[U-Boot] [PULL] u-boot-socfpga/master
Dangling PR, sorry it's late ...
The following changes since commit 571bdf16a78e9e116a93d46f4809c4f8a3f2adb6:
arm: interrupt_init: set sp in IRQ/FIQ modes (2014-10-29 09:03:28 -0400)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to a877bec3ecd7961211a59b2c130e055e0f771976:
arm: socfpga: Add socfpga_spim_enable() to reset_manager.c (2014-11-07 16:09:10 +0100)
---------------------------------------------------------------- Anatolij Gustschin (1): socfpga_cyclone5.h: fix kernel console argument in default environment
Marek Vasut (1): arm: socfpga: Add example config entry for EPCS/EPCQ SPI
Stefan Roese (4): arm: socfpga: Add I2C support to SoCFPGA arm: socfpga: Add DT support for SoCFPGA and add socfpga_socrates target arm: socfpga: Add DW master SPI clock to clock_manager.c arm: socfpga: Add socfpga_spim_enable() to reset_manager.c
arch/arm/cpu/armv7/socfpga/clock_manager.c | 14 ++ arch/arm/cpu/armv7/socfpga/misc.c | 6 + arch/arm/cpu/armv7/socfpga/reset_manager.c | 9 ++ arch/arm/dts/Makefile | 2 + arch/arm/dts/socfpga.dtsi | 755 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/socfpga_cyclone5.dtsi | 51 ++++++ arch/arm/dts/socfpga_cyclone5_socrates.dts | 50 ++++++ arch/arm/include/asm/arch-socfpga/gpio.h | 10 ++ arch/arm/include/asm/arch-socfpga/reset_manager.h | 3 + configs/socfpga_socrates_defconfig | 5 + include/configs/socfpga_common.h | 46 ++++++ include/configs/socfpga_cyclone5.h | 2 +- include/dt-bindings/reset/altr,rst-mgr.h | 90 +++++++++++ 13 files changed, 1042 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/socfpga.dtsi create mode 100644 arch/arm/dts/socfpga_cyclone5.dtsi create mode 100644 arch/arm/dts/socfpga_cyclone5_socrates.dts create mode 100644 arch/arm/include/asm/arch-socfpga/gpio.h create mode 100644 configs/socfpga_socrates_defconfig create mode 100644 include/dt-bindings/reset/altr,rst-mgr.h
