[U-Boot-Users] [PATCH] Indirect register access through PPC440 DCR.
DESCRIPTION:
Existing getdcr and setdcr monitor functions don't allow indirect access to PPC440 registers in one step. It's still possible theoretically use setdcr to write offset into correct address DCRN and then read/write from data DCRN, but that doesn't work if address got updated in the middle. For instance, I never could read value of SDR0_PINSTP (address/data DCRNs 0xE/0xF, offset 0x40) - immediately after me somebody changed address DCRN to 0x20.
The solution is to implement new special functions getidcr/setidcr for indirect access with following format:
getidcr adr_dcrn[.dat_dcrn] offset setidcr adr_dcrn[.dat_dcrn] offset value
dat_dcrn will be set adr_dcrn+1 if omitted.
Examples (Yosemite PPC440EP board has been used):
1. Read SDR0_PINSTP:
=> getidcr e 40 000e.000f-0040 Read e0000000
2. Read SDR0_CUST0, update it and read back:
=> getidcr e 4000 000e.000f-4000 Read 40082350
=> setidcr e.f 4000 50082350 000e.000f-4000 Write 50082350
=> getidcr e 4000 000e.000f-4000 Read 50082350
CHANGELOG entry:
* Add monitor functions for indirect access to PPC440 registers via Data Control Register (DCR).
PATCH: (diff file ppc440dcr.txt attached).
Signed-off-by: Leonid Baryudin leonid@a-k-a.net
Hi Leonid,
On Friday 06 October 2006 01:17, Leonid wrote:
- Add monitor functions for indirect access to PPC440 registers via Data Control Register (DCR).
Please find some comments below...
==== //depot/Alchemy/ppc/uboot/u-boot-1.1.4/common/cmd_dcr.c#1 - /home/leonid/pd/ppc/uboot/u-boot-1.1.4/common/cmd_dcr.c ==== @@ -104,10 +104,126 @@
Please generate the patch as described in the README:
diff -purN OLD NEW
Or create a git patch.
} while (nbytes);
return 0; }
- Interpreter command to retrieve an register value through AMCC PPC 4xx
- Device Control Register inderect addressing.
+int do_getidcr ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[] ) +{
- unsigned long get_dcr (unsigned short);
- unsigned long set_dcr (unsigned short, unsigned long);
- unsigned short adr_dcrn; /* Device Control Register Num for Address */
- unsigned short dat_dcrn; /* Device Control Register Num for Data */
unsigned short offset; /* Register's offset */
- unsigned long value; /* register's value */
unsigned char * ptr=NULL, buf[80];
Only tabs for indentation.
- /* Validate arguments */
- if (argc < 3) {
printf ("Usage:\n%s\n", cmdtp->usage);
return 1;
- /* Find out whether ther is '.' (dot) symbol in the first parameter. */
strncpy(buf, argv[1], sizeof(buf)-1);
Indentation.
buf[sizeof(buf)-1]=0; /* will guarantee zero-end string */
ptr = strchr(buf, '.');
- if(ptr != NULL)
{/* first parameter has fromat adr_dcrn.dat_dcrn */
Opening brace in the line of the if statement please.
* ptr = 0; /* erase '.', create zero-end string */
ptr++; /* will point to dat_dcr */
adr_dcrn = (unsigned short) simple_strtoul (buf, NULL, 16);
dat_dcrn = (unsigned short) simple_strtoul (ptr, NULL, 16);
else
{ /* first parameter has fromat adr_dcrn; dat_dcrn will be
calculated as adr_dcrn+1. */
Please use: } else {
I'm stopping here. Please recheck you patch regarding the coding style. You could of course use something like "Lindent" to help you here.
<snip>
Please fix the above mentioned issues and resubmit a new patch. Thanks.
Best regards, Stefan
On Saturday, October 07, 2006 3:46 AM Stefan Roese wrote:
Please generate the patch as described in the README: diff -purN OLD NEW
Done, attached (ppc440dcr_diff.txt).
Done.
Done.
Done.
Thanks.
Done; see below, after asterisks.
