn't has this function. Please correct me if i misunderstand your question.
- default:
bsel);
hang();
+enum {
- BOOT_DEVICE_RAM,
- BOOT_DEVICE_MMC1,
- BOOT_DEVICE_MMC2,
- BOOT_DEVICE_NAND,
- BOOT_DEVICE_NOR,
- BOOT_DEVICE_UART,
- BOOT_DEVICE_SPI,
- BOOT_DEVICE_USB,
- BOOT_DEVICE_SATA,
- BOOT_DEVICE_I2C,
- BOOT_DEVICE_DFU,
- BOOT_DEVICE_NONE
Did you try for example git grep BOOT_DEVICE arch/arm/mach-socfpga ? It should point you to spl_boot_device in spl.c
- BOOT_DEVICE_RAM,
- BOOT_DEVICE_MMC1,
- BOOT_DEVICE_MMC2,
- BOOT_DEVICE_NAND,
- BOOT_DEVICE_NOR,
- BOOT_DEVICE_UART,
- BOOT_DEVICE_SPI,
- BOOT_DEVICE_USB,
- BOOT_DEVICE_SATA,
- BOOT_DEVICE_I2C,
- BOOT_DEVICE_DFU,
- BOOT_DEVICE_NONE
Okay, i know what's you trying to say. I can change this function as common code for both SPL and U-boot.
Thanks.
Function for checking FPGA early release setting which is defined by user in FDT chosen section. This function would be used by later driver in decision applying appropriate FPGA configuration in early release or full FPGA booting mode.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/include/mach/misc.h | 1 + arch/arm/mach-socfpga/misc_arria10.c | 20 ++++++++++++++++++++ 2 files changed, 21 insertions(+), 0 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index b219aac..a8167eb 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -44,6 +44,7 @@ static inline void socfpga_fpga_add(void) {} unsigned int dedicated_uart_com_port(const void *blob); unsigned int shared_uart_com_port(const void *blob); unsigned int uart_com_port(const void *blob); +int is_early_release_fpga_config(const void *blob); u32 boot_device(void); #endif
diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c index 069a0a6..b9a8693 100644 --- a/arch/arm/mach-socfpga/misc_arria10.c +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -235,6 +235,26 @@ unsigned int uart_com_port(const void *blob) return shared_uart_com_port(blob); }
+int is_chosen_boolean_true(const void *blob, const char *name) +{ + int node; + int rval = 0; + + node = fdt_subnode_offset(blob, 0, "chosen"); + + if (node >= 0) + rval = fdtdec_get_bool(blob, node, name); + + return rval; +} + +int is_early_release_fpga_config(const void *blob) +{ + static const char *name = "early-release-fpga-config"; + + return is_chosen_boolean_true(blob, name); +} + u32 boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo);
This config enable the mechanism for loading RBF file from FAT fs into FPGA manager.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Kconfig | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 45e5379..3fbac20 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -33,6 +33,13 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE default 0xa2
+config RBF_SDMMC_FAT_SUPPORT + bool "Support FPGA program with FAT RBF" + default y if SPL_FAT_SUPPORT + help + Enable support for programming FPGA with RAW binary file + (periph rbf + core rbf) loading from FAT partition. + config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5
NAK, Xilinx already has some support for loading FPGA from FS, so improve on that.
- bool "Support FPGA program with FAT RBF"
- default y if SPL_FAT_SUPPORT
- help
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach- socfpga/Kconfig index 45e5379..3fbac20 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -33,6 +33,13 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE default 0xa2 +config RBF_SDMMC_FAT_SUPPORT
thanks for the advice. I will take a look.
- help
binary file
partition.
I can change to CONFIG_CMD_FPGA_LOADFS.
- help
binary file
partition.
That's what they use iirc.
