[U-Boot] [PATCH] net: Move initialization of Au1x00 SoC ethernet MAC to cpu_eth_init
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init as a part of ongoing eth_initialize cleanup work. The function ret value is also fixed as it should be negative on fail.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp Signed-off-by: Ben Warren biggerbadderben@gmail.com --- cpu/mips/au1x00_eth.c | 2 +- cpu/mips/cpu.c | 9 +++++++++ include/netdev.h | 1 + net/eth.c | 4 ---- 4 files changed, 11 insertions(+), 5 deletions(-)
diff --git a/cpu/mips/au1x00_eth.c b/cpu/mips/au1x00_eth.c index 8ddc06a..6272a3a 100644 --- a/cpu/mips/au1x00_eth.c +++ b/cpu/mips/au1x00_eth.c @@ -283,7 +283,7 @@ int au1x00_enet_initialize(bd_t *bis){
if ((dev = (struct eth_device*)malloc(sizeof *dev)) == NULL) { puts ("malloc failed\n"); - return 0; + return -1; }
memset(dev, 0, sizeof *dev); diff --git a/cpu/mips/cpu.c b/cpu/mips/cpu.c index 38d8697..b7180b0 100644 --- a/cpu/mips/cpu.c +++ b/cpu/mips/cpu.c @@ -23,6 +23,7 @@
#include <common.h> #include <command.h> +#include <netdev.h> #include <asm/mipsregs.h> #include <asm/cacheops.h> #include <asm/reboot.h> @@ -73,3 +74,11 @@ void write_one_tlb(int index, u32 pagemask, u32 hi, u32 low0, u32 low1) write_c0_index(index); tlb_write_indexed(); } + +int cpu_eth_init(bd_t *bis) +{ +#ifdef CONFIG_SOC_AU1X00 + au1x00_enet_initialize(bis); +#endif + return 0; +} diff --git a/include/netdev.h b/include/netdev.h index 3739980..31115e2 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -41,6 +41,7 @@ int board_eth_init(bd_t *bis); int cpu_eth_init(bd_t *bis);
/* Driver initialization prototypes */ +int au1x00_enet_initialize(bd_t*); int bfin_EMAC_initialize(bd_t *bis); int dc21x4x_initialize(bd_t *bis); int e1000_initialize(bd_t *bis); diff --git a/net/eth.c b/net/eth.c index cad8fe3..72fed69 100644 --- a/net/eth.c +++ b/net/eth.c @@ -39,7 +39,6 @@ static int __def_eth_init(bd_t *bis) int cpu_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init"))); int board_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init")));
-extern int au1x00_enet_initialize(bd_t*); extern int fec_initialize(bd_t*); extern int mpc8220_fec_initialize(bd_t*); extern int mv6436x_eth_initialize(bd_t *); @@ -189,9 +188,6 @@ int eth_initialize(bd_t *bis) #if defined(FEC_ENET) || defined(CONFIG_ETHER_ON_FCC) fec_initialize(bis); #endif -#if defined(CONFIG_AU1X00) - au1x00_enet_initialize(bis); -#endif if (!eth_devices) { puts ("No ethernet found.\n"); show_boot_progress (-64);
This is no longer used by any boards, the last one was removed in commit 6de5bf24004c8d9c9b070bb8f7418d1c45e5eb27.
