[U-Boot] [PATCH 1/2] hummingboard: Remove mx6solo specific support
Hummingboard dual, dual-lite and solo are now supported via SPL mechanism.
Remove the previous hummingboard support, which does not use SPL and supported only the solo variant.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/Kconfig | 5 - board/solidrun/hummingboard/Kconfig | 15 -- board/solidrun/hummingboard/MAINTAINERS | 6 - board/solidrun/hummingboard/Makefile | 9 -- board/solidrun/hummingboard/README | 40 ------ board/solidrun/hummingboard/hummingboard.c | 182 ----------------------- board/solidrun/hummingboard/solo.cfg | 25 ---- configs/hummingboard_solo_defconfig | 3 - include/configs/hummingboard.h | 224 ----------------------------- 9 files changed, 509 deletions(-) delete mode 100644 board/solidrun/hummingboard/Kconfig delete mode 100644 board/solidrun/hummingboard/MAINTAINERS delete mode 100644 board/solidrun/hummingboard/Makefile delete mode 100644 board/solidrun/hummingboard/README delete mode 100644 board/solidrun/hummingboard/hummingboard.c delete mode 100644 board/solidrun/hummingboard/solo.cfg delete mode 100644 configs/hummingboard_solo_defconfig delete mode 100644 include/configs/hummingboard.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7c383cb..b97f72b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -542,10 +542,6 @@ config TARGET_GW_VENTANA select CPU_V7 select SUPPORT_SPL
-config TARGET_HUMMINGBOARD - bool "Support hummingboard" - select CPU_V7 - config TARGET_KOSAGI_NOVENA bool "Support Kosagi Novena" select CPU_V7 @@ -862,7 +858,6 @@ source "board/siemens/pxm2/Kconfig" source "board/siemens/rut/Kconfig" source "board/silica/pengwyn/Kconfig" source "board/solidrun/mx6cuboxi/Kconfig" -source "board/solidrun/hummingboard/Kconfig" source "board/spear/spear300/Kconfig" source "board/spear/spear310/Kconfig" source "board/spear/spear320/Kconfig" diff --git a/board/solidrun/hummingboard/Kconfig b/board/solidrun/hummingboard/Kconfig deleted file mode 100644 index 36b7904..0000000 --- a/board/solidrun/hummingboard/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_HUMMINGBOARD - -config SYS_BOARD - default "hummingboard" - -config SYS_VENDOR - default "solidrun" - -config SYS_SOC - default "mx6" - -config SYS_CONFIG_NAME - default "hummingboard" - -endif diff --git a/board/solidrun/hummingboard/MAINTAINERS b/board/solidrun/hummingboard/MAINTAINERS deleted file mode 100644 index c0c062a..0000000 --- a/board/solidrun/hummingboard/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -HUMMINGBOARD BOARD -M: Jon Nettleton jon.nettleton@gmail.com -S: Maintained -F: board/solidrun/hummingboard/ -F: include/configs/hummingboard.h -F: configs/hummingboard_solo_defconfig diff --git a/board/solidrun/hummingboard/Makefile b/board/solidrun/hummingboard/Makefile deleted file mode 100644 index 042a2f0..0000000 --- a/board/solidrun/hummingboard/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# -# (C) Copyright 2013 Freescale Semiconductor, Inc. -# Copyright (C) 2013, Boundary Devices info@boundarydevices.com -# Copyright (C) 2013, Jon Nettleton jon.nettleton@gmail.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := hummingboard.o diff --git a/board/solidrun/hummingboard/README b/board/solidrun/hummingboard/README deleted file mode 100644 index cfd62d4..0000000 --- a/board/solidrun/hummingboard/README +++ /dev/null @@ -1,40 +0,0 @@ -U-Boot for SolidRun Hummingboard --------------------------------- - -This file contains information for the port of U-Boot to the Hummingboard. - -For more details about Hummingboard, please refer to: -http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware - -(Carrier-One was the previous name of Hummingboard). - -Building U-boot for Hummingboard --------------------------------- - -To build U-Boot for the Hummingboard Solo version: - -$ make hummingboard_solo_config -$ make - -Flashing U-boot into the SD card --------------------------------- - -- After the 'make' command completes, the generated 'u-boot.imx' binary must be -flashed into the SD card: - -$ sudo dd if=u-boot.imx of=/dev/mmcblk0 bs=1k seek=1; sync - -(Note - the SD card node may vary, so adjust this as needed). - -Also, a more detailed explanation on how to format the SD card is available -at doc/README.imximage. - -- Insert the micro SD card into the slot located in the bottom of the board - -- Connect a 3.3V USB to serial converter cable to the host PC. The MX6 UART -signals are available in the 26 pin connector as shown at: -http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware -(Check for "26 pin header layout"). - -- Power up the board via USB cable (CON201) and U-boot messages will appear in -the serial console. diff --git a/board/solidrun/hummingboard/hummingboard.c b/board/solidrun/hummingboard/hummingboard.c deleted file mode 100644 index 52c384b..0000000 --- a/board/solidrun/hummingboard/hummingboard.c +++ /dev/null @@ -1,182 +0,0 @@ -/* - * Copyright (C) 2013 Freescale Semiconductor, Inc. - * Copyright (C) 2013 SolidRun ltd. - * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com. - * - * Authors: Fabio Estevam fabio.estevam@freescale.com - Jon Nettleton jon.nettleton@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <asm/arch/clock.h> -#include <asm/arch/crm_regs.