Configuration flip-flop driver is mainly used for handling the FPGA program operation where the FPGA image loading from the flash into FPGA manager.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/cff.c | 581 ++++++++++++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/cff.h | 40 ++ include/configs/socfpga_arria10_socdk.h | 6 + 3 files changed, 627 insertions(+), 0 deletions(-) create mode 100644 arch/arm/mach-socfpga/cff.c create mode 100644 arch/arm/mach-socfpga/include/mach/cff.h
diff --git a/arch/arm/mach-socfpga/cff.c b/arch/arm/mach-socfpga/cff.c new file mode 100644 index 0000000..899e995 --- /dev/null +++ b/arch/arm/mach-socfpga/cff.c @@ -0,0 +1,581 @@ +/* + * COPYRIGHT (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <altera.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/cff.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/misc.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/reset_manager.h> +#include <errno.h> +#include <fat.h> +#include <fs.h> +#include <fdtdec.h> +#include <malloc.h> +#include <mmc.h> +#include <spi_flash.h> +#include <watchdog.h> + +#define RBF_UNENCRYPTED 0xa65c +#define RBF_ENCRYPTED 0xa65d +#define ARRIA10RBF_PERIPH 0x0001 +#define ARRIA10RBF_CORE 0x8001 + +DECLARE_GLOBAL_DATA_PTR; + +static int flash_type = -1; + +struct mmc *mmc; + +/* Local functions */ +static int cff_flash_read(struct cff_flash_info *cff_flashinfo, u32 *buffer, + u32 *buffer_sizebytes); +static int cff_flash_preinit(struct cff_flash_info *cff_flashinfo, + fpga_fs_info *fpga_fsinfo, u32 *buffer, u32 *buffer_sizebytes); +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT +static const char *get_cff_filename(const void *fdt, int *len, u32 core); +#else +static int get_cff_offset(const void *fdt, u32 core); +#endif + +static struct mmc *init_mmc_device(int dev, bool force_init) +{ + struct mmc *mmc; + + mmc = find_mmc_device(dev); + if (!mmc) { + printf("no mmc device at slot %x\n", dev); + return NULL; + } + + if (force_init) + mmc->has_init = 0; + if (mmc_init(mmc)) + return NULL; + + return mmc; +} + +static int cff_flash_probe(struct cff_flash_info *cff_flashinfo) +{ + int dev = 0; + + if(BOOT_DEVICE_MMC1 == flash_type) + { + mmc = init_mmc_device(dev, true); + + if (!mmc) + return -ENOTBLK; + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + /* we are looking at the FAT partition */ + if (fat_register_device(mmc_get_blk_desc(mmc), + cff_flashinfo->sdmmc_flashinfo.dev_part)) { + printf("Failed to set filesystem to FAT.\n"); + return -EPERM; + } +#endif + } + + return flash_type; +} + +static int flash_read(struct cff_flash_info *cff_flashinfo, + u32 size_read, + u32 *buffer_ptr) +{ + size_t ret = EEXIST; +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + loff_t actread; +#endif + + if(BOOT_DEVICE_MMC1 == flash_type) { +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + ret = fat_read_file(cff_flashinfo->sdmmc_flashinfo.filename, + buffer_ptr, cff_flashinfo->flash_offset, + size_read, &actread); + + if (ret || actread != size_read) { + printf("Failed to read %s from FAT %d ", + cff_flashinfo->sdmmc_flashinfo.filename, + ret); + printf("!= %d.