[U-Boot] [PATCH] powerpc/85xx: Add basic support for P1023RDS board
The P1023RDS board is the reference board for the P1023 SoC.
Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Haiying Wang Haiying.Wang@freescale.com Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com Signed-off-by: Lei Xu B33228@freescale.com Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- based on "Prepare v2011.06-rc2" MAINTAINERS | 1 + board/freescale/p1023rds/Makefile | 38 ++ board/freescale/p1023rds/bcsr.h | 53 +++ board/freescale/p1023rds/law.c | 35 ++ board/freescale/p1023rds/p1023rds.c | 162 +++++++ board/freescale/p1023rds/tlb.c | 118 +++++ boards.cfg | 2 + doc/README.p1023rds | 102 +++++ include/configs/P1023RDS.h | 567 +++++++++++++++++++++++++ nand_spl/board/freescale/p1023rds/Makefile | 133 ++++++ nand_spl/board/freescale/p1023rds/nand_boot.c | 99 +++++ 11 files changed, 1310 insertions(+), 0 deletions(-) create mode 100644 board/freescale/p1023rds/Makefile create mode 100644 board/freescale/p1023rds/bcsr.h create mode 100644 board/freescale/p1023rds/law.c create mode 100644 board/freescale/p1023rds/p1023rds.c create mode 100644 board/freescale/p1023rds/tlb.c create mode 100644 doc/README.p1023rds create mode 100644 include/configs/P1023RDS.h create mode 100644 nand_spl/board/freescale/p1023rds/Makefile create mode 100644 nand_spl/board/freescale/p1023rds/nand_boot.c
diff --git a/MAINTAINERS b/MAINTAINERS index c462ae2..af31552 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -511,6 +511,7 @@ Ilya Yanok yanok@emcraft.com Roy Zang tie-fei.zang@freescale.com
mpc7448hpc2 MPC7448 + P1023RDS P1023
John Zhan zhanz@sinovee.com
diff --git a/board/freescale/p1023rds/Makefile b/board/freescale/p1023rds/Makefile new file mode 100644 index 0000000..bf87580 --- /dev/null +++ b/board/freescale/p1023rds/Makefile @@ -0,0 +1,38 @@ +# +# Copyright 2010-2011 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms of the GNU General Public License as published by the Free +# Software Foundation; either version 2 of the License, or (at your option) +# any later version. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/p1023rds/bcsr.h b/board/freescale/p1023rds/bcsr.h new file mode 100644 index 0000000..0995aa4 --- /dev/null +++ b/board/freescale/p1023rds/bcsr.h @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2011 Freescale Semiconductor, Inc. + * + * Authors: Chunhe Lan b25806@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + */ + +#ifndef __BCSR_H_ +#define __BCSR_H_ + +#include <common.h> + +/* + * BCSR Bit definitions + * BCSR 15 * + 0 device insertion oriention + 1 stack processor present + 2 power supply shut down/normal operation + 3 I2C bus0 drive enable + 4 reserved + 5:7 I2C bus0 select + 5 - I2C_BUS_0_SS0 + 6 - I2C_BUS_0_SS1 + 7 - I2C_BUS_0_SS2 +*/ + +/* BCSR register base address is 0xFX000020 */ +#define BCSR_BASE_REG_OFFSET 0x20 +#define BCSR_ACCESS_REG_ADDR (CONFIG_SYS_BCSR_BASE + BCSR_BASE_REG_OFFSET) + +#define BCSR15_DEV_INS_ORI 0x80 +#define BCSR15_STACK_PRO_PRE 0x40 +#define BCSR15_POWER_SUPPLY 0x20 +#define BCSR15_I2C_BUS0_EN 0x10 +#define BCSR15_I2C_BUS0_SEG0 0x00 +#define BCSR15_I2C_BUS0_SEG1 0x04 +#define BCSR15_I2C_BUS0_SEG2 0x02 +#define BCSR15_I2C_BUS0_SEG3 0x06 +#define BCSR15_I2C_BUS0_SEG4 0x01 +#define BCSR15_I2C_BUS0_SEG5 0x05 +#define BCSR15_I2C_BUS0_SEG6 0x03 +#define BCSR15_I2C_BUS0_SEG7 0x07 +#define BCSR15_I2C_BUS0_SEG_CLR 0x07 +#define BCSR19_SGMII_SEL_L 0x01 + +/*BCSR Utils functions*/ +void fixup_i2c_bus0_sel_seg0(void); +#endif /* __BCSR_H_ */ diff --git a/board/freescale/p1023rds/law.c b/board/freescale/p1023rds/law.c new file mode 100644 index 0000000..f140f64 --- /dev/null +++ b/board/freescale/p1023rds/law.c @@ -0,0 +1,35 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_4M, + LAW_TRGT_IF_DPAA_SWP_SRAM), + /* The LAW 0xe0000000 ~ 0xefffffff for BCSR and NOR flash */ + SET_LAW(CONFIG_SYS_BCSR_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p1023rds/p1023rds.c b/board/freescale/p1023rds/p1023rds.c new file mode 100644 index 0000000..8cfd199 --- /dev/null +++ b/board/freescale/p1023rds/p1023rds.c @@ -0,0 +1,162 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * Authors: Roy Zang tie-fei.zang@freescale.com + * Chunhe Lan b25806@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/io.h> +#include <asm/cache.