Best regards, Leonid.
************************************************************************ *** DESCRIPTION:
CHANGELOG entry:
PATCH: (diff file ppc440dcr_diff.txt attached).
Hi Leonid,
sorry for being so insistent but there are still some issues that need to be cleaned up in your patch. Please see below...
--- u-boot-1.1.4-orig/common/cmd_dcr.c 2006-10-12 11:01:32.000000000 -0700 +++ u-boot-1.1.4/common/cmd_dcr.c 2006-10-12 11:29:15.000000000 -0700 @@ -106,6 +106,122 @@ int do_setdcr (cmd_tbl_t * cmdtp, int fl return 0; }
Please use tabs for indentation. Indentation size is 8 by the way. This is a problem in the complete patch.
- unsigned short offset; /* Register's offset */
- unsigned char *ptr=NULL;
Space before and after the "=".
- unsigned char buf[80];
- if (argc < 3) {
- printf ("Usage:\n%s\n", cmdtp->usage);
- return 1;
- strncpy(buf, argv[1], sizeof(buf)-1);
- buf[sizeof(buf)-1]=0; /* will guarantee zero-end string */
- ptr = strchr(buf, '.');
Why are here 2 spaces before the "="? It's not aligned to another line of code. Please use just one space.
- if(ptr != NULL) {
A space after the "if" please.
- /* first parameter has format adr_dcrn.dat_dcrn */
- ptr = 0; /* erase '.', create zero-end string */
*ptr = 0;
- ptr++; /* will point to dat_dcr */
And why not:
*ptr++ = 0;
- adr_dcrn = (unsigned short) simple_strtoul (buf, NULL, 16);
- dat_dcrn = (unsigned short) simple_strtoul (ptr, NULL, 16);
- } else {
- /* first parameter has format adr_dcrn; dat_dcrn will be
- dat_dcrn = adr_dcrn+1;
- /* Register's offset */
- offset = (unsigned short) simple_strtoul (argv[2], NULL, 16);
- /* Disable interrupts */
- disable_interrupts();
- /* Set offset */
- set_dcr(adr_dcrn, offset);
- /* get data */
- value = get_dcr(dat_dcrn);
- /* Enable interrupts */
- enable_interrupts();
- printf ("%04x.%04x-%04x Read %08lx\n", adr_dcrn, dat_dcrn, offset, value);
- Interpreter command to update an register value through AMCC PPC 4xx
+int do_setidcr (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{
- if (argc < 4) {
- return 1;
- if(ptr != NULL) {
Space after if again.
*ptr++ = 0;
- } else {
- /* New value */
- value = (unsigned long) simple_strtoul (argv[3], NULL, 16);
- /* Set offset */
- /* set data */
- set_dcr(dat_dcrn, value);
- printf ("%04x.%04x-%04x Write %08lx\n", adr_dcrn, dat_dcrn, offset, value);
U_BOOT_CMD( @@ -119,4 +235,16 @@ U_BOOT_CMD( "dcrn - set a DCR's value.\n" );
+U_BOOT_CMD(
- getidcr, 3, 1, do_getidcr,
- "getidcr - Get a register value via indirect DCR addressing\n",
- "adr_dcrn[.dat_dcrn] offset - write offset to adr_dcrn, read value from
dat_dcrn.\n" +);
+U_BOOT_CMD(
- setidcr, 4, 1, do_setidcr,
- "setidcr - Set a register value via indirect DCR addressing\n",
- "adr_dcrn[.dat_dcrn] offset value - write offset to adr_dcrn, write value
to dat_dcrn.\n" +);
#endif /* CONFIG_4xx & CFG_CMD_SETGETDCR */
Please fix the issues mentioned above and resubmit your patch. Thanks.
No worries, quite opposite, I appreciate your comments.
Well, I kind of did, but looks like xemacs, I'm using has different tab configuration. I've inserted tabs using vi, now they are 8 spaces each.
Done.
Done.
*ptr = 0;
And why not:
*ptr++ = 0;
Done.
Done.
CHANGELOG entry:
Leonid
Stefan Roese