\n", size_read); + return -EPERM; + } else + ret = actread; +#else + u32 blk = cff_flashinfo->flash_offset/mmc->read_bl_len; + u32 cnt = size_read / mmc->read_bl_len; + + if (!cnt) + cnt = 1; + + if((size_read % mmc->read_bl_len) && + (size_read >= mmc->read_bl_len)) + cnt++; + + ret = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, + buffer_ptr); + + if (cnt != ret) + return -EPERM; +#endif + } + + return ret; +} + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT +const char *get_cff_filename(const void *fdt, int *len, u32 core) +{ + const char *cff_filename = NULL; + const char *cell; + int nodeoffset; + nodeoffset = fdt_subnode_offset(fdt, 0, "chosen"); + + if (nodeoffset >= 0) { + if (core) + cell = fdt_getprop(fdt, + nodeoffset, + "cffcore-file", + len); + else + cell = fdt_getprop(fdt, nodeoffset, "cff-file", len); + + if (cell) + cff_filename = cell; + } + + return cff_filename; +} +#else +static int get_cff_offset(const void *fdt, u32 core) +{ + int nodeoffset = 0; + + nodeoffset = fdt_subnode_offset(fdt, 0, "chosen"); + + if (nodeoffset >= 0) { + if (core) + return fdtdec_get_int(fdt, + nodeoffset, + "cffcore-offset", + -ESPIPE); + else + return fdtdec_get_int(fdt, + nodeoffset, + "cff-offset", + -ESPIPE); + } + return -ESPIPE; +} +#endif + +int cff_from_sdmmc_env(u32 core) +{ + int rval = -ENOENT; + fpga_fs_info fpga_fsinfo; + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + int len = 0; + const char *cff = NULL; +#else + char addrToString[32] = {0}; + + int sdmmc_rbf_rawaddr = -ENOENT; +#endif + + flash_type = boot_device(); + + fpga_fsinfo.interface = "sdmmc"; + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + cff = get_cff_filename(gd->fdt_blob, &len, core); + + /* FAT periph RBF file reading */ + if (cff && (len > 0)) { + mmc_initialize(gd->bd); + + fpga_fsinfo.filename = (char *)cff; + + fpga_fsinfo.dev_part = getenv("cff_devsel_partition"); + + if (NULL == fpga_fsinfo.dev_part) { + /* FAT partition */ + fpga_fsinfo.dev_part = "1"; + + printf("No SD/MMC partition found in environment. "); + printf("Assuming partition 1.\n"); + } + + rval = cff_from_flash(&fpga_fsinfo); + } +#else + sdmmc_rbf_rawaddr = get_cff_offset(gd->fdt_blob, core); + + /* RAW periph RBF reading */ + if (sdmmc_rbf_rawaddr >= 0) { + sprintf(addrToString, "%x", sdmmc_rbf_rawaddr); + + fpga_fsinfo.filename = addrToString; + + rval = cff_from_flash(&fpga_fsinfo); + } +#endif + return rval; +} + +void get_rbf_image_info(struct rbf_info *rbf, u16 *buffer) +{ + /* + Magic ID starting at: + -> 1st dword in periph.rbf + -> 2nd dword in core.rbf + */ + u32 word_reading_max = 2; + u32 i; + + for(i = 0; i < word_reading_max; i++) + { + if(RBF_UNENCRYPTED == *(buffer + i)) /* PERIPH RBF */ + rbf->security = unencrypted; + else if (RBF_ENCRYPTED == *(buffer + i)) + rbf->security = encrypted; + else if (RBF_UNENCRYPTED == *(buffer + i + 1)) /* CORE RBF */ + rbf->security = unencrypted; + else if (RBF_ENCRYPTED == *(buffer + i + 1)) + rbf->security = encrypted; + else { + rbf->security = invalid; + continue; + } + + /* PERIPH RBF */ + if (ARRIA10RBF_PERIPH == *(buffer + i + 1)) { + rbf->section = periph_section; + break; + } + else if (ARRIA10RBF_CORE == *(buffer + i + 1)) { + rbf->section = core_section; + break; + } /* CORE RBF */ + else if (ARRIA10RBF_PERIPH == *(buffer + i + 2)) { + rbf->section = periph_section; + break; + } + else if (ARRIA10RBF_CORE == *(buffer + i + 2)) { + rbf->section = core_section; + break; + } + else { + rbf->section = unknown; + break; + } + } + + return; +} + +static int cff_flash_preinit(struct cff_flash_info *cff_flashinfo, + fpga_fs_info *fpga_fsinfo, u32 *buffer, u32 *buffer_sizebytes) +{ + u32 *bufferptr_after_header = NULL; + u32 buffersize_after_header = 0; + u32 rbf_header_data_size = 0; + int ret = 0; + /* To avoid from keeping re-read the contents */ + struct image_header *header = &(cff_flashinfo->header); + size_t buffer_size = *buffer_sizebytes; + u32 *buffer_ptr = (u32 *)*buffer; + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + cff_flashinfo->sdmmc_flashinfo.filename = fpga_fsinfo->filename; + cff_flashinfo->flash_offset = 0; +#else + cff_flashinfo->flash_offset = + simple_strtoul(fpga_fsinfo->filename, NULL, 16); +#endif + + /* Load mkimage header into buffer */ + ret = flash_read(cff_flashinfo, + sizeof(struct image_header), buffer_ptr); + + if (0 >= ret) { + printf(" Failed to read mkimage header from flash.