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_portals.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <netdev.h> +#include <malloc.h> + +#include "bcsr.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + /* Set ABSWP to implement conversion of addresses in the LBC */ + setbits_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); + + return 0; +} + +int checkboard(void) +{ + u8 *bcsr = (u8 *)BCSR_ACCESS_REG_ADDR; + + printf("Board: P1023 RDS\n"); + + clrbits_8(&bcsr[15], BCSR15_I2C_BUS0_SEG_CLR); + setbits_8(&bcsr[15], BCSR15_I2C_BUS0_SEG0); + + return 0; +} + +/* Fixed sdram init -- doesn't use serial presence detect. */ +phys_size_t fixed_sdram(void) +{ +#ifndef CONFIG_SYS_RAMBOOT + ccsr_ddr_t *ddr = (ccsr_ddr_t *)CONFIG_SYS_MPC85xx_DDR_ADDR; + + set_next_law(0, LAW_SIZE_2G, LAW_TRGT_IF_DDR_1); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + out_be32(&ddr->cs1_bnds, CONFIG_SYS_DDR_CS1_BNDS); + out_be32(&ddr->cs1_config, CONFIG_SYS_DDR_CS1_CONFIG); + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + out_be32(&ddr->sdram_data_init, CONFIG_SYS_DDR_DATA_INIT); + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->timing_cfg_4, CONFIG_SYS_DDR_TIMING_4); + out_be32(&ddr->timing_cfg_5, CONFIG_SYS_DDR_TIMING_5); + out_be32(&ddr->ddr_zq_cntl, CONFIG_SYS_DDR_ZQ_CNTL); + out_be32(&ddr->ddr_wrlvl_cntl, CONFIG_SYS_DDR_WRLVL_CNTL); + out_be32(&ddr->ddr_cdr1, CONFIG_SYS_DDR_CDR_1); + out_be32(&ddr->ddr_cdr2, CONFIG_SYS_DDR_CDR_2); + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); +#endif + return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024ul; +} + +#ifdef CONFIG_PCI +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} +#endif + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_BCSR_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + BCSR region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + bcsr */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_BCSR_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + setup_portals(); + + return 0; +} + +unsigned long get_board_sys_clk(ulong dummy) +{ + return gd->bus_clk; +} + +unsigned long get_board_ddr_clk(ulong dummy) +{ + return gd->mem_clk; +} + +int board_eth_init(bd_t *bis) +{ + return pci_eth_init(bis); +} + +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); +} +#endif diff --git a/board/freescale/p1023rds/tlb.c b/board/freescale/p1023rds/tlb.c new file mode 100644 index 0000000..2b3b679 --- /dev/null +++ b/board/freescale/p1023rds/tlb.c @@ -0,0 +1,118 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I, + 0, 0, BOOKE_PAGESZ_4K, 1), + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_4M, 1), + +#ifndef CONFIG_NAND_SPL + /* *W*G* - BCSR and NOR flash on local bus*/ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_BCSR_BASE, CONFIG_SYS_BCSR_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x40000000, + CONFIG_SYS_PCIE3_MEM_PHYS + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x50000000, + CONFIG_SYS_PCIE3_MEM_PHYS + 0x50000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_VIRT, CONFIG_SYS_PCIE3_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256K, 1), + + /* Bman/Qman */ + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 7, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x00100000, + CONFIG_SYS_BMAN_MEM_PHYS + 0x00100000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 8, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, + 0, 9, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x00100000, + CONFIG_SYS_QMAN_MEM_PHYS + 0x00100000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 10, BOOKE_PAGESZ_1M, 1), +#endif + + /* *I*G - NAND */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 11, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_RAMBOOT + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, + CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 12, BOOKE_PAGESZ_1G, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 13, BOOKE_PAGESZ_1G, 1), +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index d2cacc8..ee775bd 100644 --- a/boards.cfg +++ b/boards.cfg @@ -556,6 +556,8 @@ P1020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freesca P1020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SPIFLASH P1022DS powerpc mpc85xx p1022ds freescale P1022DS_36BIT powerpc mpc85xx p1022ds freescale - P1022DS:36BIT +P1023RDS powerpc mpc85xx p1023rds freescale - P1023RDS +P1023RDS_NAND powerpc mpc85xx p1023rds freescale - P1023RDS:NAND P2010RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB P2010RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT P2010RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT,SDCARD diff --git a/doc/README.p1023rds b/doc/README.p1023rds new file mode 100644 index 0000000..657bd67 --- /dev/null +++ b/doc/README.p1023rds @@ -0,0 +1,102 @@ +Overview +-------- +The P1023 process includes a performance optimized implementation of the +QorIQ data Path Acceleration Architecture (DPAA). This architecture +provides the infrastructure to support simplified sharing of networking +interfaces and accelerators by multiple CPU cores. P1023 is an e500 based +dual core SOC. + +P1023RDS board is a Low End Dual core platform supporting the P1023 +processor of QorIQ series. + +Building U-boot +--------------- +To build the u-boot for P1023RDS: +Configure to NOR boot: + make P1023RDS_config +Configure to NAND boot: + make P1023RDS_NAND_config +Build: + make + +Board Switches +-------------- +Most switches on the board should not be changed. The most frequent +user-settable switches on the board are used to configure +the flash banks. + +J4: all open + +Default NOR flash boot switch setting: + Sw3[1:8]: off on on off on on off off + Sw4[1:8]: off off off on off off off off + Sw6[1:8]: off on off on off on on off + Sw7[1:8]: off on off off on off off off + Sw8[1:8]: on off off off off off off off + +For NAND flash boot,set +Sw4[1:4]: off on on on + +The default native ethernet setting is for RGMII mode. +To use SGMII mode, set +SW8[1:2]: OFF OFF +SW7[6:7]: ON ON + +Memory Map +---------- +0x0000_0000 0x7fff_ffff DDR 2G Cacheable +0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable +0xc000_0000 0xdfff_ffff PCI 512M non-cacheable +0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable + +0xe000_0000 0xe003_ffff BCSR 256K BCSR +0xee00_0000 0xefff_ffff NOR flash 32M NOR flash +0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M +0xff60_0000 0xff7f_ffff CCSR 2M non-cacheable +0xffa0_0000 0xffaf_ffff NAND FLASH 1M non-cacheable +0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 + +Flashing u-boot Images +--------------- +To program the image in the boot flash bank: +NOR flash boot: + => tftp 1000000 u-boot.bin + => protect off all + => erase eff80000 efffffff + => cp.b 1000000 eff80000 80000 + +NAND flash boot: + => tftp 1000000 u-boot-nand.bin + => nand erase 0 80000 + => nand write 1000000 0 80000 + +Firmware ucode location +--------------------------------- +Microcode(ucode) to