[U-Boot] [PATCH 1/1] omap: Omit fastboot.userdata_size related errors
When using regular $partitions variable (for Linux boot), we can see some unwanted messages:
ERROR: cannot find partition: 'userdata'
at arch/arm/mach-omap2/utils.c:96/omap_mmc_get_part_size() Warning: fastboot.userdata_size: unable to calc
Let's remove those, as missing 'userdata' partition is correct behavior for Linux partition, and we don't want to see some Android-related messages in this case.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- arch/arm/mach-omap2/utils.c | 13 ++++--------- 1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index 0b0bf1837c..3892853c7e 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -92,10 +92,8 @@ static u32 omap_mmc_get_part_size(const char *part) }
res = part_get_info_by_name(dev_desc, part, &info); - if (res < 0) { - error("cannot find partition: '%s'\n", part); + if (res < 0) return 0; - }
/* Calculate size in bytes */ sz = (info.size * (u64)info.blksz); @@ -111,13 +109,10 @@ static void omap_set_fastboot_userdata_size(void) u32 sz_kb;
sz_kb = omap_mmc_get_part_size("userdata"); - if (sz_kb == 0) { - buf[0] = '\0'; - printf("Warning: fastboot.userdata_size: unable to calc\n"); - } else { - sprintf(buf, "%u", sz_kb); - } + if (sz_kb == 0) + return; /* probably it's not Android partition table */
+ sprintf(buf, "%u", sz_kb); env_set("fastboot.userdata_size", buf); } #else
Sam Protsenko