\n"); + return -ENOENT; + } + + WATCHDOG_RESET(); + + memcpy(header, (u_char *)buffer_ptr, sizeof(*header)); + + if (!image_check_magic(header)) { + printf("FPGA: Bad Magic Number.\n"); + return -EBADF; + } + + if (!image_check_hcrc(header)) { + printf("FPGA: Bad Header Checksum.\n"); + return -EPERM; + } + + /* Getting rbf data size */ + cff_flashinfo->remaining = + image_get_data_size(header); + + /* Calculate total size of both rbf data with mkimage header */ + rbf_header_data_size = cff_flashinfo->remaining + + sizeof(struct image_header); + + /* Loading to buffer chunk by chunk, normally for OCRAM buffer */ + if (rbf_header_data_size > buffer_size) { + /* Calculate size of rbf data in the buffer */ + buffersize_after_header = + buffer_size - sizeof(struct image_header); + cff_flashinfo->remaining -= buffersize_after_header; + } else { + /* Loading whole rbf image into buffer, normally for DDR buffer */ + buffer_size = rbf_header_data_size; + /* Calculate size of rbf data in the buffer */ + buffersize_after_header = + buffer_size - sizeof(struct image_header); + cff_flashinfo->remaining = 0; + } + + /* Loading mkimage header and rbf data into buffer */ + ret = flash_read(cff_flashinfo, buffer_size, buffer_ptr); + + if (0 >= ret) { + printf(" Failed to read mkimage header and rbf data "); + printf("from flash.\n"); + return -ENOENT; + } + + /* Getting pointer of rbf data starting address where is it + right after mkimage header */ + bufferptr_after_header = + (u32 *)((u_char *)buffer_ptr + sizeof(struct image_header)); + + /* Update next reading rbf data flash offset */ + cff_flashinfo->flash_offset += buffer_size; + + /* Update the starting addr of rbf data to init FPGA & programming + into FPGA */ + *buffer = (u32)bufferptr_after_header; + + get_rbf_image_info(&cff_flashinfo->rbfinfo, (u16 *)bufferptr_after_header); + + /* Update the size of rbf data to be programmed into FPGA */ + *buffer_sizebytes = buffersize_after_header; + +#ifdef CONFIG_CHECK_FPGA_DATA_CRC + cff_flashinfo->datacrc = + crc32(cff_flashinfo->datacrc, + (u_char *)bufferptr_after_header, + buffersize_after_header); +#endif +if (0 == cff_flashinfo->remaining) { +#ifdef CONFIG_CHECK_FPGA_DATA_CRC + if (cff_flashinfo->datacrc != + image_get_dcrc(&(cff_flashinfo->header))) { + printf("FPGA: Bad Data Checksum.\n"); + return -EPERM; + } +#endif +} + return 0; +} + + +static int cff_flash_read(struct cff_flash_info *cff_flashinfo, u32 *buffer, + u32 *buffer_sizebytes) +{ + int ret = 0; + /* To avoid from keeping re-read the contents */ + size_t buffer_size = *buffer_sizebytes; + u32 *buffer_ptr = (u32 *)*buffer; + u32 flash_addr = cff_flashinfo->flash_offset; + + /* Buffer allocated in OCRAM */ + /* Read the data by small chunk by chunk. */ + if (cff_flashinfo->remaining > buffer_size) + cff_flashinfo->remaining -= buffer_size; + else { + /* Buffer allocated in DDR, larger than rbf data most + of the time */ + buffer_size = cff_flashinfo->remaining; + cff_flashinfo->remaining = 0; + } + + ret = flash_read(cff_flashinfo, buffer_size, buffer_ptr); + + if (0 >= ret) { + printf(" Failed to read rbf data from flash.