[U-Boot] [PATCH 09/10] x86: qemu: Enable writing MP table
Enable writing MP table for QEMU boads (i440fx and q35).
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/cpu/qemu/pci.c | 34 +++++++++++++++++++++++++++++++--- configs/qemu-x86_defconfig | 1 + 2 files changed, 32 insertions(+), 3 deletions(-)
diff --git a/arch/x86/cpu/qemu/pci.c b/arch/x86/cpu/qemu/pci.c index ab93e76..acbd922 100644 --- a/arch/x86/cpu/qemu/pci.c +++ b/arch/x86/cpu/qemu/pci.c @@ -13,6 +13,8 @@
DECLARE_GLOBAL_DATA_PTR;
+static bool i440fx; + void board_pci_setup_hose(struct pci_controller *hose) { hose->first_busno = 0; @@ -61,7 +63,8 @@ int board_pci_post_scan(struct pci_controller *hose) * PCI device ID. */ device = x86_pci_read_config16(PCI_BDF(0, 0, 0), PCI_DEVICE_ID); - pam = (device == PCI_DEVICE_ID_INTEL_82441) ? I440FX_PAM : Q35_PAM; + i440fx = (device == PCI_DEVICE_ID_INTEL_82441); + pam = i440fx ? I440FX_PAM : Q35_PAM;
/* * Initialize Programmable Attribute Map (PAM) Registers @@ -71,7 +74,7 @@ int board_pci_post_scan(struct pci_controller *hose) for (i = 0; i < PAM_NUM; i++) x86_pci_write_config8(PCI_BDF(0, 0, 0), pam + i, PAM_RW);
- if (device == PCI_DEVICE_ID_INTEL_82441) { + if (i440fx) { /* * Enable legacy IDE I/O ports decode * @@ -97,10 +100,35 @@ int board_pci_post_scan(struct pci_controller *hose) * board, it shows as device 2, while for Q35 and ICH9 chipset board, * it shows as device 1. */ - vga = (device == PCI_DEVICE_ID_INTEL_82441) ? I440FX_VGA : Q35_VGA; + vga = i440fx ? I440FX_VGA : Q35_VGA; start = get_timer(0); ret = pci_run_vga_bios(vga, NULL, PCI_ROM_USE_NATIVE); debug("BIOS ran in %lums\n", get_timer(start));
return ret; } + +#ifdef CONFIG_GENERATE_MP_TABLE +int mp_determine_pci_dstirq(int bus, int dev, int func, int pirq) +{ + u8 irq; + + if (i440fx) { + /* + * Not like most x86 platforms, the PIRQ[A-D] on PIIX3 are not + * connected to I/O APIC INTPIN#16-19. Instead they are routed + * to an irq number controled by the PIRQ routing register. + */ + irq = x86_pci_read_config8(PCI_BDF(bus, dev, func), + PCI_INTERRUPT_LINE); + } else { + /* + * ICH9's PIRQ[A-H] are not consecutive numbers from 0 to 7. + * PIRQ[A-D] still maps to [0-3] but PIRQ[E-H] maps to [8-11]. + */ + irq = pirq < 8 ? pirq + 16 : pirq + 12; + } + + return irq; +} +#endif diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 62c3f35..e579c36 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -3,6 +3,7 @@ CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 CONFIG_GENERATE_PIRQ_TABLE=y +CONFIG_GENERATE_MP_TABLE=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Bin Meng
