[U-Boot] [PATCH 2/2] armv8: ls2085a: Add support of random MAC address
Add support of setting RANDOM MAC address if env variable not available.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changs for v2: Incorporated Bin Meng's comments - Moved defines to defconfig - updated subject
configs/ls2085a_simu_defconfig | 2 ++ configs/ls2085aqds_defconfig | 2 ++ configs/ls2085aqds_nand_defconfig | 2 ++ configs/ls2085ardb_defconfig | 2 ++ configs/ls2085ardb_nand_defconfig | 2 ++ 5 files changed, 10 insertions(+)
diff --git a/configs/ls2085a_simu_defconfig b/configs/ls2085a_simu_defconfig index de9776d..0c450a9 100644 --- a/configs/ls2085a_simu_defconfig +++ b/configs/ls2085a_simu_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_LS2085A_SIMU=y CONFIG_SYS_EXTRA_OPTIONS="SIMU" +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2085aqds_defconfig b/configs/ls2085aqds_defconfig index 0c770e4..267ad95 100644 --- a/configs/ls2085aqds_defconfig +++ b/configs/ls2085aqds_defconfig @@ -11,3 +11,5 @@ CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_FSL_DSPI=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2085aqds_nand_defconfig b/configs/ls2085aqds_nand_defconfig index 10eda97..916504a 100644 --- a/configs/ls2085aqds_nand_defconfig +++ b/configs/ls2085aqds_nand_defconfig @@ -5,3 +5,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2085ardb_defconfig b/configs/ls2085ardb_defconfig index 7956533..3f8be26 100644 --- a/configs/ls2085ardb_defconfig +++ b/configs/ls2085ardb_defconfig @@ -11,3 +11,5 @@ CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_FSL_DSPI=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2085ardb_nand_defconfig b/configs/ls2085ardb_nand_defconfig index 96a0dfd..5fb1901 100644 --- a/configs/ls2085ardb_nand_defconfig +++ b/configs/ls2085ardb_nand_defconfig @@ -5,3 +5,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y
Hi Prabhakar,
On Wed, Oct 7, 2015 at 6:00 PM, Prabhakar Kushwaha prabhakar@freescale.com wrote:
- updated subject
This is not needed as it is selected by CONFIG_NET_RANDOM_ETHADDR automatically.
Also please make sure adding these Kconfig options with correct order. You can do this by for example, 'make ls2085a_simu_defconfig' then 'make savedefconfig'
Regards, Bin
Bin Meng
Prabhakar Kushwaha