\n"); + return -ENOENT; + } + +#ifdef CONFIG_CHECK_FPGA_DATA_CRC + cff_flashinfo->datacrc = + crc32(cff_flashinfo->datacrc, + (unsigned char *)buffer_ptr, buffer_size); +#endif + +if (0 == cff_flashinfo->remaining) { +#ifdef CONFIG_CHECK_FPGA_DATA_CRC + if (cff_flashinfo->datacrc != + image_get_dcrc(&(cff_flashinfo->header))) { + printf("FPGA: Bad Data Checksum.\n"); + return -EPERM; + } +#endif +} + /* Update next reading rbf data flash offset */ + flash_addr += buffer_size; + + cff_flashinfo->flash_offset = flash_addr; + + /* Update the size of rbf data to be programmed into FPGA */ + *buffer_sizebytes = buffer_size; + + return 0; +} + +int cff_from_flash(fpga_fs_info *fpga_fsinfo) +{ + u32 buffer = 0; + u32 buffer_ori = 0; + u32 buffer_sizebytes = 0; + u32 buffer_sizebytes_ori = 0; + struct cff_flash_info cff_flashinfo; + u32 status; + int ret = 0; + + memset(&cff_flashinfo, 0, sizeof(cff_flashinfo)); + + if (fpga_fsinfo->filename == NULL) { + printf("no [periph/core] rbf [filename/offset] specified.\n"); + return -EINVAL; + } + + WATCHDOG_RESET(); + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + cff_flashinfo.sdmmc_flashinfo.dev_part = + simple_strtol(fpga_fsinfo->dev_part, NULL, 10); +#endif + + ret = cff_flash_probe(&cff_flashinfo); + + if (0 >= ret) { + puts("Flash probe failed.\n"); + return ret; + } + +#ifdef CONFIG_RBF_SDMMC_FAT_SUPPORT + /* Loading rbf data with DDR, faster than OCRAM, + only for core rbf */ + if (gd->ram_size != 0) { + ret = fat_size(fpga_fsinfo->filename, (loff_t *)&buffer_sizebytes); + + if(ret){ + puts("Failed to read file size.\n"); + return ret; + } + + buffer_ori = (u32)memalign(ARCH_DMA_MINALIGN, buffer_sizebytes); + + if (!buffer_ori) { + error("RBF calloc failed!\n"); + return -ENOMEM; + } + + /* Loading mkimage header and rbf data into + DDR instead of OCRAM */ + buffer = buffer_ori; + + buffer_sizebytes_ori = buffer_sizebytes; + } else { + buffer = buffer_ori = (u32)cff_flashinfo.buffer; + + buffer_sizebytes = + buffer_sizebytes_ori = + sizeof(cff_flashinfo.buffer); + } +#else + /* Adjust to adjacent block */ + buffer_sizebytes = buffer_sizebytes_ori = + (sizeof(cff_flashinfo.buffer)/ mmc->read_bl_len) * + mmc->read_bl_len; +#endif + + /* Note: Both buffer and buffer_sizebytes values can be altered by + function below. */ + ret = cff_flash_preinit(&cff_flashinfo, fpga_fsinfo, &buffer, + &buffer_sizebytes); + + if (ret) + return ret; + + if (periph_section == cff_flashinfo.rbfinfo.section) { + /* initialize the FPGA Manager */ + status = fpgamgr_program_init((u32 *)buffer, buffer_sizebytes); + if (status) { + printf("FPGA: Init with periph rbf failed with error. "); + printf("code %d\n", status); + return -EPERM; + } + } + + WATCHDOG_RESET(); + + /* transfer data to FPGA Manager */ + fpgamgr_program_write((void *)buffer, + buffer_sizebytes); + + WATCHDOG_RESET(); + + while (cff_flashinfo.remaining) { + ret = cff_flash_read(&cff_flashinfo, &buffer_ori, + &buffer_sizebytes_ori); + + if (ret) + return ret; + + /* transfer data to FPGA Manager */ + fpgamgr_program_write((void *)buffer_ori, + buffer_sizebytes_ori); + + WATCHDOG_RESET(); + } + + if ((periph_section == cff_flashinfo.rbfinfo.section) && + is_early_release_fpga_config(gd->fdt_blob)) { + if (-ETIMEDOUT != fpgamgr_wait_early_user_mode()) + printf("FPGA: Early Release Succeeded.\n"); + else { + printf("FPGA: Failed to see Early Release.\n"); + return -EIO; + } + } else if ((core_section == cff_flashinfo.rbfinfo.section) || + ((periph_section == cff_flashinfo.rbfinfo.section) && + !is_early_release_fpga_config(gd->fdt_blob))) { + /* Ensure the FPGA entering config done */ + status = fpgamgr_program_finish(); + if (status) + return status; + else + printf("FPGA: Enter user mode.