[U-Boot] [PATCH 3/3 v6] SAMSUNG: SMDKC100: Adds ethernet support.
Add setup for ethernet on SMDKC100, allowing kernel/ramdisk to be loaded over tftp.
The preinit function will configure GPIO (GPK0CON) & SROMC to look for environment in SROM Bank 3.
Signed-off-by: Naveen Krishna Ch ch.naveen@samsung.com --- Changes since V1:
1. The CONFIG_BOOTP* and Net config Macros are removed from config header. Comments from Ben Warren are fixed 2. The GPIO configuration is modified & Macro and Function are renamed. Comments from Minkyu Kang are fixedChanges since V2
Changes since V2: 1. GPIO configurations function has been implemented.
Changes since V3: 1. Comments from Minkyu Kang are fixed.
Changes since V4: None
Changes since v5: 1. Compile time warning are fixed.
board/samsung/smdkc100/smdkc100.c | 40 +++++++++++++++++++++++++++++++++++++ include/configs/smdkc100.h | 12 ++++++++++- 2 files changed, 51 insertions(+), 1 deletions(-)
diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index 15a1a27..76bd4cc 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -23,10 +23,41 @@ */
#include <common.h> +#include <asm/io.h> +#include <asm/arch/smc.h> +#include <asm/arch/gpio.h> +#include <netdev.h> + DECLARE_GLOBAL_DATA_PTR;
+/* + * Miscellaneous platform dependent initialisations + */ +static void smc9115_pre_init(void) +{ + u32 tmp; + u32 smc_bw_conf, smc_bc_conf; + + struct s5pc100_gpio *const gpio = + (struct s5pc100_gpio *)S5PC100_GPIO_BASE; + + /* gpio configuration GPK0CON */ + gpio_cfg_pin(&gpio->gpio_k0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + + /* Ethernet needs bus width of 16 bits */ + smc_bw_conf = SMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); + smc_bc_conf = SMC_BC_TACS(0x0) | SMC_BC_TCOS(0x4) | SMC_BC_TACC(0xe) + | SMC_BC_TCOH(0x1) | SMC_BC_TAH(0x4) + | SMC_BC_TACP(0x6) | SMC_BC_PMC(0x0); + + /* Select and configure the SROMC bank */ + s5pc1xx_config_sromc(CONFIG_ENV_SROM_BANK, smc_bw_conf, smc_bc_conf); +} + int board_init(void) { + smc9115_pre_init(); + gd->bd->bi_arch_number = MACH_TYPE_SMDKC100; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
@@ -49,3 +80,12 @@ int checkboard(void) return 0; } #endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index a8ba052..09bce6d 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -83,7 +83,6 @@ #undef CONFIG_CMD_FLASH #undef CONFIG_CMD_IMLS #undef CONFIG_CMD_NAND -#undef CONFIG_CMD_NET
#define CONFIG_CMD_CACHE #define CONFIG_CMD_REGINFO @@ -235,4 +234,15 @@
#define CONFIG_DOS_PARTITION 1
+/* + * Ethernet Contoller driver + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X 1 /* we have a SMC9115 on-board */ +#define CONFIG_SMC911X_16_BIT 1 /* SMC911X_16_BIT Mode */ +#define CONFIG_SMC911X_BASE 0x98800300 /* SMC911X Drive Base */ +#define CONFIG_ENV_SROM_BANK 3 /* Select SROM Bank-3 for Ethernet*/ +#endif /* CONFIG_CMD_NET */ + #endif /* __CONFIG_H */
Dear Naveen Krishna CH,
Changes since V1:
- The CONFIG_BOOTP* and Net config Macros are removed from config header.
Changes since V2:
- GPIO configurations function has been implemented.
Changes since V3:
- Comments from Minkyu Kang are fixed.
Changes since v5:
- Compile time warning are fixed.
- Miscellaneous platform dependent initialisations
- u32 tmp;
Why didn't delete this variable?
- u32 smc_bw_conf, smc_bc_conf;
- struct s5pc100_gpio *const gpio =
- (struct s5pc100_gpio *)S5PC100_GPIO_BASE;
- /* gpio configuration GPK0CON */
- gpio_cfg_pin(&gpio->gpio_k0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2));
- /* Ethernet needs bus width of 16 bits */
- smc_bw_conf = SMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK);
- smc_bc_conf = SMC_BC_TACS(0x0) | SMC_BC_TCOS(0x4) | SMC_BC_TACC(0xe)
- | SMC_BC_TCOH(0x1) | SMC_BC_TAH(0x4)
- | SMC_BC_TACP(0x6) | SMC_BC_PMC(0x0);
- /* Select and configure the SROMC bank */
- s5pc1xx_config_sromc(CONFIG_ENV_SROM_BANK, smc_bw_conf, smc_bc_conf);
Thanks Minkyu Kang
Hi kang,
Changes since V1:
header.
Changes since V2:
Changes since V3:
Changes since v5:
u32 tmp;
My Bad, Patch replaced. Can i send this one alone as v6 or should i send the patch set again as v7
SMC_BC_TACC(0xe)
smc_bc_conf);
Thanks Minkyu Kang -- from. prom. www.promsoft.net _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Naveen Krishna Ch,
On 1 March 2010 14:05, Naveen Krishna Ch naveenkrishna.ch@gmail.com wrote:
Hi kang,
Changes since V1:
Changes since V2:
Changes since V3:
Changes since v5:
- u32 tmp;
Please send next version.
GPIO_FUNC(2));
SMC_BC_TACC(0xe)
smc_bc_conf); +}
-- Shine bright, (: Naveen Krishna Ch :)
Thanks Minkyu Kang
Minkyu Kang
Naveen Krishna Ch
