[PATCH] imx: imx8mm/imx8mn_beacon: Remove redundant code
The Ethernet controller and PHY use the device tree info to configure themselves, so it's not necessary to manually do it in the board file. This permits the removal of a bunch of headers as well.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/beacon/imx8mm/imx8mm_beacon.c b/board/beacon/imx8mm/imx8mm_beacon.c index c228bbf777..204235a3f8 100644 --- a/board/beacon/imx8mm/imx8mm_beacon.c +++ b/board/beacon/imx8mm/imx8mm_beacon.c @@ -1,52 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2020 Compass Electronics Group, LLC + * Copyright 2022 Logic PD, Inc. dba Beacon EmbeddedWorks */
-#include <common.h> -#include <miiphy.h> -#include <netdev.h> #include <asm/global_data.h>
-#include <asm/arch/clock.h> -#include <asm/arch/sys_proto.h> -#include <asm/io.h> - DECLARE_GLOBAL_DATA_PTR;
-#if IS_ENABLED(CONFIG_FEC_MXC) -static int setup_fec(void) -{ - struct iomuxc_gpr_base_regs *gpr = - (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; - - /* Use 125M anatop REF_CLK1 for ENET1, not from external */ - clrsetbits_le32(&gpr->gpr[1], 0x2000, 0); - - return 0; -} - -int board_phy_config(struct phy_device *phydev) -{ - /* enable rgmii rxc skew and phy mode select to RGMII copper */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); - - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); - - if (phydev->drv->config) - phydev->drv->config(phydev); - return 0; -} -#endif - int board_init(void) { - if (IS_ENABLED(CONFIG_FEC_MXC)) - setup_fec(); - return 0; } diff --git a/board/beacon/imx8mn/imx8mn_beacon.c b/board/beacon/imx8mn/imx8mn_beacon.c index 6397dac872..204235a3f8 100644 --- a/board/beacon/imx8mn/imx8mn_beacon.c +++ b/board/beacon/imx8mn/imx8mn_beacon.c @@ -1,52 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2020 Compass Electronics Group, LLC + * Copyright 2022 Logic PD, Inc. dba Beacon EmbeddedWorks */
-#include <common.h> -#include <miiphy.h> -#include <netdev.h> - -#include <asm/arch/clock.h> -#include <asm/arch/sys_proto.h> #include <asm/global_data.h> -#include <asm/io.h>
Hi Adam,
Nice code removal.
Reviewed-by: Fabio Estevam festevam@denx.de
Acked-by: Peng Fan peng.fan@nxp.com
- Copyright 2020 Compass Electronics Group, LLC
- Copyright 2022 Logic PD, Inc. dba Beacon EmbeddedWorks
-} -#endif
setup_fec();
- return 0; }
-} -#endif
setup_fec();
- return 0; }
The Ethernet controller and PHY use the device tree info to configure themselves, so it's not necessary to manually do it in the board file. This permits the removal of a bunch of headers as well. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@denx.de Acked-by: Peng Fan peng.fan@nxp.com diff --git a/board/beacon/imx8mm/imx8mm_beacon.c b/board/beacon/imx8mm/imx8mm_beacon.c index c228bbf777..204235a3f8 100644 --- a/board/beacon/imx8mm/imx8mm_beacon.c +++ b/board/beacon/imx8mm/imx8mm_beacon.c @@ -1,52 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ /*
-} -#endif
setup_fec();
-} -#endif
setup_fec();
Best regards, Stefano Babic
Adam Ford
Fabio Estevam
Peng Fan (OSS)
sbabic@denx.de