\n"); + + } else { + printf("Config Error: Unsupported FGPA raw binary type.\n"); + return -ENOEXEC; + } + + WATCHDOG_RESET(); + return 1; +} diff --git a/arch/arm/mach-socfpga/include/mach/cff.h b/arch/arm/mach-socfpga/include/mach/cff.h new file mode 100644 index 0000000..7f3f66b --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/cff.h @@ -0,0 +1,40 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_CFF_H_ +#define _SOCFPGA_CFF_H_ + +#include <fpga.h> + +#ifndef __ASSEMBLY_ + +struct flash_info { + char *filename; + int dev_part; +}; + +enum rbf_type {unknown, periph_section, core_section}; +enum rbf_security {invalid, unencrypted, encrypted}; + +struct rbf_info { + enum rbf_type section ; + enum rbf_security security; +}; + +struct cff_flash_info { + struct flash_info sdmmc_flashinfo; + u32 buffer[4096] __aligned(ARCH_DMA_MINALIGN); + u32 remaining; + u32 flash_offset; + struct rbf_info rbfinfo; + struct image_header header; +}; + +int cff_from_sdmmc_env(unsigned int core); +int cff_from_flash(fpga_fs_info *fpga_fsinfo); +#endif /* __ASSEMBLY__ */ + +#endif /* _SOCFPGA_CFF_H_ */ diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h index 3b59b6a..83e4d47 100644 --- a/include/configs/socfpga_arria10_socdk.h +++ b/include/configs/socfpga_arria10_socdk.h @@ -58,6 +58,12 @@ * Flash configurations */ #define CONFIG_SYS_MAX_FLASH_BANKS 1 +/* Default SDMMC physical address for periph.rbf (sector alignment) */ +#define CONFIG_FS_FAT_MAX_CLUSTSIZE (32 * 1024) + +#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_RBF_SDMMC_FAT_SUPPORT) +#define CONFIG_RBF_SDMMC_FAT_SUPPORT +#endif
/* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
Same comment as to previous patch, there is already support for loading FPGA from storage used by Xilinx, improve on that.
Hi Marek,
After i going through the xilinx codes, i found that we are sharing similar fpga framework design. The only different are the way of decoding fpga design and loading from flash to fpga. So this would be handled in cff.c, as for xilinx if i am not mistaken is drivers/fpga/zynqpl.c. I think appropiate location for cff.c should be in arch/mach-socfpga because this is not fpga driver, this is more like platform specific algorithm mechanism to handle fpga decoding and loading from flash to fpga. For the U-boot console command fpga loafs, which will wrap the cff.c and acting as upper layer driver for user console interface. I plan to enhance this after having a complete boot from sdmmc, qspi and nand because this require considering a lot use case scenarios, and some workaround on PLL clock glitch issue. You know our DDR IOs is part of the fpga periph rbf, simply calling fpga loadfs to reconfigure fpga can corrupt the DDR IOs configuration, and board may hang if it is not handle properly, so i need a workable complete boot to console environment for testing out the enhancement.
Let me know what you think about this patchset, and can i continue process with this patchset?
Thanks.
Hi Marek,
I think cff.c is not even needed. Otherwise, submit patches and we'll see how that looks.
Hi Marek,
sure. we can discuss again on new patches.
Enable cff driver build which is needed as intermediate driver for handling operation of FPGA program between feeding FPGA design from flash into FPGA manager.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 824cd8e..8122ddb 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -27,6 +27,7 @@ obj-y += clock_manager_arria10.o obj-y += misc_arria10.o obj-y += pinmux_arria10.o obj-y += reset_manager_arria10.o +obj-y += cff.o endif
ifdef CONFIG_SPL_BUILD
Chee, Tien Fong