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- cpu/mpc85xx/cpu.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index b8f9125..0918fc6 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -379,7 +379,7 @@ void upmconfig (uint upm, uint * table, uint size) */ int cpu_eth_init(bd_t *bis) { -#if defined(CONFIG_TSEC_ENET) || defined(CONFIG_MPC85xx_FEC) +#if defined(CONFIG_TSEC_ENET) tsec_standard_init(bis); #endif
Affected boards: Several MPC8xx boards Several MPC8260/MPC8272 boards Several MPC85xx boards
Removed initialization of the driver from net/eth.c
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- cpu/mpc8260/cpu.c | 13 +++++++++++++ cpu/mpc85xx/cpu.c | 5 ++++- cpu/mpc8xx/cpu.c | 13 +++++++++++++ include/netdev.h | 1 + net/eth.c | 5 ----- 5 files changed, 31 insertions(+), 6 deletions(-)
diff --git a/cpu/mpc8260/cpu.c b/cpu/mpc8260/cpu.c index 9f834d3..b9e748a 100644 --- a/cpu/mpc8260/cpu.c +++ b/cpu/mpc8260/cpu.c @@ -44,6 +44,7 @@ #include <watchdog.h> #include <command.h> #include <mpc8260.h> +#include <netdev.h> #include <asm/processor.h> #include <asm/cpm_8260.h>
@@ -315,3 +316,15 @@ void ft_cpu_setup (void *blob, bd_t *bd) do_fixup_by_path_u32(blob, cpu_path, "clock-frequency", bd->bi_intfreq, 1); } #endif /* CONFIG_OF_LIBFDT */ + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +int cpu_eth_init(bd_t *bis) +{ +#if defined(CONFIG_ETHER_ON_FCC) + fec_initialize(bis); +#endif + return 0; +} diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index 0918fc6..d9e099c 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -30,6 +30,7 @@ #include <watchdog.h> #include <command.h> #include <tsec.h> +#include <netdev.h> #include <asm/cache.h> #include <asm/io.h>
@@ -379,9 +380,11 @@ void upmconfig (uint upm, uint * table, uint size) */ int cpu_eth_init(bd_t *bis) { +#if defined(CONFIG_ETHER_ON_FCC) + fec_initialize(bis); +#endif #if defined(CONFIG_TSEC_ENET) tsec_standard_init(bis); #endif - return 0; } diff --git a/cpu/mpc8xx/cpu.c b/cpu/mpc8xx/cpu.c index 420eaed..de3d679 100644 --- a/cpu/mpc8xx/cpu.c +++ b/cpu/mpc8xx/cpu.c @@ -37,6 +37,7 @@ #include <watchdog.h> #include <command.h> #include <mpc8xx.h> +#include <netdev.h> #include <asm/cache.h>
#if defined(CONFIG_OF_LIBFDT) @@ -635,3 +636,15 @@ void reset_8xx_watchdog (volatile immap_t * immr) # endif /* CONFIG_LWMON */ } #endif /* CONFIG_WATCHDOG */ + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +int cpu_eth_init(bd_t *bis) +{ +#if defined(FEC_ENET) + fec_initialize(bis); +#endif + return 0; +} diff --git a/include/netdev.h b/include/netdev.h index 31115e2..0d1b0d5 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -47,6 +47,7 @@ int dc21x4x_initialize(bd_t *bis); int e1000_initialize(bd_t *bis); int eepro100_initialize(bd_t *bis); int eth_3com_initialize (bd_t * bis); +int fec_initialize (bd_t *bis); int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); diff --git a/net/eth.c b/net/eth.c index 72fed69..6cf53f4 100644 --- a/net/eth.c +++ b/net/eth.c @@ -39,7 +39,6 @@ static int __def_eth_init(bd_t *bis) int cpu_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init"))); int board_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init")));
-extern int fec_initialize(bd_t*); extern int mpc8220_fec_initialize(bd_t*); extern int mv6436x_eth_initialize(bd_t *); extern int mv6446x_eth_initialize(bd_t *); @@ -184,10 +183,6 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_UEC_ETH6) uec_initialize(5); #endif - -#if defined(FEC_ENET) || defined(CONFIG_ETHER_ON_FCC) - fec_initialize(bis); -#endif if (!eth_devices) { puts ("No ethernet found.\n"); show_boot_progress (-64);
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- cpu/mpc83xx/cpu.c | 20 +++++++++++++++++++- cpu/mpc85xx/cpu.c | 18 ++++++++++++++++++ include/netdev.h | 1 + net/eth.c | 19 ------------------- 4 files changed, 38 insertions(+), 20 deletions(-)