FMAN's IRAM is needed to make FMAN Ethernet work. +u-boot loads ucode FLASH. The location for ucode: +NOR Flash: 0xfe000000 +NAND Flash: 0x1f00000 + +Using the Device Tree Source File +--------------------------------- +To create the DTB (Device Tree Binary) image file, +use a command similar to this: + + dtc -b 0 -f -I dts -O dtb p1023rds.dts > p1023rds.dtb + +Likely, that .dts file will come from here; + + linux-2.6/arch/powerpc/boot/dts/p1023rds.dts +or + make p1023rds.dtb ARCH=powerpc +in linux-2.6 directory. + +Booting Linux +------------- +Place a linux uImage in the TFTP disk area. + + tftp 1000000 uImage + tftp 2000000 rootfs.ext2.gz.uboot + tftp c00000 p1023rds.dtb + bootm 1000000 2000000 c00000 + diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h new file mode 100644 index 0000000..c9ad33d --- /dev/null +++ b/include/configs/P1023RDS.h @@ -0,0 +1,567 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * Authors: Roy Zang tie-fei.zang@freescale.com + * Chunhe Lan b25806@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * p1023rds board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H +#undef DEBUG + +#ifdef CONFIG_NAND +#define CONFIG_NAND_U_BOOT +#define CONFIG_RAMBOOT_NAND +#endif + +#ifdef CONFIG_NAND_U_BOOT +#define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 +#define CONFIG_SYS_TEXT_BASE 0x11001000 + +#ifdef CONFIG_NAND_SPL +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE_SPL /* start of monitor */ +#else +#define CONFIG_SYS_LDSCRIPT $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif /* CONFIG_NAND_SPL */ +#endif + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE /* BOOKE */ +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx +#define CONFIG_P1023 +#define CONFIG_P1023RDS +#define CONFIG_MP /* support multiple processors */ + +#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controler 1 (slot 1) */ +#define CONFIG_PCIE2 /* PCIE controler 2 (slot 2) */ +#define CONFIG_PCIE3 /* PCIE controler 3 (slot 3) */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif + +#define CONFIG_SYS_CLK_FREQ 66666666 +#define CONFIG_DDR_CLK_FREQ CONFIG_SYS_CLK_FREQ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_HWCONFIG + +#define CONFIG_ENABLE_36BIT_PHYS + +#define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x1fffffff /* fix me, only 1G */ +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* Implement conversion of + addresses in the LBC */ +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff600000 /* CCSRBAR Default */ +#define CONFIG_SYS_CCSRBAR 0xff600000 /* relocated CCSRBAR */ +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ + +/* DDR Setup */ +#define CONFIG_VERY_BIG_RAM + +/* ECC will be enabled based on perf_mode environment variable */ +#undef CONFIG_DDR_ECC + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef + +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 2 + +/* These are used when DDR doesn't use SPD. */ +#define CONFIG_SYS_SDRAM_SIZE 2048u /* DDR is 2GB */ + +/* Default settings for "stable" mode */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003F +#define CONFIG_SYS_DDR_CS1_BNDS 0x0040007F +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014302 +#define CONFIG_SYS_DDR_CS1_CONFIG 0x80014302 +#define CONFIG_SYS_DDR_TIMING_3 0x00020000 +#define CONFIG_SYS_DDR_TIMING_0 0x40110104 +#define CONFIG_SYS_DDR_TIMING_1 0x5C59E544 +#define CONFIG_SYS_DDR_TIMING_2 0x0fA888CA +#define CONFIG_SYS_DDR_MODE_1 0x00441210 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_CTRL 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x0A280100 +#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef +#define CONFIG_SYS_DDR_CLK_CTRL 0x01800000 +#define CONFIG_SYS_DDR_TIMING_4 0x00000001 +#define