[U-Boot] [PATCH v2 17/18] net: gmac_rockchip: Add support for the RK3228 GMAC
Spam detection software, running on the system "lists.denx.de", has identified this incoming email as possible spam. The original message has been attached to this so you can view it or label similar future email. If you have any questions, see @@CONTACT_ADDRESS@@ for details.
Content preview: The GMAC in the RK3228 once again is identical to the incarnation in the RK3288 and the RK3399, except for where some of the configuration and control registers are located in the GRF. This adds the RK3368-specific logic necessary to reuse this driver. [...]
Content analysis details: (5.7 points, 5.0 required)
pts rule name description ---- ---------------------- -------------------------------------------------- 2.7 RCVD_IN_PSBL RBL: Received via a relay in PSBL [211.157.147.133 listed in psbl.surriel.com] 0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.133 listed in bl.mailspike.net] 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted
2.7 RCVD_IN_PSBL RBL: Received via a relay in PSBL [211.157.147.133 listed in psbl.surriel.com] 0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.133 listed in bl.mailspike.net] 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted The GMAC in the RK3228 once again is identical to the incarnation in the RK3288 and the RK3399, except for where some of the configuration and control registers are located in the GRF.
Signed-off-by: David Wu david.wu@rock-chips.com
Changes in v2:
- New patch
drivers/net/gmac_rockchip.c | 85 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 85 insertions(+)
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: David Wu david.wu@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v2:
- New patch
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Hi David,
Am Donnerstag, 9. November 2017, 17:28:19 CET schrieb David Wu: [stuff that somehow got caught by the spam filter]
Shouldn't that code also handle the integrated-phy of the rk3228/rk3229? Right now it looks like this only handles rgmii connected external phys but I guess most tv-boxes based on the rk3229 might use the internal phy to save on components.
Heiko
Hi Heiko,
Yes, Next plan I want to implement the integrated-phy, because some customers are also consulting this feature, but the current RMII/RGMII of internal/external mac_clk compatible configuration still has a problem, I want to solve this first.
在 2017/12/26 4:45, Heiko Stuebner 写道:
Hi David,
Heiko
David Wu
David.Wu
Heiko Stuebner
Philipp Tomsich