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index aa9b18d..ebcc790 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -33,6 +33,7 @@ #include <asm/processor.h> #include <libfdt.h> #include <tsec.h> +#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -361,9 +362,26 @@ int dma_xfer(void *dest, u32 count, void *src) */ int cpu_eth_init(bd_t *bis) { +#if defined(CONFIG_UEC_ETH1) + uec_initialize(0); +#endif +#if defined(CONFIG_UEC_ETH2) + uec_initialize(1); +#endif +#if defined(CONFIG_UEC_ETH3) + uec_initialize(2); +#endif +#if defined(CONFIG_UEC_ETH4) + uec_initialize(3); +#endif +#if defined(CONFIG_UEC_ETH5) + uec_initialize(4); +#endif +#if defined(CONFIG_UEC_ETH6) + uec_initialize(5); +#endif #if defined(CONFIG_TSEC_ENET) tsec_standard_init(bis); #endif - return 0; } diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index d9e099c..02ac67d 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -383,6 +383,24 @@ int cpu_eth_init(bd_t *bis) #if defined(CONFIG_ETHER_ON_FCC) fec_initialize(bis); #endif +#if defined(CONFIG_UEC_ETH1) + uec_initialize(0); +#endif +#if defined(CONFIG_UEC_ETH2) + uec_initialize(1); +#endif +#if defined(CONFIG_UEC_ETH3) + uec_initialize(2); +#endif +#if defined(CONFIG_UEC_ETH4) + uec_initialize(3); +#endif +#if defined(CONFIG_UEC_ETH5) + uec_initialize(4); +#endif +#if defined(CONFIG_UEC_ETH6) + uec_initialize(5); +#endif #if defined(CONFIG_TSEC_ENET) tsec_standard_init(bis); #endif diff --git a/include/netdev.h b/include/netdev.h index 0d1b0d5..3b11961 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -65,6 +65,7 @@ int rtl8139_initialize(bd_t *bis); int rtl8169_initialize(bd_t *bis); int skge_initialize(bd_t *bis); int tsi108_eth_initialize(bd_t *bis); +int uec_initialize(int index); int uli526x_initialize(bd_t *bis);
/* Boards with PCI network controllers can call this from their board_eth_init() diff --git a/net/eth.c b/net/eth.c index 6cf53f4..3793dd7 100644 --- a/net/eth.c +++ b/net/eth.c @@ -44,7 +44,6 @@ extern int mv6436x_eth_initialize(bd_t *); extern int mv6446x_eth_initialize(bd_t *); extern int ppc_4xx_eth_initialize(bd_t *); extern int scc_initialize(bd_t*); -extern int uec_initialize(int);
#ifdef CONFIG_API extern void (*push_packet)(volatile void *, int); @@ -165,24 +164,6 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_MPC8220_FEC) mpc8220_fec_initialize(bis); #endif -#if defined(CONFIG_UEC_ETH1) - uec_initialize(0); -#endif -#if defined(CONFIG_UEC_ETH2) - uec_initialize(1); -#endif -#if defined(CONFIG_UEC_ETH3) - uec_initialize(2); -#endif -#if defined(CONFIG_UEC_ETH4) - uec_initialize(3); -#endif -#if defined(CONFIG_UEC_ETH5) - uec_initialize(4); -#endif -#if defined(CONFIG_UEC_ETH6) - uec_initialize(5); -#endif if (!eth_devices) { puts ("No ethernet found.\n"); show_boot_progress (-64);
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- board/sorcery/sorcery.c | 2 ++ cpu/mpc8220/cpu.c | 13 +++++++++++++ include/netdev.h | 1 + net/eth.c | 4 ---- 4 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/board/sorcery/sorcery.c b/board/sorcery/sorcery.c index 3e1bd6f..90d4298 100644 --- a/board/sorcery/sorcery.c +++ b/board/sorcery/sorcery.c @@ -62,5 +62,7 @@ void pci_init_board (void)
int board_eth_init(bd_t *bis) { + /* Initialize built-in FEC first */ + cpu_eth_init(bis); return pci_eth_init(bis); } diff --git a/cpu/mpc8220/cpu.c b/cpu/mpc8220/cpu.c index 5b3fdd3..563cfe0 100644 --- a/cpu/mpc8220/cpu.c +++ b/cpu/mpc8220/cpu.c @@ -29,6 +29,7 @@ #include <watchdog.h> #include <command.h> #include <mpc8220.h> +#include <netdev.h> #include <asm/processor.h>
DECLARE_GLOBAL_DATA_PTR; @@ -89,3 +90,15 @@ unsigned long get_tbclk (void) }
/* ------------------------------------------------------------------------- */ + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +int cpu_eth_init(bd_t *bis) +{ +#if defined(CONFIG_MPC8220_FEC) + mpc8220_fec_initialize(bis); +#endif + return 0; +} diff --git a/include/netdev.h b/include/netdev.h index 3b11961..55183e8 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -56,6 +56,7 @@ int mcdmafec_initialize(bd_t *bis); int mcffec_initialize(bd_t *bis); int mpc512x_fec_initialize(bd_t *bis); int mpc5xxx_fec_initialize(bd_t *bis); +int mpc8220_fec_initialize(bd_t *bis); int natsemi_initialize(bd_t *bis); int npe_initialize(bd_t *bis); int ns8382x_initialize(bd_t *bis); diff --git a/net/eth.c b/net/eth.c index 3793dd7..d543163 100644 --- a/net/eth.c +++ b/net/eth.c @@ -39,7 +39,6 @@ static int __def_eth_init(bd_t *bis) int cpu_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init"))); int board_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init")));
