[PATCH] mtd: cqspi: Wait for transfer completion
Wait for the read/write transfer finish bit get actually cleared, this does not happen immediately on at least SoCFPGA Gen5.
Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Vignesh R vigneshr@ti.com Cc: Pratyush Yadav p.yadav@ti.com --- drivers/spi/cadence_qspi_apb.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 429ee335db6..2cdf4c9c9f8 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -858,6 +858,14 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, writel(CQSPI_REG_INDIRECTRD_DONE, plat->regbase + CQSPI_REG_INDIRECTRD);
+ /* Check indirect done status */ + ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD, + CQSPI_REG_INDIRECTRD_DONE, 0, 10, 0); + if (ret) { + printf("Indirect read clear completion error (%i)\n", ret); + goto failrd; + } + return 0;
failrd: @@ -1012,6 +1020,15 @@ cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat, /* Clear indirect completion status */ writel(CQSPI_REG_INDIRECTWR_DONE, plat->regbase + CQSPI_REG_INDIRECTWR); + + /* Check indirect done status */ + ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTWR, + CQSPI_REG_INDIRECTWR_DONE, 0, 10, 0); + if (ret) { + printf("Indirect write clear completion error (%i)\n", ret); + goto failwr; + } + if (bounce_buf) free(bounce_buf); return 0;
- /* Check indirect done status */
- ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD,
- if (ret) {
goto failrd;
Huh, this is strange. I would expect the bit to clear immediately since it doesn't really do any operation on the flash. How long does it usually take to clear? If you don't wait for it to clear does anything break?
- ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTWR,
- if (ret) {
goto failwr;
- if (bounce_buf) free(bounce_buf); return 0;
-- 2.33.0
- if (ret) {
goto failrd;
Often it does clear immediately, but there were a few odd cases where it did not happen right away, in which case I had transfer corruption.
- if (ret) {
goto failrd;
By "transfer corruption" do you mean the current transfer gets corrupted or the next one?
We get here _after_ the transfer is completed and this bit should have little to do with the data received. If the current transfer fails then I suspect something else might be going wrong the this is just a symptom of the problem.
- if (ret) {
goto failrd;
As far as I recall, the problem was triggered when using UBI on the SPI NOR, so that could very well be the next transfer.
- if (ret) {
goto failrd;
Any further decisions here? shall I take it or v2?
Jagan.
- if (ret) {
goto failrd;
I think we need more information here. I don't see why checking this bit would interfere with the current transfer since that is already finished by the time we get here. If it is the next transfer then this might just be a symptom and the real problem might be somewhere else.
On 14/09/21 05:22AM, Marek Vasut wrote: > Wait for the read/write transfer finish bit get actually cleared, > this does not happen immediately on at least SoCFPGA Gen5. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Jagan Teki jagan@amarulasolutions.com > Cc: Vignesh R vigneshr@ti.com > Cc: Pratyush Yadav p.yadav@ti.com > --- > drivers/spi/cadence_qspi_apb.c | 17 +++++++++++++++++ > 1 file changed, 17 insertions(+) > > diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c > index 429ee335db6..2cdf4c9c9f8 100644 > --- a/drivers/spi/cadence_qspi_apb.c > +++ b/drivers/spi/cadence_qspi_apb.c > @@ -858,6 +858,14 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, > writel(CQSPI_REG_INDIRECTRD_DONE, > plat->regbase + CQSPI_REG_INDIRECTRD); > + /* Check indirect done status */ > + ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD, > + CQSPI_REG_INDIRECTRD_DONE, 0, 10, 0); > + if (ret) { > + printf("Indirect read clear completion error (%i)\n", ret); > + goto failrd; > + } > +
What additional information do you need ?
Hi Marek,
On 9/14/21 7:42 PM, Pratyush Yadav wrote: > On 14/09/21 05:22AM, Marek Vasut wrote: > > Wait for the read/write transfer finish bit get actually cleared, > > this does not happen immediately on at least SoCFPGA Gen5. > > > > Signed-off-by: Marek Vasut marex@denx.de > > Cc: Jagan Teki jagan@amarulasolutions.com > > Cc: Vignesh R vigneshr@ti.com > > Cc: Pratyush Yadav p.yadav@ti.com > > --- > > drivers/spi/cadence_qspi_apb.c | 17 +++++++++++++++++ > > 1 file changed, 17 insertions(+) > > > > diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c > > index 429ee335db6..2cdf4c9c9f8 100644 > > --- a/drivers/spi/cadence_qspi_apb.c > > +++ b/drivers/spi/cadence_qspi_apb.c > > @@ -858,6 +858,14 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, > > writel(CQSPI_REG_INDIRECTRD_DONE, > > plat->regbase + CQSPI_REG_INDIRECTRD); > > + /* Check indirect done status */ > > + ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD, > > + CQSPI_REG_INDIRECTRD_DONE, 0, 10, 0); > > + if (ret) { > > + printf("Indirect read clear completion error (%i)\n", ret); > > + goto failrd; > > + } > > + > > Huh, this is strange. I would expect the bit to clear immediately since > it doesn't really do any operation on the flash. How long does it > usually take to clear? If you don't wait for it to clear does anything > break?
Sorry for the late reply. I dropped the ball on this one.
The additional information I needed was to know what exactly happens if we don't wait for this bit to be cleared. Does the _current_ transfer go though fine? If it does, what gets corrupted in the next transfer? Do you only get partial data? Do you get garbage data? Do you get no data at all?
All this information would be useful for understanding if this fix is the right one, and if so why it is the right one.
Hi Pratyush,
Do you mean the bit is using on the patch is not proper for all transfers? did you find any issues on your tests some where? please indicate what's wrong?
Jagan.
Hi Marek,
if (ret) {
goto failrd;
if (ret) {
goto failwr;
Does this patch to be part of the release?
Jagan.
On 12/2/21 06:48, Jagan Teki wrote:
Hi Marek,
if (ret) {
goto failrd;
failrd:
if (ret) {
goto failwr;
Yes, this fix was posted way before the 2022.01 MR even opened, it can be added.
Hi Marek,
if (ret) {
goto failrd;
failrd:
if (ret) {
goto failwr;
Yeah. was delayed. in fact I was waited response from Pratyush previous comments. I will send the PR anyway.
Thanks, Jagan.
Jagan Teki
Pratyush Yadav