CONFIG_SYS_DDR_TIMING_5 0x01401400 +#define CONFIG_SYS_DDR_ZQ_CNTL 0x89080600 +#define CONFIG_SYS_DDR_WRLVL_CNTL 0x8675F605 +#define CONFIG_SYS_DDR_CONTROL 0xC70C0008 /* Type = DDR3: No Interleaving */ +#define CONFIG_SYS_DDR_CONTROL2 0x24401010 +#define CONFIG_SYS_DDR_CDR1 0x00000000 +#define CONFIG_SYS_DDR_CDR2 0x00000000 + +#define CONFIG_SYS_DDR_ERR_INT_EN 0x00000000 +#define CONFIG_SYS_DDR_ERR_DIS 0x00000000 +#define CONFIG_SYS_DDR_SBE 0x00000000 + +/* Settings that differ for "performance" mode */ +#define CONFIG_SYS_DDR_CS0_BNDS_PERF 0x0000007F /* Interleaving Enabled */ +#define CONFIG_SYS_DDR_CS1_BNDS_PERF 0x00000000 /* Interleaving Enabled */ +#define CONFIG_SYS_DDR_CS1_CONFIG_PERF 0x80014302 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x5C58E544 +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x0FA888CA +#define CONFIG_SYS_DDR_CONTROL_PERF 0xC70C4008 /* Type = DDR3: cs0-cs1 interleaving */ +#define CONFIG_SYS_DDR_CDR_1 0x00000000 +#define CONFIG_SYS_DDR_CDR_2 0x00000000 + +#undef CONFIG_CLOCKS_IN_MHZ + +/* + * Memory map + * + * 0x0000_0000 0x7fff_ffff DDR 2G Cacheable + * 0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable + * 0xc000_0000 0xdfff_ffff PCI 512M non-cacheable + * 0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable + * + * Localbus non-cacheable + * 0xe000_0000 0xe003_ffff BCSR 256K BCSR + * 0xee00_0000 0xefff_ffff NOR flash 32M NOR flash + * 0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M + * 0xff60_0000 0xff7f_ffff CCSR 2M non-cacheable + * 0xffa0_0000 0xffaf_ffff NAND 1M non-cacheable + * 0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 + */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_BCSR_BASE 0xe0000000 /* start of on board FPGA */ +#define CONFIG_SYS_BCSR_BASE_PHYS CONFIG_SYS_BCSR_BASE + +#ifndef CONFIG_NAND +#define CONFIG_SYS_FLASH_BASE 0xee000000 /* start of FLASH 32M */ + +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE + +#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_16 | BR_V) +#define CONFIG_FLASH_OR_PRELIM 0xfe000ff7 + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ +#else +#define CONFIG_SYS_NO_FLASH +#endif + +#if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) +#define CONFIG_SYS_RAMBOOT +#else +#undef CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f function */ +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ + +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (6 * 1024 * 1024) /* Reserved for malloc */ + +#ifndef CONFIG_NAND_SPL +#define CONFIG_SYS_NAND_BASE 0xffa00000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#else +#define CONFIG_SYS_NAND_BASE 0xfff00000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#endif + +#define CONFIG_SYS_NAND_BASE_LIST {CONFIG_SYS_NAND_BASE} +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND +#define CONFIG_NAND_FSL_ELBC +#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024) + +/* NAND boot: 4K NAND loader config */ +#define CONFIG_SYS_NAND_SPL_SIZE 0x1000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE ((512 << 10) + CONFIG_SYS_NAND_SPL_SIZE) +#define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000 - CONFIG_SYS_NAND_SPL_SIZE) +#define CONFIG_SYS_NAND_U_BOOT_START 0x11000000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (0) +#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000 +#define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_RELOC + 0x10000) + +/* NAND flash config */ +#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_NAND_OR_PRELIM (0xFFF80000 /* length 32K */ \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) + +#ifdef CONFIG_RAMBOOT_NAND +#define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Address */ +#define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ +/* chip select 1 - BCSR */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_BCSR_BASE_PHYS) \ + | BR_MS_GPCM | BR_PS_8 | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_GPCM_CSNT | OR_GPCM_XACS \ + | OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR \ + | OR_GPCM_EAD) +#else +#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ +#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ +/* chip select 1 - BCSR */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_BCSR_BASE_PHYS) \ + | BR_MS_GPCM | BR_PS_8 | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_GPCM_CSNT | OR_GPCM_XACS \ + | OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR \ + | OR_GPCM_EAD) +#endif + +/* Serial Port + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) +#ifdef CONFIG_NAND_SPL +#define CONFIG_NS16550_MIN_FUNCTIONS +#endif + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +#define CONFIG_SYS_64BIT_VSPRINTF +#define CONFIG_SYS_64BIT_STRTOUL + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x51 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* + * I2C2 EEPROM + */ +#define CONFIG_ID_EEPROM +#ifdef CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#endif +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x51 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_BUS_NUM 0 + +#define CONFIG_CMD_I2C + +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ATMEL + +#define CONFIG_HARD_SPI +#define CONFIG_FSL_ESPI + +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +/* controller 3, Slot 1, tgtid 3, Base address b000 */ +#define CONFIG_SYS_PCIE3_NAME "Slot 3" +#define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xffc00000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_PHYS 0xffc00000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ + +/* controller 2, direct to uli, tgtid 2, Base address 9000 */ +#define CONFIG_SYS_PCIE2_NAME "Slot 2" +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 1, Slot 2, tgtid 1, Base address a000 */ +#define CONFIG_SYS_PCIE1_NAME "Slot 1" +#define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc20000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc20000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +#if defined(CONFIG_PCI) +#define CONFIG_E1000 /* Defind e1000 pci Ethernet card */ +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#endif /* CONFIG_PCI */ + +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI +#endif + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_RAMBOOT_NAND) +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x4000) +#define CONFIG_ENV_SIZE 0x2000 +#endif +#else +#define CONFIG_ENV_IS_IN_FLASH +#if CONFIG_SYS_MONITOR_BASE > 0xfff80000 +#define CONFIG_ENV_ADDR 0xfff80000 +#else +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#endif +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_PING +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_REGINFO + +#if defined(CONFIG_PCI) +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* + * USB + */ +#define CONFIG_USB_EHCI + +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_USB_EHCI_FSL +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_BOOTFILE uImage +#define CONFIG_UBOOTPATH (u-boot.bin) /* U-Boot image on TFTP server */ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ + +#define CONFIG_BAUDRATE 115200 + +/* Qman/Bman */ +#define CONFIG_SYS_DPAA_QBMAN /* support Q/Bman */ +#define CONFIG_SYS_QMAN_MEM_BASE 0xff000000 +#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 +#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 + +/* For FM */ +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#endif + +#ifndef CONFIG_NAND +/* Default address of microcode for the Linux Fman driver */ +/* QE microcode/firmware address */ +#define CONFIG_SYS_FMAN_FW_ADDR 0xEF000000 +#define CONFIG_SYS_FMAN_FW_ADDR_PHYS CONFIG_SYS_FMAN_FW_ADDR +#else +#define CONFIG_SYS_QE_FW_IN_NAND 0x1f00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x10000000 +#define CONFIG_SYS_FMAN_FW_LENGTH 0x10000 +#endif + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x2 +#define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x7 + +#define CONFIG_SYS_TBIPA_VALUE 8 +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=usb1:dr_mode=host,phy_type=ulpi\0" + +#endif /* __CONFIG_H */ diff --git a/nand_spl/board/freescale/p1023rds/Makefile b/nand_spl/board/freescale/p1023rds/Makefile new file mode 100644 index 0000000..9e03830 --- /dev/null +++ b/nand_spl/board/freescale/p1023rds/Makefile @@ -0,0 +1,133 @@ +# +# Copyright 2010-2011 Freescale Semiconductor, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +NAND_SPL := y +PAD_TO := 0xfff01000 + +include $(TOPDIR)/config.mk + +nandobj := $(OBJTREE)/nand_spl/ + +LDSCRIPT= $(TOPDIR)/$(CPUDIR)/u-boot-nand_spl.lds +LDFLAGS := -T $(nandobj)u-boot-nand_spl.lds -Ttext $(CONFIG_SYS_TEXT_BASE_SPL) \ + $(LDFLAGS) $(LDFLAGS_FINAL) +AFLAGS += -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_NAND_SPL + +SOBJS = start.o resetvec.o +COBJS = cache.o cpu_init_early.o cpu_init_nand.o fsl_law.o law.o \ + nand_boot.o nand_boot_fsl_elbc.o ns16550.o tlb.o tlb_table.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(nandobj)board/$(BOARDDIR) + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) $(PLATFORM_LIBS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +$(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + +# create symbolic links for common files + +$(obj)cache.c: + @rm -f $(obj)cache.c + ln -sf $(SRCTREE)/arch/powerpc/lib/cache.c $(obj)cache.c + +$(obj)cpu_init_early.c: + @rm -f $(obj)cpu_init_early.c + ln -sf $(SRCTREE)/$(CPUDIR)/cpu_init_early.c $(obj)cpu_init_early.c + +$(obj)cpu_init_nand.c: + @rm -f $(obj)cpu_init_nand.c + ln -sf $(SRCTREE)/$(CPUDIR)/cpu_init_nand.c $(obj)cpu_init_nand.c + +$(obj)fsl_law.c: + @rm -f $(obj)fsl_law.c + ln -sf $(SRCTREE)/drivers/misc/fsl_law.c $(obj)fsl_law.c + +$(obj)law.c: + @rm -f $(obj)law.c + ln -sf $(SRCTREE)/board/$(BOARDDIR)/law.c $(obj)law.c + +$(obj)nand_boot_fsl_elbc.c: + @rm -f $(obj)nand_boot_fsl_elbc.c + ln -sf $(SRCTREE)/nand_spl/nand_boot_fsl_elbc.c \ + $(obj)nand_boot_fsl_elbc.c + +$(obj)ns16550.c: + @rm -f $(obj)ns16550.c + ln -sf $(SRCTREE)/drivers/serial/ns16550.c $(obj)ns16550.c + +$(obj)resetvec.S: + @rm -f $(obj)resetvec.S + ln -s $(SRCTREE)/$(CPUDIR)/resetvec.S $(obj)resetvec.S + +$(obj)fixed_ivor.S: + @rm -f $(obj)fixed_ivor.S + ln -sf $(SRCTREE)/$(CPUDIR)/fixed_ivor.S $(obj)fixed_ivor.S + +$(obj)start.S: $(obj)fixed_ivor.S + @rm -f $(obj)start.S + ln -sf $(SRCTREE)/$(CPUDIR)/start.S $(obj)start.S + +$(obj)tlb.c: + @rm -f $(obj)tlb.c + ln -sf $(SRCTREE)/$(CPUDIR)/tlb.c $(obj)tlb.c + +$(obj)tlb_table.c: + @rm -f $(obj)tlb_table.c + ln -sf $(SRCTREE)/board/$(BOARDDIR)/tlb.c $(obj)tlb_table.c + +ifneq ($(OBJTREE), $(SRCTREE)) +$(obj)nand_boot.c: + @rm -f $(obj)nand_boot.c + ln -s $(SRCTREE)/nand_spl/board/$(BOARDDIR)/nand_boot.c $(obj)nand_boot.c +endif + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### + diff --git a/nand_spl/board/freescale/p1023rds/nand_boot.c b/nand_spl/board/freescale/p1023rds/nand_boot.c new file mode 100644 index 0000000..0065c87 --- /dev/null +++ b/nand_spl/board/freescale/p1023rds/nand_boot.c @@ -0,0 +1,99 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * Author: Roy Zang tie-fei.zang@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <ns16550.h> +#include <asm/io.h> +#include <nand.h> +#include <asm/fsl_law.h> + +/* Fixed sdram init -- doesn't use serial presence detect. */ +void sdram_init(void) +{ + ccsr_ddr_t *ddr = (ccsr_ddr_t *)CONFIG_SYS_MPC85xx_DDR_ADDR; + + set_next_law(0, LAW_SIZE_2G, LAW_TRGT_IF_DDR_1); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + out_be32(&ddr->cs1_bnds, CONFIG_SYS_DDR_CS1_BNDS); + out_be32(&ddr->cs1_config, CONFIG_SYS_DDR_CS1_CONFIG); + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + out_be32(&ddr->sdram_data_init, CONFIG_SYS_DDR_DATA_INIT); + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->timing_cfg_4, CONFIG_SYS_DDR_TIMING_4); + out_be32(&ddr->timing_cfg_5, CONFIG_SYS_DDR_TIMING_5); + out_be32(&ddr->ddr_zq_cntl, CONFIG_SYS_DDR_ZQ_CNTL); + out_be32(&ddr->ddr_wrlvl_cntl, CONFIG_SYS_DDR_WRLVL_CNTL); + out_be32(&ddr->ddr_cdr1, CONFIG_SYS_DDR_CDR_1); + out_be32(&ddr->ddr_cdr2, CONFIG_SYS_DDR_CDR_2); + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); +} + +void board_init_f(ulong bootflag) +{ + u32 plat_ratio, bus_clk; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + + /* initialize selected port with appropriate baud rate */ + plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; + plat_ratio >>= 1; + bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + bus_clk / 16 / CONFIG_BAUDRATE); + + puts("\nNAND boot... "); + /* Initialize the DDR3 */ + sdram_init(); + /* copy code to RAM and jump to it - this should not return */ + /* NOTE - code has to be copied out of NAND buffer before + * other blocks can be read. + */ + relocate_code(CONFIG_SYS_NAND_U_BOOT_RELOC_SP, 0, + CONFIG_SYS_NAND_U_BOOT_RELOC); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + nand_boot(); +} + +void putc(char c) +{ + if (c == '\n') + NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM1, '\r'); + + NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM1, c); +} + +void puts(const char *str) +{ + while (*str) + putc(*str++); +}
Dear Roy Zang,
In message 1307508687-12522-1-git-send-email-tie-fei.zang@freescale.com you wrote:
Please fix the checkpatch warnings (7 lines over 80 characters)
etc. Please do not undef what is not defined in the first place.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Wednesday, June 08, 2011 13:31 PM To: Zang Roy-R61911 Cc: u-boot@lists.denx.de; Xu Lei-B33228; Kumar Gala; Wang Haiying-R54964; sun york-R58495; Lan Chunhe-B25806 Subject: Re: [U-Boot] [PATCH] powerpc/85xx: Add basic support for P1023RDS board
Dear Roy Zang,
I can fix it. In fact, I use checkpatch every time before I send out patch. If you check the board header file, most of them has this problem.
Do you think + /* physical addr of CCSRBAR */ +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR is better than +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ ??? Please clarify.
Will fix. Thanks. Roy
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Real Programmers always confuse Christmas and Halloween because OCT 31 == DEC 25 ! - Andrew Rutherford (andrewr@ucs.adelaide.edu.au)
Dear Zang Roy-R61911,
[excessive Cc: list trimmed]
In message 2239AC579C7D3646A720227A37E0268115768A@039-SN1MPN1-004.039d.mgd.msft.net you wrote:
Then I do not understand why you submitted the patch at all before cleaning it up.
Cleanup patches are welcome.
Do you think
- /* physical addr of CCSRBAR */
At least the first version does not violate coding style requirements.
Regarding the general topic of comments - there are such and such comments. Things like
i = i + 1; /* Increment variable i by one */
are gratuitous and of no use at all.
In your example above, I ask myself why we need CONFIG_SYS_CCSRBAR_PHYS at all when whe already have CONFIG_SYS_CCSRBAR (or vice versa).
And why we need a comment that explains this in grat detail - separate for each single macro.
Please re-read "Chapter 8: Commenting" in the coding-style document for more details.
Roy Zang
Zang Roy-R61911