-extern int mpc8220_fec_initialize(bd_t*); extern int mv6436x_eth_initialize(bd_t *); extern int mv6446x_eth_initialize(bd_t *); extern int ppc_4xx_eth_initialize(bd_t *); @@ -161,9 +160,6 @@ int eth_initialize(bd_t *bis) #ifdef SCC_ENET scc_initialize(bis); #endif -#if defined(CONFIG_MPC8220_FEC) - mpc8220_fec_initialize(bis); -#endif if (!eth_devices) { puts ("No ethernet found.\n"); show_boot_progress (-64);
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- cpu/mpc8xx/cpu.c | 4 ++++ include/netdev.h | 1 + net/eth.c | 4 ---- 3 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cpu/mpc8xx/cpu.c b/cpu/mpc8xx/cpu.c index de3d679..40f81ef 100644 --- a/cpu/mpc8xx/cpu.c +++ b/cpu/mpc8xx/cpu.c @@ -37,6 +37,7 @@ #include <watchdog.h> #include <command.h> #include <mpc8xx.h> +#include <commproc.h> #include <netdev.h> #include <asm/cache.h>
@@ -643,6 +644,9 @@ void reset_8xx_watchdog (volatile immap_t * immr) */ int cpu_eth_init(bd_t *bis) { +#if defined(SCC_ENET) + scc_initialize(bis); +#endif #if defined(FEC_ENET) fec_initialize(bis); #endif diff --git a/include/netdev.h b/include/netdev.h index 55183e8..45e59b6 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -64,6 +64,7 @@ int pcnet_initialize(bd_t *bis); int plb2800_eth_initialize(bd_t *bis); int rtl8139_initialize(bd_t *bis); int rtl8169_initialize(bd_t *bis); +int scc_initialize(bd_t *bis); int skge_initialize(bd_t *bis); int tsi108_eth_initialize(bd_t *bis); int uec_initialize(int index); diff --git a/net/eth.c b/net/eth.c index d543163..0b954ed 100644 --- a/net/eth.c +++ b/net/eth.c @@ -42,7 +42,6 @@ int board_eth_init(bd_t *bis) __attribute((weak, alias("__def_eth_init"))); extern int mv6436x_eth_initialize(bd_t *); extern int mv6446x_eth_initialize(bd_t *); extern int ppc_4xx_eth_initialize(bd_t *); -extern int scc_initialize(bd_t*);
#ifdef CONFIG_API extern void (*push_packet)(volatile void *, int); @@ -157,9 +156,6 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_4xx) && !defined(CONFIG_IOP480) && !defined(CONFIG_AP1000) ppc_4xx_eth_initialize(bis); #endif -#ifdef SCC_ENET - scc_initialize(bis); -#endif if (!eth_devices) { puts ("No ethernet found.\n"); show_boot_progress (-64);
On Thu, Oct 30, 2008 at 12:53 AM, Ben Warren biggerbadderben@gmail.com wrote:
Um....8540ADS uses it. And the 8572 has one, even though we don't have any boards which expose it at this time. Unless I've missed something. If you look at drivers/net/tsec.c, you'll see it's used in the standard tsec init array.
Andy
As a follow-up, it should be noted that the FEC on the 85xx is different from the FEC on older chips. The older FEC is a variant of the FCC. The 85xx FEC is just a tsec without gigabit (and lacking a few other accompanying features that don't affect u-boot).
This has caused frequent confusion.
Andy
I see... check this out:
bwarren@bwarren-linux:~/src/u-boot$ grep -R MPC85xx_FEC * cpu/mpc85xx/cpu.c:#if defined(CONFIG_TSEC_ENET) || defined(CONFIG_MPC85xx_FEC)
bwarren@bwarren-linux:~/src/u-boot$ grep -R MPC85XX_FEC * drivers/net/tsec.c:#ifdef CONFIG_MPC85XX_FEC drivers/net/tsec.c: .devname = CONFIG_MPC85XX_FEC_NAME, include/configs/MPC8540EVAL.h:#define CONFIG_MPC85XX_FEC 1 include/configs/MPC8540EVAL.h:#define CONFIG_MPC85XX_FEC_NAME "FE C" include/configs/sbc8548.h:#undef CONFIG_MPC85XX_FEC include/configs/ATUM8548.h:#undef CONFIG_MPC85XX_FEC include/configs/PM854.h:#define CONFIG_MPC85XX_FEC 1 include/configs/PM854.h:#define CONFIG_MPC85XX_FEC_NAME "FEC" include/configs/MPC8540ADS.h:#define CONFIG_MPC85XX_FEC 1 include/configs/MPC8540ADS.h:#define CONFIG_MPC85XX_FEC_NAME "FEC" include/configs/TQM85xx.h:#define CONFIG_MPC85XX_FEC 1 include/configs/TQM85xx.h:#define CONFIG_MPC85XX_FEC_NAME "FEC" include/configs/MPC8548CDS.h:#undef CONFIG_MPC85XX_FEC include/configs/socrates.h:#undef CONFIG_MPC85XX_FEC
Andy Fleming
Ben Warren