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/iomux.h> -#include <asm/arch/mx6-pins.h> -#include <asm/arch/sys_proto.h> -#include <asm/errno.h> -#include <asm/gpio.h> -#include <asm/imx-common/iomux-v3.h> -#include <asm/io.h> -#include <mmc.h> -#include <fsl_esdhc.h> -#include <miiphy.h> -#include <netdev.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ - PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define USDHC_PAD_CLK_CTRL (PAD_CTL_SPEED_LOW | \ - PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | \ - PAD_CTL_HYS) - -#define USDHC_PAD_GPIO_CTRL (PAD_CTL_PUS_22K_UP | \ - PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define ENET_PAD_CTRL_PD (PAD_CTL_PUS_100K_DOWN | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define ENET_PAD_CTRL_CLK ((PAD_CTL_PUS_100K_UP & ~PAD_CTL_PKE) | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define ETH_PHY_RESET IMX_GPIO_NR(4, 15) - -int dram_init(void) -{ - gd->ram_size = ((phys_size_t)CONFIG_DDR_MB * 1024 * 1024); - - return 0; -} - -static iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -static void setup_iomux_uart(void) -{ - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); -} - -static iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CLK_CTRL), - MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_GPIO_4__SD2_CD_B | MUX_PAD_CTRL(USDHC_PAD_GPIO_CTRL), -}; - -#ifdef CONFIG_FSL_ESDHC -static struct fsl_esdhc_cfg usdhc_cfg[1] = { - { USDHC2_BASE_ADDR }, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - return 1; /* SD card is the boot medium, so always present */ -} - -int board_mmc_init(bd_t *bis) -{ - imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - - return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -} -#endif - -#ifdef CONFIG_FEC_MXC -static iomux_v3_cfg_t const enet_pads[] = { - MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - /* AR8035 reset */ - MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - /* AR8035 interrupt */ - MX6_PAD_DI0_PIN2__GPIO4_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* GPIO16 -> AR8035 25MHz */ - MX6_PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), - /* AR8035 CLK_25M --> ENET_REF_CLK (V22) */ - MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL_CLK), - MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), - MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), -}; - -static void setup_iomux_enet(void) -{ - imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); - - gpio_direction_output(ETH_PHY_RESET, 0); - mdelay(2); - gpio_set_value(ETH_PHY_RESET, 1); -} - -int board_phy_config(struct phy_device *phydev) -{ - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; - - int ret = enable_fec_anatop_clock(ENET_25MHZ); - if (ret) - return ret; - - /* set gpr1[ENET_CLK_SEL] */ - setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); - - setup_iomux_enet(); - - return cpu_eth_init(bis); -} -#endif - -int board_early_init_f(void) -{ - setup_iomux_uart(); - - return 0; -} - -int board_init(void) -{ - /* address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; - - return 0; -} - -int checkboard(void) -{ - puts("Board: Hummingboard\n"); - - return 0; -} diff --git a/board/solidrun/hummingboard/solo.cfg b/board/solidrun/hummingboard/solo.cfg deleted file mode 100644 index 28dd750..0000000 --- a/board/solidrun/hummingboard/solo.cfg +++ /dev/null @@ -1,25 +0,0 @@ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* image version */ -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ -BOOT_FROM sd - -#define __ASSEMBLY__ -#include <config.h> -#include "asm/arch/mx6-ddr.h" -#include "asm/arch/iomux.h" -#include "asm/arch/crm_regs.h" - -#include "../mx6-microsom/ddr-800mhz-32bit-setup.cfg" -#include "../mx6-microsom/800mhz_2x128mx16.cfg" -#include "../mx6-microsom/clocks.cfg" diff --git a/configs/hummingboard_solo_defconfig b/configs/hummingboard_solo_defconfig deleted file mode 100644 index 600fa00..0000000 --- a/configs/hummingboard_solo_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/solidrun/hummingboard/solo.cfg,MX6S,DDR_MB=512" -CONFIG_ARM=y -CONFIG_TARGET_HUMMINGBOARD=y diff --git a/include/configs/hummingboard.h b/include/configs/hummingboard.h deleted file mode 100644 index 973f2c5..0000000 --- a/include/configs/hummingboard.h +++ /dev/null @@ -1,224 +0,0 @@ -/* - * Copyright (C) 2013 Freescale Semiconductor, Inc. - * Copyright (C) 2013 SolidRun ltd. - * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com - * - * Configuration settings for the SolidRun Hummingboard. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#include "mx6_common.h" -#include <asm/arch/imx-regs.h> -#include <asm/imx-common/gpio.h> -#include <linux/sizes.h> - -#define CONFIG_MX6 -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO - -#define CONFIG_MACH_TYPE 4773 - -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG - -#define CONFIG_SYS_GENERIC_BOARD - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (2 * SZ_1M) - -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_MXC_GPIO - -#define CONFIG_MXC_UART -#define CONFIG_MXC_UART_BASE UART1_BASE - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_I2C - -#define CONFIG_CMD_BMODE -#define CONFIG_CMD_SETEXPR -#define CONFIG_CMD_MEMTEST -#define CONFIG_BOOTDELAY 3 - -#define CONFIG_SYS_MEMTEST_START 0x10000000 -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 500 * SZ_1M) -#define CONFIG_LOADADDR 0x12000000 -#define CONFIG_SYS_TEXT_BASE 0x17800000 - -/* MMC Configuration */ -#define CONFIG_FSL_ESDHC -#define CONFIG_FSL_USDHC -#define CONFIG_SYS_FSL_USDHC_NUM 1 -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 - -#define CONFIG_MMC -#define CONFIG_CMD_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_BOUNCE_BUFFER -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION - -/* Ethernet Configuration */ -#define CONFIG_FEC_MXC -#ifdef CONFIG_FEC_MXC -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_MII -#define CONFIG_CMD_NET -#define CONFIG_MII -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_FEC_MXC_PHYADDR 0 -#define CONFIG_PHYLIB -#define CONFIG_PHY_ATHEROS -#endif - -#if defined(CONFIG_MX6S) -#define CONFIG_DEFAULT_FDT_FILE "imx6dl-hummingboard.dtb" -#endif - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "script=boot.scr\0" \ - "image=zImage\0" \ - "console=ttymxc0\0" \ - "splashpos=m,m\0" \ - "fdt_high=0xffffffff\0" \ - "initrd_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "fdt_addr=0x18000000\0" \ - "boot_fdt=try\0" \ - "ip_dyn=yes\0" \ - "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ - "update_sd_firmware_filename=u-boot.imx\0" \ - "update_sd_firmware=" \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "if mmc dev ${mmcdev}; then " \ - "if ${get_cmd} ${update_sd_firmware_filename}; then " \ - "setexpr fw_sz ${filesize} / 0x200; " \ - "setexpr fw_sz ${fw_sz} + 1; " \ - "mmc write ${loadaddr} 0x2 ${fw_sz}; " \ - "fi; " \ - "fi\0" \ - "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=${mmcroot}\0" \ - "loadbootscript=" \ - "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source\0" \ - "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if run loadfdt; then " \ - "bootz ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "if test ${boot_fdt} = try; then " \ - "bootz; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi; " \ - "else " \ - "bootz; " \ - "fi;\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "${get_cmd} ${image}; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ - "bootz ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "if test ${boot_fdt} = try; then " \ - "bootz; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi; " \ - "else " \ - "bootz; " \ - "fi;\0" - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "fi; " \ - "else run netboot; fi" - -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_CMDLINE_EDITING - -/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM -#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR -#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE - -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - -#define CONFIG_ENV_SIZE (8 * 1024) - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_OF_LIBFDT -#define CONFIG_CMD_BOOTZ - -#ifndef CONFIG_SYS_DCACHE_OFF -#define CONFIG_CMD_CACHE -#endif - -#endif /* __CONFIG_H * */
Cubox-i boards are also supported, so update the README file.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/solidrun/mx6cuboxi/README | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/README b/board/solidrun/mx6cuboxi/README index 3050c48..b417ff0 100644 --- a/board/solidrun/mx6cuboxi/README +++ b/board/solidrun/mx6cuboxi/README @@ -1,7 +1,7 @@ -How to use U-boot on Solid-run mx6 hummingboard ------------------------------------------------ +How to use U-boot on Solid-run mx6 Hummingboard and Cubox-i +-----------------------------------------------------------
-- Build U-boot for hummingboard: +- Build U-boot for Hummingboard/Cubox-i:
$ make mrproper $ make mx6cuboxi_defconfig @@ -17,5 +17,5 @@ sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync
sudo dd if=u-boot.img of=/dev/mmcblk0 bs=1k seek=69; sync
-- Insert the SD card in the hummingboard, power it up and U-boot messages -should come up. +- Insert the SD card in the board, power it up and U-boot messages should +come up.
Hi Stefano,
Are you fine with this series?
Thanks,
Fabio Estevam
Fabio Estevam
Fabio Estevam
